[Stable Update] 2017-05-19 - Kernels, LibreOffice, Mesa, Thunderbird, Cinnamon
update
stable
#44
Had the same problem cause radiotray requires this package, here’s my solution
sudo pacman -Rdd gstreamer0.10-good-plugins
sudo pacman -Rdd libsoup
yaourt -S libsoup-gnome-git
yaourt -S gstreamer0.10-good-plugins
#45
Perfect! Went smoothly…Thanks!
#46
Smooth, no problems. KDE, pacman -Syu
#47
Error when building mkinitcpio for linux 4.4 - module crc32 not found; However, still boots fine as I’m not using F2FS.
I’ve always had issues at boot while entering decryption passphrase however, don’t know if its related?
#48
One again everything went well with the update.
Thank you @philm and the Manjaro team.
My system:
OS: Manjaro 17.0.1 Gellivara
Kernel: x86_64 Linux 4.10.16-1-MANJARO
Uptime: 8h 3m
Packages: 1800
Shell: bash 4.4.12
Resolution: 1920x1080
DE: XFCE4
WM: Xfwm4
WM Theme: Default
GTK Theme: Adwaita-Maia [GTK2]
Icon Theme: Faience-Ocre
Font: Ubuntu 14
CPU: Intel Core i7-5500U @ 4x 3GHz [54.5°C]
GPU: Mesa DRI Intel® HD Graphics 5500 (Broadwell GT2)
RAM: 5059MiB / 7903MiB
#49
great, but where is Mesa 17.1? :frowning:
#50
Did the update and things work great. Thanks.
#51
We updated to v17.0.6 my friend. v17.1 will be added when ready.
#52
No issues updating Xfce Laptop intel integrated graphics. Used pacman in xfce terminal. Thank you all so much!
#53
What’s in 17.1 that you are waiting for so expectantly?
#54
Threaded GL, shader-on-disk cache, more vulkan work and of course many optimisations. I’m really happy with it! But mesa 17.1 is still in arch testing for now.
#56
Everything was super smooth as usual guys! Thanks for your work.
DE: GNOME
Kernels: linux44 & linux49
#57
I was longing for Cinnamon 3.4!!! Thanks :grin:
#58
Flawless update on KDE, no issues at all. Thanks!
#59
Hi, since the latest Update the Hardware Keys for Brightness are not working any more. This Problem I saw on 4 different Notebooktypes. Any Solution?
#60
Same problem.
#61
The actual update went flawless and smooth.
The only issue I encountered was when it tried to update an AUR pkg I use called SkyChart.
Apparently whomever maintains that pkg screwed up and forgot one of the dependencies called libpasastro.
So, just removed pkg’s associated with program until I read in the AUR it has been repaied, then will reinstall entire large program.
#62
Updated LXDE here. Flawless.
#63
Well, well - the 4.11.1 line of Kernel keeps bugging me massively; For now back to 4.9.28 which is/was the last one that worked flawless.
#64
Is 4.11.1 the recommend/LTS kernel?
