[Stable Update] 2018-03-23 - Kernels, Mesa, Browsers, Deepin, Python, Haskell
Hi community,
welcome to another stable update of Manjaro. We worked again on our Kernels, added some fixes to MSM and Pamac, updated Mesa, Firefox, Python and Haskell packages plus worked on GCC and VIM.
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
  • linux316 3.16.56
  • linux318 3.18.100 [EOL]
  • linux41 4.1.50
  • linux44 4.4.122
  • linux49 4.9.88
  • linux414 4.14.29
  • linux415 4.15.12
  • linux416 4.16-rc6
  • linux-RT-LTS 4.14.28_rt23
  • linux-RT 4.14.28_rt23
Package Updates (Thu Mar 22 08:31:05 CET 2018)
  • stable community x86_64: 412 new and 398 removed package(s)
  • stable core x86_64: 26 new and 26 removed package(s)
  • stable extra x86_64: 326 new and 422 removed package(s)
  • stable multilib x86_64: 15 new and 10 removed package(s)
A detailed list of all package changes can be found here.
0 voters
Known issues and solutions
nxagent and nx-xcompext are in conflict. Remove nx-xcompext? [y/N]
Yes.
Warnung: Verzeichnis-Berechtigungen unterscheiden sich für /etc/NetworkManager/system-connections/
sudo chmod 700 /etc/NetworkManager/system-connections/
firefox: /usr/lib/firefox/distribution/distribution.ini exists in filesystem
sudo rm /usr/lib/firefox/distribution/distribution.ini
OT:
I got this message:
(35/44) Aktualisiere networkmanager        [##############################################################] 100%
Dateisystem: 755  Paket: 700
Any action to take?
Good update on my NB with Xfce.
You may do: sudo chmod 700 /etc/NetworkManager/system-connections/ if you want to “fix” it. It simply reduces the rights to root only.
Gnome on Thinkpad X230 - everything went fine.
XFCE on virtualbox on windows 7 host hanged during install phase but I think it’s windows fault. I reverted to snapshot from before update, did it again and it went fine. I’m writing this to just remind people that backup before update is always a good idea.
Somewhere else there is perhaps a black friday, but here is a happy friday :sunglasses:
All works fine
regards
caho
Excellent.
20180323_002 20180323_001
no problems on KDE.
thank you
Everything good so far. XFCE edition.
Manjaro MATE , kernel 4.14. Easy update.
Thanks!
KDE.
Have some problem with SDDM.
When I enter password after lock session, it looking hang up.
Then I switch via ctlr+alt+f2 and return back and see session successfully unlocked.
Run following command in terminal
I am getting this message:
error: failed to commit transaction (conflicting files)
Should I remove that file?
No problems here, thank you!
Thanks to maintain gtk3-classic, it’s really great to have it in our repos.
All is fine!
Thanks :wink:
no issue while updating, running Xfce@kernel 416
need to test resume from suspend tough, since this caused some issue (black screen, no response from system) in the last weeks
flawless update on KDE, great work as always! :smiley:
This update make my nvidia drivers start crashing. I never had on bumblebee-git package error that: Cannot load GPU and now I have, when I restart drivers works but my favourite game crash :confused:
I also appreciate that Manjaro Team maintain the gtk3-classic!! :grin:
I’m also having this issue. Anyone know a fix or something we can try?
