Hey, everyone. Recently I moved back to KDE (2 weeks old install) fully updated.
Looking at Htop this looks very weird to me. Never seen such behavior in previous installs of KDE (arch and ubuntu-based),
You can check it here: https://imgur.com/LKpyJ6B
qBittorrent has a lot of entries too.
The first screenshot is right after a reboot.
The second one is after a couple of hours of usage. And my system becomes sluggish and stuff is opening a lot slower.
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=59eab1cd-71fd-4073-a7e5-e54f837e4eec ro quiet udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire ES1-512 v: V1.10 serial: <filter>
Mobo: Acer model: Aspire ES1-512 v: V1.10 serial: <filter> UEFI: Insyde
v: 1.10 date: 12/15/2014
ID-1: BAT0 charge: 26.3 Wh condition: 26.3/36.7 Wh (72%) volts: 12.3/11.4
model: LGC AC14B18J type: Li-ion serial: <filter> status: Full
Info: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont family: 6 model-id: 37 (55) stepping: 8 microcode: 838
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8671
Speed: 556 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 556 2: 588
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0f31
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus ID: 1-4:4
chip ID: 04f2:b47f serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.3.3
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:0f04
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 2000 bus ID: 02:00.0
chip ID: 168c:0036
IF: wls2 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus ID: 03:00.0 chip ID: 10ec:8168
IF: ens3 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb
bus ID: 1-3.1:7 chip ID: 04ca:300b
Local Storage: total: 931.51 GiB used: 121.9 GiB (13.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-22JC3T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1A01
ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 121.9 GiB (13.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 172 Uptime: 5h 01m wakeups: 1 Memory: 3.73 GiB
used: 2.12 GiB (56.9%) Init: systemd v: 247 Compilers: gcc: N/A
Packages: 1169 pacman: 1159 lib: 358 snap: 10 Shell: Bash v: 5.1.0
running in: yakuake inxi: 3.2.02
