spyder start ✔
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 573, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 891, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 782, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (mccabe 0.7.0 (/usr/lib/python3.10/site-packages), Requirement.parse('mccabe<0.7.0,>=0.6.0'), {'flake8'})
During handling of the above exception, another exception occurred:
File "/usr/bin/spyder", line 33, in <module>
sys.exit(load_entry_point('spyder==5.2.0', 'gui_scripts', 'spyder')())
File "/usr/bin/spyder", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 162, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/usr/lib/python3.10/site-packages/spyder/app/start.py", line 47, in <module>
from spyder.utils.external import lockfile
File "/usr/lib/python3.10/site-packages/spyder/utils/external/lockfile.py", line 31, in <module>
from spyder.utils.programs import is_spyder_process
File "/usr/lib/python3.10/site-packages/spyder/utils/programs.py", line 28, in <module>
import pkg_resources
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3266, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3240, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3278, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 575, in _build_master
return cls._build_from_requirements(__requires__)
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 588, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
Check the comments in this bug report:
There is a mention to a workaround that you can try.
Thank you a lot!!
