[Stable Update] 2017-03-20 - Deepin, KDE Framework, Haskell, Python, Kernels
update
stable
#1
Hi community,
with this update we have updated most of our Kernels, added the latest KDE framework, pushed out some more Deepin packages and renewed Python and Haskell.
Please report any issues you may have with this update.
Kind regards,
Philip Müller and the Manjaro Development Team
Current supported Kernels
  • linux310 3.10.105
  • linux312 3.12.70
  • linux316 3.16.41
  • linux318 3.18.48 [EOL]
  • linux41 4.1.39
  • linux44 4.4.54
  • linux48 4.8.17 [EOL]
  • linux49 4.9.15
  • linux410 4.10.3
  • linux-RT-LTS 4.4.50_rt62
  • linux-RT 4.9.13_rt11
Package Updates (Fri Mar 17 08:15:08 CET 2017)
  • stable community i686: 365 new and 351 removed package(s)
  • stable community x86_64: 368 new and 353 removed package(s)
  • stable core i686: 21 new and 21 removed package(s)
  • stable core x86_64: 21 new and 21 removed package(s)
  • stable extra i686: 265 new and 257 removed package(s)
  • stable extra x86_64: 265 new and 257 removed package(s)
  • stable multilib x86_64: 20 new and 14 removed package(s)
A detailed list of all package changes can be found here.
Troubleshoot
If manjaro-system can’t handle the file conflict issue with ca-certificates-utils do the following:
# pacman -Syuw                           # download packages
# rm /etc/ssl/certs/ca-certificates.crt  # remove conflicting file
# pacman -Su                             # perform upgrade
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Conflicts in updating system
#2
I get this:
Warning: could not fully load metadata for package ca-certificates-utils-20160507-1
Failed to prepare transaction:
invalid or corrupted package
#3
Are you on stable or testing branch?
Take a look here:
#4
I removed the conflicting file and it helped. Thanks!
#5
I’ve added the note for ca-certificates-utils to the first post.
#6
Thanks again.
I had an error on updating with pamac saying corrupt package. Updated repos and all OK. Upgrading now.
… and all went well
#7
manjaro-system could not automatically fix it for me - manual steps worked as expected. Thanks for the smooth update.
Should, a new ca-certificates.crt be created during the update? - or is that symlink entirely gone?
#8
Smooth update as always. :smile:
edit:never mind
#9
Apart from the ca-certificates-util error everything went smoothly. Thanks!
#10
It’s not a good solution just to remove it though. It needed to follow the three steps.
https://www.archlinux.org/news/ca-certificates-utils-20170307-1-upgrade-requires-manual-intervention/
#11
No certificates errors on KDE edition. Smoth update (as usual :slight_smile:) on 2 machines (as usual :slight_smile:). Thanks !
#12
I just did the update, at first it was blaming about conflicting files.
so I run the update from terminal following the steps described in the post.
but when I tried to remove certificate with rm /etc/ssl/certs/ca-certificates.crt it said, there is no such file.
so I proceed next and run the upgrade command, and it worked smoothly.
Now, it seems everything works fine, but I am wondering why there were not a certificate file? and am I fine now?
#13
I got this error with the kernel 4.4:
( 2/16) Updating linux44 initcpios
==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: ‘default’
-> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64.img
==> Starting build: 4.4.54-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [encrypt]
==> ERROR: module not found: crc32' -> Running build hook: [filesystems] -> Running build hook: [keyboard] ==> Generating module dependencies ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64.img ==> WARNING: errors were encountered during the build. The image may not be complete. ==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'fallback' -> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64-fallback.img -S autodetect ==> Starting build: 4.4.54-1-MANJARO -> Running build hook: [base] -> Running build hook: [udev] -> Running build hook: [modconf] -> Running build hook: [block] -> Running build hook: [encrypt] ==> ERROR: module not found:crc32’
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64-fallback.img
error: command failed to execute correctly
No problem with the kernel 4.9 installed on the same PC.
Anyway all seems to work with both the kernel: very strange.
#14
Please do not upgrade deepin-daemon to 3.1.5 ! if you already have, downgrade to 3.1.4
I’m currently trying to downgrade the package in the repos but have some kind of issues with that :wink:
In case you’re unable to launch a terminal from your graphical session because of broken deepin-daemon, you need to switch to a tty (with for example Ctrl+Alt+F2), login there and run downgrade then select version 3.1.4 (local) and confirm to downgrade.
#15
Smooth update on
System: Host: mgundogdu-pc Kernel: 4.9.15-1-MANJARO x86_64 (64 bit)
Desktop: Xfce 4.12.3 Distro: Manjaro Linux
Machine: Device: laptop System: HP product: HP ProBook 450 G4
Mobo: HP model: 8231 v: KBC Version 42.1E
UEFI: HP v: P85 Ver. 01.02 date: 08/30/2016
Battery BAT0: charge: 15.7 Wh 40.1% condition: 39.2/39.2 Wh (100%)
CPU: Dual core Intel Core i7-7500U (-HT-MCP-) cache: 4096 KB
clock speeds: max: 3500 MHz 1: 614 MHz 2: 600 MHz 3: 813 MHz
4: 607 MHz
Graphics: Card-1: Intel Device 5916
Card-2: NVIDIA GM108M [GeForce 930MX]
Display Server: X.Org 1.19.2 drivers: intel (unloaded: nvidia)
Resolution: 1366x768
GLX Renderer: Mesa DRI Intel HD Graphics 620 (Kabylake GT2)
GLX Version: 3.0 Mesa 17.0.1
Audio: Card Intel Device 9d71 driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.9.15-1-MANJARO
#16
Update on 12 Machines without Problems.
DK3
#17
I have updated 4 machine so far I two more to do. So far I have to the manual fix on each of them but it has worked well. Thanks for taking time to resolve the certifcate issue!
#18
Do you have the ca-certificates.crt symlink recreated by the package or is it gone for good on your installs as well?
#19
I believe so. I didn’t go back and check my logs.
#20
Thank you @oberon I was about to give up on deepin and switch to good old gnome. :slight_smile:
