[Stable Update] 2017-01-17 - Python, Xorg, Ruby, Gcc, Inkscape
update
stable
#84
Absolute no problems on Plasma.
Thanks to the Team!
Quad core Intel Core i5-4570
Kernel: 4.9.2-1-MANJARO x86_64
Cedar [Radeon HD 7350/8350 / R5 220]
Display Server: X.Org 1.19.1 driver: radeon
Desktop: KDE Plasma 5.8.5 (Qt 5.7.1)
#85
Beautiful work @oberon.
Some kernel versions are in the testing repository. Very good. :wink:
There are packages of extra and community that do not interfere with operation system, you do not need to accumulate updates for these packages.
Core updates require greater care.
#86
Used pamac, no problems. Thanks.
#87
Updated via the cli and on reboot and login got:
Could not start kdeinit5. Check your installation
Corrected by following the guide for Infinality fonts removal in a tty. Rebooted and all is well.
#88
Smooth update, no problems. :+1::+1:
First time with https mirrors, a bit slower but by not that much. Having to use more distant locations to get https links. :expressionless:
#89
Big update for me, nearly 1GB download, but all went very smoothly on KDE.
Great work @oberon and the Manjaro team, many thanks.
EDIT: Using my system for a couple of hours and it is flying, xorg 1.19 update performance improvements are very noticeable to me. Manjaro KDE is such a pleasure to use.
#90
I am having two problems with the update.
When updating python-setuptools:
python2-setuptools: /usr/lib/python2.7/site-packages/pkg_resources/__init__.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/pkg_resources/extern/__init__.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/__init__.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/archive_util.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/__init__.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/bdist_egg.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/build_py.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/easy_install.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/egg_info.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/install.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/install_egg_info.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/install_lib.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/install_scripts.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/py36compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/sdist.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/command/setopt.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/config.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/depends.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/dist.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/extension.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/extern/__init__.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/glob.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/lib2to3_ex.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/monkey.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/msvc.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/namespaces.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/package_index.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/py26compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/py27compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/py31compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/py33compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/py36compat.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/sandbox.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/ssl_support.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/unicode_utils.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/version.pyc exists in filesystem
python2-setuptools: /usr/lib/python2.7/site-packages/setuptools/windows_support.pyc exists in filesystem
And my the xf86-input-synaptics-xswipe-git touchpad driver isn’t loading anymore.
[     4.038] (II) config/udev: Adding input device DLL06E4:01 06CB:7A13 Touchpad (/dev/input/event10)
[     4.038] (**) DLL06E4:01 06CB:7A13 Touchpad: Applying InputClass "evdev touchpad catchall"
[     4.038] (**) DLL06E4:01 06CB:7A13 Touchpad: Applying InputClass "libinput touchpad catchall"
[     4.038] (II) LoadModule: "synaptics"
[     4.039] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[     4.039] (II) Module synaptics: vendor="X.Org Foundation"
[     4.040] 	compiled for 1.18.4, module version = 1.8.3
[     4.040] 	Module class: X.Org XInput Driver
[     4.040] 	ABI class: X.Org XInput driver, version 22.1
[     4.040] (EE) synaptics: module ABI major version (22) doesn't match the server's version (24)
[     4.040] (II) UnloadModule: "synaptics"
[     4.040] (II) Unloading synaptics
[     4.040] (EE) Failed to load module "synaptics" (module requirement mismatch, 0)
[     4.040] (EE) No input driver matching `synaptics'
[     4.040] (II) Falling back to input driver `libinput'
[     4.040] (II) Using input driver 'libinput' for 'DLL06E4:01 06CB:7A13 Touchpad'
#91
Netbook Spin was smooth. KDE version seemed to update well after:
:: Replace calligra-karbon with extra/calligra? [Y/n] y
:: Replace calligra-libs with extra/calligra? [Y/n] y
resolving dependencies...
:: calligra and calligra-braindump are in conflict. Remove calligra-braindump? [y/N] y
:: xorg-server and xf86-input-acecad are in conflict (X-ABI-XINPUT_VERSION). Remove xf86-input-acecad? [y/N] y
:: xorg-server and xf86-input-joystick are in conflict (X-ABI-XINPUT_VERSION). Remove xf86-input-joystick? [y/N] y
warning: dependency cycle detected:
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Everything seemed great after the re-boot. I like the new Plasma wallpaper.
#92
For the first problem, please, read what Oberon wrote in the first post about checking which package the file belongs to and if it is from AUR rebuild it.
Second issue: Maybe red this topic -> Synaptic vs libinput
What I read from there is that reinstalling synaptics driver restores its function.
#93
1st problem: I already reinstalled all the packages that returned, which didn’t fix the upgrading python-setuptools.
2nd problem: I can’t even reinstall it. It throws the error:
error: target not found: X-ABI-XINPUT_VERSION=22.1 which looks to be about the same thing as the error that xorg throws out when trying to load the driver: (EE) synaptics: module ABI major version (22) doesn't match the server's version (24)
#94
  1. it say that the file already exist. then backup all the listed file somewhere just in case. and delete them.
  2. it’s an AUR package. that ask X-ABI-XINPUT_VERSION=22.1 and the new xorg-server have ABI 24.1. then you need to see with the package maintener. or you can try to edit the PKGBUILD and change the dependencies version and see how it goes.
#95
all went well apart from one error - there appears to be a mismatch between atom and apm. As a result cant update or install new packages in atom.
get the following error with apm.
    module.js:597
  return process.dlopen(module, path._makeLong(filename));
Error: Module version mismatch. Expected 48, got 51.
    at Error (native)
    at Object.Module._extensions..node (module.js:597:18)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
    at Object.<anonymous> (/usr/lib/node_modules/atom-package-manager/node_modules/git-utils/lib/git.js:8:16)
    at Object.<anonymous> (/usr/lib/node_modules/atom-package-manager/node_modules/git-utils/lib/git.js:371:4)
    at Module._compile (module.js:570:32)
#96
Well, waited a bit and then did the update.
Was approx. 707 MB and went smooth and flawless.
Just the way I like it. :grinning:
#97
removed atom and apm - installed the version from aur - works fine now
#98
Update went smoothly. Thank you @oberon!:relaxed: I used tty to update because the last time I updated cinnamon via pamac the whole laptop froze and I had to restart again.
There was a .pacnew file for lightdm. What should I do with it? There are a few changes in the new config that I noticed via meld-
Should I delete the old one and rename the .pacnew file as lightdm.conf or should I delete the pacnew fiile?
#99
That happed to me as well. Just the same.
#100
Everything I’ve tried so far looks good with one exception:
python seems to have upgraded to 3.6 successfully…
but when I call it up in the terminal, it still loads 3.5:
[charlie@Asus ~]$ python
Python 3.5.2 |Anaconda 4.2.0 (64-bit)| (default, Jul  2 2016, 17:53:06)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-1)] on linux
Type "help", "copyright", "credits" or "license" for more information.
Does it have something to do with the fact that I installed it with anaconda?
#101
The update itself went smoothly, as in I could install everything.
Something is not right here though with KDE. Kwin_x11 is using up ~10% cpu (the number fluctuates but it sits around 10%). All the compositing/effects from kwin look choppy and slow.
And when I plug or unplug my hdmi cable in I get logged out, I am guessing that X is killed.
I don’t know what to do, any ideas? Seems like I’m the only one with problems.
inxi -Fx
System:    Host: hyperion Kernel: 4.9.2-1-MANJARO x86_64 (64 bit gcc: 6.2.1)
           Desktop: KDE Plasma 5.8.5 (Qt 5.7.1) Distro: Manjaro Linux
Machine:   Device: laptop System: Hewlett-Packard product: HP EliteBook 8570w v: A1029D1102
           Mobo: Hewlett-Packard model: 176B v: KBC Version 50.1B
           BIOS: Hewlett-Packard v: 68IAV Ver. F.41 date: 05/20/2013
Battery    BAT0: charge: 46.9 Wh 100.0% condition: 46.9/46.9 Wh (100%)
           model: Hewlett-Packard Primary status: Full
CPU:       Quad core Intel Core i7-3720QM (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 20761
           clock speeds: max: 3600 MHz 1: 1572 MHz 2: 1625 MHz 3: 1681 MHz 4: 1306 MHz 5: 1266 MHz 6: 1418 MHz
           7: 1204 MHz 8: 1584 MHz
Graphics:  Card: NVIDIA GK107GLM [Quadro K2000M] bus-ID: 01:00.0
           Display Server: X.Org 1.19.1 drivers: nouveau (unloaded: modesetting) Resolution: 1920x1080@59.98hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits)
           GLX Version: 3.0 Mesa 13.0.3 Direct Rendering: Yes
Audio:     Card-1 NVIDIA GK107 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Card-2 Intel 7 Series/C216 Family High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.9.2-1-MANJARO
Network:   Card-1: Intel 82579LM Gigabit Network Connection driver: e1000e v: 3.2.6-k port: 5040 bus-ID: 00:19.0
           IF: enp0s25 state: down mac: 2c:44:fd:65:23:13
           Card-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi bus-ID: 25:00.0
           IF: wlo1 state: up mac: 3c:a9:f4:4f:0d:0c
Drives:    HDD Total Size: 500.1GB (95.0% used)
           ID-1: /dev/sda model: HGST_HTS725050A7 size: 500.1GB
Partition: ID-1: / size: 12G used: 11G (90%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 447G used: 432G (97%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 56.0C mobo: 55.0C gpu: 50.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 213 Uptime: 11 min Memory: 1618.9/7919.6MB Init: systemd Gcc sys: 6.3.1
           Client: Shell (bash 4.4.51) inxi: 2.3.5
#102
Did you reboot yet?
#103
I ran into this issue today myself. I thought I hit “y” but apparently I fat fingered enter which defaulted to N and I came here looking for answers. Glad to know I’m not the only one that had the issue, but after running the update again and making sure I hit y everything works great.
