Cannot log in to plasma desktop after hibernate/suspend
My Plasma desktop has crashed after hibernate or suspend. After waking up from sleep, the desktop is stuck on the unlock interface. Unable to enter password to enter desktop. I can only enter other tty terminals, and then I can enter the desktop normally after restarting the computer.
I have a laptop with intel CPU and video-hybrid-intel-nvidia-prime driver.
  • Manjaro release: 23.1.0
  • Kernel: 6.1.68-1
  • Plasma version: 5.27.10-1
The journalctl log of the last failed login might be helpful:
  • journalctl -b 0 -p4 --no-pager
Dec 21 11:23:42 mktb-asus kernel:  #13 #14 #15 #16 #17 #18 #19
Dec 21 11:23:42 mktb-asus kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 21 11:23:42 mktb-asus kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Dec 21 11:23:42 mktb-asus kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 21 11:23:42 mktb-asus kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Dec 21 11:23:42 mktb-asus kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
Dec 21 11:23:42 mktb-asus kernel: pci 10000:e0:06.2: Primary bus is hard wired to 0
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT B
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.2: PCI INT B: no GSI
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
Dec 21 11:23:42 mktb-asus kernel: nvme 10000:e1:00.0: PCI INT A: not connected
Dec 21 11:23:42 mktb-asus kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT A
Dec 21 11:23:42 mktb-asus kernel: nvme 10000:e2:00.0: PCI INT A: not connected
Dec 21 11:23:42 mktb-asus kernel: nvme nvme1: missing or invalid SUBNQN field.
Dec 21 11:23:42 mktb-asus kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
Dec 21 11:23:42 mktb-asus kernel: caller igen6_probe+0x19d/0x7e0 [igen6_edac] mapping multiple BARs
Dec 21 11:23:43 mktb-asus kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Dec 21 11:23:43 mktb-asus kernel: nvidia: loading out-of-tree module taints kernel.
Dec 21 11:23:43 mktb-asus kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 21 11:23:43 mktb-asus kernel: Disabling lock debugging due to kernel taint
Dec 21 11:23:43 mktb-asus kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  545.29.06  Thu Nov 16 01:59:08 UTC 2023
Dec 21 11:23:43 mktb-asus kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
Dec 21 11:23:43 mktb-asus kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 21 11:23:44 mktb-asus (uetoothd)[1063]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support csip plugin
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support micp plugin
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support vcp plugin
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support mcp plugin
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support bass plugin
Dec 21 11:23:44 mktb-asus bluetoothd[1063]: src/plugin.c:plugin_init() System does not support bap plugin
Dec 21 11:23:46 mktb-asus kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 21 11:23:46 mktb-asus kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Dec 21 11:23:46 mktb-asus kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Dec 21 11:23:48 mktb-asus kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Dec 21 11:23:49 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus (systemd)[1381]: pam_env(systemd-user:session): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus (systemd)[1381]: pam_env(systemd-user:session): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus (systemd)[1381]: pam_env(systemd-user:session): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus (systemd)[1381]: pam_env(systemd-user:session): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus (systemd)[1381]: pam_env(systemd-user:session): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:23:49 mktb-asus systemd[1381]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Dec 21 11:23:49 mktb-asus systemd[1381]: Failed to start Update XDG user dir configuration.
Dec 21 11:23:49 mktb-asus sddm-greeter[1392]: QObject: Cannot create children for a parent that is in a different thread.
                                              (Parent is QGuiApplication(0x7ffc4008d5b0), parent's thread is QThread(0x55bc6cdddda0), current thread is QThread(0x55bc6cf424b0)
Dec 21 11:23:49 mktb-asus sddm-greeter[1392]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Dec 21 11:23:51 mktb-asus sddm-greeter[1392]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Dec 21 11:23:51 mktb-asus sddm-greeter[1392]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Dec 21 11:23:51 mktb-asus sddm-greeter[1392]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Dec 21 11:23:51 mktb-asus systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Dec 21 11:23:52 mktb-asus systemd[1]: Failed to start pkgfile database update.
Dec 21 11:23:52 mktb-asus sddm-greeter[1392]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Dec 21 11:23:52 mktb-asus sddm-greeter[1392]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Dec 21 11:23:52 mktb-asus sddm-greeter[1392]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.21'
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1377]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus (systemd)[1465]: pam_env(systemd-user:session): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus (systemd)[1465]: pam_env(systemd-user:session): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus (systemd)[1465]: pam_env(systemd-user:session): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus (systemd)[1465]: pam_env(systemd-user:session): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus (systemd)[1465]: pam_env(systemd-user:session): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:session): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:session): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:session): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:session): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:35 mktb-asus sddm-helper[1462]: pam_env(sddm:session): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:36 mktb-asus ksplashqml[1496]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Dec 21 11:24:36 mktb-asus ksplashqml[1496]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Dec 21 11:24:36 mktb-asus ksmserver[1572]: Qt: Session management error: networkIdsList argument is NULL
Dec 21 11:24:36 mktb-asus ksmserver[1572]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.21'
Dec 21 11:24:36 mktb-asus plasmashell[1691]: Checking screens: available: (QScreen(0x564daf1d5df0, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x564daf1d5df0, name="eDP-1"))
Dec 21 11:24:36 mktb-asus kded5[1574]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.21'
Dec 21 11:24:36 mktb-asus plasmashell[1691]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Dec 21 11:24:36 mktb-asus plasmashell[1691]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Dec 21 11:24:36 mktb-asus kded5[1574]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
Dec 21 11:24:36 mktb-asus kded5[1574]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Dec 21 11:24:36 mktb-asus kded5[1574]: kscreen.kded: PowerDevil SuspendSession action not available!
Dec 21 11:24:37 mktb-asus ksystemstats[1785]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Dec 21 11:24:37 mktb-asus ksplashqml[1496]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Dec 21 11:24:37 mktb-asus ksplashqml[1496]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Dec 21 11:24:37 mktb-asus ksystemstats[1785]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Dec 21 11:24:37 mktb-asus org_kde_powerdevil[1757]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kf.config.core: "\"fsrestore6\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
Dec 21 11:24:37 mktb-asus kdeconnectd[1925]: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:22:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
Dec 21 11:24:37 mktb-asus plasmashell[1691]: Checking screens: available: (QScreen(0x7f5ee0001930, name="HDMI-1-0"), QScreen(0x564daf1d5df0, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x7f5ee0001930, name="HDMI-1-0"), QScreen(0x564daf1d5df0, name="eDP-1"))
Dec 21 11:24:37 mktb-asus kioslave5[2116]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Dec 21 11:24:37 mktb-asus plasmashell[1691]: libpng warning: iCCP: known incorrect sRGB profile
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kwin_core: XCB error: 3 (BadWindow), sequence: 2774, resource id: 4194337, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kwin_core: XCB error: 3 (BadWindow), sequence: 2790, resource id: 4194358, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 21 11:24:37 mktb-asus kwin_x11[1575]: kwin_core: XCB error: 152 (BadDamage), sequence: 2804, resource id: 16777303, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 21 11:24:37 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
Dec 21 11:24:38 mktb-asus plasmashell[1691]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Dec 21 11:24:38 mktb-asus plasmashell[1691]: org.kde.plasma.kicker: DragHelper is deprecated and will be removed in Plasma 6. Use Qt Quick Drag instead.
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/contents/ui/main.qml:136:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/contents/ui/main.qml:120:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/contents/ui/main.qml:128:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/CompactRepresentation.qml:21:1: QML CompactRepresentation (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "maximumWidth"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/contents/ui/CompactRepresentation.qml:67:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 21 11:24:38 mktb-asus plasmashell[1691]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Dec 21 11:24:38 mktb-asus plasmashell[1691]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:407: TypeError: Cannot read property 'Window' of null
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:190:19: QML MouseEventListener: Binding loop detected for property "height"
Dec 21 11:24:38 mktb-asus plasmashell[1691]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:24:39 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 21 11:24:39 mktb-asus plasmashell[1691]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Dec 21 11:24:39 mktb-asus plasmashell[1691]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:190:19: QML MouseEventListener: Binding loop detected for property "height"
Dec 21 11:24:42 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 21 11:24:43 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 21 11:24:45 mktb-asus plasmashell[1691]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 21 11:24:47 mktb-asus plasmashell[1691]: QMetaObject::invokeMethod: No such method FolderViewDropArea_QMLTYPE_64_QML_66::actionTriggered(QVariant)
Dec 21 11:24:47 mktb-asus kioslave5[2116]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Dec 21 11:24:48 mktb-asus plasmashell[1691]: QMetaObject::invokeMethod: No such method FolderViewDropArea_QMLTYPE_64_QML_66::actionTriggered(QVariant)
Dec 21 11:24:48 mktb-asus kioslave5[2116]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Dec 21 11:24:49 mktb-asus plasmashell[1691]: QMetaObject::invokeMethod: No such method FolderViewDropArea_QMLTYPE_64_QML_66::actionTriggered(QVariant)
Dec 21 11:24:49 mktb-asus kioslave5[2116]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Dec 21 11:24:59 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:59 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:59 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:24:59 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:24:59 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:25:12 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:25:12 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:25:12 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:25:12 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:25:12 mktb-asus sudo[2727]: pam_env(sudo:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:25:22 mktb-asus plasmashell[1691]: QMetaObject::invokeMethod: No such method FolderViewDropArea_QMLTYPE_64_QML_66::actionTriggered(QVariant)
Dec 21 11:25:22 mktb-asus kioslave5[2116]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Dec 21 11:25:22 mktb-asus kwin_x11[1575]: kwin_core: XCB error: 3 (BadWindow), sequence: 17659, resource id: 27263255, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 21 11:25:23 mktb-asus plasmashell[1691]: trying to show an empty dialog
Dec 21 11:25:23 mktb-asus plasmashell[1691]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Dec 21 11:25:24 mktb-asus plasmashell[1691]: trying to show an empty dialog
Dec 21 11:25:36 mktb-asus firefox[2793]: Failed to call GetIdletime(): GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.Mutter.IdleMonitor was not provided by any .service files
Dec 21 11:28:28 mktb-asus kstart5[3559]: Omitting both --window and --windowclass arguments is not recommended
Dec 21 11:29:46 mktb-asus kded5[1574]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Dec 21 11:29:46 mktb-asus kscreenlocker_greet[4072]: Qt: Session management error: networkIdsList argument is NULL
Dec 21 11:29:46 mktb-asus kscreenlocker_greet[4072]: kf.kirigami: Failed to find a Kirigami platform plugin
Dec 21 11:29:46 mktb-asus plasmashell[1691]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
Dec 21 11:31:02 mktb-asus kernel: IRQ145: set affinity failed(-22).
Dec 21 11:31:02 mktb-asus kernel: IRQ146: set affinity failed(-22).
Dec 21 11:31:02 mktb-asus kernel: pcieport 10000:e0:06.2: can't derive routing for PCI INT A
Dec 21 11:31:02 mktb-asus kernel: nvme 10000:e2:00.0: PCI INT A: no GSI
Dec 21 11:31:02 mktb-asus kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
Dec 21 11:31:02 mktb-asus kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
Dec 21 11:31:02 mktb-asus rtkit-daemon[1563]: The canary thread is apparently starving. Taking action.
Dec 21 11:31:02 mktb-asus rtkit-daemon[1563]: Recovering from system lockup, not allowing further RT threads.
Dec 21 11:31:02 mktb-asus kdeconnectd[1925]: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:setcred): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:setcred): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:setcred): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:setcred): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:setcred): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:session): non-alphanumeric key 'GTK_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:session): non-alphanumeric key 'QT_IM_MODULE  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:session): non-alphanumeric key 'XMODIFIERS    DEFAULT=@im=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:session): non-alphanumeric key 'INPUT_METHOD  DEFAULT=fcitx' in /etc/environment', ignoring
Dec 21 11:31:14 mktb-asus login[4615]: pam_env(login:session): non-alphanumeric key 'SDL_IM_MODULE DEFAULT=fcitx' in /etc/environment', ignoring
What is the content of /etc/environment ?
This also looks off … maybe check its status?
systemctl --user status xdg-user-dirs-update
pkgfile is having problems.
No big surprise there.
But you probably want to get rid of the thing.
sudo pacman -Rns pkgfile
If ‘splash’ is set, try unsetting it.
Something wrong with dbus?
This might be the tip of the problem.
I dont know what this is … but it looks like a problem too.
Are you missing large parts of plasma? Did you remove things recently?
We can maybe take a look at recent removals by checking the pacman logs, ex:
grep -i removed /var/log/pacman.log
Please also include the output of inxi -Fazy for general system information.
Thank you for your reply.
  • Content of the /etc/environment
# This file is parsed by pam_env module
# Syntax: simple "KEY=VAL" pairs on separate lines
I think the problem is not with this file. These settings were configured when setting up the input method before.
  • Check xdg-user-dirs-update
○ xdg-user-dirs-update.service - Update XDG user dir configuration
     Loaded: loaded (/usr/lib/systemd/user/xdg-user-dirs-update.service; enabled; preset: enabled)
     Active: inactive (dead) since Thu 2023-12-21 11:32:47 CST; 1h 21min ago
       Docs: man:xdg-user-dirs-update(1)
   Main PID: 1517 (code=exited, status=0/SUCCESS)
        CPU: 683us
Dec 21 11:32:47 mktb-asus systemd[1480]: Starting Update XDG user dir configuration...
Dec 21 11:32:47 mktb-asus systemd[1480]: Finished Update XDG user dir configuration.
  • I will try to unsetting ‘splash’
  • I have removed the pkgfile
  • removed packages in pacman logs
[2022-09-28T21:03:31+0800] [ALPM] removed amd-ucode (20220708.be7798e-1)
[2022-09-29T16:57:53+0800] [ALPM] removed yakuake (22.08.0-1)
[2022-09-29T16:57:53+0800] [ALPM] removed konsole (22.08.0-1)
[2022-09-29T10:03:31+0800] [ALPM] removed octopi (0.13.0-2)
[2022-09-29T10:03:31+0800] [ALPM] removed qtermwidget (1.1.0-1)
[2022-09-29T10:03:31+0800] [ALPM] removed alpm-octopi-utils (1.0.2-2)
[2022-10-17T16:18:45+0800] [ALPM] removed appimagelauncher (2.2.0-9)
[2022-10-17T16:18:45+0800] [ALPM] removed libappimage (1.0.4.5-3)
[2022-10-17T16:18:45+0800] [ALPM] removed squashfuse (0.1.105-1)
[2022-10-17T16:21:30+0800] [ALPM] removed appimagelauncher (2.2.0-9)
[2022-10-17T16:21:30+0800] [ALPM] removed libappimage (1.0.4.5-3)
[2022-10-17T16:21:30+0800] [ALPM] removed squashfuse (0.1.105-1)
[2022-10-26T17:34:22+0800] [ALPM] removed networkmanager-iwd-overlay (1.1-1)
[2022-10-26T17:36:29+0800] [ALPM] removed networkmanager-iwd-overlay (1.1-1)
[2022-10-26T17:36:29+0800] [ALPM] removed iwd (1.30-1)
[2022-10-26T17:36:29+0800] [ALPM] removed ell (0.53-1)
[2022-11-01T18:51:27+0800] [ALPM] removed sunloginclient (11.0.1.44968-2)
[2022-11-10T10:02:41+0800] [ALPM] removed dpkg (1.21.9-1)
[2022-11-10T10:22:07+0800] [ALPM] removed debtap (3.5.1-1)
[2022-11-10T10:22:07+0800] [ALPM-SCRIPTLET] ==> /var/cache/debtap has not been removed
[2022-11-10T10:52:46+0800] [ALPM] removed debtap (3.5.1-1)
[2022-11-10T10:52:46+0800] [ALPM-SCRIPTLET] ==> /var/cache/debtap has not been removed
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-terminal (5.4.34-1)
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-qt5integration (5.5.24-1)
[2022-11-11T11:34:30+0800] [ALPM] removed dtkwidget (5.6.0.2-2)
[2022-11-11T11:34:30+0800] [ALPM] removed startup-notification (0.12-7)
[2022-11-11T11:34:30+0800] [ALPM] removed dtkgui (1:5.6.0.2-1)
[2022-11-11T11:34:30+0800] [ALPM] removed libqtxdg (3.9.1-4)
[2022-11-11T11:34:30+0800] [ALPM] removed dtkcore (1:5.6.2-1)
[2022-11-11T11:34:30+0800] [ALPM] removed lshw (B.02.19.2-5)
[2022-11-11T11:34:30+0800] [ALPM] removed gsettings-qt (0.2-1)
[2022-11-11T11:34:30+0800] [ALPM] removed dtkcommon (5.5.23-1)
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-desktop-base (2:2022.07.26-2)
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-qt-dbus-factory (5.5.22-5)
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-qt5platform-plugins (5.0.67-1)
[2022-11-11T11:34:30+0800] [ALPM] removed deepin-wayland (1.0.0-1)
[2022-11-11T11:36:09+0800] [ALPM] removed deepin-terminal (5.3.0.9-1)
[2022-11-11T11:36:09+0800] [ALPM] removed deepin-qt5integration (5.5.24-1)
[2022-11-11T11:36:09+0800] [ALPM] removed dtkwidget (5.6.0.2-2)
[2022-11-11T11:36:09+0800] [ALPM] removed startup-notification (0.12-7)
[2022-11-11T11:36:09+0800] [ALPM] removed dtkgui (1:5.6.0.2-1)
[2022-11-11T11:36:09+0800] [ALPM] removed libqtxdg (3.9.1-4)
[2022-11-11T11:36:09+0800] [ALPM] removed dtkcore (1:5.6.2-1)
[2022-11-11T11:36:09+0800] [ALPM] removed lshw (B.02.19.2-5)
[2022-11-11T11:36:09+0800] [ALPM] removed gsettings-qt (0.2-1)
[2022-11-11T11:36:10+0800] [ALPM] removed dtkcommon (5.5.23-1)
[2022-11-11T11:36:10+0800] [ALPM] removed deepin-desktop-base (2:2022.07.26-2)
[2022-11-11T11:36:10+0800] [ALPM] removed deepin-qt-dbus-factory (5.5.22-5)
[2022-11-11T11:36:10+0800] [ALPM] removed deepin-qt5platform-plugins (5.0.67-1)
[2022-11-11T11:36:10+0800] [ALPM] removed deepin-wayland (1.0.0-1)
[2022-11-11T11:41:53+0800] [ALPM] removed remmina (1:1.4.27-2)
[2022-11-12T15:57:55+0800] [ALPM] removed kwayland-server (5.24.6-1)
[2022-11-12T15:57:55+0800] [ALPM] removed at-spi2-atk (2.38.0-1)
[2022-11-12T15:57:55+0800] [ALPM] removed atk (2.38.0-1)
[2022-11-16T09:09:33+0800] [ALPM] removed teamviewer (15.35.5-1)
[2023-01-06T17:47:18+0800] [ALPM] removed cudnn (8.6.0.163-1)
[2023-01-06T18:24:32+0800] [ALPM] removed cudnn (8.6.0.163-1)
[2023-01-13T22:00:36+0800] [ALPM] removed powerline-fonts (2.8.3-1)
[2023-01-13T22:00:37+0800] [ALPM] removed powerline-common (2.8.3-1)
[2023-01-17T13:39:06+0800] [ALPM] removed mpv (1:0.35.0-2)
[2023-01-17T13:39:06+0800] [ALPM] removed uchardet (0.0.7-1)
[2023-01-17T13:39:06+0800] [ALPM] removed rubberband (3.1.2-1)
[2023-01-17T13:39:06+0800] [ALPM] removed mujs (1.3.2-1)
[2023-01-17T13:39:06+0800] [ALPM] removed luajit (2.1.0.beta3.r464.g8625eee7-1)
[2023-01-17T13:39:06+0800] [ALPM] removed libxpresent (1.0.1-1)
[2023-01-17T13:39:06+0800] [ALPM] removed libcdio-paranoia (10.2+2.0.1-2)
[2023-02-03T11:10:23+0800] [ALPM] removed nerd-fonts-noto-sans-mono (2.2.2-1)
[2023-02-03T11:10:57+0800] [ALPM-SCRIPTLET] >>> pipewire-media-session is deprecated and will soon be removed from the
[2023-02-18T19:50:08+0800] [ALPM] removed microsoft-edge-dev-bin (111.0.1652.0-1)
[2023-04-10T12:10:15+0800] [ALPM] removed wqy-microhei (0.2.0_beta-11)
[2023-04-11T11:35:40+0800] [ALPM] removed retroarch (1.15.0-1)
[2023-04-11T11:35:40+0800] [ALPM] removed mbedtls (2.28.2-1)
[2023-06-01T17:11:27+0800] [ALPM] removed python-mysql-connector (8.0.33-1)
[2023-06-01T17:11:27+0800] [ALPM] removed python-dnspython (1:2.3.0-1)
[2023-07-15T20:21:36+0800] [ALPM-SCRIPTLET]   The "Infinality" TrueType interpreter version has been removed.
[2023-08-07T15:23:08+0800] [ALPM] removed steam (1.0.0.78-2)
[2023-08-07T15:23:08+0800] [ALPM] removed zenity (3.44.1-1)
[2023-08-07T15:23:08+0800] [ALPM] removed xorg-xrandr (1.5.2-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-nss (3.91-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-sqlite (3.42.0-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-p11-kit (0.25.0-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-libtasn1 (4.19.0-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-nspr (4.35-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-libxss (1.2.3-3)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-libxcrypt-compat (4.4.36-1)
[2023-08-07T15:23:08+0800] [ALPM] removed lib32-alsa-plugins (1.2.7.1-2)
[2023-08-07T15:23:08+0800] [ALPM] removed game-devices-udev (0.22-1)
[2023-10-03T14:57:27+0800] [ALPM] removed netease-cloud-music (1.2.1-8)
[2023-10-03T15:00:42+0800] [ALPM] removed rust (1:1.72.0-1)
[2023-10-03T15:00:42+0800] [ALPM] removed meson (1.2.1-1)
[2023-10-03T15:00:42+0800] [ALPM] removed python-tqdm (4.66.1-2)
[2023-10-03T15:00:42+0800] [ALPM] removed ninja (1.11.1-3)
[2023-10-24T20:52:56+0800] [ALPM] removed qt5-doc (5.15.11-2)
[2023-10-24T20:52:56+0800] [ALPM] removed python-installer (0.7.0-3)
[2023-10-24T20:52:56+0800] [ALPM] removed python-flit-core (3.9.0-1)
[2023-10-24T20:52:56+0800] [ALPM] removed python-build (1.0.1-1)
[2023-10-24T20:52:56+0800] [ALPM] removed python-pyproject-hooks (1.0.0-5)
[2023-10-26T12:44:08+0800] [ALPM] removed bluez-qt (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed qqc2-desktop-style (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed purpose (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed prison (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed modemmanager-qt (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed ktexteditor (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed syntax-highlighting (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed krunner (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed threadweaver (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed plasma-framework (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kwayland (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kquickcharts (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kpeople (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed knotifyconfig (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kimageformats (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kholidays (1:5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kdoctools (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kdnssd (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kdesu (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kpty (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kparts (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kitemmodels (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kunitconversion (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kcontacts (1:5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kcmutils (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kdeclarative (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kactivities-stats (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kactivities (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed frameworkintegration (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed knewstuff (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed syndication (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kpackage (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed baloo (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kio (5.110.0-2)
[2023-10-31T20:16:48+0800] [ALPM] removed kded (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed ktextwidgets (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed sonnet (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kcompletion (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kwallet (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kservice (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed knotifications (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kbookmarks (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kxmlgui (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kitemviews (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kiconthemes (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kconfigwidgets (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kguiaddons (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kcodecs (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kauth (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kglobalaccel (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kcrash (5.110.0-1)
[2023-10-31T20:16:48+0800] [ALPM] removed kwindowsystem (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kdbusaddons (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kjobwidgets (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kwidgetsaddons (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed solid (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kidletime (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kfilemetadata (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kcoreaddons (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed kconfig (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed karchive (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed ki18n (5.110.0-1)
[2023-10-31T20:16:49+0800] [ALPM] removed attica (5.110.0-1)
[2023-11-11T22:02:11+0800] [ALPM] removed networkmanager-qt (5.108.0-1)
[2023-11-11T22:02:11+0800] [ALPM] removed kirigami-addons (0.11.0-2)
[2023-11-15T17:02:26+0800] [ALPM] removed libqaccessibilityclient (0.4.1-2)
[2023-11-15T17:02:26+0800] [ALPM] removed kuserfeedback (1.2.0-1)
[2023-11-15T17:02:26+0800] [ALPM] removed kdsoap (2.1.1-1)
[2023-11-19T12:44:24+0800] [ALPM] removed qt5-doc (5.15.11-2)
[2023-11-19T12:44:24+0800] [ALPM] removed python-installer (0.7.0-3)
[2023-11-19T12:44:24+0800] [ALPM] removed python-build (1.0.3-1)
[2023-11-19T12:44:24+0800] [ALPM] removed python-pyproject-hooks (1.0.0-5)
[2023-11-19T12:44:24+0800] [ALPM] removed python-flit-core (3.9.0-1)
[2023-11-19T12:56:55+0800] [ALPM] removed wps-office (11.1.0.11708-1)
[2023-11-19T12:57:31+0800] [ALPM] removed ttf-wps-fonts (1.0-5)
[2023-11-19T12:58:55+0800] [ALPM] removed netease-cloud-music (1.2.1-8)
[2023-12-09T17:39:32+0800] [ALPM] removed libkdcraw (23.08.3-1)
[2023-12-09T17:39:32+0800] [ALPM] removed appstream-qt (0.16.4-1)
[2023-12-11T15:53:25+0800] [ALPM] removed kgamma5 (5.27.9-1)
[2023-12-12T20:16:41+0800] [ALPM] removed linux515-nvidia (545.29.06-4)
[2023-12-12T20:16:47+0800] [ALPM] removed linux515 (5.15.142-1)
[2023-12-17T17:12:21+0800] [ALPM] removed zoom (5.16.6-1)
[2023-12-18T12:36:37+0800] [ALPM] removed perl-anyevent-i3 (0.17-9)
[2023-12-18T12:36:37+0800] [ALPM] removed perl-anyevent (4:7.17-6)
[2023-12-18T12:36:37+0800] [ALPM] removed perl-json-xs (4.03-4)
[2023-12-18T12:36:37+0800] [ALPM] removed perl-types-serialiser (1.01-2)
[2023-12-18T12:36:37+0800] [ALPM] removed perl-common-sense (3.75-5)
[2023-12-18T12:36:37+0800] [ALPM] removed xss-lock (0.3.0.g1e158fb20108-4)
[2023-12-18T12:36:37+0800] [ALPM] removed rofi (1.7.5-2)
[2023-12-18T12:36:37+0800] [ALPM] removed libxdg-basedir (1.2.3-2)
[2023-12-18T12:36:37+0800] [ALPM] removed dmenu (5.2-1)
[2023-12-18T12:36:37+0800] [ALPM] removed i3status (2.14-1)
[2023-12-18T12:36:37+0800] [ALPM] removed i3lock (2.14.1-1)
[2023-12-18T12:36:44+0800] [ALPM] removed i3-wm (4.23-1)
[2023-12-18T12:36:44+0800] [ALPM] removed yajl (2.1.0-5)
[2023-12-18T12:36:44+0800] [ALPM] removed xcb-util-xrm (1.3-2)
[2023-12-18T12:36:44+0800] [ALPM] removed startup-notification (0.12-8)
[2023-12-18T12:36:44+0800] [ALPM] removed libev (4.33-2)
[2023-12-18T12:53:52+0800] [ALPM] removed cudnn (8.9.6.50-1)
[2023-12-18T12:53:52+0800] [ALPM] removed cuda (12.3.0-6)
[2023-12-18T12:53:52+0800] [ALPM] removed opencl-nvidia (545.29.06-1)
[2023-12-18T12:53:52+0800] [ALPM] removed gcc12 (12.3.0-3)
[2023-12-18T12:53:52+0800] [ALPM] removed gcc12-libs (12.3.0-3)
[2023-12-18T12:54:08+0800] [ALPM] removed linux61-nvidia (545.29.06-8)
[2023-12-18T12:54:10+0800] [ALPM] removed lib32-nvidia-utils (545.29.06-1)
[2023-12-18T12:54:10+0800] [ALPM] removed nvidia-prime (1.0-4)
[2023-12-18T12:54:10+0800] [ALPM] removed libxnvctrl (545.29.06-1)
[2023-12-18T12:54:10+0800] [ALPM] removed nvidia-utils (545.29.06-1)
[2023-12-18T12:54:10+0800] [ALPM] removed egl-wayland (2:1.1.13-1)
[2023-12-18T12:54:10+0800] [ALPM] removed eglexternalplatform (1.1-2)
[2023-12-18T13:09:14+0800] [ALPM] removed linux61-nvidia-470xx (470.223.02-12)
[2023-12-18T13:09:16+0800] [ALPM] removed lib32-nvidia-470xx-utils (470.223.02-1)
[2023-12-18T13:09:16+0800] [ALPM] removed nvidia-prime (1.0-4)
[2023-12-18T13:09:16+0800] [ALPM] removed nvidia-470xx-settings (470.223.02-1)
[2023-12-18T13:09:16+0800] [ALPM] removed libxnvctrl-470xx (470.223.02-1)
[2023-12-18T13:09:16+0800] [ALPM] removed nvidia-470xx-utils (470.223.02-1)
[2023-12-18T13:09:16+0800] [ALPM] removed egl-wayland (2:1.1.13-1)
[2023-12-18T13:09:16+0800] [ALPM] removed eglexternalplatform (1.1-2)
 ~  cat /etc/environment                                                            ✔  base Py  12:50:53
 ~  systemctl --user status xdg-user-dirs-update                                    ✔  base Py  12:51:38
        CPU: 683us
 ~  sudo pacman -Rns pkgfile                                                      3 ✘  base Py  12:54:32
[sudo] password for mktb:
checking dependencies...
Packages (1) pkgfile-21-2
Total Removed Size:  0.05 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing pkgfile                                             [####################################] 100%
==> /var/cache/pkgfile has not been removed
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
 ~  grep -i removed /var/log/pacman.log                                       ✔  11s  base Py  12:56:39
[2023-12-21T12:56:39+0800] [ALPM] removed pkgfile (21-2)
[2023-12-21T12:56:39+0800] [ALPM-SCRIPTLET] ==> /var/cache/pkgfile has not been removed
These removed packages should be automatically replaced during system upgrades. I have not manually removed the packages.
  • general system information
  Kernel: 6.1.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=902851ab-b7b6-4fb9-929c-9e911c9a4806 rw quiet
    resume=UUID=b654cc39-cda7-46d4-ad4d-11a843fc805a udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX507ZM_FX507ZM
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FX507ZM v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: FX507ZM.315 date: 06/17/2022
  ID-1: BAT1 charge: 53.5 Wh (62.6%) condition: 85.5/90.2 Wh (94.7%)
    volts: 15.8 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x430
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 474 high: 1049 min/max: 400/4600:4700:3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 814 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 836 10: 400 11: 400 12: 400 13: 1049 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107560
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
    chip-ID: 10de:2520 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 13d3:56a2
  Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
    s-diag: 1407mm (55.38")
  Monitor-1: HDMI-1-0 pos: primary,right res: 2560x1440 hz: 60 dpi: 109
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-2: eDP-1 pos: left res: 2560x1440 hz: 165 dpi: 189
    size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a6 memory: 30.25 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
    device-ID: 10de:2520 surfaces: xcb,xlib
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Device-3: ASUSTek C-Media Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:7
    chip-ID: 0b05:6203 class-ID: 0300
  API: ALSA v: k6.1.68-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
  IF: eno2 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 1.4 TiB used: 270.88 GiB (18.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL2512HCJQ-00B00
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: GXA7401Q temp: 47.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Hynix
    model: ZHITAI PC005 Active 1TB size: 953.87 GiB block-size: physical: 512 B
    fw-rev: ZT00D212 temp: 54.9 C scheme: GPT
  ID-1: / raw-size: 936.79 GiB size: 921.01 GiB (98.32%)
    used: 270.68 GiB (29.4%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:9
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8
  ID-1: swap-1 type: partition size: 16.78 GiB used: 205.2 MiB (1.2%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:10
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2300
  Processes: 438 Uptime: 1h 27m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 30.98 GiB used: 11.06 GiB (35.7%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11
  clang: 16.0.6 Packages: 1588 pm: pacman pkgs: 1582 libs: 445
  tools: octopi,pamac,yay pm: flatpak pkgs: 6 Shell: Zsh v: 5.9
  running-in: konsole inxi: 3.3.31
These are not valid entries for /etc/environment, as outlined in the header:
I dont know what you were trying to do before … but the lines in that file are not OK.
Example of some of mine;
# Editors
EDITOR=/usr/bin/micro
SUDO_EDITOR=/usr/bin/micro
VISUAL=/usr/bin/kate
DIFFPROG=/usr/bin/meld
# Portals
GTK_USE_PORTAL=1
GDK_DEBUG=portals
# Less Debug Logging
QT_LOGGING_RULES="*.debug=false"
Thank you, I have corrected the file. But it still can’t weak from hibernate.
# GTK_IM_MODULE DEFAULT=fcitx
# QT_IM_MODULE  DEFAULT=fcitx
# XMODIFIERS    DEFAULT=@im=fcitx
# INPUT_METHOD  DEFAULT=fcitx
# SDL_IM_MODULE DEFAULT=fcitx
GTK_IM_MODULE=fcitx
QT_IM_MODULE=fcitx
XMODIFIERS=fcitx
INPUT_METHOD=fcitx
SDL_IM_MODULE=fcitx
