[Stable Update] 2018-10-08 - Kernels, Gnome 3.30, Cinnamon, Deepin, Pamac, SPL/ZFS
update
stable
#185
Thanks, I looked into it further and it’s the gnome-shell theme that’s broken and caused the problem. My application theme (Zukitwo) is still good, so I did not need to change that. The maintainer will need to update his shell theme for Gnome 3.30.
Besides the Vimix shell themes, the Adapta shell themes from original install of OS also still work correctly, so no surprise not a lot of users noticed this problem.
#186
Updated Dell laptop/XFCE with no issues. Many thanks Manjaro Team :smiley:
#187
I got the same. I have Thinkpad X230, maybe it’s too old to support this feature.
#188
#189
I have the same issue on my Desktop and laptop.
Using Manjaro Gnome of course
.eScreenshot%20from%202018-10-16%2016-51-30
#190
AFAICT this “Smooth Boot” needs UEFI boot. Your X230 might be in BIOS/legacy boot mode.
#191
Not according to philm instructions
#192
Smooth boot as in grub-quiet? Can we use one consistent nomenclature, please?
petsam is right, I’ve tested on both bios-legacy and uefi, works in both.
Just that in uefi, ‘welcome to grub’ bar stays on whereas in bios-legacy, it appears for a moment.
And AFAICT ? …OIC, IDK it says ‘tell’ or ‘think’. :grin:
But, OP is right, having encryption may not work.
And personally, even in ‘normal’ situations, having timeout=0 is a not good.
Cheers.
#193
Actually it is OK as you can now hold shift key down during boot and the menu appears.
#194
Okay. Before starting up computer, we press shift key?
Got to try it but have to reinstall back grub-quiet. Sure timeout=0 is set from timeout=5?
Thanks for the feedback.
#195
Chromium 70 is incoming.
#196
In Testing Branch Version 70.0.3538.67 (Official Build) (64-bit)
#197
No, pressing ‘shift’ key with timeout=0 boots immediately to OS.
Can you check if you have “timeout=0” in /etc/default/grub?
Issues enabling "smooth boot" -Testing
#198
You are right after the last update that appears to be now broken @philm
#199
9 posts were merged into an existing topic: [Security Update] 2018-10-18 - Thunderbird, Chromium
#200
I’ve noticed two issues with this update, one of them being a major security issue:
The file manager issue is annoying, but I can work with it for the time being. The taskbar being visible from the lockscreen, however, is a major issue that we need to work to get fixed ASAP. Please let me know what information you need from me to start troubleshooting this issue.
#201
Netbeans doesn’t start after this update.
When I tried to open with terminal appears
Cannot read cluster file: //etc/netbeans.clusters
#202
It’s in pure uefi, not even in uefi/legacy. I’m not really bothered by that to be honest and I will be reinstalling after 18.0 iso GA. I’ve been messing with my system a lot and I don’t even remember what I have done :smile:
#203
