[Stable Update] 2018-10-21 - Kernels, GTK3, MHWD, Pamac
update
stable
#49
hi guys … i don’t know if it is due to the last update or what … but i lost my second partition in the hard drive that it contains my work (i can’t find it) … please guys any help … now am downloading systemrecueCD
#50
Check with TestDisk 7.0
#51
Ok,
Thank you very much for your answer :+1:
#52
thank you my friend … i created a post here for the issue
#53
XFCE, 4.18.16
Everything went smoothly! Thanks for the hard work.
#54
I found a solution for the non appearing clock in my previous post.
Purging the downloaded packages cache then: sudo pacman -S --overwrite '*' tzdata solved the problem.
#55
Hi Phil,
This update is missing the NVIDIA drivers for the 4.14 LTS kernel but it appears to have the drivers for the other kernels:
                 linux419-nvidia        1:410.66-0.26        1:410.66-0.27
           linux419-nvidia-340xx         340.107-0.26         340.107-0.27
           linux419-nvidia-390xx          390.87-0.26          390.87-0.27
               linux419-nvidiabl            0.88-0.26            0.88-0.27
                  linux44-nvidia           1:410.66-1           1:410.66-2
            linux44-nvidia-340xx           340.107-18           340.107-19
            linux44-nvidia-390xx             390.87-7             390.87-8
                linux44-nvidiabl             0.88-113             0.88-114
Please build and release all versions of the NVIDIA drivers for 4.14 LTS.
#56
So far, so good. Thank you Manjaro team!
#57
Hi, no big problems whit the update, just one really. The speakers of my laptop stop working, i can use headset whitout issues and in Windows (dual boot) they work like always. Any advice is wellcome.
#58
Will this smooth-boot, fully flickerfree ever be available for other kernels?
I have default:
4.14.78-1-MANJARO #1 SMP PREEMPT Sun Oct 21 07:57:51 UTC 2018 x86_64 GNU/Linux
#59
I double checked some mirrors. All is fine for Linux419. You may check for yourself: https://manjaro.moson.eu/pool/overlay/
#60
Bitcoin-qt have no more starts its gui with no error message ???
#61
