Whenever the laptops goes to sleep, be it because of prolonged inactivity or by pressing the sleep button, the moment the lights turn off, they turn back on instantly and show the log in page.
Here are my laptop specs:
Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=c0b7a99b-f9c9-49a0-9421-a744ae0f2d61 rw rootflags=subvol=@
quiet splash udev.log_priority=3 gpio_ich.use_gpio=0
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
wm: kwin_wayland with: Docker vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 83LT v: Legion Pro 5 16ADR10
serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ADR10
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_83LT_BU_idea_FM_Legion Pro 5 16ADR10
uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: RLCN32WW
date: 11/25/2025
ID-1: BAT0 charge: 30.7 Wh (37%) condition: 83/80 Wh (103.7%) power: 81.1 W
volts: 16.01 min: 15.52 model: COSMX L24X4PC0 type: Li-poly serial: <filter>
charging: status: charging type: standard avail: long_life,standard
cycles: 11
Device-1: apple_mfi_fastcharge_1-2 model: N/A serial: N/A charge: N/A
status: N/A
System RAM: total: 32 GiB available: 30.64 GiB used: 5.42 GiB (17.7%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Cxmt part-no: CXMR4E816S6AS-CN1C serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 8745HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1490 min/max: 404/5153 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1490 2: 1490 3: 1490
4: 1490 5: 1490 6: 1490 7: 1490 8: 1490 9: 1490 10: 1490 11: 1490 12: 1490
13: 1490 14: 1490 15: 1490 16: 1490 bogomips: 114982
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 595.71.05 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0
chip-ID: 10de:2d59 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Lenovo
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 54.0 C
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30c9:00f8
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung ATNA60HS03-0 built: 2024 res:
mode: 2560x1600 hz: 165 scale: 125% (1.25) to: 2048x1280 dpi: 191 gamma: 1.2
chroma: red: x: 0.682 y: 0.318 green: x: 0.220 y: 0.725 blue: x: 0.141
y: 0.039 white: x: 0.314 y: 0.329 size: 340x220mm (13.39x8.66")
diag: 405mm (15.94") modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
640x480
EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
112
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:164e
memory: 500 MiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 26.0.6-arch1.1
device-ID: 1002:164e surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 5060 Laptop GPU driver: nvidia v: 595.71.05
device-ID: 10de:2d59 surfaces: N/A
Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22eb class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
and here are the logs that are shown when I run
sudo journalctl -b -0 --since "5 minutes ago" -f
მაი 05 22:16:13 lcim systemd-logind[747]: The system will suspend now!
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Demoting known real-time threads.
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.1365] manager: sleep: sleep requested (sleeping: no enabled: yes)
მაი 05 22:16:13 lcim ModemManager[805]: <msg> [sleep-monitor-systemd] system is about to suspend
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.1365] device (enp4s0): state change: unavailable -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
მაი 05 22:16:13 lcim ModemManager[805]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
მაი 05 22:16:13 lcim vivaldi-stable[3388]: [3460:3466:0505/221613.137830:ERROR:chromium/net/socket/ssl_client_socket_impl.cc:924] handshake failed; returned -1, SSL error code 1, net_error -331
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1606 of process 1594.
მაი 05 22:16:13 lcim vivaldi-stable[3388]: [3380:3417:0505/221613.138097:ERROR:chromium/google_apis/gcm/engine/connection_factory_impl.cc:483] ConnectionHandler failed with net error: -2
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1594 of process 1594.
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1384 of process 1373.
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1373 of process 1373.
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1377 of process 1372.
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Successfully demoted thread 1372 of process 1372.
მაი 05 22:16:13 lcim rtkit-daemon[1380]: Demoted 6 threads.
მაი 05 22:16:13 lcim kwin_wayland[1306]: Failed to delay sleep: The operation inhibition has been requested for is already running
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.1431] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.1432] manager: NetworkManager state is now DISABLED (ASLEEP)
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.1434] device (wlo1): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
მაი 05 22:16:13 lcim systemd[1]: Starting Network Manager Script Dispatcher Service...
მაი 05 22:16:13 lcim systemd[1]: Started Network Manager Script Dispatcher Service.
მაი 05 22:16:13 lcim kernel: wlo1: deauthenticating from 78:44:76:ce:14:14 by local choice (Reason: 3=DEAUTH_LEAVING)
მაი 05 22:16:13 lcim wpa_supplicant[878]: nl80211: send_event_marker failed: Source based routing not supported
მაი 05 22:16:13 lcim wpa_supplicant[878]: wlo1: CTRL-EVENT-DISCONNECTED bssid=78:44:76:ce:14:14 reason=3 locally_generated=1
მაი 05 22:16:13 lcim wpa_supplicant[878]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
მაი 05 22:16:13 lcim wpa_supplicant[878]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.3670] device (wlo1): supplicant interface state: completed -> disconnected
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.3672] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.3674] dhcp4 (wlo1): canceled DHCP transaction
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.3674] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.3675] dhcp4 (wlo1): state changed no lease
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.4142] device (wlo1): set-hw-addr: set MAC address to 3A:04:89:D4:7A:D7 (scanning)
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.4947] device (wlo1): state change: disconnected -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
მაი 05 22:16:13 lcim NetworkManager[742]: <info> [1778004973.5709] device (wlo1): set-hw-addr: reset MAC address to 44:F7:9F:5E:19:99 (unmanage)
მაი 05 22:16:13 lcim wpa_supplicant[878]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
მაი 05 22:16:13 lcim wpa_supplicant[878]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
მაი 05 22:16:13 lcim wpa_supplicant[878]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
მაი 05 22:16:13 lcim systemd[1]: Reached target Sleep.
მაი 05 22:16:13 lcim systemd[1]: Starting NVIDIA system suspend actions...
მაი 05 22:16:13 lcim systemd[1]: nvidia-suspend.service: Skipped due to 'exec-condition'.
მაი 05 22:16:13 lcim systemd[1]: Condition check resulted in NVIDIA system suspend actions being skipped.
მაი 05 22:16:13 lcim systemd[1]: Starting System Suspend...
მაი 05 22:16:13 lcim systemd-sleep[4202]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
მაი 05 22:16:13 lcim systemd-sleep[4202]: This is not recommended, and might result in unexpected behavior, particularly
მაი 05 22:16:13 lcim systemd-sleep[4202]: in suspend-then-hibernate operations or setups with encrypted home directories.
მაი 05 22:16:13 lcim systemd-sleep[4202]: Performing sleep operation 'suspend'...
მაი 05 22:16:13 lcim kernel: PM: suspend entry (deep)
მაი 05 22:16:14 lcim kernel: Filesystems sync: 0.052 seconds
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/ldac
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/aptx_hd
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aptx_hd
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/aac
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aac
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/opus_g
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/opus_g
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/sbc
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/sbc
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aptx_ll_1
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aptx_ll_0
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/faststream
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/faststream_duplex
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/opus_05
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/opus_05
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSink/opus_05_duplex
მაი 05 22:16:14 lcim bluetoothd[744]: Endpoint unregistered: sender=:1.103 path=/MediaEndpoint/A2DPSource/opus_05_duplex
მაი 05 22:16:14 lcim kded6[1479]: No object for name "alsa_input.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:14 lcim plasmashell[1527]: No object for name "alsa_input.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:14 lcim kded6[1479]: No object for name "alsa_output.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:14 lcim plasmashell[1527]: No object for name "alsa_output.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:14 lcim kded6[1479]: No object for name "@DEFAULT_SINK@"
მაი 05 22:16:14 lcim kded6[1479]: No object for name "@DEFAULT_SOURCE@"
მაი 05 22:16:14 lcim plasmashell[1527]: No object for name "@DEFAULT_SINK@"
მაი 05 22:16:14 lcim plasmashell[1527]: No object for name "@DEFAULT_SOURCE@"
მაი 05 22:16:14 lcim kwin_wayland[1306]: Failed to open drm node: "/dev/dri/card0"
მაი 05 22:16:14 lcim vivaldi-stable[3388]: [4253:4253:0505/221614.084309:ERROR:chromium/base/memory/shared_memory_switch.cc:289] Failed global descriptor lookup: 7
მაი 05 22:16:14 lcim kernel: nvidia 0000:01:00.0: Enabling HDA controller
მაი 05 22:16:22 lcim kernel: Freezing user space processes
მაი 05 22:16:22 lcim kernel: Freezing user space processes completed (elapsed 0.001 seconds)
მაი 05 22:16:22 lcim kernel: OOM killer disabled.
მაი 05 22:16:22 lcim kernel: Freezing remaining freezable tasks
მაი 05 22:16:22 lcim kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
მაი 05 22:16:22 lcim kernel: printk: Suspending console(s) (use no_console_suspend to debug)
მაი 05 22:16:22 lcim kernel: queueing ieee80211 work while going to suspend
მაი 05 22:16:22 lcim kernel: ACPI: EC: interrupt blocked
მაი 05 22:16:22 lcim kernel: ACPI: PM: Preparing to enter system sleep state S3
მაი 05 22:16:22 lcim kernel: ACPI: EC: event blocked
მაი 05 22:16:22 lcim kernel: ACPI: EC: EC stopped
მაი 05 22:16:22 lcim kernel: ACPI: PM: Saving platform NVS memory
მაი 05 22:16:22 lcim kernel: Disabling non-boot CPUs ...
მაი 05 22:16:22 lcim kernel: smpboot: CPU 15 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 14 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 13 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 12 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 11 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 10 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 9 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 8 is now offline
მაი 05 22:16:22 lcim kernel: Spectre V2 : Update user space SMT mitigation: STIBP off
მაი 05 22:16:22 lcim kernel: smpboot: CPU 7 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 6 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 5 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 4 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 3 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 2 is now offline
მაი 05 22:16:22 lcim kernel: smpboot: CPU 1 is now offline
მაი 05 22:16:22 lcim kernel: ACPI: PM: Low-level resume complete
მაი 05 22:16:22 lcim kernel: ACPI: EC: EC started
მაი 05 22:16:22 lcim kernel: ACPI: PM: Restoring platform NVS memory
მაი 05 22:16:22 lcim kernel: AMD-Vi: Virtual APIC enabled
მაი 05 22:16:22 lcim kernel: LVT offset 0 assigned for vector 0x400
მაი 05 22:16:22 lcim kernel: Enabling non-boot CPUs ...
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
მაი 05 22:16:22 lcim kernel: CPU1 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
მაი 05 22:16:22 lcim kernel: CPU2 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
მაი 05 22:16:22 lcim kernel: CPU3 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
მაი 05 22:16:22 lcim kernel: CPU4 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
მაი 05 22:16:22 lcim kernel: CPU5 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
მაი 05 22:16:22 lcim kernel: CPU6 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
მაი 05 22:16:22 lcim kernel: CPU7 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
მაი 05 22:16:22 lcim kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
მაი 05 22:16:22 lcim kernel: CPU8 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#9, should never happen.
მაი 05 22:16:22 lcim kernel: CPU9 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#10, should never happen.
მაი 05 22:16:22 lcim kernel: CPU10 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#11, should never happen.
მაი 05 22:16:22 lcim kernel: CPU11 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#12, should never happen.
მაი 05 22:16:22 lcim kernel: CPU12 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#13, should never happen.
მაი 05 22:16:22 lcim kernel: CPU13 is up
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#14, should never happen.
მაი 05 22:16:22 lcim kernel: CPU14 is up
მაი 05 22:16:22 lcim com.docker.backend[1781]: [18:16:22.408272280Z][main.ipc ] (d63a3d2d-3) c632a1de-BackendAPI S<-C f09c8b99-time GET /time
მაი 05 22:16:22 lcim kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
მაი 05 22:16:22 lcim com.docker.backend[1781]: [18:16:22.408406446Z][main.ipc ] (d63a3d2d-3) c632a1de-BackendAPI S->C f09c8b99-time GET /time (130.603µs): 2026-05-05 22:16:22.408369639 +0400 +04 m=+87.232247525
მაი 05 22:16:22 lcim kernel: Spurious APIC interrupt (vector 0xFF) on CPU#15, should never happen.
მაი 05 22:16:22 lcim kernel: CPU15 is up
მაი 05 22:16:22 lcim kernel: ACPI: PM: Waking up from system sleep state S3
მაი 05 22:16:22 lcim kernel: ACPI: EC: interrupt unblocked
მაი 05 22:16:22 lcim kernel: nvidia 0000:01:00.0: Enabling HDA controller
მაი 05 22:16:22 lcim kernel: ACPI: EC: event unblocked
მაი 05 22:16:22 lcim kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: PSP is resuming...
მაი 05 22:16:22 lcim kernel: nvme nvme0: D3 entry latency set to 10 seconds
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
მაი 05 22:16:22 lcim kernel: nvme nvme0: 16/0/0 default/read/poll queues
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: SMU is resuming...
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: SMU is resumed successfully!
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: kiq ring mec 2 pipe 1 q 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x05002F00
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
მაი 05 22:16:22 lcim kernel: amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
მაი 05 22:16:22 lcim kernel: usb 5-1: reset high-speed USB device number 2 using xhci_hcd
მაი 05 22:16:22 lcim kernel: OOM killer enabled.
მაი 05 22:16:22 lcim kernel: Restarting tasks: Starting
მაი 05 22:16:22 lcim kernel: Restarting tasks: Done
მაი 05 22:16:22 lcim kernel: efivarfs: resyncing variable state
მაი 05 22:16:22 lcim kernel: efivarfs: finished resyncing variable state
მაი 05 22:16:22 lcim kernel: random: crng reseeded on system resumption
მაი 05 22:16:23 lcim bluetoothd[744]: Controller resume with wake event 0x0
მაი 05 22:16:23 lcim kernel: PM: suspend exit
მაი 05 22:16:23 lcim systemd-sleep[4202]: System returned from sleep operation 'suspend'.
მაი 05 22:16:23 lcim systemd[1]: systemd-suspend.service: Deactivated successfully.
მაი 05 22:16:23 lcim systemd[1]: Finished System Suspend.
მაი 05 22:16:23 lcim systemd[1]: systemd-suspend.service: Consumed 3.415s CPU time over 5.728s wall clock time, 20.6M memory peak.
მაი 05 22:16:23 lcim systemd[1]: Stopped target Sleep.
მაი 05 22:16:23 lcim systemd[1]: Reached target Suspend.
მაი 05 22:16:23 lcim systemd-logind[747]: Operation 'suspend' finished.
მაი 05 22:16:23 lcim ModemManager[805]: <msg> [sleep-monitor-systemd] system is resuming
მაი 05 22:16:23 lcim systemd[1]: Starting NVIDIA system resume actions...
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.1884] manager: sleep: wake requested (sleeping: yes enabled: yes)
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.1884] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
მაი 05 22:16:23 lcim systemd[1]: Stopped target Suspend.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Resuming known real-time threads.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1606 of process 1594 owned by '1000' RT at priority 20.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1594 of process 1594 owned by '1000' high priority at nice level -11.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1384 of process 1373 owned by '1000' RT at priority 20.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1373 of process 1373 owned by '1000' high priority at nice level -11.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1377 of process 1372 owned by '1000' RT at priority 20.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Successfully made thread 1372 of process 1372 owned by '1000' high priority at nice level -11.
მაი 05 22:16:23 lcim rtkit-daemon[1380]: Resumed scheduling 6 threads.
მაი 05 22:16:23 lcim kernel: Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
მაი 05 22:16:23 lcim systemd[1]: nvidia-resume.service: Skipped due to 'exec-condition'.
მაი 05 22:16:23 lcim systemd[1]: Condition check resulted in NVIDIA system resume actions being skipped.
მაი 05 22:16:23 lcim wireplumber[1373]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/ldac
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/aptx_hd
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aptx_hd
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/aac
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aac
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/opus_g
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/opus_g
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/sbc
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/sbc
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aptx_ll_1
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aptx_ll_0
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/faststream
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/faststream_duplex
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/opus_05
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/opus_05
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSink/opus_05_duplex
მაი 05 22:16:23 lcim bluetoothd[744]: Endpoint registered: sender=:1.111 path=/MediaEndpoint/A2DPSource/opus_05_duplex
მაი 05 22:16:23 lcim kded6[1479]: No object for name "auto_null"
მაი 05 22:16:23 lcim kded6[1479]: No object for name "@DEFAULT_SOURCE@"
მაი 05 22:16:23 lcim plasmashell[1527]: No object for name "auto_null"
მაი 05 22:16:23 lcim plasmashell[1527]: No object for name "@DEFAULT_SOURCE@"
მაი 05 22:16:23 lcim kded6[1479]: No object for name "alsa_output.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:23 lcim kded6[1479]: No object for name "alsa_input.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:23 lcim plasmashell[1527]: No object for name "alsa_output.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:23 lcim plasmashell[1527]: No object for name "alsa_input.pci-0000_05_00.6.analog-stereo"
მაი 05 22:16:23 lcim kdeconnectd[1763]: Failed to open any MDNS client sockets
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.3681] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
მაი 05 22:16:23 lcim kernel: r8169 0000:04:00.0 enp4s0: Link is Down
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.3867] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
მაი 05 22:16:23 lcim NetworkManager[742]: <warn> [1778004983.3867] device (p2p-dev-wlo1): error setting IPv4 forwarding to '1': Resource temporarily unavailable
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.3868] manager: NetworkManager state is now CONNECTED_LOCAL
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4150] device (wlo1): supplicant interface state: internal-starting -> disconnected
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4151] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4152] Wi-Fi P2P device controlled by interface wlo1 created
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4153] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/9)
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4154] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
მაი 05 22:16:23 lcim NetworkManager[742]: <warn> [1778004983.4154] device (p2p-dev-wlo1): error setting IPv4 forwarding to '1': Resource temporarily unavailable
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4160] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
მაი 05 22:16:23 lcim NetworkManager[742]: <info> [1778004983.4162] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim ModemManager[805]: <wrn> [plugin-manager] task 8,wlo1: error when checking support with plugin 'generic': (generic) Missing port probe for port (net/wlo1)
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5905] policy: auto-activating connection 'DACHI' (8d7928f1-d3d1-4dee-a267-ba16eaded50d)
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5909] device (wlo1): Activation: starting connection 'DACHI' (8d7928f1-d3d1-4dee-a267-ba16eaded50d)
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5910] device (wlo1): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5911] manager: NetworkManager state is now CONNECTING
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5912] device (wlo1): state change: prepare -> config (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5913] device (wlo1): Activation: (wifi) access point 'DACHI' has security, but secrets are required.
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5913] device (wlo1): state change: config -> need-auth (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5914] sup-iface[1f81a82cbbae07e2,4,wlo1]: wps: type pbc start...
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5922] device (wlo1): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: WPS-PBC-ACTIVE
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5923] device (wlo1): state change: prepare -> config (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] device (wlo1): Activation: (wifi) connection 'DACHI' has security, and secrets exist. No new secrets needed.
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'ssid' value 'DACHI'
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'scan_ssid' value '1'
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'bgscan' value 'simple:30:-70:86400'
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'auth_alg' value 'OPEN'
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.5924] Config: added 'psk' value '<hidden>'
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: WPS-CANCEL
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.6611] device (wlo1): supplicant interface state: disconnected -> scanning
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.6611] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: SME: Trying to authenticate with 78:44:76:ce:14:14 (SSID='DACHI' freq=2412 MHz)
მაი 05 22:16:25 lcim kernel: Bluetooth: hci0: Opcode 0x0401 failed: -16
მაი 05 22:16:25 lcim kernel: wlo1: authenticate with 78:44:76:ce:14:14 (local address=44:f7:9f:5e:19:99)
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.7608] device (wlo1): supplicant interface state: scanning -> authenticating
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.7608] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
მაი 05 22:16:25 lcim kernel: wlo1: send auth to 78:44:76:ce:14:14 (try 1/3)
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: Trying to associate with 78:44:76:ce:14:14 (SSID='DACHI' freq=2412 MHz)
მაი 05 22:16:25 lcim kernel: wlo1: authenticated
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.7656] device (wlo1): supplicant interface state: authenticating -> associating
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.7656] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
მაი 05 22:16:25 lcim kernel: wlo1: associate with 78:44:76:ce:14:14 (try 1/3)
მაი 05 22:16:25 lcim kernel: wlo1: RX AssocResp from 78:44:76:ce:14:14 (capab=0x411 status=0 aid=6)
მაი 05 22:16:25 lcim kernel: wlo1: associated
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: Associated with 78:44:76:ce:14:14
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8230] device (wlo1): supplicant interface state: associating -> 4way_handshake
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8230] device (p2p-dev-wlo1): supplicant management interface state: associating -> 4way_handshake
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: WPA: Key negotiation completed with 78:44:76:ce:14:14 [PTK=CCMP GTK=CCMP]
მაი 05 22:16:25 lcim wpa_supplicant[878]: wlo1: CTRL-EVENT-CONNECTED - Connection to 78:44:76:ce:14:14 completed [id=0 id_str=]
მაი 05 22:16:25 lcim wpa_supplicant[878]: bgscan simple: Failed to enable signal strength monitoring
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8726] device (wlo1): supplicant interface state: 4way_handshake -> completed
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8726] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DACHI"
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8727] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8729] device (wlo1): state change: config -> ip-config (reason 'none', managed-type: 'full')
მაი 05 22:16:25 lcim NetworkManager[742]: <info> [1778004985.8732] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
მაი 05 22:16:27 lcim ModemManager[805]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:03:00.0': not supported by any plugin
მაი 05 22:16:27 lcim ModemManager[805]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:03.3/0000:04:00.0': not supported by any plugin
მაი 05 22:16:27 lcim kernel: input: Yoga Pro Mouse as /devices/virtual/misc/uhid/0005:17EF:619F.0008/input/input41
მაი 05 22:16:27 lcim kernel: input: Yoga Pro Mouse Keyboard as /devices/virtual/misc/uhid/0005:17EF:619F.0008/input/input42
მაი 05 22:16:27 lcim kernel: input: Yoga Pro Mouse as /devices/virtual/misc/uhid/0005:17EF:619F.0008/input/input43
მაი 05 22:16:27 lcim kernel: input: Yoga Pro Mouse as /devices/virtual/misc/uhid/0005:17EF:619F.0008/input/input44
მაი 05 22:16:27 lcim kernel: hid-generic 0005:17EF:619F.0008: input,hidraw4: BLUETOOTH HID v0.01 Mouse [Yoga Pro Mouse] on 44:f7:9f:5e:19:9a
მაი 05 22:16:28 lcim systemd-logind[747]: Watching system buttons on /dev/input/event20 (Yoga Pro Mouse Keyboard)
მაი 05 22:16:28 lcim systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
მაი 05 22:16:29 lcim systemd[1]: Starting Network Manager Script Dispatcher Service...
მაი 05 22:16:29 lcim systemd[1]: Started Network Manager Script Dispatcher Service.
მაი 05 22:16:39 lcim systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
მაი 05 22:16:39 lcim kded6[1479]: Failed to notify "Created too many similar notifications in quick succession"
მაი 05 22:16:43 lcim bluetoothd[744]: src/profile.c:record_cb() Unable to get QBluetoothSocket-1763 SDP record: Host is down
What might be the cause of these wakeups?
