[Stable Update] 2017-01-17 - Python, Xorg, Ruby, Gcc, Inkscape
update
stable
#244
I’m still having trouble with the XServer crashes. Edit: They are not directly related to video or audio output as assumed before.
I found the following in journalctl
[details=Summary]> Jan 27 14:18:20 systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Jan 27 14:18:20 systemd[1]: Started Process Core Dump (PID 30415/UID 0).
Jan 27 14:18:21 xfce4-notifyd[24188]: xfce4-notifyd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jan 27 14:18:24 kernel: Network Thread[5880]: segfault at 198 ip 00000000005ad290 sp 00007fbc53ffd5f8 error 4 in spotify[400000+2320000]
Jan 27 14:18:22 polkitd[510]: Unregistered Authentication Agent for unix-session:c2 (system bus name :1.27, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Jan 27 14:18:24 pulseaudio[970]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
Jan 27 14:18:24 pulseaudio[970]: after 12 requests (6 known processed) with 0 events remaining.
Jan 27 14:18:24 org.a11y.atspi.Registry[971]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Jan 27 14:18:24 org.a11y.atspi.Registry[971]: after 20485 requests (20485 known processed) with 0 events remaining.
Jan 27 14:18:21 unknown[6796]: scp-dbus-service.py: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jan 27 14:18:22 rtkit-daemon[984]: Successfully made thread 30426 of process 30426 (/usr/bin/pulseaudio) owned by ‘1000’ high priority at nice level -11.
Jan 27 14:18:24 pulseaudio[30426]: W: [pulseaudio] pid.c: Stale PID file, overwriting.
Jan 27 14:18:21 unknown[3064]: gnome-terminal-server: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jan 27 14:18:22 rtkit-daemon[984]: Supervising 1 threads of 1 processes of 1 users.
Jan 27 14:18:24 bamfdaemon[30427]: Unable to init server: Could not connect: Connection refused
Jan 27 14:18:21 unknown[1002]: bamfdaemon: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jan 27 14:18:23 rtkit-daemon[984]: Supervising 1 threads of 1 processes of 1 users.
Jan 27 14:18:21 systemd[862]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:23 rtkit-daemon[984]: Successfully made thread 30452 of process 30426 (/usr/bin/pulseaudio) owned by ‘1000’ RT at priority 5.
Jan 27 14:18:24 bamfdaemon[30449]: Unable to init server: Could not connect: Connection refused
Jan 27 14:18:21 systemd[862]: bamfdaemon.service: Unit entered failed state.
Jan 27 14:18:23 rtkit-daemon[984]: Supervising 2 threads of 1 processes of 1 users.
Jan 27 14:18:24 bamfdaemon[30454]: Unable to init server: Could not connect: Connection refused
Jan 27 14:18:21 systemd[862]: bamfdaemon.service: Failed with result ‘exit-code’.
Jan 27 14:18:24 bamfdaemon[30456]: Unable to init server: Could not connect: Connection refused
Jan 27 14:18:21 systemd[862]: xfce4-notifyd.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:23 rtkit-daemon[984]: Successfully made thread 30453 of process 30426 (/usr/bin/pulseaudio) owned by ‘1000’ RT at priority 5.
Jan 27 14:18:21 systemd[862]: xfce4-notifyd.service: Unit entered failed state.
Jan 27 14:18:23 rtkit-daemon[984]: Supervising 3 threads of 1 processes of 1 users.
Jan 27 14:18:21 systemd[862]: xfce4-notifyd.service: Failed with result ‘exit-code’.
Jan 27 14:18:23 dbus[493]: [system] Activating via systemd: service name=‘org.bluez’ unit='dbus-org.bluez.service’
Jan 27 14:18:21 systemd[862]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:21 systemd[862]: pulseaudio.service: Unit entered failed state.
Jan 27 14:18:21 systemd[862]: pulseaudio.service: Failed with result ‘exit-code’.
Jan 27 14:18:21 systemd[862]: gnome-terminal-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:21 systemd[862]: gnome-terminal-server.service: Unit entered failed state.
Jan 27 14:18:21 systemd[862]: gnome-terminal-server.service: Failed with result ‘exit-code’.
Jan 27 14:18:22 systemd[862]: bamfdaemon.service: Service hold-off time over, scheduling restart.
Jan 27 14:18:22 systemd[862]: pulseaudio.service: Service hold-off time over, scheduling restart.
Jan 27 14:18:22 systemd[862]: Stopped Sound Service.
Jan 27 14:18:22 systemd[862]: Starting Sound Service…
Jan 27 14:18:22 systemd[862]: Stopped BAMF Application Matcher Framework.
Jan 27 14:18:22 systemd[862]: Starting BAMF Application Matcher Framework…
Jan 27 14:18:22 systemd[1]: Started Process Core Dump (PID 30425/UID 0).
Jan 27 14:18:22 unknown[30427]: cannot open display: :0
Jan 27 14:18:22 systemd[862]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:22 systemd[862]: Failed to start BAMF Application Matcher Framework.
Jan 27 14:18:22 systemd[862]: bamfdaemon.service: Unit entered failed state.
Jan 27 14:18:22 systemd[862]: bamfdaemon.service: Failed with result ‘exit-code’.
Jan 27 14:18:23 systemd[862]: bamfdaemon.service: Service hold-off time over, scheduling restart.
Jan 27 14:18:23 systemd[862]: Stopped BAMF Application Matcher Framework.
Jan 27 14:18:23 systemd[862]: Starting BAMF Application Matcher Framework…
Jan 27 14:18:23 unknown[30449]: cannot open display: :0
Jan 27 14:18:23 systemd[862]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:23 systemd[862]: Failed to start BAMF Application Matcher Framework.
Jan 27 14:18:23 systemd[862]: bamfdaemon.service: Unit entered failed state.
Jan 27 14:18:23 systemd[862]: bamfdaemon.service: Failed with result ‘exit-code’.
Jan 27 14:18:23 unknown[30454]: cannot open display: :0
Jan 27 14:18:23 systemd[862]: Started Sound Service.
Jan 27 14:18:23 unknown[30456]: cannot open display: :0
Jan 27 14:18:24 NetworkManager[494]: [1485523104.0257] device (wlp3s0): state change: activated -> deactivating (reason ‘connection-removed’) [100 110 38]
Jan 27 14:18:24 systemd-coredump[30416]: Process 539 (Xorg) of user 0 dumped core.
                                             Stack trace of thread 650:
                                             #0  0x00007f566e16bf24 n/a (intel_drv.so)
                                             #1  0x00000000004bb772 n/a (Xorg)
                                             #2  0x0000000000582d13 n/a (Xorg)
                                             #3  0x0000000000583b14 miPointerSetPosition (Xorg)
                                             #4  0x000000000044cece n/a (Xorg)
                                             #5  0x000000000044d6d3 n/a (Xorg)
                                             #6  0x000000000044ef7f GetPointerEvents (Xorg)
                                             #7  0x000000000044f530 QueuePointerEvents (Xorg)
                                             #8  0x00007f566b84b3c5 n/a (libinput_drv.so)
                                             #9  0x00007f566b84bf90 n/a (libinput_drv.so)
                                             #10 0x0000000000599a8c n/a (Xorg)
                                             #11 0x000000000059c191 n/a (Xorg)
                                             #12 0x00000000005998e6 n/a (Xorg)
                                             #13 0x00007f5672eee454 start_thread (libpthread.so.0)
                                             #14 0x00007f5672c317df __clone (libc.so.6)
                                             Stack trace of thread 539:
                                             #0  0x00007f5672ef6f1c __lll_lock_wait (libpthread.so.0)
                                             #1  0x00007f5672ef0bb6 pthread_mutex_lock (libpthread.so.0)
                                             #2  0x00000000005997d0 input_lock (Xorg)
                                             #3  0x00000000004bbc56 n/a (Xorg)
                                             #4  0x00000000004ba4c5 n/a (Xorg)
                                             #5  0x00000000005833ab miPointerUpdateSprite (Xorg)
                                             #6  0x00000000005835fa n/a (Xorg)
                                             #7  0x00000000004c8de1 n/a (Xorg)
                                             #8  0x0000000000515500 n/a (Xorg)
                                             #9  0x000000000043f6c8 n/a (Xorg)
                                             #10 0x0000000000440b07 WindowHasNewCursor (Xorg)
                                             #11 0x0000000000468860 ChangeWindowAttributes (Xorg)
                                             #12 0x00000000004305ed n/a (Xorg)
                                             #13 0x00000000004368d5 n/a (Xorg)
                                             #14 0x000000000043a858 n/a (Xorg)
                                             #15 0x00007f5672b69291 __libc_start_main (libc.so.6)
                                             #16 0x000000000042453a _start (Xorg)
                                             Stack trace of thread 606:
                                             #0  0x00007f5672ef410f pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                             #1  0x00007f566e1af709 n/a (intel_drv.so)
                                             #2  0x00007f5672eee454 start_thread (libpthread.so.0)
                                             #3  0x00007f5672c317df __clone (libc.so.6)
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2190] device (wlp3s0): state change: deactivating -> disconnected (reason ‘connection-removed’) [110 30 38]
Jan 27 14:18:24 avahi-daemon[499]: Withdrawing address record for on wlp3s0.
Jan 27 14:18:24 avahi-daemon[499]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address .
Jan 27 14:18:24 avahi-daemon[499]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address fe80::a3f5:9595:da1e:a47b.
Jan 27 14:18:24 avahi-daemon[499]: Registering new address record for fe80::a3f5:9595:da1e:a47b on wlp3s0.*.
Jan 27 14:18:24 avahi-daemon[499]: Withdrawing address record for fe80::a3f5:9595:da1e:a47b on wlp3s0.
Jan 27 14:18:24 avahi-daemon[499]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address fe80::a3f5:9595:da1e:a47b.
Jan 27 14:18:24 avahi-daemon[499]: Interface wlp3s0.IPv6 no longer relevant for mDNS.
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2512] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 1362
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2513] dhcp4 (wlp3s0): state changed bound -> done
Jan 27 14:18:24 kernel: wlp3s0: deauthenticating from by local choice (Reason: 3=DEAUTH_LEAVING)
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2515] dhcp6 (wlp3s0): canceled DHCP transaction
Jan 27 14:18:24 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid= reason=3 locally_generated=1
Jan 27 14:18:24 kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Jan 27 14:18:24 avahi-daemon[499]: Leaving mDNS multicast group on interface wlp3s0.IPv4 with address .
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2656] device (wlp3s0): set-hw-addr: set MAC address to 2E:A1:6A:00:0E:A0 (scanning)
Jan 27 14:18:24 avahi-daemon[499]: Interface wlp3s0.IPv4 no longer relevant for mDNS.
Jan 27 14:18:24 NetworkManager[494]: [1485523104.2751] dns-mgr: Writing DNS information to /usr/bin/resolvconf
Jan 27 14:18:24 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jan 27 14:18:24 systemd[1]: Started Process Core Dump (PID 30471/UID 0).
Jan 27 14:18:24 NetworkManager[494]: [1485523104.3521] dns-mgr: Writing DNS information to /usr/bin/resolvconf
Jan 27 14:18:24 NetworkManager[494]: [1485523104.4359] sup-iface[0x259b8a0,wlp3s0]: connection disconnected (reason -3)
Jan 27 14:18:24 NetworkManager[494]: [1485523104.4361] device (wlp3s0): supplicant interface state: completed -> disconnected
Jan 27 14:18:24 dbus[493]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit='dbus-org.freedesktop.nm-dispatcher.service’
Jan 27 14:18:24 systemd[1]: Starting Network Manager Script Dispatcher Service…
Jan 27 14:18:24 dbus[493]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher’
Jan 27 14:18:24 systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 27 14:18:24 nm-dispatcher[30517]: req:1 ‘down’ [wlp3s0]: new request (2 scripts)
Jan 27 14:18:24 nm-dispatcher[30517]: req:1 ‘down’ [wlp3s0]: start running ordered scripts…
Jan 27 14:18:24 systemd[1]: Stopping Network Time Service…
Jan 27 14:18:24 ntpd[5330]: ntpd exiting on signal 15 (Terminated)
Jan 27 14:18:24 ntpd[5330]: 78.47.226.8 local addr ->
Jan 27 14:18:24 ntpd[5330]: 62.116.162.126 local addr ->
Jan 27 14:18:24 ntpd[5330]: 2001:43f8:1f5:100::57 local addr ->
Jan 27 14:18:24 ntpd[5330]: 24.124.0.251 local addr ->
Jan 27 14:18:24 systemd[1]: Stopped Network Time Service.
Jan 27 14:18:24 bamfdaemon[30459]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
Jan 27 14:18:24 unknown[30459]: cannot open display: :0
Jan 27 14:18:24 lightdm[30545]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Jan 27 14:18:24 systemd[862]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 14:18:24 systemd[30548]: pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
Jan 27 14:18:24 systemd[862]: Failed to start BAMF Application Matcher Framework.
Jan 27 14:18:24 systemd[862]: bamfdaemon.service: Unit entered failed state.
Jan 27 14:18:24 systemd[862]: bamfdaemon.service: Failed with result ‘exit-code’.
Jan 27 14:18:24 lightdm[524]: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
Jan 27 14:18:24 systemd[1]: Created slice User Slice of lightdm.
Jan 27 14:18:24 systemd[1]: Starting User Manager for UID 620…
Jan 27 14:18:24 systemd-logind[496]: New session c4 of user lightdm.
Jan 27 14:18:24 systemd[1]: Started Session c4 of user lightdm.
Jan 27 14:18:24 systemd[30548]: Listening on Sound System.
Jan 27 14:18:24 systemd[30548]: Reached target Paths.
Jan 27 14:18:24 systemd[30548]: Starting D-Bus User Message Bus Socket.
Jan 27 14:18:24 systemd[30548]: Reached target Timers.
Jan 27 14:18:24 systemd[30548]: Listening on D-Bus User Message Bus Socket.
Jan 27 14:18:24 systemd[30548]: Reached target Sockets.
Jan 27 14:18:24 systemd[30548]: Reached target Basic System.
Jan 27 14:18:24 systemd[30548]: Starting Update XDG user dir configuration…
Jan 27 14:18:24 systemd[862]: bamfdaemon.service: Service hold-off time over, scheduling restart.
Jan 27 14:18:24 systemd[862]: Stopped BAMF Application Matcher Framework.
Jan 27 14:18:24 systemd[862]: bamfdaemon.service: Start request repeated too quickly.
Jan 27 14:18:24 systemd[30548]: Started Update XDG user dir configuration.
Jan 27 14:18:24 systemd[30548]: Reached target Default.
Jan 27 14:18:24 systemd[30548]: Startup finished in 52ms.
Jan 27 14:18:24 systemd[1]: Started User Manager for UID 620.
Jan 27 14:18:24 systemd[30548]: Started D-Bus User Message Bus.
Jan 27 14:18:24 dbus-daemon[30557]: Activating via systemd: service name=‘org.a11y.Bus’ unit='at-spi-dbus-bus.service’
Jan 27 14:18:24 systemd[30548]: Starting Accessibility services bus…
Jan 27 14:18:24 dbus-daemon[30557]: Successfully activated service 'org.a11y.Bus’
Jan 27 14:18:24 systemd[30548]: Started Accessibility services bus.
Jan 27 14:18:24 at-spi-bus-launcher[30558]: Activating service name='org.a11y.atspi.Registry’
Jan 27 14:18:24 dbus-daemon[30557]: Activating via systemd: service name=‘org.gtk.vfs.Daemon’ unit='gvfs-daemon.service’
Jan 27 14:18:24 systemd[30548]: Starting Virtual filesystem service…
Jan 27 14:18:24 at-spi-bus-launcher[30558]: Successfully activated service 'org.a11y.atspi.Registry’
Jan 27 14:18:24 org.a11y.atspi.Registry[30563]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 27 14:18:24 dbus-daemon[30557]: Successfully activated service 'org.gtk.vfs.Daemon’
Jan 27 14:18:24 systemd[30548]: Started Virtual filesystem service.
Jan 27 14:18:26 systemd-coredump[30473]: Process 919 (skype) of user 1000 dumped core.
                                             Stack trace of thread 1237:
                                             #0  0x00000000f77bec99 __kernel_vsyscall (linux-gate.so.1)
                                             #1  0x00000000f4aeaeb0 raise (libc.so.6)
                                             #2  0x00000000f4aec3d7 abort (libc.so.6)
                                             #3  0x0000000057321ded n/a (skype)
Jan 27 14:18:26 systemd-coredump[30429]: Process 5854 (spotify) of user 1000 dumped core.
                                             Stack trace of thread 5880:
                                             #0  0x00000000005ad290 n/a (spotify)
                                             #1  0x00000000007b74f1 n/a (spotify)
                                             #2  0x00000000014f2ab0 n/a (spotify)
                                             #3  0x00000000014f3695 n/a (spotify)
                                             #4  0x0000000000f7e868 n/a (spotify)
                                             #5  0x0000000000f7e3ff n/a (spotify)
                                             #6  0x0000000000f8182c n/a (spotify)
                                             #7  0x0000000000f81769 n/a (spotify)
                                             #8  0x00000000005ec047 n/a (spotify)
                                             #9  0x00000000014f6371 n/a (spotify)
                                             #10 0x00000000014f276d n/a (spotify)
                                             #11 0x00000000014f244b n/a (spotify)
                                             #12 0x00000000014f34ab n/a (spotify)
                                             #13 0x00000000014d9abb n/a (spotify)
                                             #14 0x00000000014da4cb n/a (spotify)
                                             #15 0x00000000014dc89b n/a (spotify)
                                             #16 0x00000000014dc851 n/a (spotify)
                                             #17 0x00000000014dc830 n/a (spotify)
                                             #18 0x00000000014dc7a9 n/a (spotify)
                                             #19 0x000000000159dc1f n/a (spotify)
                                             #20 0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #21 0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5865:
                                             #0  0x00007fbcbb7d310f pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                             #1  0x00007fbcbe4026da n/a (libcef.so)
                                             #2  0x00007fbcbe4025a2 n/a (libcef.so)
                                             #3  0x00007fbcbe3de09f n/a (libcef.so)
                                             #4  0x00007fbcbe3f399e n/a (libcef.so)
                                             #5  0x00007fbcbe3dbf6a n/a (libcef.so)
                                             #6  0x00007fbcbddbbebe n/a (libcef.so)
                                             #7  0x00007fbcbddbbfac n/a (libcef.so)
                                             #8  0x00007fbcbe410c1e n/a (libcef.so)
                                             #9  0x00007fbcbe40d863 n/a (libcef.so)
                                             #10 0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #11 0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5863:
                                             #0  0x00007fbcb824add3 epoll_wait (libc.so.6)
                                             #1  0x00007fbcbc44e478 n/a (libcef.so)
                                             #2  0x00007fbcbc44c021 n/a (libcef.so)
                                             #3  0x00007fbcbe3deafe n/a (libcef.so)
                                             #6  0x00007fbcbddbbe7e n/a (libcef.so)
                                             #7  0x00007fbcbddbbf92 n/a (libcef.so)
                                             Stack trace of thread 5854:
                                             #0  0x000000000108f870 n/a (spotify)
                                             #1  0x00007fbcb8197990 __run_exit_handlers (libc.so.6)
                                             #2  0x00007fbcb81979ea exit (libc.so.6)
                                             #3  0x00007fbcbafbf7b8 _XIOError (libX11.so.6)
                                             #4  0x00007fbcbafbd00d _XEventsQueued (libX11.so.6)
                                             #5  0x00007fbcbafaecb7 XPending (libX11.so.6)
                                             #6  0x00007fbcbacb2179 g_main_context_check (libglib-2.0.so.0)
                                             #7  0x00007fbcbacb2724 n/a (libglib-2.0.so.0)
                                             #8  0x00007fbcbacb289c g_main_context_iteration (libglib-2.0.so.0)
                                             #9  0x00007fbcbe3de396 n/a (libcef.so)
                                             #10 0x00007fbcbe3f399e n/a (libcef.so)
                                             #11 0x00007fbcbe3dbf6a n/a (libcef.so)
                                             #12 0x000000000154d529 n/a (spotify)
                                             #13 0x00000000005a5d44 n/a (spotify)
                                             #14 0x00000000005a5469 _start (spotify)
                                             #15 0x00007fbcb8182291 __libc_start_main (libc.so.6)
                                             #16 0x00000000005a5394 _start (spotify)
                                             Stack trace of thread 5855:
                                             #0  0x00007fbcb824148d poll (libc.so.6)
                                             #1  0x00007fbcbdfb8ae2 n/a (libcef.so)
                                             #2  0x00007fbcbe41047e n/a (libcef.so)
                                             #3  0x00007fbcbe41031d n/a (libcef.so)
                                             #4  0x00007fbcbe40d863 n/a (libcef.so)
                                             #5  0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #6  0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5857:
                                             #6  0x00007fbcbe410c1e n/a (libcef.so)
                                             #7  0x00007fbcbe40d863 n/a (libcef.so)
                                             #8  0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #9  0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5864:
                                             #6  0x00007fbcbddbbe9e n/a (libcef.so)
                                             #7  0x00007fbcbddbbf9f n/a (libcef.so)
                                             Stack trace of thread 5862:
                                             #0  0x00007fbcbb7d34b8 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0)
                                             #1  0x00007fbcbe4022c3 n/a (libcef.so)
                                             #2  0x00007fbcbe4026c3 n/a (libcef.so)
                                             #3  0x00007fbcbe3de095 n/a (libcef.so)
                                             #6  0x00007fbcbddbbe5e n/a (libcef.so)
                                             #7  0x00007fbcbddbbf85 n/a (libcef.so)
                                             Stack trace of thread 5866:
                                             #6  0x00007fbcbddbbede n/a (libcef.so)
                                             #7  0x00007fbcbddbbfb9 n/a (libcef.so)
                                             Stack trace of thread 5858:
                                             #0  0x00007fbcb82430b3 __select (libc.so.6)
                                             #1  0x00007fbcbe3cbf81 n/a (libcef.so)
                                             #2  0x00007fbcbe3c5756 n/a (libcef.so)
                                             #3  0x00007fbcbe3dc7f5 n/a (libcef.so)
                                             #4  0x00007fbcbe3dcae8 n/a (libcef.so)
                                             #5  0x00007fbcbe3dce0b n/a (libcef.so)
                                             #6  0x00007fbcbe3de01b n/a (libcef.so)
                                             #7  0x00007fbcbe3f399e n/a (libcef.so)
                                             #8  0x00007fbcbe3dbf6a n/a (libcef.so)
                                             #9  0x00007fbcbe410c1e n/a (libcef.so)
                                             #10 0x00007fbcbe40d863 n/a (libcef.so)
                                             #11 0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #12 0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5868:
                                             Stack trace of thread 5867:
                                             #3  0x00007fbcbe3deae6 n/a (libcef.so)
                                             #6  0x00007fbcbddbbefe n/a (libcef.so)
                                             #7  0x00007fbcbddbbfc6 n/a (libcef.so)
                                             Stack trace of thread 5869:
                                             #1  0x00007fbcbe5070c8 n/a (libcef.so)
                                             Stack trace of thread 5873:
                                             #1  0x00007fbcbe40e54e n/a (libcef.so)
                                             #2  0x00007fbcbe40de22 n/a (libcef.so)
                                             Stack trace of thread 5876:
                                             #1  0x00007fbcbacb2786 n/a (libglib-2.0.so.0)
                                             #2  0x00007fbcbacb289c g_main_context_iteration (libglib-2.0.so.0)
                                             #3  0x00007fbcbacb28e1 n/a (libglib-2.0.so.0)
                                             #4  0x00007fbcbacda0d5 n/a (libglib-2.0.so.0)
                                             Stack trace of thread 5870:
                                             Stack trace of thread 5931:
                                             #1  0x00007fbca83f3121 n/a (libpulse.so.0)
                                             #2  0x00007fbca83e48f1 pa_mainloop_poll (libpulse.so.0)
                                             #3  0x00007fbca83e4f8e pa_mainloop_iterate (libpulse.so.0)
                                             #4  0x00007fbca83e5040 pa_mainloop_run (libpulse.so.0)
                                             #5  0x00007fbca83f3069 n/a (libpulse.so.0)
                                             #6  0x00007fbca8191ed8 n/a (libpulsecommon-9.0.so)
                                             #7  0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #8  0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5877:
                                             #2  0x00007fbcbacb2b12 g_main_loop_run (libglib-2.0.so.0)
                                             #3  0x00007fbcb9e84316 n/a (libgio-2.0.so.0)
                                             Stack trace of thread 5926:
                                             #1  0x000000000061122b _ZN5boost4asio6detail11posix_event4waitINS1_11scoped_lockINS1_11posix_mutexEEEEEvRT_ (spotify)
                                             #2  0x0000000000610c26 _ZN5boost4asio6detail15task_io_service10do_run_oneERNS1_11scoped_lockINS1_11posix_mutexEEERNS1_27task_io_service_thread_infoERKNS_6system10error_codeE (spotify)
                                             #3  0x0000000000610a35 _ZN5boost4asio6detail15task_io_service3runERNS_6system10error_codeE (spotify)
                                             #4  0x0000000000610986 _ZN5boost4asio10io_service3runEv (spotify)
                                             #5  0x00000000013635de n/a (spotify)
                                             #6  0x0000000001363591 n/a (spotify)
                                             #7  0x0000000001363570 n/a (spotify)
                                             #8  0x0000000001363469 n/a (spotify)
                                             #9  0x000000000159dc1f n/a (spotify)
                                             Stack trace of thread 5872:
                                             Stack trace of thread 5927:
                                             #1  0x0000000000610f7d _ZN5boost4asio6detail13epoll_reactor3runEbRNS1_8op_queueINS1_25task_io_service_operationEEE (spotify)
                                             #2  0x0000000000610cb5 _ZN5boost4asio6detail15task_io_service10do_run_oneERNS1_11scoped_lockINS1_11posix_mutexEEERNS1_27task_io_service_thread_infoERKNS_6system10error_codeE (spotify)
                                             #5  0x00000000010cf8fc n/a (spotify)
                                             #6  0x00000000010cf8b9 n/a (spotify)
                                             #7  0x00000000010cf899 n/a (spotify)
                                             #8  0x00000000010cf80d n/a (spotify)
                                             #9  0x00007fbcb87d2970 execute_native_thread_routine_compat (libstdc++.so.6)
                                             Stack trace of thread 5875:
                                             #5  0x0000000000610950 n/a (spotify)
                                             #6  0x0000000000610901 n/a (spotify)
                                             #7  0x00000000006108e0 n/a (spotify)
                                             #8  0x0000000000610859 n/a (spotify)
                                             Stack trace of thread 5883:
                                             #1  0x00000000014ff448 n/a (spotify)
                                             #2  0x00000000015025fa n/a (spotify)
                                             #3  0x00000000015025b1 n/a (spotify)
                                             #4  0x0000000001502590 n/a (spotify)
                                             #5  0x0000000001502509 n/a (spotify)
                                             #6  0x000000000159dc1f n/a (spotify)
                                             Stack trace of thread 5945:
                                             Stack trace of thread 5928:
                                             #5  0x0000000000c4b03c n/a (spotify)
                                             #6  0x0000000000c4aff9 n/a (spotify)
                                             #7  0x0000000000c4afd9 n/a (spotify)
                                             #8  0x0000000000c4af4d n/a (spotify)
                                             Stack trace of thread 5929:
                                             #5  0x0000000000c4349c n/a (spotify)
                                             #6  0x0000000000c43459 n/a (spotify)
                                             #7  0x0000000000c43439 n/a (spotify)
                                             #8  0x0000000000c433ad n/a (spotify)
                                             Stack trace of thread 5947:
                                             Stack trace of thread 20296:
                                             #2  0x00007fbcbe4125ab n/a (libcef.so)
                                             #3  0x00007fbcbe4129aa n/a (libcef.so)
                                             Stack trace of thread 5932:
                                             #1  0x000000000108754e n/a (spotify)
                                             #2  0x000000000159e516 n/a (spotify)
                                             #3  0x000000000159e48e _ZN5boost11this_thread5hiden9sleep_forERK8timespec (spotify)
                                             #4  0x00000000005a959e _ZN5boost11this_thread9sleep_forERKNS_6chrono8durationIlNS_5ratioILl1ELl1000000000EEEEE (spotify)
                                             #5  0x0000000000f86063 n/a (spotify)
                                             #6  0x0000000000f85fb8 n/a (spotify)
                                             #7  0x0000000000f87c6b n/a (spotify)
                                             #8  0x0000000000f87c21 n/a (spotify)
                                             #9  0x0000000000f87c00 n/a (spotify)
                                             #10 0x0000000000f87b79 n/a (spotify)
                                             #11 0x000000000159dc1f n/a (spotify)
                                             #12 0x00007fbcbb7cd454 start_thread (libpthread.so.0)
                                             #13 0x00007fbcb824a7df __clone (libc.so.6)
                                             Stack trace of thread 5944:
Jan 27 14:18:27 wpa_supplicant[769]: wlp3s0: Reject scan trigger since one is already pending
Jan 27 14:18:30 lightdm[30545]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 27 14:18:30 lightdm[30592]: pam_unix(lightdm:session): session opened for user by (uid=0)
Jan 27 14:18:30 lightdm[524]: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
Jan 27 14:18:30 systemd-logind[496]: Removed session c4.
Jan 27 14:18:30 systemd[1]: Stopping User Manager for UID 620…
Jan 27 14:18:30 systemd-logind[496]: New session c5 of user .
Jan 27 14:18:30 systemd[1]: Started Session c5 of user .
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3324] policy: auto-activating connection 'eduroam’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3336] device (wlp3s0): Activation: starting connection ‘eduroam’ (ec78f6ca-1bfc-4f07-8af4-dc549d84343c)
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3337] device (wlp3s0): state change: disconnected -> prepare (reason ‘none’) [30 40 0]
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3366] device (wlp3s0): set-hw-addr: set-cloned MAC address to 28:B2:BD:88:AA:B3 (permanent)
Jan 27 14:18:30 kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3440] device (wlp3s0): state change: prepare -> config (reason ‘none’) [40 50 0]
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3442] device (wlp3s0): Activation: (wifi) access point ‘eduroam’ has security, but secrets are required.
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3442] device (wlp3s0): state change: config -> need-auth (reason ‘none’) [50 60 0]
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3473] device (wlp3s0): state change: need-auth -> prepare (reason ‘none’) [60 40 0]
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3475] device (wlp3s0): state change: prepare -> config (reason ‘none’) [40 50 0]
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3476] device (wlp3s0): Activation: (wifi) connection ‘eduroam’ has security, and secrets exist. No new secrets needed.
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3476] Config: added ‘ssid’ value 'eduroam’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3476] Config: added ‘scan_ssid’ value '1’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘key_mgmt’ value 'WPA-EAP’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘eap’ value 'PEAP’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘fragment_size’ value '1266’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘phase2’ value 'auth=MSCHAPV2’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘identity’ value ''
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘bgscan’ value 'simple:30:-65:300’
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3477] Config: added ‘proactive_key_caching’ value '1’
Jan 27 14:18:30 systemd[30548]: Stopping Virtual filesystem service…
Jan 27 14:18:30 systemd[30548]: Stopping D-Bus User Message Bus…
Jan 27 14:18:30 systemd[30548]: Stopped target Default.
Jan 27 14:18:30 systemd[30548]: Stopping Accessibility services bus…
Jan 27 14:18:30 systemd[30548]: Stopped D-Bus User Message Bus.
Jan 27 14:18:30 systemd[30548]: Stopped Accessibility services bus.
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3694] sup-iface[0x259b8a0,wlp3s0]: config: set interface ap_scan to 1
Jan 27 14:18:30 NetworkManager[494]: [1485523110.3760] device (wlp3s0): supplicant interface state: disconnected -> scanning
Jan 27 14:18:30 systemd[30548]: Stopped Virtual filesystem service.
Jan 27 14:18:30 systemd[30548]: Stopped target Basic System.
Jan 27 14:18:30 systemd[30548]: Stopped target Sockets.
Jan 27 14:18:30 systemd[30548]: Closed Sound System.
Jan 27 14:18:30 systemd[30548]: Stopped target Paths.
Jan 27 14:18:30 systemd[30548]: Stopped target Timers.
Jan 27 14:18:30 systemd[30548]: Closed D-Bus User Message Bus Socket.
Jan 27 14:18:30 systemd[30549]: pam_unix(systemd-user:session): session closed for user lightdm
Jan 27 14:18:30 systemd[30548]: Reached target Shutdown.
Jan 27 14:18:30 systemd[30548]: Starting Exit the Session…
Jan 27 14:18:30 systemd[30548]: Received SIGRTMIN+24 from PID 30653 (kill).
Jan 27 14:18:30 systemd[1]: Stopped User Manager for UID 620.
Jan 27 14:18:30 systemd[1]: Removed slice User Slice of lightdm.
Jan 27 14:18:30 systemd[862]: Starting Sound Service…
Jan 27 14:18:30 rtkit-daemon[984]: Successfully made thread 30716 of process 30716 (/usr/bin/pulseaudio) owned by ‘1000’ high priority at nice level -11.
Jan 27 14:18:30 rtkit-daemon[984]: Supervising 1 threads of 1 processes of 1 users.
Jan 27 14:18:30 at-spi-bus-launcher[965]: Activating service name='org.a11y.atspi.Registry’
Jan 27 14:18:30 at-spi-bus-launcher[965]: Successfully activated service 'org.a11y.atspi.Registry’
Jan 27 14:18:30 org.a11y.atspi.Registry[971]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 27 14:18:30 rtkit-daemon[984]: Successfully made thread 30738 of process 30716 (/usr/bin/pulseaudio) owned by ‘1000’ RT at priority 5.
Jan 27 14:18:30 rtkit-daemon[984]: Supervising 2 threads of 1 processes of 1 users.
Jan 27 14:18:30 rtkit-daemon[984]: Successfully made thread 30739 of process 30716 (/usr/bin/pulseaudio) owned by ‘1000’ RT at priority 5.
Jan 27 14:18:30 rtkit-daemon[984]: Supervising 3 threads of 1 processes of 1 users.
Jan 27 14:18:30 systemd[862]: Started Sound Service.
Jan 27 14:18:30 dbus-daemon[892]: Activating via systemd: service name=‘org.ayatana.bamf’ unit='bamfdaemon.service’
Jan 27 14:18:30 systemd[862]: bamfdaemon.service: Start request repeated too quickly.
Jan 27 14:18:30 systemd[862]: Failed to start BAMF Application Matcher Framework.
Jan 27 14:18:30 systemd[862]: bamfdaemon.service: Failed with result ‘exit-code’.
Jan 27 14:18:30 dbus[493]: [system] Activating via systemd: service name=‘org.manjaro.pamac’ unit='pamac.service’
Jan 27 14:18:30 systemd[1]: Starting Pamac…
Jan 27 14:18:30 dbus-daemon[892]: Activating via systemd: service name=‘org.freedesktop.Notifications’ unit='xfce4-notifyd.service’
Jan 27 14:18:30 systemd[862]: Starting XFCE notifications service…
Jan 27 14:18:31 dbus-daemon[892]: Activating service name='org.freedesktop.thumbnails.Thumbnailer1’
Jan 27 14:18:31 polkitd[510]: Registered Authentication Agent for unix-session:c5 (system bus name :1.205 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jan 27 14:18:31 dbus-daemon[892]: Successfully activated service 'org.freedesktop.Notifications’
Jan 27 14:18:31 systemd[862]: Started XFCE notifications service.
Jan 27 14:18:31 dbus[493]: [system] Successfully activated service 'org.manjaro.pamac’
Jan 27 14:18:31 systemd[1]: Started Pamac.
Jan 27 14:18:31 dbus-daemon[892]: Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1’
Jan 27 14:18:31 msm_notifier[30737]: qt5ct: using qt5ct plugin
Jan 27 14:18:31 msm_notifier[30737]: qt5ct: D-Bus system tray: no
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: SME: Trying to authenticate with (SSID=‘eduroam’ freq=5500 MHz)
Jan 27 14:18:33 kernel: wlp3s0: authenticate with
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: Trying to associate with (SSID=‘eduroam’ freq=5500 MHz)
Jan 27 14:18:33 NetworkManager[494]: [1485523113.4982] device (wlp3s0): supplicant interface state: scanning -> authenticating
Jan 27 14:18:33 kernel: wlp3s0: send auth to (try 1/3)
Jan 27 14:18:33 kernel: wlp3s0: authenticated
Jan 27 14:18:33 kernel: wlp3s0: associate with (try 1/3)
Jan 27 14:18:33 NetworkManager[494]: [1485523113.5006] device (wlp3s0): supplicant interface state: authenticating -> associating
Jan 27 14:18:33 kernel: wlp3s0: RX AssocResp from (capab=0x1111 status=0 aid=3)
Jan 27 14:18:33 kernel: wlp3s0: associated
Jan 27 14:18:33 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: Associated with
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-EAP-STARTED EAP authentication started
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-EAP-METHOD EAP vendor 0 method 25 (PEAP) selected
Jan 27 14:18:33 NetworkManager[494]: [1485523113.5133] device (wlp3s0): supplicant interface state: associating -> associated
Jan 27 14:18:33 kernel: wlp3s0: Limiting TX power to 17 dBm as advertised by
Jan 27 14:18:33 wpa_supplicant[769]: EAP-MSCHAPV2: Authentication succeeded
Jan 27 14:18:33 wpa_supplicant[769]: EAP-TLV: TLV Result - Success - EAP-TLV/Phase2 Completed
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-EAP-SUCCESS EAP authentication completed successfully
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: WPA: Key negotiation completed with [PTK=CCMP GTK=CCMP]
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to completed [id=0 id_str=]
Jan 27 14:18:33 NetworkManager[494]: [1485523113.8926] device (wlp3s0): supplicant interface state: associated -> completed
Jan 27 14:18:33 NetworkManager[494]: [1485523113.8927] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network ‘eduroam’.
Jan 27 14:18:33 NetworkManager[494]: [1485523113.8928] device (wlp3s0): state change: config -> ip-config (reason ‘none’) [50 70 0]
Jan 27 14:18:33 NetworkManager[494]: [1485523113.8932] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9023] dhcp4 (wlp3s0): dhclient started with pid 30942
Jan 27 14:18:33 wpa_supplicant[769]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-34 noise=9999 txrate=866700
Jan 27 14:18:33 dhclient[30942]: DHCPREQUEST on wlp3s0 to 255.255.255.255 port 67
Jan 27 14:18:33 dhclient[30942]: DHCPACK from
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9977] dhcp4 (wlp3s0): address
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9980] dhcp4 (wlp3s0): plen 23 (255.255.254.0)
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9981] dhcp4 (wlp3s0): gateway
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9981] dhcp4 (wlp3s0): server identifier
Jan 27 14:18:33 avahi-daemon[499]: Joining mDNS multicast group on interface wlp3s0.IPv4 with address .
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9981] dhcp4 (wlp3s0): lease time 278
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9981] dhcp4 (wlp3s0): nameserver ''
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9982] dhcp4 (wlp3s0): nameserver ''
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9982] dhcp4 (wlp3s0): domain name '<domain.tld>'
Jan 27 14:18:33 NetworkManager[494]: [1485523113.9982] dhcp4 (wlp3s0): state changed unknown -> bound
Jan 27 14:18:34 avahi-daemon[499]: New relevant interface wlp3s0.IPv4 for mDNS.
Jan 27 14:18:34 NetworkManager[494]: [1485523114.0028] device (wlp3s0): state change: ip-config -> ip-check (reason ‘none’) [70 80 0]
Jan 27 14:18:34 avahi-daemon[499]: Registering new address record for on wlp3s0.IPv4.
Jan 27 14:18:34 NetworkManager[494]: [1485523114.0035] device (wlp3s0): state change: ip-check -> secondaries (reason ‘none’) [80 90 0]
Jan 27 14:18:34 NetworkManager[494]: [1485523114.0037] device (wlp3s0): state change: secondaries -> activated (reason ‘none’) [90 100 0]
Jan 27 14:18:34 dhclient[30942]: bound to – renewal in 112 seconds.
Jan 27 14:18:34 NetworkManager[494]: [1485523114.0410] dns-mgr: Writing DNS information to /usr/bin/resolvconf
Jan 27 14:18:34 NetworkManager[494]: [1485523114.0834] device (wlp3s0): Activation: successful, device activated.
Jan 27 14:18:34 nm-dispatcher[30517]: req:2 ‘up’ [wlp3s0]: new request (2 scripts)
Jan 27 14:18:34 nm-dispatcher[30517]: req:2 ‘up’ [wlp3s0]: start running ordered scripts…
Jan 27 14:18:34 systemd[1]: Starting Network Time Service…
Jan 27 14:18:34 ntpd[30994]: ntpd 4.2.8p9@1.3265-o Sat Nov 26 17:04:19 UTC 2016 (1): Starting
Jan 27 14:18:34 ntpd[30994]: Command line: /usr/bin/ntpd -g -u ntp:ntp
Jan 27 14:18:34 systemd[1]: Started Network Time Service.
Jan 27 14:18:34 ntpd[30996]: proto: precision = 0.067 usec (-24)
Jan 27 14:18:34 ntpd[30996]: Listen and drop on 0 v6wildcard [::]:123
Jan 27 14:18:34 ntpd[30996]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 2 lo 127.0.0.1:123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 3 enp0s25 :123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 4 wlp3s0 :123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 5 lo [::1]:123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 6 enp0s25 [2001:41b8:830:105:3581:b772:56fd:45b5]:123
Jan 27 14:18:34 ntpd[30996]: Listen normally on 7 enp0s25 [fe80::4dfe:99ec:2d55:71ee%2]:123
Jan 27 14:18:34 ntpd[30996]: bind(24) AF_INET6 fe80::a3f5:9595:da1e:a47b%3#123 flags 0x11 failed: Cannot assign requested address
Jan 27 14:18:34 ntpd[30996]: unable to create socket on wlp3s0 (8) for fe80::a3f5:9595:da1e:a47b%3#123
Jan 27 14:18:34 ntpd[30996]: failed to init interface for address fe80::a3f5:9595:da1e:a47b%3
Jan 27 14:18:34 ntpd[30996]: Listening on routing socket on fd #24 for interface updates
Jan 27 14:18:34 dbus-daemon[892]: Activating via systemd: service name=‘org.gnome.Terminal’ unit='gnome-terminal-server.service’
Jan 27 14:18:34 systemd[862]: Starting GNOME Terminal Server…
Jan 27 14:18:35 dbus-daemon[892]: Successfully activated service 'org.gnome.Terminal’
Jan 27 14:18:35 systemd[862]: Started GNOME Terminal Server.
Jan 27 14:18:35 ntpd[30996]: bind(27) AF_INET6 fe80::a3f5:9595:da1e:a47b%3#123 flags 0x11 failed: Cannot assign requested address
Jan 27 14:18:35 ntpd[30996]: unable to create socket on wlp3s0 (9) for fe80::a3f5:9595:da1e:a47b%3#123
Jan 27 14:18:35 ntpd[30996]: failed to init interface for address fe80::a3f5:9595:da1e:a47b%3
Jan 27 14:18:35 avahi-daemon[499]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address fe80::a3f5:9595:da1e:a47b.
Jan 27 14:18:35 avahi-daemon[499]: New relevant interface wlp3s0.IPv6 for mDNS.
Jan 27 14:18:35 avahi-daemon[499]: Registering new address record for fe80::a3f5:9595:da1e:a47b on wlp3s0..
Jan 27 14:18:35 org.gtk.vfs.Daemon[30707]: fusermount: failed to access mountpoint /run/user/1000/gvfs: Permission denied
Jan 27 14:18:35 org.a11y.Bus[30707]: Activating service name='org.a11y.atspi.Registry’
Jan 27 14:18:35 org.a11y.Bus[30707]: Successfully activated service 'org.a11y.atspi.Registry’
Jan 27 14:18:35 org.a11y.atspi.Registry[31142]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 27 14:18:37 NetworkManager[494]: [1485523117.0962] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Jan 27 14:18:37 NetworkManager[494]: [1485523117.0963] dhcp6 (wlp3s0): hostname is not a FQDN, it will be ignored
Jan 27 14:18:37 NetworkManager[494]: [1485523117.0976] dhcp6 (wlp3s0): dhclient started with pid 31163
Jan 27 14:18:37 dhclient[31163]: XMT: Info-Request on wlp3s0, interval 1070ms.
Jan 27 14:18:37 dhclient[31163]: RCV: Reply message on wlp3s0 from fe80::1.
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2601] dhcp6 (wlp3s0): nameserver '2001:41b8:83f:22::63’
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2601] dhcp6 (wlp3s0): nameserver '2001:41b8:83f:56::60’
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2601] dhcp6 (wlp3s0): nameserver '2001:41b8:83f:22::60’
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2601] dhcp (wlp3s0): domain search '<domain.tld>.'
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2601] dhcp6 (wlp3s0): state changed unknown -> bound
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2612] dns-mgr: Writing DNS information to /usr/bin/resolvconf
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2736] dhcp6 (wlp3s0): client pid 31163 exited with status 0
Jan 27 14:18:37 NetworkManager[494]: [1485523117.2736] dhcp6 (wlp3s0): state changed bound -> done
Jan 27 14:18:37 nm-dispatcher[30517]: req:3 ‘dhcp6-change’ [wlp3s0]: new request (2 scripts)
Jan 27 14:18:37 nm-dispatcher[30517]: req:3 ‘dhcp6-change’ [wlp3s0]: start running ordered scripts…
Jan 27 14:18:39 avahi-daemon[499]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address fe80::a3f5:9595:da1e:a47b.
Jan 27 14:18:39 avahi-daemon[499]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address .
Jan 27 14:18:39 avahi-daemon[499]: Registering new address record for on wlp3s0.
Jan 27 14:18:39 avahi-daemon[499]: Withdrawing address record for fe80::a3f5:9595:da1e:a47b on wlp3s0.
Jan 27 14:18:40 ntpd[30996]: Listen normally on 10 wlp3s0 []:123
Jan 27 14:18:40 ntpd[30996]: Listen normally on 11 wlp3s0 [fe80::a3f5:9595:da1e:a47b%3]:123
Jan 27 14:18:40 ntpd[30996]: new interface(s) found: waking up resolver
Jan 27 14:18:48 dbus[493]: [system] Failed to activate service ‘org.bluez’: timed out
Jan 27 14:18:48 pulseaudio[30716]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service ‘org.bluez’: timed out[/details]
[Stable Update] 2017-01-30 - Kernels, Steam, Budgie, Deepin, KDE Framework, Virtualbox
#245
Have you tried re-installing gtk-engines along with gtk-engine-murrine?
#246
After the update the WLAN ceased working on one of my two laptops. I found the fix here:
https://bbs.archlinux.org/viewtopic.php?id=72159
#247
@vmyrdge, It didn’t work. I didn’t have gtk-engines installed to begin with, though I did install it and reinstalled gtk-engine-murrine to see what would happen. Unfortunately the situation remains the same. I did find that arc-icon-theme works, so that helps, but its fallback elementary-icon-theme also fails to work. So there are a couple of ugly Gnome icons sticking out. However, thanks for trying to help!
In other news, mpv no longer works with SMplayer and fails to play audio. It has been at least two upgrade cycles since mpv has stopped working with SMplayer, though it worked fine on its own. But today was the first time it failed to play audio of any kind. No audio from movies, mp3s, nothing. Could that be an ffmpeg problem? Has ffmpeg been updated recently? Would harfbuzz have the ability to bork ffmpeg and mpv too?
It’s time to move on. As much as I hate to, I’m going back to XFCE. The latest round of updates/upgrades have made it necessary. I held out for as long as I could.
cc: @oberon
#248
Sorry, but I don’t know what to to. I’me a Kde user and I’ve installed:
cairo-infinality-ultimate
fontconfig-infinality-ultimate
freetype2-infinality-ultimate
How can I switch to freetype2 subpixel rendering or updated freetype2-infinality package ?
If I try to remove freetype2-infinality-ultimate system says I’ll have to remove another 870 packages :scream:
Thanks
#249
Since the update I miss the wikipedia-applet in Amarok! :cry:
#250
If you want to install official packages install
cairo
freetype2
fontconfig
those packages going to replace with AUR packages and uninstall them.
#251
Hi, @mgundogdu, I’ve installed cairo, freetype2 and fontconfig but some fonts are ugly and awful! For example some “normal” text in this forum appears as bold.
Please help me, thanks.
#252
After manipulating fonts in linux it a little tricky to revert back especially lcdfilter :slight_smile: It seems that you have some missing fonts. If you want to use freetype, fontconfig and cairo infinality you can install font-meta-extended package from AUR it really nice package and also fixing some issues.
#253
Hi!, i have de same problem but i am using kde in two computers
#254
Hi @mgundogdu, I’ve installed font-meta-extended-lt but it didn’t solve my problem.
#255
Did you make any changes in your font configs. Some changes in configs prevent to installing new font related packages properly. Maybe a screenshot let us what your fonts look like.
#256
@mgundogdu here is a screenshot:
#257
When i try to convert a youtube video after the update i get this error…
[iulian@iulian-pc ~]$ youtube-dl --extract-audio --audio-format vorbis --audio-quality 5 https://www.youtube.com/link
[youtube] Kihk5HSkIgw: Downloading webpage
[youtube] Kihk5HSkIgw: Downloading video info webpage
[youtube] Kihk5HSkIgw: Extracting video information
[youtube] Kihk5HSkIgw: Downloading js player en_US-vflkk7pUE
ERROR: Signature extraction failed: Traceback (most recent call last):
File “/usr/lib/python3.6/site-packages/youtube_dl/extractor/youtube.py”, line 1035, in _decrypt_signature
video_id, player_url, s
File “/usr/lib/python3.6/site-packages/youtube_dl/extractor/youtube.py”, line 949, in _extract_signature_function
errnote=‘Download of %s failed’ % player_url)
File “/usr/lib/python3.6/site-packages/youtube_dl/extractor/common.py”, line 519, in _download_webpage
res = self._download_webpage_handle(url_or_request, video_id, note, errnote, fatal, encoding=encoding, data=data, headers=headers, query=query)
File “/usr/lib/python3.6/site-packages/youtube_dl/extractor/common.py”, line 426, in _download_webpage_handle
urlh = self._request_webpage(url_or_request, video_id, note, errnote, fatal, data=data, headers=headers, query=query)
File “/usr/lib/python3.6/site-packages/youtube_dl/extractor/common.py”, line 406, in _request_webpage
return self._downloader.urlopen(url_or_request)
File “/usr/lib/python3.6/site-packages/youtube_dl/YoutubeDL.py”, line 2000, in urlopen
req = sanitized_Request(req)
File “/usr/lib/python3.6/site-packages/youtube_dl/utils.py”, line 525, in sanitized_Request
return compat_urllib_request.Request(sanitize_url(url), *args, **kwargs)
File “/usr/lib/python3.6/urllib/request.py”, line 329, in init
self.full_url = url
File “/usr/lib/python3.6/urllib/request.py”, line 355, in full_url
self._parse()
File “/usr/lib/python3.6/urllib/request.py”, line 384, in _parse
raise ValueError(“unknown url type: %r” % self.full_url)
ValueError: unknown url type: ‘/yts/jsbin/player-en_US-vflkk7pUE/base.js’
(caused by ValueError(“unknown url type: ‘/yts/jsbin/player-en_US-vflkk7pUE/base.js’”,)); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; see https://yt-dl.org/update on how to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
How do i fix it…?
#258
Ok i found a fix on this problem:
sudo pacman -S python-pip
sudo pip install youtube-dl
sudo pip install --upgrade youtube-dl
These commands fix my problems,the problem it has that u need the latest version of youtube-dl in other to use it.
#259
I wouldn’t recommend installling with python-pip if not absolutely necessary. On python updates you’ll keep running into file conflicts since all those files will be installed without pacman tracking them.
In case of youtube-dl you have the alternative of the -git package from the AUR.
#260
Sorry I missed your post. I never encounter problem like that. Which desktop environment do you use and which applications effects from this issue. If you just in web browser check its font configuration and
I m not sure maybe you can check .Xresources file to be sure autohint should be ‘false’. I dont know but Arch wiki give some ideas :confused:
Font Configuration
#261
Here is my config. I notice ugly fonts in webpages and some applications like Libreoffice.
System:    Host: icpo Kernel: 4.9.6-1-MANJARO x86_64 (64 bit gcc: 6.3.1) Desktop: KDE Plasma 5.8.5 (Qt 5.7.1)
           Distro: Manjaro Linux
Machine:   Device: desktop Mobo: ASRock model: H170M Pro4S UEFI: American Megatrends v: P1.70 date: 01/21/2016
CPU:       Quad core Intel Core i5-6600 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 26504
           clock speeds: max: 3900 MHz 1: 3749 MHz 2: 3800 MHz 3: 3800 MHz 4: 3898 MHz
Graphics:  Card: Intel HD Graphics 530 bus-ID: 00:02.0
           Display Server: X.Org 1.19.1 driver: intel Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           GLX Version: 3.0 Mesa 13.0.3 Direct Rendering: Yes
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.9.6-1-MANJARO
Network:   Card: Intel Ethernet Connection (2) I219-V driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: d0:50:99:82:58:47
Drives:    HDD Total Size: 3250.7GB (23.4% used)
           ID-1: /dev/sdc model: WDC_WD10EZRX size: 1000.2GB
           ID-2: /dev/sdb model: WDC_WD20EZRX size: 2000.4GB
           ID-3: /dev/sda model: Crucial_CT250MX2 size: 250.1GB
Partition: ID-1: / size: 209G used: 140G (71%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 21.47GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 29.0C mobo: 22.0C
           Fan Speeds (in rpm): cpu: N/A fan-1: 0 fan-2: 1508 fan-4: 0 fan-5: 0 fan-6: 0
Info:      Processes: 190 Uptime: 7 min Memory: 2790.3/15727.5MB Init: systemd Gcc sys: 6.3.1
           Client: Shell (bash 4.4.111) inxi: 2.3.8
#262
I’ve partially solved my problem:
  • I’ve removed ttf-ms-win10
  • I’ve installed ttf-ms-fonts and fontconfig-ttf-ms-fonts from aur
Now fonts looks better but after system update fonts was even better.
#263
I give up for trying playing with font configurations. Because after some things especially Lcdfilter settings never revert back (maybe I cant) I just install meta-package from AUR and ttf-ms-fonts and hinting + subpixel settings from Settings-Appearance just those and my fonts look even great than Windows and Ubuntu :slight_smile:
