Sorry for the delay in getting back to you!
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=6c2c293d-fac0-49eb-889e-82f89ed81b47 rw quiet
cryptdevice=UUID=713c9504-15dd-413d-bed1-2e38b389b84f:luks-713c9504-15dd-413d-bed1-2e38b389b84f
root=/dev/mapper/luks-713c9504-15dd-413d-bed1-2e38b389b84f splash
resume=/dev/mapper/luks-3a3eb2c7-7f7b-4ee4-ac4c-cb363e3f0df0
udev.log_priority=3
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy avail: swayidle dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASRock model: AB350 Pro4 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P8.02
date: 02/06/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: discharging
System RAM: total: 32 GiB available: 31.27 GiB used: 4.9 GiB (15.7%)
(unregistered) size: 8 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2B3200C16 serial: N/A
part-no: CMK16GX4M2L3000C15 serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1861 min/max: 2200/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1861 2: 1861 3: 1861
4: 1861 5: 1861 6: 1861 7: 1861 8: 1861 9: 1861 10: 1861 11: 1861 12: 1861
bogomips: 86430
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2
bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 34.0 C
Device-2: Polycom Poly Studio P5 webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1:4 chip-ID: 095d:9296
class-ID: 0300 serial: <filter>
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Idek Iiyama PL2288H serial: <filter> built: 2019
res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.651 y: 0.353 green:
x: 0.322 y: 0.631 blue: x: 0.153 y: 0.051 white: x: 0.314 y: 0.329
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900,
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 640x480,
720x400
Monitor-2: HDMI-A-1 model: Idek Iiyama PL2288H serial: <filter>
built: 2019 res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.651
y: 0.353 green: x: 0.322 y: 0.631 blue: x: 0.153 y: 0.051 white: x: 0.314
y: 0.329 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
(radeonsi polaris10 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO)
device-ID: 1002:67df memory: 7.81 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.303 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 480 Graphics (RADV POLARIS10) driver: N/A device-ID: 1002:67df
surfaces: xcb,xlib,wayland
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: kscreen-doctor
gpu: corectrl,radeontop wl: swaymsg x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock
bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Polycom Poly Studio P5 webcam
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
IF-ID-1: br-63704af50e44 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: global
IF-ID-4: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0a2b
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
Device-1: luks-713c9504-15dd-413d-bed1-2e38b389b84f maj-min: 254:0
type: LUKS dm: dm-0 size: 896.81 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 896.82 GiB
Device-2: luks-3a3eb2c7-7f7b-4ee4-ac4c-cb363e3f0df0 maj-min: 254:1
type: LUKS dm: dm-1 size: 34.4 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 34.4 GiB
Local Storage: total: 2.61 TiB used: 2.22 TiB (85.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR021 temp: 35.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3250310AS
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: A scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: KC45 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS120 X rev: FL02
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 896.81 GiB size: 881.66 GiB (98.31%)
used: 825.46 GiB (93.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-713c9504-15dd-413d-bed1-2e38b389b84f label: N/A
uuid: 6c2c293d-fac0-49eb-889e-82f89ed81b47
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F1F5-9E98
ID-3: /mnt/big_n_slow raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 824.45 GiB (90.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Big n slow uuid: 30545173-fb41-416d-9a83-6b776c784f11
ID-4: /mnt/hdd raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 450.77 GiB (96.8%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: hdd
uuid: 2CBED554BED51764
ID-5: /mnt/things_and_stuff raw-size: 232.38 GiB
size: 232.38 GiB (100.00%) used: 174.02 GiB (74.9%) fs: ntfs dev: /dev/sdb2
maj-min: 8:18 label: Things and Stuff uuid: 9E6877ED6877C297
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-3a3eb2c7-7f7b-4ee4-ac4c-cb363e3f0df0 label: swap
uuid: 26cbad25-cef3-4996-811e-68d51e28a7ee
ID-1: /dev/sdd1 maj-min: 8:49 size: 111.79 GiB fs: ext4 label: N/A
uuid: 0d56eb84-5306-4479-bcec-d053098ce6b0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Device-3: 1-10:4 info: SHARKOON GmbH Keyboard type: keyboard,HID
driver: semitek,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1ea7:0907 class-ID: 0300
serial: <filter>
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:4 info: Polycom Poly Studio P5 webcam
type: video,audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 095d:9296 class-ID: 0300 serial: <filter>
Device-2: 3-3:3 info: C-Media Blue Snowball type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 34.8 C mobo: 29.0 C gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1620 fan-3: 0 fan-4: 747 fan-5: 760
gpu: amdgpu fan: 724
Power: 12v: N/A 5v: N/A 3.3v: 3.22 vbat: 3.28 gpu: amdgpu watts: 16.10
Packages: 2390 pm: pacman pkgs: 2230 libs: 536
tools: gnome-software,pamac,paru pm: flatpak pkgs: 160
1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
3: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://linorg.usp.br/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 439
1: cpu: 21.2% command: gnome-software pid: 2177 mem: 489.9 MiB (1.5%)
2: cpu: 17.1% command: signal-desktop pid: 2934 mem: 576.6 MiB (1.8%)
3: cpu: 15.3% command: librewolf pid: 3484 mem: 590.0 MiB (1.8%)
4: cpu: 9.4% command: gnome-shell pid: 1941 mem: 417.8 MiB (1.3%)
5: cpu: 7.0% command: librewolf pid: 3801 mem: 363.2 MiB (1.1%)
Memory top: 5 of 439
1: mem: 590.0 MiB (1.8%) command: librewolf pid: 3484 cpu: 15.3%
2: mem: 578.8 MiB (1.8%) command: telegram-desktop pid: 2658 cpu: 1.2%
3: mem: 576.6 MiB (1.8%) command: signal-desktop pid: 2934 cpu: 17.1%
4: mem: 489.9 MiB (1.5%) command: gnome-software pid: 2177 cpu: 21.2%
5: mem: 417.8 MiB (1.3%) command: gnome-shell pid: 1941 cpu: 9.4%
Processes: 439 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: gsd-power,upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: blackbox inxi: 3.3.37
I had another crash today
[ 0.785996] [Hardware Error]: System Fatal error.
[ 0.786006] [Hardware Error]: CPU:0 (17:1:1) MC5_STATUS[-|UE|MiscV|AddrV|PCC|TCC|SyndV|-|-|-]: 0xbea0000000000108
[ 0.786025] [Hardware Error]: Error Addr: 0x0001ffffb04cb084
[ 0.786031] [Hardware Error]: IPID: 0x000500b000000000, Syndrome: 0x000000004d000000
[ 0.786040] [Hardware Error]: Execution Unit Ext. Error Code: 0
[ 0.786042] [Hardware Error]: cache level: RESV, tx: GEN, mem-tx: GEN
[ 3.670963] hid-generic 0003:0D8C:0005.0004: No inputs registered, leaving
[ 17.060357] Bluetooth: hci0: Reading supported features failed (-16)
I’ll have a look at the XMP now, thank you
