[Stable Update] 2016-05-29 - Mate, Kernels, Calamares, Python
Manjaro Update - 2016-05-29 (stable)
We are happy to publish our second release candidate of our upcoming stable release we call Daniella.
Works went into OpenRC, manjaro-tools and our graphical installers. Calamares should now start faster than before and starts now also in Deepin and Gnome. In Thus we fixed some small issues. Pamac got updated to v4.1 and added a progressbar to visualize the current ongoing task better. The Andromeda theme got some new icons and manjaro-tools supports 3rd-party repositories once again. After a little struggle we decided to maintain MATE on our own, since Archlinux has no active maintainer anymore for this destkop environment.
The headline changes in MATE 1.14 are:
  • Improved GTK+3 support across the entire MATE Desktop.
  • Full GTK 3.20 support in all MATE themes.
  • Client Side Decorated applications render correctly in all themes.
  • Completely ported MATE System Monitor and Mozo to GTK+3 only (we ship v1.12 for gtk2 branch).
  • Touchpad configuration now supports edge and two-finger scrolling independently.
  • Python extensions in Caja can now be managed separately.
  • All three window focus modes are selectable.
  • MATE Panel now has the ability to change icon sizes for menubar and menu items.
  • MATE NetSpeed Applet has been merged into the MATE Applets package.
  • MATE Terminal support VTE 2.91 API when built for GTK+3.
  • Volume and Brightness OSD can now be enabled/disabled.
  • Translations are updated.
Archlinux upstream fixes are now from: Tue May 29 16:58:34 CEST 2016.
It is always good to check for updated packages, even we don’t notify you about them. As usual people using our testing branch will help us to get snaps over to our stable branch almost smoothly. For notifications on daily bases please take a look at our mailing list. Full details on the package changes can been found here.
Kind regards,
Philip Müller and the Manjaro Development Team
Troubleshoots
GTK3
With this we updated Gnome and GTK to 3.20. This will break most of the themes, which will be fixed if and when their developers decide to update them. Some GTK 3.20-compliant themes are ready now - see further down this post.
The new default Manjaro GTK theme, which is GTK 3.20 compatible, is Vertex-Maia
You can install it with:
sudo pacman -Sy vertex-maia-themes vertex-maia-icon-theme xcursor-maia
ufw
If you have issues with ufw not working anymore, you have to copy your custom rules to a different folder. Do it like this:
sudo cp -v /usr/lib/ufw/user.rules.pacsave /etc/ufw/user.rules
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Steam might not work due incompatiblity of libgpg. You my try followed command to “fix” it:
find ~/.steam/root/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
Reference: Archlinux wiki
Did you experience any issue with this update?
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Current supported kernels
  • Linux310 3.10.101
  • Linux312 3.12.59
  • Linux314 3.14.70
  • Linux316 3.16.35
  • Linux318 3.18.33
  • Linux319 3.19.8.21
  • Linux41 4.1.24
  • Linux42 4.2.8.11
  • Linux44 4.4.11
  • Linux45 4.5.5
  • Linux46 4.6.0
Package changes
  • community i686: 446 new and 424 removed package(s)
  • community x86_64: 448 new and 426 removed package(s)
  • core i686: 29 new and 28 removed package(s)
  • core x86_64: 29 new and 28 removed package(s)
  • extra i686: 124 new and 123 removed package(s)
  • extra x86_64: 124 new and 123 removed package(s)
  • multilib x86_64: 6 new and 6 removed package(s)
You can now also download our new Manjaro 16.06-rc2 release.
