Unable to update manjaro xfce
I have installed linux headers and rtl8821ce wifi driver recently. My system is unable to update and freezes when I try to update. I tried three time but failed at same point. Hard shutdown currupt the manjaro to boot.
Don’t post images. post the terminal output (images removed)
paste the text between two lines with three (3) backtics each like this
this is the output
system freezes.cant paste output.
Struck each time at
Install DKMS modules
dkms install --no-depmod -m rtl8821ce -v1.0.5.r110.gd95376d -k 5.4.80-2- MANJARO
inxi -Fxxi
  Host: manjaro Kernel: 5.4.78-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.2.0 Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 wm: xfwm4 dm: LightDM
  Distro: Manjaro Linux
  Type: Desktop System: LENOVO product: 90LX0091IN v: ideacentre 510S-07ICK
  serial: <superuser/root required> Chassis: type: 3
  Mobo: LENOVO model: 3178 v: NOK serial: <superuser/root required>
  UEFI: LENOVO v: M30KT19A date: 01/31/2020
  Info: Quad Core model: Intel Core i3-9100 bits: 64 type: MCP
  arch: Kaby Lake rev: B L2 cache: 6144 KiB
  bogomips: 28808
  Speed: 901 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900
  Device-1: Intel 8th Gen Core Processor Gaussian Mixture Model
  vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e91
  Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
  alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.2
  direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
  Sound Server: ALSA v: k5.4.78-1-MANJARO
  vendor: Lenovo driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  chip ID: 10ec:8168
  IF: enp2s0 state: down mac: a4:ae:12:2e:80:d5
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Lenovo driver: rtl8821ce v: N/A port: d000 bus ID: 03:00.0
  chip ID: 10ec:c821
  IF: wlp3s0 state: up mac: 00:45:e2:15:c0:1b
  IP v4: 192.168.43.23/24 type: dynamic noprefixroute scope: global
  broadcast: 192.168.43.255
  IP v6: fe80::3bf3:c526:3e74:f708/64 type: noprefixroute scope: link
  WAN IP: 117.237.219.175
  Local Storage: total: 1.14 TiB used: 321.57 GiB (27.6%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
  speed: 31.6 Gb/s lanes: 4 serial: 50026B7282710CF5
  ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
  size: 931.51 GiB speed: 6.0 Gb/s serial: WD-WCC6Y7RU7AZ5
  ID-1: / size: 219.86 GiB used: 40.87 GiB (18.6%) fs: ext4
  dev: /dev/nvme0n1p3
  ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 41.0 C mobo: N/A
  Processes: 193 Uptime: 54m Memory: 7.67 GiB used: 1.36 GiB (17.7%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1185
  Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
pls help
There is no any response of my query till now. Are there some mistakes writing in forum??
