I use OpenDNS to filter content for the family … which worked just fine until my ISP decided to operate with Dynamic IP instead of Static IP. I have followed all the suggested methods i can find on the net regarding ddclient and NetworkManager, as well as that suggested by OpenDNS Support, to no avail …
changes in IP are not transferred to OpenDNS!
Any suggestions on how i might trouble shoot this problem. Thanks
KDE Plasma Version: 5.26.4
KDE Frameworks Version: 5.101.0
Qt Version: 5.15.7
Kernel Version: 6.0.15-1-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-2500 CPU @ 3.30GHz
Memory: 15.5 GiB of RAM
There should be no correlation between IP and DNS (but you can assign a DNS resolver for a given interface). If you want to use OpenDNS as a resolver, simply put its IP to /etc/resolv.conf, remove the others. sudo chattr +i /etc/resolv.conf afterwards to prevent changes by other apps. Verify with resolvectl status.
Using an upstream resolver to filter bad content has nothing to do with your public IP as provided by your ISP.
Dynamic DNS however is completely different and is used to be able to access your home network from outside using a custom domain name.
An update script will be initiated from inside your network - thus revealing your public IP to the DDNS service which then assign that IP a predefined custom domain.
I guess they are paying for the service, so you must give them your IP that they can authenticate.
With a roaming IP, this is not possible. Could you ask their customer support what to do on this case?
After digging my old OpenDNS account up and checking - there is indeed a need to let OpenDNS know about any changes in the IP because OpenDNS offers individual filtering including whitelisting domans otherwise blocked.
My above comment on broadcasting your IP change to OpenDNS service still stands. You need configure according to provider instruction - especially username and password.
EDIT2:
I am sure the instructions worked for the author.
Just remember that the last line in the config is the label of the network you created in your OpenDNS dashboard.
And you may need to run the ddclient.service manually at least once to update your dnsomatic opendns service
sudo systemctl start ddclient.service
The changes needed may vary depending on which resolver you use.
I guess if the issue is (to this point he didn’t clarify anything, the thread makes no sense) about how to configure services to synchronize the ISP IP with other services, like an OpenDNS customer account, then he already has the solution, he posted the link to it.
The reason i could not get the ddclient script to update OpenDNS with my changing IP was because of the password i was using. As it turns out the password to log on to OpenDNS cannot contain an ampersand if updating one’s IP address via ddclient!!
HOWEVER, when changing the password manually at OpenDNS the user is forced to add a ‘special character’ … and the ampersand is suggested as being valid!!
I have since provided this feedback and while one still needs to use a ‘special character’ in their logon password they have removed reference that the Ampersand is valid.
In any case, to prevent this issue ever occurring again I have requested and been given a STATIC IP address from my ISP.
No more need to update a changing IP address with OpenDNS anymore!!!
