Hi, i can’t find the ss command on the repositories, do you know something about ?
The /usr/bin/ss
executable is owned by the package iproute2
Check if you have that package installed:
pacman -Qs iproute2
If there is no output, install iproute2
(sudo pacman -Syu iproute2
) and run the ss
command from a terminal window.
for find a file in packages (not installed)
sudo pacman -Fy # for update local database
pacman -F "ss"
