Hi, and thanks, after this last round of updates, for some reason after varying amounts of time, my mouse cannot click certain things like browser tabs, desktop menus, dragging items, but other things will be fine like my IDE (Webstorm). I am using the community build of Awesome. So it is version 4.3 and using Lua 5.4. I can use shortcuts on the menus and the browser tabs, so the apps or the DE is not frozen. Any help with this would be greatly appreciated.
System: Kernel: 4.19.152-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=e31138bb-7612-4a43-907d-43ea092e71bb rw quiet resume=UUID=9e4d0f4c-5d35-4872-96cd-3270ff4c99c1 Desktop: Xfce wm: awesome 4.3 dm: LightDM 1.30.0 Distro: Manjaro Linux Machine: Type: Desktop Mobo: ASUSTeK model: SABERTOOTH X79 v: Rev 1.xx serial: <filter> BIOS: American Megatrends v: 4801 date: 07/25/2014 Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master serial: <filter> charge: 55% (should be ignored) rechargeable: yes status: Discharging Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master serial: <filter> charge: 100% (should be ignored) rechargeable: yes status: Discharging CPU: Topology: 6-Core model: Intel Core i7-3960X bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2D (45) stepping: 7 microcode: 71A L2 cache: 15.0 MiB flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 100094 Speed: 1517 MHz min/max: 1200/5700 MHz Core speeds (MHz): 1: 1517 2: 1517 3: 1517 4: 1516 5: 1517 6: 1516 7: 1516 8: 1517 9: 1517 10: 1516 11: 1516 12: 1517 Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown mitigation: PTI Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: NVIDIA GM204GL [Quadro M4000] driver: nvidia v: 430.64 bus ID: 01:00.0 chip ID: 10de:13f1 Display: x11 server: X.org 1.20.9 driver: nvidia resolution: <xdpyinfo missing> Message: Unable to show advanced data. Required tool glxinfo missing. Audio: Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1d20 Device-2: NVIDIA GM204 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo bus ID: 4-1.2:3 chip ID: 046d:0843 serial: <filter> Device-4: RODE Microphones type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 4-1.4:5 chip ID: 19f7:0003 Sound Server: ALSA v: k4.19.152-1-MANJARO Network: Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0 chip ID: 8086:1503 IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter> Drives: Local Storage: total: 10.22 TiB used: 1.65 TiB (16.2%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda vendor: Samsung model: SSD 840 Series size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8B0Q scheme: MBR ID-2: /dev/sdb vendor: Samsung model: SSD 840 Series size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8B0Q scheme: MBR ID-3: /dev/sdc vendor: Western Digital model: WD2002FAEX-007BA0 size: 1.82 TiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1D05 scheme: MBR ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 2TB size: 1.82 TiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 2B6Q scheme: MBR ID-5: /dev/sde type: USB vendor: Western Digital model: WD My Passport 2627 size: 4.55 TiB block size: physical: 4096 B logical: 512 B serial: <filter> rev: 4008 scheme: GPT ID-6: /dev/sdf type: USB vendor: Western Digital model: WD My Passport 25E2 size: 1.82 TiB block size: physical: 512 B logical: 512 B serial: <filter> rev: 4005 scheme: MBR Partition: ID-1: / raw size: 111.79 GiB size: 109.53 GiB (97.98%) used: 101.93 GiB (93.1%) fs: ext4 dev: /dev/sda1 Swap: Alert: No Swap data was found. Sensors: System Temperatures: cpu: 36.0 C mobo: 37.0 C gpu: nvidia temp: 80 C Fan Speeds (RPM): cpu: 0 fan-1: 0 fan-2: 2122 fan-3: 1053 fan-4: 0 fan-5: 0 gpu: nvidia fan: 62% Voltages: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.30 Info: Processes: 334 Uptime: 19m Memory: 62.85 GiB used: 5.62 GiB (8.9%) Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: pacman: 1310 lib: 354 Shell: Zsh v: 5.8 running in: sakura inxi: 3.1.05
