Hi,
Bit of a problem here:
I am running Manjaro KDE with x11 on a AMD Ryzen 7 8845HS w/ Radeon 780M Graphics.
I recently tried Wayland and also dual displays, but after that I lost AMDGPU driver?
(it is in software mode now - “llvmpipe” according to Info Center)
Can someone help me fix the above?
Thank you in advance!
Jesse
Kernel:6.12.48-1-MANJAROarch:x86_64bits:64compiler:gccv:15.2.1
clocksource:tscavail:hpet,acpi_pm
parameters:BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
root=UUID=d49c7a29-82dd-4a37-93f8-c1ea1df72ef7 rw quiet
cryptdevice=UUID=9c0390c7-ef75-4609-9f94-fd8d1043c88d:luks-9c0390c7-ef75-4609-9f94-fd8d1043c88d
root=/dev/mapper/luks-9c0390c7-ef75-4609-9f94-fd8d1043c88d splash
udev.log_priority=3
Desktop:KDE Plasmav:6.3.6tk:Qtv:N/Ainfo:frameworksv:6.18.0
wm:kwin_x11vt:2dm:SDDMDistro:Manjarobase:Arch Linux
Type:Mini-pcMobo:AZWmodel:SER8v:V10serial:<superuser required>
part-nu:75uuid:<superuser required>UEFI:American Megatrends LLC.
v:HPT.8xxx.SER8.V029.P8C0M0C15.13.Linkdate:02/21/2025
Message:No system battery data found. Is one present?
System RAM: total:32 GiBavailable:23.25 GiBused:9.25 GiB (39.8%)
Message:For most reliable report, use superuser + dmidecode.
Array-1: capacity:64 GiBslots:2modules:2EC:None
max-module-size:32 GiBnote:est.
Device-1:Channel-A DIMM 0type:DDR5detail:synchronous unbuffered
(unregistered)size:16 GiBspeed:5600 MT/svolts: note:checkcurr:1
min:1max:1width (bits): data:64total:64manufacturer:Crucial
part-no:CT16G56C46S5.M8G1serial:<filter>
Device-2:Channel-B DIMM 0type:DDR5detail:synchronous unbuffered
Permissions:Unable to run dmidecode. Root privileges required.
Info: model:AMD Ryzen 7 8845HS w/ Radeon 780M Graphicsbits:64
type:MT MCParch:Zen 4gen:4level:v4note:checkbuilt:2022+
process:TSMC n5 (5nm)family:0x19 (25)model-id:0x75 (117)stepping:2
microcode:0xA705208
Topology: cpus:1xdies:1clusters:1cores:8threads:16tpc:2
smt:enabledcache: L1:512 KiBdesc:d-8x32 KiB; i-8x32 KiBL2:8 MiB
desc:8x1024 KiBL3:16 MiBdesc:1x16 MiB
Speed (MHz): avg:1098min/max:400/5137boost:enabledscaling:
driver:amd-pstate-eppgovernor:powersavecores: 1:10982:10983:1098
4:10985:10986:10987:10988:10989:109810:109811:109812:1098
13:109814:109815:109816:1098bogomips:121422
Flags:3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves xtopology
Type:gather_data_samplingstatus:Not affected
Type:indirect_target_selectionstatus:Not affected
Type:itlb_multihitstatus:Not affected
Type:l1tfstatus:Not affected
Type:mdsstatus:Not affected
Type:meltdownstatus:Not affected
Type:mmio_stale_datastatus:Not affected
Type:reg_file_data_samplingstatus:Not affected
Type:retbleedstatus:Not affected
Type:spec_rstack_overflowmitigation:Safe RET
Type:spec_store_bypassmitigation:Speculative Store Bypass disabled via
Type:spectre_v1mitigation:usercopy/swapgs barriers and __user pointer
Type:spectre_v2mitigation:Enhanced / Automatic IBRS; IBPB:
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type:srbdsstatus:Not affected
Type:tsamitigation:Clear CPU buffers
Type:tsx_async_abortstatus:Not affected
Type:vmscapemitigation:IBPB before exit to userspace
Device-1:Advanced Micro Devices [AMD/ATI] HawkPoint1driver:amdgpu
v:kernelarch:RDNA-3code:Phoenixprocess:TSMC n4 (4nm)built:2023+
pcie: gen:4speed:16 GT/slanes:16ports: active:DP-1,HDMI-A-1
empty:DP-2, DP-3, DP-4, DP-5, DP-6, Writeback-1bus-ID:65:00.0
chip-ID:1002:1900class-ID:0300temp:31.0 C
Display:x11server:``X.Org``v:21.1.18with:Xwaylandv:24.1.8
compositor:kwin_x11driver: X: loaded:amdgpuunloaded:modesetting
alternate:fbdev,vesadri:radeonsigpu:amdgpudisplay-ID::0screens:1
Screen-1:0s-res:1920x1080s-dpi:96s-size:507x285mm (19.96x11.22")
s-diag:582mm (22.9")
Monitor-1:DP-1mapped:DisplayPort-0pos:primary
model:LG (GoldStar) Ultra HDserial:<filter>built:2023res:
mode:1920x1080hz:60scale:100% (1)dpi:81gamma:1.2chroma: red:
x:0.655y:0.333green: x:0.306y:0.639blue: x:0.149y:0.059white:
x:0.314y:0.329size:600x340mm (23.62x13.39")diag:690mm (27.2")
ratio:16:9modes:3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 800x600, 720x480, 640x480
Monitor-2:HDMI-A-1mapped:HDMI-A-0model:LG (GoldStar) TV SSCR2
serial:<filter>built:2020res:1920x1080dpi:61gamma:1.2chroma: red:
x:0.639y:0.329green: x:0.298y:0.600blue: x:0.149y:0.059white:
x:0.314y:0.329size:1600x900mm (62.99x35.43")diag:1836mm (72.3")
ratio:16:9modes:3840x2160, 4096x2160, 2560x1440, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1:parse_edid: unhandled CEA mode 972:parse_edid:
unhandled CEA mode 963:parse_edid: unhandled CEA mode 1024:parse_edid:
unhandled CEA mode 1015:parse_edid: unhandled CEA mode 936:parse_edid:
unhandled CEA mode 947:parse_edid: unhandled CEA mode 958:parse_edid:
unhandled CEA mode 989:parse_edid: unhandled CEA mode 9910:parse_edid:
unhandled CEA mode 100
API:EGLv:1.5platforms: device:1drv:swrastgbm: drv:kms_swrast
surfaceless: drv:swrastx11: drv:swrastinactive:wayland,device-0
API:OpenGLv:4.5vendor:mesav:25.2.3-arch1.2glx-v:1.4
direct-render:yesrenderer:llvmpipe (LLVM 20.1.8 256 bits)
device-ID:ffffffff:ffffffffmemory:22.71 GiBunified:yes
API:VulkanMessage:No Vulkan data available.
Info: Tools: api:clinfo, eglinfo, glxinfo, vulkaninfo
de:kscreen-console,kscreen-doctorwl:wayland-info
x11:xdpyinfo, xprop, xrandr
Device-1:Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix]driver:snd_hda_intelv:kernelpcie: gen:4
speed:16 GT/slanes:16bus-ID:65:00.1chip-ID:1002:1640class-ID:0403
Device-2:Advanced Micro Devices [AMD] Audio Coprocessor
driver:snd_pci_psv:kernelalternate:snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70pcie: gen:4speed:16 GT/slanes:16
bus-ID:65:00.5chip-ID:1022:15e2class-ID:0480
Device-3:Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
driver:snd_hda_intelv:kernelpcie: gen:4speed:16 GT/slanes:16
bus-ID:65:00.6chip-ID:1022:15e3class-ID:0403
API:ALSAv:k6.12.48-1-MANJAROstatus:kernel-apiwith:aoss
type:oss-emulatortools:alsactl,alsamixer,amixer
Server-1:JACKv:1.9.22status:offtools:N/A
Server-2:PipeWirev:1.4.8status:activewith: 1:pipewire-pulse
status:active2:wireplumberstatus:active3:pipewire-alsatype:plugin
tools:pactl,pw-cat,pw-cli,wpctl
Device-1:Realtek RTL8125 2.5GbEdriver:r8169v:kernelpcie: gen:2
speed:5 GT/slanes:1port:f000bus-ID:01:00.0chip-ID:10ec:8125
class-ID:0200
IF:enp1s0state:upspeed:1000 Mbpsduplex:fullmac:<filter>
IP v4:<filter>type:dynamic noprefixroutescope:global
broadcast:<filter>
IP v6:<filter>type:dynamic noprefixroutescope:global
IP v6:<filter>type:noprefixroutescope:link
Device-2:Intel Wi-Fi 6 AX200driver:iwlwifiv:kernelpcie: gen:2
speed:5 GT/slanes:1bus-ID:02:00.0chip-ID:8086:2723class-ID:0280
IF:wlp2s0state:downmac:<filter>
IF-ID-1:wg0-mullvadstate:unknownspeed:N/Aduplex:N/Amac:N/A
IP v4:<filter>scope:global
Info: services:NetworkManager, systemd-timesyncd, wpa_supplicant
WAN IP:<filter>
Device-1:Intel AX200 Bluetoothdriver:btusbv:0.8type:USBrev:2.0
speed:12 Mb/slanes:1mode:1.1bus-ID:1-5:4chip-ID:8087:0029
class-ID:e001
Report:rfkillID:hci0rfk-id:0state:upaddress:see --recommends
Message:No logical block device data found.
Device-1:luks-9c0390c7-ef75-4609-9f94-fd8d1043c88dmaj-min:254:0
type:LUKSdm:dm-0size:931.22 GiB
Components:
p-1:nvme0n1p2maj-min:259:2size:931.22 GiB
Message:No RAID data found.
Local Storage: total:931.51 GiBused:720.37 GiB (77.3%)
SMART Message:Required tool smartctl not installed. Check --recommends
ID-1:/dev/nvme0n1maj-min:259:0vendor:Crucialmodel:CT1000P3PSSD8
size:931.51 GiBblock-size: physical:512 Blogical:512 Bspeed:63.2 Gb/s
lanes:4tech:SSDserial:<filter>fw-rev:P9CR411temp:28.9 C
scheme:GPT
Message:No optical or floppy data found.
ID-1:/raw-size:931.22 GiBsize:915.53 GiB (98.32%)
used:720.36 GiB (78.7%)fs:ext4dev:/dev/dm-0maj-min:254:0
mapped:luks-9c0390c7-ef75-4609-9f94-fd8d1043c88dlabel:N/A
uuid:d49c7a29-82dd-4a37-93f8-c1ea1df72ef7
ID-2:/boot/efiraw-size:300 MiBsize:299.4 MiB (99.80%)
used:536 KiB (0.2%)fs:vfatdev:/dev/nvme0n1p1maj-min:259:1label:N/A
uuid:A3F0-C0C9
Alert:No swap data was found.
Message:No unmounted partitions found.
Hub-1:1-0:1info:hi-speed hub with single TTports:5rev:2.0
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0chip-ID:1d6b:0002
class-ID:0900
Device-1:1-3:2info:China Resource Semico USB Keyboard
type:keyboard,HIDdriver:hid-generic,usbhidinterfaces:2rev:1.1
speed:1.5 Mb/s (183 KiB/s)lanes:1mode:1.0power:500mA
chip-ID:1a2c:4094class-ID:0300
Hub-2:1-4:3info:Hitachiports:4rev:2.0speed:480 Mb/s (57.2 MiB/s)
lanes:1mode:2.0chip-ID:045b:0209class-ID:0900
Hub-3:1-4.1:5info:Hitachiports:4rev:2.0
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0chip-ID:045b:0209
class-ID:0900
Hub-4:1-4.3:6info:Hitachiports:4rev:2.1
class-ID:0900
Hub-5:1-4.3.1:7info:Hitachiports:4rev:2.1
class-ID:0900
Device-1:1-4.3.1.1:9info:ShenZhen ShanWan Android Gamepadtype:HID
driver:hid-generic,usbhidinterfaces:2rev:1.1speed:12 Mb/s (1.4 MiB/s)
lanes:1mode:1.1power:350mAchip-ID:2563:0526class-ID:0300
Device-2:1-4.3.1.2:11info:Logitech Unifying Receiver
type:keyboard,mouse,HIDdriver:logitech-djreceiver,usbhidinterfaces:3
rev:2.0speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1power:98mA
chip-ID:046d:c52bclass-ID:0300
Device-3:1-4.3.2:8info:ShenZhen ShanWan ZD-V+ Wired Gaming Controller
type:HIDdriver:hid-generic,usbhidinterfaces:1rev:2.0
speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1power:500mA
chip-ID:2563:0575class-ID:0300serial:<filter>
Device-4:1-4.3.4:10info:Brother Industries DCP-L2550DW series
type:printerdriver:usblpinterfaces:2rev:2.0
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0power:2mA
chip-ID:04f9:0424class-ID:0701serial:<filter>
Device-5:1-5:4info:Intel AX200 Bluetoothtype:bluetoothdriver:btusb
interfaces:2rev:2.0speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1
power:100mAchip-ID:8087:0029class-ID:e001
Hub-6:2-0:1info:super-speed hubports:2rev:3.1
speed:10 Gb/s (1.16 GiB/s)lanes:1mode:3.2 gen-2x1chip-ID:1d6b:0003
class-ID:0900
Hub-7:3-0:1info:hi-speed hub with single TTports:1rev:2.0
class-ID:0900
Hub-8:4-0:1info:super-speed hubports:1rev:3.1
class-ID:0900
Hub-9:5-0:1info:hi-speed hub with single TTports:1rev:2.0
class-ID:0900
Hub-10:6-0:1info:super-speed hubports:1rev:3.1
class-ID:0900
Hub-11:7-0:1info:hi-speed hub with single TTports:1rev:2.0
class-ID:0900
Device-1:7-1:2info:USB Optical Mousetype:mouse
driver:hid-generic,usbhidinterfaces:1rev:1.1
speed:1.5 Mb/s (183 KiB/s)lanes:1mode:1.0power:100mA
chip-ID:30fa:0400class-ID:0301
Hub-12:8-0:1info:super-speed hubports:1rev:3.1
class-ID:0900
System Temperatures: cpu:40.5 Cmobo:33.2 Cgpu:amdgputemp:31.0 C
Fan Speeds (rpm):N/A
Packages:1571pm:pacmanpkgs:1537libs:471tools:pamacpm:rpmpkgs:0
pm:flatpakpkgs:34
Active pacman repo servers in:/etc/pacman.d/mirrorlist
1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch``
2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch``
3: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch``
4: https://mirrors2.manjaro.org/stable/$repo/$arch``
5: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch``
6: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch``
7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch``
8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch``
Processes:
CPU top:5 of 485
1: cpu:14.1%command:firefoxpid:6362mem:454.1 MiB (1.9%)
2: cpu:7.4%command:konsolepid:167593mem:238.5 MiB (1.0%)
3: cpu:3.2%command:firefoxpid:6183mem:1410.1 MiB (5.9%)
4: cpu:2.8%command:chromepid:166360mem:243.9 MiB (1.0%)
5: cpu:2.5%command:zshpid:167642mem:10.3 MiB (0.0%)
Memory top:5 of 485
1: mem:1410.1 MiB (5.9%)command:firefoxpid:6183cpu:3.2%
2: mem:999.4 MiB (4.1%)command:plasmashellpid:1426cpu:1.2%
3: mem:608.9 MiB (2.5%)command:firefoxpid:6528cpu:0.5%
4: mem:454.1 MiB (1.9%)command:firefoxpid:6362cpu:14.1%
5: mem:424.9 MiB (1.7%)command:firefoxpid:6396cpu:0.6%
Processes:485Power: uptime:11h 43mstates:freeze,mem,disk
suspend:s2idlewakeups:0hibernate:platformavail:shutdown, reboot,
suspend, test_resumeimage:9.28 GiBservices:org_kde_powerdevil,
power-profiles-daemon, upowerdInit:systemdv:257default:graphical
tool:systemctl
Compilers: clang:20.1.8gcc:15.2.1Shell:Zshv:5.9running-in:konsole
inxi: 3.3.39
