Is there anyway to disable AVRCP absolute volume on pipewire? In pulseaudio you can with avrcp_absolute_volume=false
in default.pa
Never mind, I’ve found the settings for it.
The equivalent settings is bluez5.enable-hw-volume = false
in bluez-monitor.conf
The configuration template is located in /usr/share/pipewire/media-session.d/bluez-monitor.conf
Copy it to either /etc/pipewire/media-session.d/bluez-monitor.conf
(for system-wide configuration) or ~/.config/pipewire/media-session.d/bluez-monitor.conf
(for user-specific configuration).
