[Stable Update] 2017-09-23 - Kernels, Mesa, PulseAudio, GST, Python, Haskell
update
stable
#41
Try refreshing your keys
sudo pacman-key --populate manjaro
#42
smooth update (besides the key signing mentioned in post #2) on KDE using CLI, thanks team!
And 4.13 is booting again :smiley:
nevertheless, i am a bit shocked that 4.12 is EOL already
#43
Non LTS kernels don’t have a very long lifespans, so don’t get too attached to 4.13 either, the grim reaper will be after it soon enough too… :skull_and_crossbones:
4.14 is the next LTS kernel so it will live to a ripe old age…
#44
i know, but don’t they usually last longer than .3-version of the following kernel?
#45
More likely with the speed Greg K-H is currently having, v4.13 series might have at least a .10.
#46
Hi @Aladar, simply go to any keyserver and search for our keys. Thanos for example is a new developer, which got signed by our team. So all listed keys are valid used to sign his key.
Taking my key on the other hand, which exists since the beginning of this project, you see one key not valid and existing anymore.
Taking badboy @oberon you see a lot of expired keys on his developer key, which is the PGP Global Directory Verification Key.
Tho this makes the noise so far during the integrity check.
So we have to clean-up my key:
phil@manjaro ~ $ gpg --edit-key 11C7F07E
gpg (GnuPG) 2.2.1; Copyright (C) 2017 Free Software Foundation, Inc.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Secret key is available.
sec  rsa2048/CAA6A59611C7F07E
     created: 2012-05-05  expires: never       usage: SC
     trust: ultimate      validity: ultimate
ssb  rsa2048/320011450576724A
     created: 2012-05-05  expires: never       usage: E
[ultimate] (1). Philip Müller (Called Little) <philm@manjaro.org>
gpg> clean
User ID "Philip Müller (Called Little) <philm@manjaro.org>": 3 signatures removed
gpg> save
phil@manjaro ~ $ gpg --check-signatures 11C7F07E
pub   rsa2048 2012-05-05 [SC]
      E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E
uid           [ultimate] Philip Müller (Called Little) <philm@manjaro.org>
sig!3        CAA6A59611C7F07E 2012-05-05  Philip Müller (Called Little) <philm@manjaro.org>
sig!         62443D89B35859F8 2014-12-07  artoo (manjaro.org) <flower_of_life@gmx.net>
sig!         8934292D604F8BA2 2014-12-07  Alexandru Ianu <alexandru@manjaro.org>
sig!         2C089F09AC97B894 2014-12-07  Ramon Buldü <ramon@manjaro.org>
sig!         2B80869C5C0102A6 2014-12-08  Rob McCathie <korrode@gmail.com>
sig!         DAD3B211663CA268 2016-02-28  Bernhard Landauer <oberon@manjaro.org>
sig!3        9C08A255442FAFF0 2015-03-01  Jonathon Fernyhough <jonathon@manjaro.org>
sig!         7EC47C82A42D53A2 2016-04-16  kendell clark <kendell@manjaro.org>
sig!         8DB9F8C18DF53602 2016-06-25  Stefano Capitani <stefano@manjaro.org>
sig!         E3B3F44AC45EE0AA 2017-06-04  artoo-manjaro <artoo@manjaro.org>
sig!         8238651DDF5E0594 2017-06-02  Matti Hyttinen <matti@manjaro.org>
sig!         1817DC63CD3B5DF5 2017-09-15  Thanos Apostolou (manjaro maintainer) <thanos@manjaro.org>
sig!         17C752B61B2F2E90 2017-05-31  Frede Hundewadt <fh@manjaro.org>
sub   rsa2048 2012-05-05 [E]
sig!         CAA6A59611C7F07E 2012-05-05  Philip Müller (Called Little) <philm@manjaro.org>
gpg: 14 good signatures
That fixed, we send it to our key-server:
phil@manjaro ~ $ gpg --send-keys 11C7F07E
gpg: sending key CAA6A59611C7F07E to hkp://keys.gnupg.net
We will sync with it in a while and with one of our next manjaro-keyring updates this is fixed. To learn more about keys you can read also this.
#47
Update on 12 Machines without Problems.
DK3
#48
after update , and install new kernel 4.13
i have to upgrade bios --> lost of list efi boot
i have to restore Grub Efi , dont know why bios still looking for Bootx64.efi and not Grubx64.efi
#49
All seems smooth on my KDE installation.
I tried the experimental 4.14 kernel but found it very laggy, but since that’s only experimental I’m not going to worry, just go back to 4.13.
#50
thanks for the reply. that’s what I got after running the command:
==> Appending keys from manjaro.gpg...
key 5BD96CC4247B52CC:
1 signature not checked due to a missing key
key CAA6A59611C7F07E:
3 signatures not checked due to missing keys
key 363DFFFD59152F77:
key 2B80869C5C0102A6:
2 signatures not checked due to missing keys
key 8934292D604F8BA2:
key 2C089F09AC97B894:
key 137C934B5DCB998E:
key 62443D89B35859F8:
key DAD3B211663CA268:
key 8DB9F8C18DF53602:
==> Locally signing trusted keys in keyring...
  -> Locally signing key 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
  -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
  -> Locally signing key 76C6E477042BFE985CC220BD9C08A255442FAFF0...
  -> Locally signing key 2D14560CDCE6A75BB186DB758238651DDF5E0594...
  -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
  -> Locally signing key 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
  -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
  -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
  -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
  -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
  -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
  -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
  -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
  -> Locally signing key 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
  -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
  -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
  -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
  -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
==> Updating trust database...
gpg: next trustdb check due at 2017-10-20
sadly, nothing has changed afterwards.
#51
From the output, the keys has been signed locally so it should worked now. Can you post the output of pacman -Syu?
#52
Seems the same mirror that was having problem before summer (missing core.db), the date of the last core sync is near the fix to the previous problem: Core.db missing from CatN mirror
#53
sure, here it goes…
sudo pacman -Syu
:: Synchronising package databases...
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
resolving dependencies...
Package (54)                 Old Version               New Version  Net Change  Download Size
extra/boost-libs             1.64.0-4                  1.65.1-1       0.29 MiB
core/device-mapper           2.02.173-1                2.02.174-1     0.00 MiB
extra/exiv2                  0.26-1                    0.26-2        -0.01 MiB
extra/fontconfig             2.12.5-1                  2.12.6-1       0.00 MiB
extra/fuse-common            3.1.1-1                   3.2.0-1        0.01 MiB
extra/fuse2                  2.9.7-3                   2.9.7-4       -0.02 MiB
extra/fuse3                  3.1.1-1                   3.2.0-1       -0.01 MiB
core/gnupg                   2.2.0-1                   2.2.1-1       -0.32 MiB
extra/gsfonts                20170727-1                20170829-1     0.05 MiB
extra/gst-libav              1.12.2-1                  1.12.3-1      -0.01 MiB
extra/gst-plugins-bad        1.12.2+27+g2b8edd9c0-1    1.12.3-1       0.00 MiB
extra/gst-plugins-base       1.12.2-1                  1.12.3-1       0.00 MiB
extra/gst-plugins-base-libs  1.12.2-1                  1.12.3-1      -0.12 MiB
extra/gst-plugins-good       1.12.2-1                  1.12.3-1      -0.09 MiB
extra/gst-plugins-ugly       1.12.2-1                  1.12.3-1      -0.01 MiB
extra/gstreamer              1.12.2-1                  1.12.3-1      -0.14 MiB
extra/imagemagick            6.9.9.13-1                6.9.9.14-1     0.02 MiB
community/inxi               2.3.38-1                  2.3.39-1       0.00 MiB
extra/jasper                 2.0.13-2                  2.0.14-1       0.04 MiB
community/kdeconnect         1.0.3-1                   1.2-1          0.31 MiB
extra/krita                  3.2.1-1                   3.2.1-2       -0.18 MiB
multilib/lib32-fontconfig    2.12.5-1                  2.12.6-1       0.00 MiB
multilib/lib32-libgcrypt     1.7.8-1                   1.8.1-1        0.07 MiB
multilib/lib32-libpulse      11.0-1                    11.1-1         0.00 MiB
multilib/lib32-llvm-libs     4.0.1-1                   5.0.0-1        7.52 MiB
multilib/lib32-mesa          17.2.0-1                  17.2.1-1       0.03 MiB      11.19 MiB
extra/libcdr                 0.1.3-3                   0.1.4-1        0.10 MiB
extra/libcmis                0.5.1-6                   0.5.1-7        0.02 MiB
extra/libixion               0.12.2-2                  0.12.2-3       0.01 MiB
core/libksba                 1.3.4-2                   1.3.5-1        0.00 MiB
extra/libnm                  1.8.3dev+18+gf43222d41-1  1.8.4-1        0.00 MiB
extra/libnm-glib             1.8.3dev+18+gf43222d41-1  1.8.4-1        0.00 MiB
extra/liborcus               0.12.1-2                  0.12.1-3       0.02 MiB
extra/libpulse               11.0-1                    11.1-1        -0.01 MiB
extra/libtorrent-rasterbar   1:1.1.4-1                 1:1.1.4-2      0.05 MiB
core/linux413                4.13.2-1                  4.13.3-2       0.00 MiB      65.85 MiB
extra/linux413-bbswitch      0.8-2                     0.8-3          0.00 MiB       0.02 MiB
extra/linux413-ndiswrapper   1.61-2                    1.61-3         0.00 MiB       0.13 MiB
extra/linux413-nvidia        1:375.82-2                1:375.82-3     0.00 MiB       6.94 MiB
extra/llvm-libs              4.0.1-5                   5.0.0-1        6.65 MiB
core/lvm2                    2.02.173-1                2.02.174-1     0.00 MiB
core/man-pages               4.12-1                    4.13-1         0.03 MiB
extra/mesa                   17.2.0-2                  17.2.1-3      11.21 MiB
extra/networkmanager         1.8.3dev+18+gf43222d41-1  1.8.4-1       -0.02 MiB
extra/noto-fonts             20170428-1                20170920-1   247.69 MiB
extra/pulseaudio             11.0-1                    11.1-1        -0.05 MiB
extra/pulseaudio-bluetooth   11.0-1                    11.1-1         0.00 MiB
extra/pulseaudio-gconf       11.0-1                    11.1-1         0.00 MiB
extra/pulseaudio-zeroconf    11.0-1                    11.1-1         0.00 MiB
extra/python-setuptools      1:36.4.0-1                1:36.5.0-1     0.00 MiB
community/qbittorrent        3.3.16-1                  3.3.16-2       0.00 MiB
core/s-nail                  14.9.3-1                  14.9.4-1       0.05 MiB
community/sshfs              3.2.0-1                   3.2.0-2        0.00 MiB
extra/xf86-input-libinput    0.25.1-1                  0.26.0-1      -0.01 MiB
Total Download Size:    84.14 MiB
Total Installed Size:  874.16 MiB
Net Upgrade Size:      273.18 MiB
:: Retrieving packages...
 linux413-4.13.3-2-x86_64                                 65.9 MiB  7.81M/s 00:08 [###############################################] 100%
 linux413-bbswitch-0.8-3-x86_64                           21.9 KiB  7.13M/s 00:00 [###############################################] 100%
 linux413-ndiswrapper-1.61-3-x86_64                      137.6 KiB  8.40M/s 00:00 [###############################################] 100%
 linux413-nvidia-1:375.82-3-x86_64                         6.9 MiB  8.14M/s 00:01 [###############################################] 100%
 lib32-mesa-17.2.1-1-x86_64                               11.2 MiB  7.41M/s 00:02 [###############################################] 100%
(54/54) checking keys in keyring                                                  [###############################################] 100%
(54/54) checking package integrity                                                [###############################################] 100%
error: lib32-mesa: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/lib32-mesa-17.2.1-1-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: linux413: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/linux413-4.13.3-2-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: linux413-bbswitch: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/linux413-bbswitch-0.8-3-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: linux413-ndiswrapper: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/linux413-ndiswrapper-1.61-3-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: linux413-nvidia: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/linux413-nvidia-1:375.82-3-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
#54
Kernel 4.13.3 fixed the problem "4.13.2 boots, but none of the usb devices are working on my main pc"
No problems updating on 4 machines.
#55
@najodleglejszy, please try :
sudo pacman-key --lsign-key caa6a59611c7f07e
#56
  -> Locally signing key caa6a59611c7f07e...
unfortunately, I’m still getting the exact same output as in my previous comment when running pacman -Syu.
#57
Updating my machine for work… :rofl: lets hope the best~
€dit: Everything’s OK :smiley:
#58
Another smooth update on my machine. Big thanks to Phil, core team & everyone who contributed upstream.
More power to you all & the amazing community.
Ruziel :slight_smile:
#59
Okay try this :
sudo pacman-mirrors -c all -f 5 -y
sudo pacman -Syw manjaro-keyring
sudo pacman -U /var/cache/pacman/pkg/manjaro-keyring-$(expac '%v' manjaro-keyring)-any.pkg.tar.xz
Hope this one works!
#60
looks like I’m getting stuck on the second step :confused:
 core is up to date
 extra is up to date
Package (1)           Old Version  New Version  Net Change
core/manjaro-keyring  20170919-1   20170919-1     0.00 MiB
Total Download Size:  0.00 MiB
:: Proceed with download? [Y/n]
(1/1) checking keys in keyring                                                    [###############################################] 100%
(1/1) checking package integrity                                                  [###############################################] 100%
error: manjaro-keyring: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/manjaro-keyring-20170919-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
