Hey everyone,
I need some help figuring out how to get the OS to discover the bluetooth controller. It is visible using lsusb but for some reason it is not visible using bluetoothctl. It has worked fine in the past and does not work since updating. I tried different kernels (6.1, 6.2, 5.15) but the issue persists.
lsusb | grep -i bluetooth
Bus 005 Device 005: ID 8087:0025 Intel Corp. Wireless-AC 9260 Bluetooth Adapter
sudo systemctl status bluetooth ξ² β
β bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-04-12 21:02:09 CEST; 3min 59s ago
Docs: man:bluetoothd(8)
Main PID: 1440 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 38394)
Memory: 2.3M
CPU: 16ms
CGroup: /system.slice/bluetooth.service
ββ1440 /usr/lib/bluetooth/bluetoothd
Apr 12 21:02:09 ms7b85 systemd[1]: Starting Bluetooth service...
Apr 12 21:02:09 ms7b85 (uetoothd)[1440]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Apr 12 21:02:09 ms7b85 bluetoothd[1440]: Bluetooth daemon 5.66
Apr 12 21:02:09 ms7b85 bluetoothd[1440]: Starting SDP server
Apr 12 21:02:09 ms7b85 systemd[1]: Started Bluetooth service.
Apr 12 21:02:09 ms7b85 bluetoothd[1440]: Bluetooth management interface 1.21 initialized
sudo dmesg | grep -i bluetooth
[ 5.490785] Bluetooth: Core ver 2.22
[ 5.490802] NET: Registered PF_BLUETOOTH protocol family
[ 5.490803] Bluetooth: HCI device and connection manager initialized
[ 5.490806] Bluetooth: HCI socket layer initialized
[ 5.490808] Bluetooth: L2CAP socket layer initialized
[ 5.490809] Bluetooth: SCO socket layer initialized
[ 5.901444] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.901446] Bluetooth: BNEP filters: protocol multicast
[ 5.901448] Bluetooth: BNEP socket layer initialized
[ 7.704346] Bluetooth: hci0: Reading Intel version command failed (-110)
[ 7.704346] Bluetooth: hci0: command 0xfc05 tx timeout
bluetoothctl
Agent registered
[bluetooth]# scan on
No default controller available
[bluetooth]# list
[bluetooth]#
Any help would be very much appreciated, thanks!
