[Stable Update] 2017-06-06 - Plasma 5, Boost, Deepin, Mesa, GCC
update
stable
#82
Working beautifully. Thanks for another swift and comprehensive update.
#83
Works fine for me. Sad that Wayland still doesn’t work on Plasma 5.10 yet :cry:
#84
Thanks for sharing. I ran into the same issue, saw your post, and was able to upgrade afterwards after removing gcc-libs-multilib using the command above.
#85
Everything went well in XFCE. Updated from cli.
I must have missed something here. What’s the difference between updating from gui and doing it from cli ???
Thanks.
#86
I also had this issue,
The problem in my case was caused by lib32-gcc-libs, installed as dependence of other 32bit packages,
with gcc.
Despite this, smooth update
#87
I had a problem with GCC too.
I use Octave and I had to unnistall gcc-fortran, update gcc-multilib gcc-libs-multilib lib32-gcc-libs and then reinstall gcc-fortran.
Everything is fine now.
#88
Please also add gcc-objc-multilib to the line :wink:
Please also add gcc-fortran-multilib to the line :wink:
Remove pacman-debug as it is not needed.
Please switch over to unstable branch and update to Plasma v5.10.1.
GCC issue is already explained multiple times. Don’t mix standard GCC with GCC-multilib.
#89
Same. On OpenRC XFCE of 3 May 17. Thanks, @jeancf
#90
It worked. thanx…
#91
Hello, I am a nooby and I notice when I install adapta-maia theme the windows main title of the window (for example thunar) are still vertex-maia theme. Does your solution fix that?
#92
To change the looks of title bar, you need to change it in the Window Manager menu (Specifically in the Style tab) from Settings
#93
A bit strange this bug is still not fixed on Manjaro : https://phabricator.kde.org/D5128 on see at: Scrollbar oversized in Firefox 52
The bug is fixed already on a Distribution using Plasma 5.8.7 LTS ?
JohnW
#94
Smooth update, however there’s no slider for icon size in task manager. Other Plasma features do exist, though.
#95
Where were you expecting to see this? In the Task Manager itself? or somewhere In Settings?
I haven’t seen such a slider the last several releases of KDE either.
I thought they were all scaled relative to taskbar size.
#97
Watch the video
#98
Did you forget the link?
#99
I think he meant the video that @philm posted on the thread…
#100
Exactly
#101
Had gcc multilib issue, but running philm’s fix from above
$ sudo pacman -S gcc-multilib gcc-libs-multilib lib32-gcc-libs
replaced gcc itself, and allowed the update to proceed. Good work everybody.
Using KDE Plasma, Linux 4.9
#102
Thank You, Thank You…
I am not so great at the Command Line in the Terminal but this seemed to fix the problem of gcc-libs for me so I at least can get a new install of Manjaro Cinnamon going.
Always learning, but never have been a master here
