Currently Spectacle is segfaulting on launch. I’m running 24.0.1, all up to date. Running Wayland. I get this message popping up in a notification window when I press prnt scr:
Message recipient disconnected from the message bus without replying.
I see some similar issues where Plasma applications are segfaulting:
As other users suggest I’ve tried removing files in .local, .cache and .config having anything to do with “kde”, “plasma”, or “spectacle”. Uninstalled and reinstalled Spectacle. Rebooted my computer. Still get segfault on launch.
dmesg shows:
[ 658.607537] Thread (pooled)[5115]: segfault at d8 ip 00007f0a5983cab4 sp 00007f0a355f7d78 error 4 in libX11.so.6.4.0[7f0a5982d000+8b000]
[ 658.607543] Code: 84 00 00 00 00 00 f3 0f 1e fa 8b 47 1c c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 8b 47 74 c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 87 d8 00 00 00 c3 0f 1f 40 00 f3 0f 1e fa 48 63 f6 48 c1 e6
I don’t see anything particularly helpful from running the app with gdb.
Any ideas how I can get screenshots working again? Unlike these other threads I linked to, other Plasma/QT apps are working fine for me, it appears to be just Spectacle that’s broken.
Update: Spectacle does work when I reboot into X11 instead of Wayland. That’s not ideal, but good to know I have a workaround.
Quite strange - as spectacle work on my systems - I am guessing the only difference is our branches.
Spectacle version 24.05.0-1 is the defacto state of spectacle also upstream.
With relation to a plasma reset - it seems you have tried everything.
The only idea left is that - if your housecleaning was done inside a plasma session - as opposed to logging off and switch to a TTY - plasma may have cached configs which is then written to disk - with the settings causing the crash.
This is pure speculation.
I would log out - switch to a TTY - login as my user - remove the ~/.cache and the spectacle related files.
file ~/.config/spectaclerc
folder ~/.local/share/spectacle
Then refresh user-space
systemctl soft-reboot
Login and retry the screenshot
testing and unstable branches is update more frequently than stable.
Looking at announce
stable snap at May 29.
testing snap at June 3.
unstable had several syncs since - latest today - but nothing that seems to be related to spectacle - plasma-workspace is the only candidate.
I also still cannot get it to work while in a Wayland session. I’m using Plasma 6.1.4, Spectacle 24.05.2-1
Spectacle not working in Wayland isn’t a big deal for me since I primarily use X11 right now; but I was curious if other screenshot apps work, and I found Flameshot works.
Something I was going to recommend, at least as a temporary workaround until what I assume is a bug in the currently-used kernel is fixed (I had issues with one of the 6.6 series, albeit unrelated). Certainly worth testing with another kernel e.g. linux61 LTS.
I had to install option 1. because I am (currently at least) on x11. I tried wayland and though it worked, I concluded there were heaps of settings I needed to do to make it look they way I like it. I though: “some other day.” Lazy old dog, you know.
“recordmydesktop” needs some settings, so read all about it in man. Good tool, works fine.
Option 2. might also be used: https://www.vlchelp.com/how-to-record-desktop/
I’ve tried it for fun and though it works for me, I couldn’t get the mouse pointer trick working (supply the full path to the image if you want to try).
No audio either, but that could be me not knowing how to set it up properly. Like I said, just tried it for fun.
