SSD heating
Hi all,
I just installed ManjaroLinux 18.0.4 Illyria ('cat /etc/lsb-release') with XFCE and with 4.19.69 Kernel ('uname -r') on a MacBook Air 2013 -- I updated the packages and settled usual minor issues with broadcom drivers.
I have a problem that persists, namely that, 'sensors' gives me 'TH0a: +76.2°C' (I can also feel it on my legs) without any load ('top' shows that no swap is used, 1.79Gof free memory, and df -h shows more than 70G free space, same for 'iotop' or 'iostats').
I believe 'TH0a' refers to a sensor in my SSD (Apple SSD SD0128) and I believe the temperature is way too high -- especially if I compare it to the CPU temperature, which is 20° below).
Have you specific manips in mind that should be carried in order to address it? Let me know if you need more information.
Note: 1) Manjaro is the only OS installed on the MacBook (no dual boots). 2) Debian Stretch worked fine, a month before, on the very same laptop, 3) I can confirm that fans are working.
Thanks already!
NB.: I have to confess that I encountered a similar issue when upgrading from Debian Stretch to Buster, and that was the ultimate trigger for switching to Manjaro.
We are not in the mindreading business.
Please elaborate - and be specific on your request - what did you install?
I would recommend reading this
https://wiki.archlinux.org/index.php/Mac#Post-installation
and the dedicated thread here
https://bbs.archlinux.org/viewtopic.php?id=165899
Thanks. I partly did, before writing the post.
This being said, the first link does not say much about 'SSD' or 'Hard Drive' (besides for dual or triple boots, which is not my case) and the second link does not seem extremely relevant (beside it being slightly outdated, it seems to say nothing of heating SSDs).
If the SSD is warm then it is active.
There are various reasons why this might be happening.
For example:
  1. Numerous filesystems defer initialisation operations until a later time. This speeds up the initial "format" and lets the user get on with using the disk.
  2. An file indexer may be running, e.g. tracker or updatedb which is scanning the disk and its content.
You can check what is using your disk with iotop.
However, given you have experienced this already with a different distro it's most likely option 1.
Thread title edited to remove "with Manjaro" as this isn't a Manjaro-specific issue
Thanks for your answer.
Indeed, most processes displayed by 'iotop' show marginal reading, writing or IO ('0%' or '0 B/s' everywhere) -- this was for the second point I guess.
I am not sure how I should understand your understand your first point. What can be done about it?
If it's the filesystem then you simply have to wait.
There's nothing "to be done".
Maybe it is a kernel issue then. Have you tried older kernels?
Lack of cooling you should not use a laptop restricting the air flow. also the fan may by full of dust.
I will try other kernel, and post updates.
I tried manjaro with different Kernels: 4.19.69, 4.14.141, 4.9.190, 4.4.190. It seemed to heat, whenever the WiFi was working -- whenever the broadcom 4360 driver was installed.
I reinstalled completely Manjaro, and noted that, when the install was fresh, no updates done and no wifi working, the ssd temperature was good (between 40 and 60 with normal load) -- now I remember that the issues started when I updated the fresh install and installed broadcom-wl (following advices found there: BCM4360 - No wifi in Manjaro Illyria)
Does it sound possible?
The wl drivers have been working better on the newer kernels. I would test out kernels 5.2 and 5.3.
Wifi drivers have been known to create many strange side effects. Broadcom drivers have many strange quirks.
Did you test the brcmfmac kernel driver?
See:
https://wiki.archlinux.org/index.php/Broadcom_wireless
It would be best if you could post your system specs:
inxi -Fxxxz
So it's not the SSD which is heating up, it's the wifi being active which is creating heat.
A number of wifi chipsets are known to create heat so this sounds plausible.
gives:
  Host: touki-pc Kernel: 4.19.28-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: Xfce 4.13.2git-UNKNOWN tk: Gtk 3.24.3 info: xfce4-panel
  wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
  Type: Laptop System: Apple product: MacBookAir6,2 v: 1.0 serial: <filter>
  Chassis: type: 10 v: Mac-7DF21CB3ED6977E5 serial: <filter>
  Mobo: Apple model: Mac-7DF21CB3ED6977E5 v: MacBookAir6,2 serial: <filter>
  UEFI: Apple v: MBA61.88Z.0099.B20.1509081314 date: 09/08/2015
  ID-1: BAT0 charge: 33.8 Wh condition: 33.1/54.3 Wh (61%) volts: 8.3/7.6
  model: SMP bq20z451 type: Li-ion serial: N/A status: Charging cycles: 1212
  Topology: Dual Core model: Intel Core i5-4250U bits: 64 type: MT MCP
  arch: Haswell rev: 1 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15204
  Speed: 800 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0a26
  Display: x11 server: X.Org 1.20.4 driver: intel unloaded: modesetting
  alternate: fbdev,vesa tty: N/A
  OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.3.4
  compat-v: 3.0 direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
  v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0 chip ID: 8086:9c20
  Device-3: Broadcom and subsidiaries 720p FaceTime HD Camera
  driver: bdc-pci bus ID: 02:00.0 chip ID: 14e4:1570
  Sound Server: ALSA v: k4.19.28-1-MANJARO
  Device-1: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network
  Adapter
  vendor: Apple driver: bcma-pci-bridge v: N/A port: efa0 bus ID: 03:00.0
  chip ID: 14e4:43a0
  IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 113.00 GiB used: 47.71 GiB (42.2%)
  ID-1: /dev/sda vendor: Apple model: SSD SD0128F size: 113.00 GiB
  speed: 6.0 Gb/s serial: <filter> rev: 821 scheme: GPT
  ID-1: / size: 110.43 GiB used: 47.71 GiB (43.2%) fs: ext4 dev: /dev/sda2
  System Temperatures: cpu: 60.0 C mobo: N/A
  Processes: 186 Uptime: 20h 29m Memory: 3.79 GiB used: 1.76 GiB (46.4%)
  Init: systemd v: 241 Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0
  running in: xfce4-terminal inxi: 3.0.32
I am not sure the "brcmfmac" supports the "bcm-4360". I can indeed try more recent kernel.
At the very least you should update your system. It may even be fixed in a newer version of the same kernel series.
I already did -- and it didn't not do anything, rather it was correlated with heating.
This were the specs of a fresh install that is not heating.
I don't think that updating is related to enabling your wifi - you said you updated and installed a wifi driver.
Have you looked through the other threads about this wifi chip:
https://forum.manjaro.org/search?q=BCM4360
I did. I followed the procedure in one of the post.
Initially : 1) I installed Manjaro, 2) I updated, 3) I installed the WiFi, 4) it started heating, 5) I installed other kernels (previous and next) and it seemed keeping heating whenever the broadcom WiFi kept working (without needing reinstallation, after having switch to another kernel).
I guess will now update Illyrio and see what happens, then I will tinker with broadcom drivers ans see what happens.
It's also worth disabling the wifi connection to narrow that down as the cause.
Is it possible you disabled wifi power saving from a recommendation in a help thread. Disabling wifi power saving helps with connectivity problems, but could possibly contribute to an overtemp condition.
