Try to use clonezilla or any other disk cloning software from a live ISO boot and clone the whole disk. Afterwards boot without the old HDD disk beeing connected. It could be required to assign the SSD as boot device in your firmware.
Sorry I wasn’t more clear. I want to replace the Manjaro install on the dual boot HDD (*which is old and outdated) with the newer, up-to-date Manjaro install that is installed stand alone on the SSD.
So the SSD, has ample space and an up-to-date Manjaro install. I have room to partition the remaining space on the SSD and add the Windows install from the HDD, but didn’t know if there are specific caveats with this.
[david@david-pc ~]$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=ce7f22f1-b420-4c0b-af47-de7841dda8ed / ext4 defaults,noatime 0 1
UUID=a143b1f8-f9fe-4b13-b5e4-fa4045542c7c swap swap defaults,noatime 0 2
/data/Music /srv/nfs/Music none bind 0 0
server01:/nfs/music /data/music nfs auto,x-systemd.automount,x-systemd.device-
timeout=10,timeo=14,x-systemd.idle-timeout=1min 0 0
OK here we go. So let’s summarize your plan:
You want to migrate Windoze to the SSD and contiue to use the existing Manjaro installed on the SSD. I think you only can keep your Manjaro on the SSD if you get it shrinked to place it temporary on the HDD (or to another backup location of course). If that’s right then I would do the following:
Backup!!
Make sure you have a live ISO ready with GParted and clonezilla
Boot into live ISO
Delete the not further used partition /dev/sdb7 (old Linux system)
Make as much as possible space available on /dev/sdb
Shrink /dev/sda1 as much as possible
Verifiy if you could copy /dev/sda1 to the free space on /dev/sdb
8a) If that’s not possible - sorry my suggestion won’t work!
8b) If copying is possible, then proceed with copying /dev/sda1 to /dev/sdb
Delete the swap partiton entry from your /etc/fstab
I doubt this would work, as a Windoze clone usually only works if it sits exactly at the same sectors as it was and also partition table should be identical etc. Hard to achieve by clonezilla I guess if you leave the Manjaro partiton.
Ahh dang, well thanks. There is no way I can fit the new Manjaro partition from the ssd into the old Manjaro install on the HDD. Too big of a size difference. (40gb vs 180 gb).
Wollie, I took a second look and I had an adjacent partition that I was able to delete to make room for the Manjaro install (from the SSD). Here is what I’ve done so far:
-Cloned the HDD with Dual Boot Windows and (older) Manjaro(X) and verified it’s function
-Removed the adjacent partition on the above, and expanded the Manjaro(X) partition to allow
adequate room for the Manjaro(A) install I desire from the SSD.
Mounted the Manjaro(X) partition using a live environment and deleted all of it’s contents
Copied all the contents of Manjaro(A) partition from the SSD to the emptied partition of the HDD
Once it’s all copied over, going to put the newly copied drive over and see if it boots, and functions as desired. If so I’ll then clone it to the SSD.
So copying the partition did not work, as I suspected it might not.
I will clone Manjaro(A) on the SSD, resize, then clone the resized partition to the new partition on the HDD. Once I confirm it’s working, I’ll clone the whole shabang to the SSD.
