The Problem:
However, since upgrading to Gnome 40, the extension has been broken for me. The extension starts and looks normal, however when trying to take a screenshot it errors out.
Is anyone else experiencing the same issue? Does anyone have a workaround to get things working again with the screenshot-tool extension under Gnome 40 + Wayland?
Thanks in advance to everyone for your time and help. It is greatly appreciated!
It installed, but it looks like I am getting the same error as before. I took a screenshot (using a different Screenshot utility) to capture the error I am seeing:
Screenshot:
Thanks for your help so far, I really appreciate it!
It uses the gnome-screenshot cli tool as the default backend.
Install gnome-screenshot and try again:
sudo pacman -S gnome-screenshot
Was this the same error you got before? Next time rather than telling that there’s a error also share that what’s the error. Also refrain from sharing screenshots for text based stuff.
