[Stable Update] 2017-06-06 - Plasma 5, Boost, Deepin, Mesa, GCC
update
stable
#184
It has been a couple of months since I have tried this:
https://bugs.kde.org/show_bug.cgi?id=360333#c33
If you try, could you report back on whether it works?
#185
The taskbar icons are too small not the systray ones. The minimize all widget is huge while added apps are way too small after the update.
Problem solved! The icon size for Oxygen was reduced.
System-settings -> Symbols -> Advanced -> taskbar size e.g. 64
#186
KDE - you are right - the icons are far too small.
I am going blind - no such settings here!
The issue has been tracked down:
[Stable Update] 2017-06-18 - Kernels, Plasma, KDE Apps, Firefox, Thunderbird, Mesa
#187
Absolutely no issues on xfce, small and buttery smooth; Thx a lot!
#188
Back to the icon size issue - I have just applied the work-around, but the icon are not scaling.
I set the size to 2
Any ideas how to make it work? It looks ridiculous…
I am sure it worked just fine in October…
#189
