I have Manjaro installed on a 500GB SSD but have all my data on a 4TB HDD. I have created symbolic links in my $HOME directory linking to folders on the HDD.
I am trying to import my Music folder contents to Spotify. When I try to enter the path “/run/media/username/drivename/foldername/Music” I get an error, “Error when getting information for file “/run/media/username/drivename/foldername”: No such file or directory”
When I click on File System and select the run directory, it only displays the following folders: flatpak, host, systemd, user.
I haven’t had to “hack” config files and permissions in ages, so I’m a bit rusty. Any help would be appreciated.
The method you linked worked perfectly! I had to import the gpg key to get makepkg to work, but I now have Spotify working and reading compatible local files.
