Spectre Meltdown checker
I get an update for spectre-meltdown-checker nearly every day.
What is going on?
Do you have the AUR (or some other) version installed?
pacman -Qi spectre-meltdown-checker
I guess the new apocalyptic CPU vulnerabilities are added to it, so it requires updates.
There has been a lot of updates lately but I can only assume it’s been more actively maintained. The question is, would you rather they provide timely updates or not? Personally I prefer security type updates to come as fast as possible.
@ ydar The fact that there are timely updates is fine. I just wanted to know what was going on. It’s no biggie.
@ cscs Just standard from Extras
@ mithrial All good then
There has been one about two weeks ago, there was one yesterday, and there was another one today.
Considering that this is a security-related package, any update to the package gets pushed out immediately as it becomes available. :wink:
Hi, I found this topic interesting so I checked my installation of spectre-meltdown-checker. For some reason it is installed via the Official Repositories and AUR. If I try to remove the AUR version it also removes the Official Repositories version.
Here’s the results of pacman -Qi spectre-meltdown-checker on my system:
Version         : 0.46+10+gc1c1ac4-1
Description     : Zenbleed, ZombieLoad, RIDL, Fallout, Foreshadow, Spectre, Meltdown vulnerability/mitigation
                  checker
Architecture    : any
URL             : https://github.com/speed47/spectre-meltdown-checker
Licenses        : GPL3
Groups          : None
Provides        : None
Depends On      : sh  sqlite
Optional Deps   : None
Required By     : None
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 268.03 KiB
Packager        : Mark Wagie <mark@manjaro.org>
Build Date      : Thu 10 Aug 2023 10:02:47 AM EDT
Install Date    : Fri 11 Aug 2023 09:25:57 AM EDT
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
That’s the official Manjaro repo version. The AUR version has version number 0.46-1. But if you have it installed twice, then maybe you’ve added another repo to your /etc/pacman.conf — Chaotic AUR perhaps?
Either way, package repository issues are a separate topic, so if you have more problems with that, then I recommend starting a new thread. :wink:
So when can we expect the kernels with those exploits fixed in stable?
I know they are already in testing, but its been a few days since the exploits became known. Not sure if i would put manjaro responding to them as “swiftly”.
It all depends on how serious those exploits are, by which I mean to what extent they would pose an imminent threat to a Manjaro system.
The next update will also include microcode, by the way.
The fixes should be in the respective microcode and not the kernel. It is not a bug on the kernel but CPU “drivers”.
It should be safe to install only this package from the testing branch, if you wish to do so.
