Spinning wheel graphic damaged at login
Hello,
after logging into the system, the basic user avatar appears on the spinning wheel during loading. Additionally, after logging in, the volume bar immediately appears on the desktop. How can I fix this problem?
Mod edit:- A brief description is sufficient to not warrant inclusion of screenshots. Images removed – Save the Server!
We know nothing about your system.
Not what Desktop Environment, not what display manager, not what theme you applied to either one, not what startup applications or scripts are set …
So, trying to answer the question as it stands is not possible and would amount to pure speculation.
Indeed; the results of inxi -zv8 would be a good start. :wink:
(Please use proper code formatting). :smiley:
@KernelPanic
I’m forced to agree. Without sufficient supporting information provided, we enter the realm of vague guesswork, at best.
My immediate guesses include;
  • Broken theme configuration or file(s).
  • Manjaro was installed without first checking the ISO for consistency; a damaged may result in problems that are impossible to predict, despite the OS installation completing without issue.
Please provide (at minimum) the requested system information as described (below). There you will also find a link to instructions for expected formatting and other important information, including Forum Rules.
Note:- Topic title changed to correct spelling and enhance search results. Change it again to include the Desktop Environment that you use; please also add that DE as an optional tag. :eyes:
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
System is after full clean reinstall with KDE. Everything standard from installer.
After changing X11 to Wayland there is just black square instead of avatar image
Below output of inxi -zv8:
inxi -zv8         ✔
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=6de25dee-8d03-48cf-b0d8-b740a426fd32 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=131771e8-1b9e-4fd6-8510-f669aa3e102d:luks-131771e8-1b9e-4fd6-8510-f669aa3e102d
    root=/dev/mapper/luks-131771e8-1b9e-4fd6-8510-f669aa3e102d splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: A.D0 date: 04/28/2023
  System RAM: total: 32 GiB available: 31.27 GiB used: 2 GiB (6.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: IRX3200D464L16A/16G serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3392 min/max: 550/4468 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3392 2: 3392 3: 3392
    4: 3392 5: 3392 6: 3392 7: 3392 8: 3392 9: 3392 10: 3392 11: 3392 12: 3392
    bogomips: 84046
    xsaves xtopology
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: ASUSTeK
    driver: nouveau v: kernel non-free: 550-580.xx+ status: current (as of
    2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2b:00.0 chip-ID: 10de:24c9
    class-ID: 0300
    alternate: fbdev,vesa dri: zink gpu: nouveau display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) HDR WFHD serial: <filter>
    built: 2022 res: mode: 2560x1080 hz: 60 scale: 100% (1) dpi: 81 gamma: 1.2
    chroma: red: x: 0.651 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 798x334mm (31.42x13.15")
    diag: 869mm (34.2") modes: 2560x1080, 3840x2160, 2560x1440, 1920x1080,
    1680x1050, 1600x900, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768,
    832x624, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 89 2: parse_edid:
    unhandled CEA mode 90 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
  API: EGL v: 1.5 platforms: device: 0 drv: zink device: 1 drv: swrast gbm:
    drv: zink surfaceless: drv: zink wayland: drv: zink x11: drv: zink
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.2.3-arch1.2 glx-v: 1.4
    direct-render: yes renderer: zink Vulkan 1.4(NVIDIA GeForce RTX 3060 Ti
    (NVK GA104) (MESA_NVK)) device-ID: 10de:24c9 memory: 7.81 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti (NVK GA104) driver: mesa nvk v: 25.2.3-arch1.2
    device-ID: 10de:24c9 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.1 chip-ID: 10de:228b
    class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:8
    chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
  Device-4: Razer USA Barracuda X 2.4
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1:6 chip-ID: 1532:0552 class-ID: 0301
    serial: <filter>
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.1:4 chip-ID: 8087:0029
    class-ID: e001
  Device-1: luks-131771e8-1b9e-4fd6-8510-f669aa3e102d maj-min: 254:0
    type: LUKS dm: dm-0 size: 952.4 GiB
  Components:
  p-1: nvme0n1p1 maj-min: 259:7 size: 952.4 GiB
  Local Storage: total: 1.92 TiB used: 106.06 GiB (5.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Lexar model: SSD NM620 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN15023 temp: 30.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Lexar model: SSD NM620 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 9846 temp: 30.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Transcend model: JetFlash 64GB
    size: 56.32 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 1100 scheme: MBR
  ID-1: / raw-size: 952.4 GiB size: 952.4 GiB (100.00%)
    used: 105.58 GiB (11.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-131771e8-1b9e-4fd6-8510-f669aa3e102d label: N/A
    uuid: 6de25dee-8d03-48cf-b0d8-b740a426fd32
  ID-2: /boot raw-size: 1000 MiB size: 965.9 MiB (96.59%)
    used: 422.2 MiB (43.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:8
    label: N/A uuid: d4101b33-13a0-4b6b-8fd1-81f43bc2a8bc
  ID-3: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 69.7 MiB (14.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:9
    label: N/A uuid: 445A-6C69
  ID-4: /home raw-size: 952.4 GiB size: 952.4 GiB (100.00%)
  ID-5: /var/cache raw-size: 952.4 GiB size: 952.4 GiB (100.00%)
  ID-6: /var/log raw-size: 952.4 GiB size: 952.4 GiB (100.00%)
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 3AC4-C8E4
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 389.78 GiB fs: ntfs label: N/A
    uuid: 342CCB0F2CCACAD6
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 751 MiB fs: ntfs label: N/A
    uuid: B6308F0E308ED531
  ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 563.24 GiB fs: ntfs label: N/A
    uuid: A0B23A8CB23A66C6
  ID-6: /dev/sda1 maj-min: 8:1 size: 56.32 GiB fs: vfat label: Transcend
    uuid: 6970-3E91
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-2.1:4 info: Intel AX200 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-2.4:6 info: Microsoft Xbox 360 Wireless Receiver for Windows
    type: <vendor specific> driver: xpad interfaces: 8 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 260mA
    chip-ID: 045e:0291 class-ID: ff00
  Hub-3: 1-4:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 1-5:5 info: Logitech M185 compact wireless mouse type: mouse
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
  Device-2: 1-7:7 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
    serial: <filter>
  Device-3: 1-9:8 info: Creative Pebble V3 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
  Device-4: 1-10:9 info: Logitech G213 Prodigy Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 2-4:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  Device-1: 2-4.3:3 info: Transcend Information JetFlash type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 304mA chip-ID: 8564:1000 class-ID: 0806
    serial: <filter>
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:6 info: Razer USA Barracuda X 2.4 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    chip-ID: 1532:0552 class-ID: 0301 serial: <filter>
  Device-2: 3-3:2 info: SteelSeries ApS Rival 3 type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:184c class-ID: 0300
  Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 36.4 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1486 pm: pacman pkgs: 1475 libs: 465 tools: pamac pm: flatpak
    pkgs: 11
    1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: https://repos.silknet.com/manjaro/stable/$repo/$arch
    3: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    4: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    5: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    6: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    8: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    9: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    10: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    12: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    13: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    14: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    15: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    16: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    17: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    18: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    19: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    20: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    21: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    22: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    23: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    25: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    26: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    27: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    28: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    29: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    30: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    31: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    32: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    33: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    34: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    35: https://mirror.init7.net/manjaro/stable/$repo/$arch
    36: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    37: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    38: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    39: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    41: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    42: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    43: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    44: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    45: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    46: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    47: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    48: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    49: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    50: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    51: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    52: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    53: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    54: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    55: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    56: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    57: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    58: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    59: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    60: https://manjaro.kurdy.org/stable/$repo/$arch
    61: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    62: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    64: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    65: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    66: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    67: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    68: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    69: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    70: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    71: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    72: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    73: http://manjaro.grena.ge/stable/$repo/$arch
    74: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    75: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    76: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    77: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    78: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    79: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    80: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    81: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    82: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    83: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    84: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    85: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    86: https://mirror.23m.com/manjaro/stable/$repo/$arch
    87: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    88: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    89: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    90: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    91: https://mirrors2.manjaro.org/stable/$repo/$arch
    92: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    93: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    95: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    96: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    97: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    98: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    99: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    100: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    101: http://manjaro.mirror.ac.za/stable/$repo/$arch
    102: https://manjaro.ynh.ovh/stable/$repo/$arch
    103: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    104: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    105: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    106: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    107: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    108: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    109: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    111: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    112: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    113: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    114: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    115: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    116: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    117: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    118: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    119: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    120: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    121: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    122: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    123: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    124: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    125: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    126: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    127: https://linorg.usp.br/manjaro/stable/$repo/$arch
    128: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    129: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    130: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    131: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    132: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    133: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    134: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    135: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 342
  1: cpu: 12.1% command: konsole pid: 5294 mem: 263.3 MiB (0.8%)
  2: cpu: 6.4% command: firefox pid: 4771 mem: 612.4 MiB (1.9%)
  3: cpu: 6.2% command: firefox pid: 5016 mem: 336.4 MiB (1.0%)
  4: cpu: 5.6% command: zsh pid: 5312 mem: 11.9 MiB (0.0%)
  5: cpu: 3.7% command: kwin_wayland pid: 4232 mem: 313.8 MiB (0.9%)
  Memory top: 5 of 342
  1: mem: 612.4 MiB (1.9%) command: firefox pid: 4771 cpu: 6.4%
  2: mem: 475.4 MiB (1.4%) command: plasmashell pid: 4424 cpu: 1.6%
  3: mem: 336.4 MiB (1.0%) command: firefox pid: 5016 cpu: 6.2%
  4: mem: 313.8 MiB (0.9%) command: kwin_wayland pid: 4232 cpu: 3.7%
  5: mem: 263.3 MiB (0.8%) command: konsole pid: 5294 cpu: 12.1%
  Processes: 342 Power: uptime: 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
Just so I have this right the avatar isn’t displayed in the few seconds between logging in and displaying the KDE desktop?
Does the login screen display the avatar correctly?
The login is handled by SDDM, then once logged in your are passed over to X or Wayland desktop. A web search for “sddm not displaying avatar” shows MANY similar issues but I’m not entirely sure that is where your problem is.
Can you describe where it appears? Is it the popup from the notification panel? Does it disappear by itself or do you have to do something? Can you interact with it?
I can’t help with the user avatar issue, but the volume OSD (on-screen display) should be easily fixable. Just open System Settings → Sound and remove the ticks from the “Show OSD popups for changes to:” section:
No, thing is that after you give password on login screen normally there is a spinning wheel under manjaro logo (loading spining circle). With my bug there is also spining avatar image. I added screenshot of it, because its very unusual, but mod deleted it. Gonna try to send it one more time, especially there are questions about it.
Assistant edit:
removed the picture once again - uploaded it to a sharing platform, where it will be available for 5 days from now via the following link:
forumpic — Postimages
It pops out on the center of screen, couple centimeters above taskbar. Disappear by itself just normal when volume is changed. Can interact with it, and its not very annoying. Mentioned it just to give some hint.
Yesterday i had two freezes, something about 30-45 minutes after system start. Everything stopped except mouse arrow and music played from speakers. Maybe thats a clue
Thanks for the answer, but expect that unusual start pop out I want that notifications. I mentioned about it just to give a little clue
The picture you posted
(which I replaced with a link to some image sharing platform where it is now hosted for the next 5 days)
shows a customized installation.
This is not the standard theme which is present with a fresh install.
It is not unlikely that your issue is caused by an incompatible theme … :man_shrugging:
Please do the following, and then reboot; Go to:
System SettingsAppearance & StyleColours & ThemesSplash Screen
Change the Splash screen from whatever it is now, to something else – perhaps “Breeze” or “None”.
Reboot and see if that helps. If not, then do the same as before but choose Login Screen (SDDM) (instead of Splash Screen)…
Set your login screen to “Breeze”, or in any case, something different from whatever is currently selected, then reboot.
Lastly, if neither of the above steps helped, change your global theme to one of the defaults.
Let us know if any of these helped.
I trully didn’t change it. Until now, I didn’t even know it could be changed.
Its with manjaro installer, on previous instalation worked fine.
That helped, thanks a lot.
Is there any possibility to fix that “breath” splash screen? I cant delete it to make reinstall
That is odd :wink:
I just three hours ago did an installation using the most recent Manjaro Plasma (minimal) edition -
and that is definitely not the theme or display manager background it comes with.
That picture isn’t even available in the standard selection this edition comes with by default.
That is why I concluded that yours is not an unaltered fresh installation. :man_shrugging:
So I had to change it randomly, sorry for deception.
Hmm … no, you didn’t have to -
but you did. :grin:
Whenever you go for something that isn’t already there by default - when you click: “get new” or something to that effect - you might be getting incompatible stuff.
There is a clear warning message in orange at the top of that window when you go that route:
Use caution when accessing user-created content shown here, as it may contain executable code that hasn’t been tested by KDE or Manjaro Linux for safety, stability, or quality.
I suggest you go back to defaults and then see whether your issue persists …
ps:
I just removed your solution mark from (your own) post number 12 here
since it is unclear how this was your solution to your problem
… it might have been the solution - but it wasn’t yours … :wink:
Glad I could help.
The “Breath” splash screen is part of a (default) global theme – I don’t know if it can be easily removed/replaced – certainly it can’t be while it is in use.
However, I imagine it might be replaced as a matter of course with the next “big update” that includes the next KDE version; but, please don’t ask “when” that will be; all I could tell you is “soon(ish)”.
That being the case, wait until then and try switching back to the Breath splash screen to see if it’s fixed.
