[Stable Update] 2017-07-27 - Kernels, VirtualBox, Deepin, Mesa
update
stable
#21
It was never un-resolved. The change was intentional, and stands.
#22
yes but you can find it in AUR now
#23
Deepin update with no issues. I reported this before upstream, but I’m waiting for the day my USB devices show up on the dock. I have two devices attached [screenshot] but no dock icon regardless of what icon set I use. :frowning:
#24
Smooth update. First in a KDE VM, then on two KDE Laptops and last on one LXQt netbook.
#25
Synchronising databases…
Command finished with errors!
That’s sth new for me.
:: Synchronising package databases…
error: failed to update core (no servers configured for repository)
error: failed to update extra (no servers configured for repository)
error: failed to update community (no servers configured for repository)
error: failed to update multilib (no servers configured for repository)
error: failed to synchronise any databases
error: failed to init transaction (no servers configured for repository
#26
Perfect!!!
regards
caho
#27
Try running this first :
sudo pacman-mirrors -c -all -g -y
#28
As always no issues on running XFCE on System76 Kudu4
#29
update ok
#30
Do you know why guayadeque was removed from the repository?
It was the default music player for Manjaro.
#31
Smooth Update. Why do you prefer yaourt for AUR over pacaur?
#32
Maybe this is the reason?
#33
… Poland : http://mirror.chmuri.net/manjaro/
.: Error [Errno 113] No route to host ‘http://mirror.chmuri.net/manjaro/
.: Info Writing mirror list
.: Info Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[estudio@Dell ~]$ sudo pacman-mirrors -c -all -g -y
usage: pacman-mirrors [-h] [-g] [-f NUMBER] [-i] [-d] [-m {rank,random}]
[-c COUNTRY [COUNTRY …]] [–geoip] [-l]
[-b {stable,testing,unstable} | -G | -S {stable,testing,unstable}]
[-a] [-p PREFIX]
[-P {all,http,https,ftp,ftps} [{all,http,https,ftp,ftps} …]]
[-R] [-U URL] [-q] [-t SECONDS] [-v] [-n | -y]
pacman-mirrors: error: argument -c/–country: expected at least one argument
anything else we could do here? thx by the way :slight_smile:
#34
That one was a typo. Try this :
sudo pacman-mirrors -c all -g -y
#35
Update OK except for kernel 4.12.3-1.
On resume from Suspend-to-RAM, system no longer responds to mouse or keyboard clicks; network connection fails to resume.
[stephen@w6 ~]$ inxi -Fxzc0
System: Host: w6 Kernel: 4.12.3-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: KDE Plasma 5.10.4 (Qt 5.9.1)
Distro: Manjaro Linux
Machine: Device: desktop System: ASUS product: All Series
Mobo: ASUSTeK model: Z97-A v: Rev 1.xx BIOS: American Megatrends v: 1204 date: 06/20/2014
CPU: Quad core Intel Core i5-4690S (-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25597
clock speeds: max: 3900 MHz 1: 1040 MHz 2: 899 MHz 3: 900 MHz 4: 900 MHz
Graphics: Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller bus-ID: 00:02.0
Display Server: x11 (X.Org 1.19.3) drivers: intel (unloaded: modesetting)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel Haswell Desktop version: 4.5 Mesa 17.1.5 Direct Render: Yes
Audio: Card-1 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
driver: snd_hda_intel bus-ID: 00:03.0
Card-2 Intel 9 Series Family HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.12.3-1-MANJARO
Network: Card: Intel Ethernet Connection (2) I218-V driver: e1000e v: 3.2.6-k port: f080 bus-ID: 00:19.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
Drives: HDD Total Size: 5257.1GB (31.7% used)
ID-1: /dev/sda model: Crucial_CT256M55 size: 256.1GB
ID-2: /dev/sdb model: ST2000DM001 size: 2000.4GB
ID-3: /dev/sdc model: WDC_WD30EZRX size: 3000.6GB
Partition: ID-1: / size: 234G used: 11G (5%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 473M used: 116M (26%) fs: ext2 dev: /dev/sda1
ID-3: /var size: 1.8T used: 16G (1%) fs: ext4 dev: /dev/sdb2
ID-4: /home size: 2.7T used: 1.5T (58%) fs: ext4 dev: /dev/sdc1
ID-5: swap-1 size: 17.18GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C
Fan Speeds (in rpm): cpu: 0
Info: Processes: 189 Uptime: 7 min Memory: 1892.6/15928.2MB Init: systemd Gcc sys: 7.1.1
Client: Shell (bash 4.4.121) inxi: 2.3.23
Second system – different hardware, same problem:
[stephen@W7 ~]$ inxi -Fxzc0
System: Host: W7 Kernel: 4.12.3-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: KDE Plasma 5.10.4 (Qt 5.9.1)
Machine: Device: desktop System: Gigabyte product: Z270M-D3H v: Default string
Mobo: Gigabyte model: Z270M-D3H-CF v: x.x UEFI: American Megatrends v: F2 date: 11/25/2016
CPU: Quad core Intel Core i5-7600 (-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 28040
clock speeds: max: 4100 MHz 1: 799 MHz 2: 1567 MHz 3: 799 MHz 4: 800 MHz
Graphics: Card: Intel Device 5912 bus-ID: 00:02.0
Display Server: x11 (X.Org 1.19.3) driver: intel Resolution: 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2)
Audio: Card Intel 200 Series PCH HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
Network: Card: Intel Ethernet Connection (2) I219-V driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac:
Drives: HDD Total Size: 5251.1GB (31.5% used)
ID-1: /dev/sdb model: WDC_WD30EZRX size: 3000.6GB
ID-2: /dev/sdc model: ST2000DM001 size: 2000.4GB
ID-3: /dev/sda model: Samsung_SSD_850 size: 250.1GB
Partition: ID-1: / size: 228G used: 8.7G (5%) fs: ext4 dev: /dev/sda1
ID-2: /var size: 251G used: 8.3G (4%) fs: ext4 dev: /dev/sdc1
ID-3: /home size: 2.7T used: 1.5T (58%) fs: ext4 dev: /dev/sdb1
ID-4: swap-1 size: 34.36GB used: 0.00GB (0%) fs: swap dev: /dev/sdc2
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 165 Uptime: 1 min Memory: 569.6/32099.2MB Init: systemd Gcc sys: 7.1.1
#36
While updating it says the following:
Failed to commit transaction:
conflicting files:
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSBase.h already exists in filesystem
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSContextRef.h already exists in filesystem
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSObjectRef.h already exists in filesystem
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSStringRef.h already exists in filesystem
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSTypedArray.h already exists in filesystem
webkit2gtk: /usr/include/webkitgtk-4.0/JavaScriptCore/JSValueRef.h already exists in filesystem
anyone know how to solve this?
#37
Check who owns that file
For example :
pacman -Qo /usr/include/webkitgtk-4.0/JavaScriptCore/JSBase.h
If no one owns it, you may safely delete it or move it and do the update again…
#38
Yes it worked before the update. Normally I update a few days after the announcement, when problems are discussed.
Yes I did reboot.
Kernel: 4.9.39-1-MANJARO x86_64 (64 bit) , as indicated in my profile.
DE: XFCE
Thank you.
#39
@philm
When I open some images with different image viewers (tested by me are ristretto and viewnior), for exampletompaatthegates
(Tomas “Tompa” Lindberg from At the Gates)
they give me the error: Unsupported number of color components (1)
Before the update, everything worked fine.
Update downgrade gdk-pixbuf2 2.36.7-1 to version 2.36.6-2 has resolved the issue.
#40
I am running high on the Manjaro wave - thanks guys!
