After the update Spectacle no more start from menu or shortcut: it send a notification that it cannot start the job.
Launching from a terminal works and the application remains open and can take more screenshot
Here the launch in Italian and English
[mirto@mostro ~]$ spectacle
spectacle: Unable to load Tesseract candidate "tesseract" : "Impossibile caricare la libreria tesseract: tesseract: impossibile aprire il file oggetto condiviso: File o directory non esistente"
spectacle: Unable to locate a suitable Tesseract shared library
spectacle: Tesseract runtime library not available
qt.qml.propertyCache.append: Member focusPolicy of the object UndoRedoGroup_QMLTYPE_52 overrides a member of the base object. Consider renaming it or adding final or override specifier
qt.qml.propertyCache.append: Member focusPolicy of the object ButtonGrid_QMLTYPE_56 overrides a member of the base object. Consider renaming it or adding final or override specifier
qt.qml.propertyCache.append: Member focusPolicy of the object AnnotationOptionsToolBarContents_QMLTYPE_102 overrides a member of the base object. Consider renaming it or adding final or override specifier
[mirto@mostro ~]$
[mirto@mostro ~]$
[mirto@mostro ~]$ LANG=C spectacle
Detected locale "LC_CTYPE=C;LC_NUMERIC=it_IT.UTF-8;LC_TIME=it_IT.UTF-8;LC_COLLATE=C;LC_MONETARY=it_IT.UTF-8;LC_MESSAGES=C;LC_PAPER=it_IT.UTF-8;LC_NAME=it_IT.UTF-8;LC_ADDRESS=it_IT.UTF-8;LC_TELEPHONE=it_IT.UTF-8;LC_MEASUREMENT=it_IT.UTF-8;LC_IDENTIFICATION=it_IT.UTF-8" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
spectacle: Unable to load Tesseract candidate "tesseract" : "Cannot load library tesseract: tesseract: cannot open shared object file: No such file or directory"
qt.qml.propertyCache.append: Member focusPolicy of the object ButtonGrid_QMLTYPE_92 overrides a member of the base object. Consider renaming it or adding final or override specifier
qt.qml.propertyCache.append: Member focusPolicy of the object UndoRedoGroup_QMLTYPE_94 overrides a member of the base object. Consider renaming it or adding final or override specifier
qt.qml.propertyCache.append: Member focusPolicy of the object AnnotationOptionsToolBarContents_QMLTYPE_105 overrides a member of the base object. Consider renaming it or adding final or override specifier
[mirto@mostro ~]$
It complains that the Tesseract shared library is missing
Anyone have the same problem?
[mirto@mostro ~]$ LANG=C kinfo
KDE Plasma Version: 6.6.5
KDE Frameworks Version: 6.26.0
Qt Version: 6.11.1
Kernel Version: 7.0.10-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 32 × AMD Ryzen 9 5950X 16-Core Processor
Memory: 128 GiB of RAM (125.7 GiB usable)
Graphics Processor: AMD Radeon RX 6700 XT
[mirto@mostro ~]$ uname -a
Linux mostro 7.0.10-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun, 24 May 2026 04:47:00 +0000 x86_64 GNU/Linux
[mirto@mostro ~]$
