Hi, maybe any one could help. I’m trying to use spectacle as a gui screenshot tool because I’m used to it. However today I have an Issue and its not launching at all both by clicking and running it on terminal. I’m looking as well for other alternatives of spectacle which you might be recommending without too much adjustments.
Here is the main error when launching it on terminal
No protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though
it was found.
This application failed to start because no Qt platform plugin could be initi
alized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscree
n, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx,
xcb.
[1] 5497 abort (core dumped) spectacle
Here is log for qt debug
QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/qt/plugins/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqeglfs.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqeglfs.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"eglfs"
"archreq": 0,
"className": "QEglFSIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("eglfs")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqlinuxfb.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqlinuxfb.so, metadata=
"MetaData": {
"Keys": [
"linuxfb"
"archreq": 0,
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqminimal.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"archreq": 0,
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqminimalegl.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqminimalegl.so, metadata=
"MetaData": {
"Keys": [
"minimalegl"
"archreq": 0,
"className": "QMinimalEglIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("minimalegl")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqoffscreen.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"archreq": 0,
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqvnc.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqvnc.so, metadata=
"MetaData": {
"Keys": [
"vnc"
"archreq": 0,
"className": "QVncIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("vnc")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqwayland-egl.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-egl"
"archreq": 0,
"className": "QWaylandEglPlatformIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("wayland-egl")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqwayland-generic.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-generic.so, metadata=
"MetaData": {
"Keys": [
"wayland"
"archreq": 0,
"className": "QWaylandIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("wayland")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-egl"
"archreq": 0,
"className": "QWaylandXCompositeEglPlatformIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("wayland-xcomposite-egl")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqwayland-xcomposite-glx.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-glx"
"archreq": 0,
"className": "QWaylandXCompositeGlxPlatformIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("wayland-xcomposite-glx")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/qt/plugins/platforms/libqxcb.so"
Found metadata in lib /usr/lib/qt/plugins/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"archreq": 0,
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 331520
Got keys from plugin meta data ("xcb")
QFactoryLoader::QFactoryLoader() checking directory path "/usr/bin/platforms"
