[Stable Update] 2017-07-16 - Kernels, Deepin, Palemoon, KDE-Framework, XFCE4-GTK3
update
stable
#81
Same question for you
Can You give info about your system, hardware, desktop and which drivers.
I ask not because I can help but just because I’m scared for my system :slight_smile:
#82
Kernel: 4.9.35-1-MANJARO i686 (32 bit) Desktop: Gnome 3.24.2
Machine: Device: laptop System: ASUSTeK product: F7F v: 1.0
Mobo: ASUSTeK model: F7F v: 2.1 BIOS: American Megatrends v: 203
CPU: Dual core Intel Core Duo T2250 (-MCP-) cache: 2048 KB
Graphics: Card: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics Controller
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.9.35-1-MANJARO
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8168
Card-2: Intel PRO/Wireless 3945ABG [Golan] Network Connection driver: iwl3945
Drives: HDD Total Size: 240.1GB (77.8% used)
#83
175 packages, OpenRC, KDE and XFCE, 0 issues. Excelent work. :slight_smile:
#84
Seems to be working here with no issues on the 4.11 kernel using GNOME.
I did get a warning after the update though
could not get file information for etc/xdg/autostart/msm_notifier.desktop
I tested 4.12.1 briefly as well and it seemed to work fine. I didn’t modify any files for changing schedulers or anything like that. I’m going back to 4.11 in order to avoid potential issues.
#85
I don’t understand the kernel thing either. I’m using 4.9.37 which appears to be the LTS/Recommended one. I don’t understand why I would use anything but the LTS/Recommended kernel. When a different kernel becomes the LTS/Recommended version, I’ll switch to that one.
#86
XFCE here.
Updated, switched kernels, rebooted, opened a few apps, everything seems fine and dandy.
#87
Hi folks,
Translate bug (French lang)
Return of the famous pamac mirrors select bug
#88
KDE_64 Kernel 411 - 412
after the update I got ‘cgroup: remount is not allowed’ on shutdown or reboot
#89
yes… i know. the recommended kernel (4.9) is still on board.
#90
Had to remove npm prior to installing the update, since that was preventing me from updating throwing out an error everytime. After removal of npm everything went smoothely. Installed npm again after update. However, I noticed that it the update also installed alot of KDE depedencies while I do not have KDE nor any KDE apps… Can I safely remove these dependecies?
#91
Great work, updates on 3 machines went very smoothy.
OS: Manjaro 17.0.2 Gellivara
Kernel: x86_64 Linux 4.11.10-1-MANJARO
Uptime: 37m
Packages: 1259
Shell: bash 4.4.12
Resolution: 1600x900
DE: Cinnamon 3.4.3
WM: Muffin
WM Theme: Vertex-Maia (Vertex-Maia-Dark)
GTK Theme: Vertex-Maia [GTK2/3]
Icon Theme: Vibrancy-Full-Dark-Teal
Font: Cantarell 10
CPU: Intel Pentium P6200 @ 2x 2.133GHz [49.0°C]
GPU: Mesa DRI Intel(R) Ironlake Mobile
RAM: 1688MiB / 3629MiB ```
`  OS: Manjaro 17.0.2 Gellivara
  Uptime: 34m
  Packages: 1232
  Shell: bash 4.4.12
  Resolution: 1920x1080
  DE: Cinnamon 3.4.3
  WM: Muffin
  GTK Theme: Vertex-Maia-Dark [GTK2/3]
  Font: Cantarell 10
  CPU: Intel Core i5-7500 @ 4x 3.8GHz [39.0°C]
  GPU: Gallium 0.4 on AMD POLARIS10 (DRM 3.10.0 / 4.11.10-1-MANJARO, LLVM 4.0.1)
  RAM: 2075MiB / 16016MiB```
```  eepc1201n
 Uptime: 2m
 Packages: 1004
 Shell: bash 4.4.12
 Resolution: 1366x768
 DE: Budgie
 WM: BudgieWM
 WM Theme: Adwaita
 Icon Theme: Arc-Maia
 Font: Cantarell 11
 CPU: Intel Atom 330 @ 4x 1.6GHz [57.0°C]
 GPU: ION
 RAM: 1089MiB / 1752MiB ```
#92
Same problem as [Stable Update] 2017-07-16 - Kernels, Deepin, Palemoon, KDE-Framework, XFCE4-GTK3 here.
With kernel 4.12, message ‘[FAILED] Failed to start load kernel modules’ appears, and while I can log in from tty2, I don’t know what is wrong.
Kernel 4.11 works fine.
#93
I have done a full update, installed kernel 4.12 and rebooted.
Now I have a single 4.12 entry in the GRUB menu at boot, other kernels and operating systems are not listed any more. This is not a problem for me, but it’s not the way it should work.
The Octopi bug/regression not listing AUR packages to be updated is still there.
I have not tried suspension yet.
#94
I encountered this something like a login loop(I enter my credentials press enter and then login form appears again), after system update and reboot. Can’t solve this problem
#95
hi,
the update went fine but I noticed plasmashell is eating up my RAM over time until all available RAM is consumed.
running Manjaro KDE 17.02 with this update on DELL Optiplex 9020.
#96
One question about the updates:
I’m away from home since June 22 and therefore have missed a few updates, including the one of today. When I’m home and I do an update will it all go well, or is this one of the rare cases where a re-install is needed?
What I’m referring to is this:
When a package received an update on June and one in July will I have 2 updates or just the last one?
How is this organized?
#97
Also have this problem. Have reverted to Kernel 4.11.10-1, which works OK
#98
hi,
whatever kernel version i choose, it ended up consuming all available ram until system hangs. even running the recommended kernel
#99
not a bug, you can translate at https://www.transifex.com/manjarolinux/manjaro-settings-manager/
French:  91% 19 chaînes à traduire
#100
Good update on 4 machines
