[Stable Update] 2017-06-26 - Cinnamon, Kernels, LibreOffice, Haskell
update
stable
#41
I’m using cinnamon and this update is trying to install nautilus, even though I already have (obviously) nemo installed. I don’t want a bunch of file explorers coexisting together in my computer!!!
#42
Update went through without problems. Some of the last 3 updates has reduced GFX corruption while starting plasma. Previously the screen flashed corruption several times while booting, now it only boots up corrupted and updates with one pass.
I have pinpointed this problem happens only when i boot with my second display connected.
#43
been getting the below error in Chromium since the patch last week which was installed the day before this patch and no idea how to fix it.
$1 was blocked because it is out of date
#44
I mentioned in an earlier post all had gone well. In fact I had even posted from my firefox browser!
Later in the day when I decided to use my bookmarks menu I was presented by this unusual arrangement.
Sort of menu stepping going to infinity and NOT opening to reveal the bookmarks within.
I have to say I have never seen anything quite like this before.
Troubleshooting steps. Backed up .mozilla folder. Restarted firefox-kde and was presented with the default bookmarks menu and exactly the same problem - stepdown menus going on and on.
The image you see above is from the backed up .mozilla folder.
I’ll probably download the newly announced ISO today and re-install but before I do I am I intrigued to find out if any other users have ever seen this before?
Thanks
#45
Something like this?
#47
Yeeeeeeeeeeeeeees, that is exactly the same problem.
Thanks that thread is perfect
#48
Smooth as always, great job o/
#49
Ditto. Another smooth update.
#50
Smooth update on 4 machines
#51
Same thing happened to me after the last update. My fix was to uninstall firefox-kde and just install regular firefox. Worked like a charm.
#52
Can confirm on the Firefox KDE bookmark problem, the solution was to remove it and replace it with the regular Firefox.
#53
On Manjaro Cinnamon here, all good! The last couple of updates have been flawless, and were downloaded in a flash - even on my 3 mbps connection. Thanks guys.
#54
smooth update on xps9550 KDE
#55
Right on. Rolling on.
XFCE smooth.
#56
Smooth update.
#57
I don’t know if this is a bug or I just haven’t found the settings yet but I’m having this issue quite often after the update:
This happens randomly no matter what applications I’m running as far as I observed.
#58
Thanks for doing the legwork on that. I was also perplexed why suddently I was getting 700 MB of haskell packages. Removed pandoc and that solved the problem. Don’t know why I had pandoc. I’m a pretty longtime Manjaro user though, can’t even remember I first installed it.
Do you know how I get a list of all my aur packages, to double check if anyone of them needed pandoc?
#59
@Kaleb this was triggered by a bad chain of dependencies. It’s fixed with the latest cinnamon package. You can now remove again these packages:
sudo pacman -Rsn gnome-panel tint2 metacity
This will also remove nautilus among others.
#60
I run
pacman -Qm
after every big upgrade, as sometimes packages get ‘demoted’ to the AUR.
#61
Me neither, it was pulled in as a dependency for something, but at some stage became an orphaned package on my system.
You can check when it was installed in pacman log
cat /var/log/pacman.log | grep pandoc
