Special device does not exist, can't boot
  Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.10-x86_64 root=/dev/sda4 rw quiet
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 1 dm: LightDM v: 1.32.0
  Type: Desktop System: Shuttle product: DS81D v: V1.0
    serial: <superuser required>
  Mobo: Shuttle model: FS81 v: 1.0 serial: <superuser required> part-nu: 1.0
    uuid: <superuser required> UEFI: American Megatrends v: 3.14
    date: 09/17/2018
  System RAM: total: 16 GiB available: 15.51 GiB used: 3.33 GiB (21.5%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: curr: 2 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Crucial part-no: CT102464BF160B.C16
    serial: <filter>
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-4785T bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1496 min/max: 800/3200 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1496 2: 1496 3: 1496 4: 1496 5: 1496 6: 1496
    7: 1496 8: 1496 bogomips: 35131
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: DP-2,HDMI-A-1 empty: DP-1,
    HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-2 pos: right model: 100027813 serial: <filter> built: 2021
    res: 1920x1080 hz: 60 dpi: 80 gamma: 1.2 chroma: red: x: 0.651 y: 0.329
    green: x: 0.318 y: 0.620 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 609x348mm (23.98x13.7") diag: 690mm (27.2") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: 100094417
    serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    chroma: red: x: 0.651 y: 0.329 green: x: 0.318 y: 0.620 blue: x: 0.149
    y: 0.071 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0412 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 7 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.2.2-arch1.1
    device-ID: 8086:0412 surfaces: xcb,xlib
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
    class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Holco
    Enterprise Co /Shuttle driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
    vendor: Holco Enterprise Co /Shuttle driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF-ID-1: enp0s20u2u1u1 state: unknown speed: -1 duplex: half mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: T & A Mobile Phones TCL TAB 8 LE driver: rndis_host,usbfs
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1.1:7
    chip-ID: 1bbb:0173 class-ID: 0a00 serial: <filter>
  Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 3-6:5 chip-ID: 0a12:0001 class-ID: e001
  Report: ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6
    status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 1.43 TiB used: 890.24 GiB (60.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Fanxiang model: S301 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 195 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 model: USB DISK 3.0 size: 57.77 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
    scheme: MBR
  ID-1: / raw-size: 192.22 GiB size: 192.22 GiB (100.00%)
    used: 116.43 GiB (60.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: N/A
  ID-2: /boot raw-size: 1.3 GiB size: 1.25 GiB (95.88%)
    used: 319.8 MiB (25.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Boot
    uuid: d7c5b3f3-f6a2-46ea-a020-fc5e9aaf918b
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 54.1 MiB (10.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
    uuid: 0C5A-87F5
  ID-4: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 773.45 GiB (84.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: home
    uuid: bfa899b9-f545-4ead-a125-da3138006af5
  ID-1: swap-1 type: partition size: 31.52 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 2c99a5cd-a236-42fc-a710-770a98b1b5b3
  ID-1: /dev/sda3 maj-min: 8:3 size: 136.36 GiB fs: ntfs label: Windows 10
    uuid: 5208F48108F464FF
  ID-2: /dev/sda5 maj-min: 8:5 size: 15.38 GiB fs: ext4 label: Ubuntu
    uuid: 0ce37a6d-d76f-4599-ae2e-a701a9836721
  ID-3: /dev/sda7 maj-min: 8:7 size: 1.79 GiB fs: vfat label: N/A
    uuid: 80E5-D996
  ID-4: /dev/sda8 maj-min: 8:8 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdc1 maj-min: 8:33 size: 57.73 GiB fs: exfat label: Linux
    uuid: 4E21-0000
  ID-6: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 223C-F3F8
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Hub-6: 3-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Hub-7: 3-2.1:4 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Device-1: 3-2.1.1:7 info: T & A Mobile Phones TCL TAB 8 LE
    type: bluetooth,CDC-data driver: rndis_host,usbfs interfaces: 3 rev: 2.0
  Device-2: 3-5:3 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-3: 3-6:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-8: 3-7:8 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-8:9 info: Genesys Logic GL827L SD/MMC/MS Flash Card Reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 05e3:0723 class-ID: 0806
  Device-2: 3-10:10 info: Areson Corp 2.4G Wireless Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa10 class-ID: 0301
  Hub-9: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-10: 4-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Hub-11: 4-2.1:3 info: Hitachi ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
  Device-1: 4-2.3:4 info: Phison SP Mobile C31 (64GB) type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 13fe:6300 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 58.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 2374 libs: 589 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://mirrors2.manjaro.org/stable/$repo/$arch
    4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    9: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    14: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    15: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    17: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    19: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    25: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    26: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    28: https://mirror.init7.net/manjaro/stable/$repo/$arch
    29: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    31: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    32: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    33: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    34: https://manjaro.ynh.ovh/stable/$repo/$arch
    35: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    36: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    37: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    38: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    39: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    40: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    41: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    42: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    43: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    45: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    46: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    47: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    49: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    50: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    51: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    52: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    53: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    54: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    55: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    56: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    57: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 279
  1: cpu: 99.1% command: QtWebEngineProcess pid: 2479 mem: 319.3 MiB (2.0%)
  2: cpu: 56.9% command: falkon pid: 1768 mem: 472.5 MiB (2.9%)
  3: cpu: 21.5% command: QtWebEngineProcess pid: 2530 mem: 208.8 MiB (1.3%)
  4: cpu: 20.3% command: QtWebEngineProcess pid: 2504 mem: 208.4 MiB (1.3%)
  5: cpu: 15.5% command: scrcpy pid: 1815 mem: 113.2 MiB (0.7%)
  Memory top: 5 of 279
  1: mem: 497.7 MiB (3.1%) command: telegram-desktop pid: 2030 cpu: 0.3%
  2: mem: 472.5 MiB (2.9%) command: falkon pid: 1768 cpu: 56.9%
  3: mem: 423.5 MiB (2.6%) command: firefox pid: 1775 cpu: 2.4%
  4: mem: 319.3 MiB (2.0%) command: QtWebEngineProcess pid: 2479 cpu: 99.1%
  5: mem: 208.8 MiB (1.3%) command: QtWebEngineProcess pid: 2530 cpu: 21.5%
  Processes: 279 Power: uptime: 20m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.32
    running-in: xfce4-terminal inxi: 3.3.36
Thanks for the tip on fdisk. file -s /dev/sda4 still shows what I call the correct UUID which agrees with what gparted shows. fdisk is showing what I’ve been calling the wrong UUID. And grub-probe doesn’t even run now. The real cause I think is them being different. Which one is right. I think I can change the UUID in parted or was it gdisk.
[gnuorder-ds81d ~]# grub-probe /dev/sda4
grub-probe: error: failed to get canonical path of `dev'.
[gnuorder-ds81d ~]# pwd
/root
[gnuorder-ds81d ~]# fdisk -l /dev/sda -o +UUID
Disk /dev/sda: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: Fanxiang S301 51
Disklabel type: gpt
Disk identifier: 7A8D344F-38A6-4D0B-988C-8E4BD2D4999B
Device         Start        End   Sectors   Size Type                 UUID
/dev/sda1       2048    1050623   1048576   512M EFI System           9129381E-B041-4DE5-BD51-ED963C0DAD3F
/dev/sda2    1050624    3784703   2734080   1.3G Linux filesystem     7D4D6686-1379-49FF-A2FB-7E1A591ED60A
/dev/sda3    3784704  289748991 285964288 136.4G Microsoft basic data 16C37FB7-1D98-4354-A83E-83F0B5C166F1
/dev/sda4  289748992  692854783 403105792 192.2G Linux filesystem     4E18BE9D-1C64-41AF-8E57-E7CA2CF5B6EE
/dev/sda5  901859328  934119423  32260096  15.4G Linux filesystem     B336AB75-38FA-4E3D-8FAE-4C8961E8C838
/dev/sda6  934119424 1000214527  66095104  31.5G Linux swap           6536A947-D974-4855-A5BF-5E6F78C978DD
/dev/sda7  692854784  696604671   3749888   1.8G Microsoft basic data F708B1AD-27EA-4C95-8428-276429C47632
/dev/sda8  696604672  696637439     32768    16M Linux filesystem     FB665D61-0D49-429B-A720-0E8199C8B80C
Partition table entries are not in disk order.
[gnuorder-ds81d ~]# file -s /dev/sda4
/dev/sda4: BTRFS Filesystem label "Manjaro", sectorsize 4096, nodesize 16384, leafsize 16384, UUID=c29fdc05-ea12-4e06-8421-24cde767c946, 124826017792/206390165504 bytes used, 1 devices
I’d suggest using UUIDS as soon as practical - sudo blkid should find them easily enough.
Although it may be unlikely for the nodes to change, you will likely find yourself in trouble if you boot with another disk connected, or opt to multiboot with another OS (on a separate disk) at a future time.
That is all.
I plan to as soon as I sort this out. blkid still doesn’t show the btrfs UUID. File and fdisk show different UUIDs.
This, as of recently, is flagged as an EOL kernel. Run 6.11 if you want the latest.
Ignore grub-probe, it’s little use to most people except to dual boot Windows easily. You fix this by fixing the main issue(s). It is really a mash of bourne shell scripts that I find very finicky. I am surprised it even worked for you before with this setup.
I don’t like changing the actual partition UUID in cases like this unless I know for fact it changed, and I want it back. Are you certain the only reference to that UUID was in fstab? Plus it doesn’t find the root of the problem, which may or may not be solved.
It does. Did you check if your boot was mounted properly once inside the chroot? I know I’ve even run into that, and just had to mount the boot partition before manajro-chroot, even though it should work.
It’s late here.
To clarify, you have booted a live image, then done a sudo lsblk -f, and got the output from there? (And getting on a supported kernel might even help.)
inxi data shows BTRFS root partition /dev/sda4 has 0% free space and no UUID
    uuid: N/A
/dev/sda1 - vfat /boot/efi - 0.02% free space - uuid: 0C5A-87F5
/dev/sda2 - ext4 /boot - 4.2% free space - uuid: d7c5b3f3-f6a2-46ea-a020-fc5e9aaf918b
/dev/sdb1 - ext4 /home - 1.68% free space - uuid: bfa899b9-f545-4ead-a125-da3138006af5
I would suggest testing if this filesystem has no space left
(even if only 60% is used)
 sudo btrfs filesystem usage /
You find good Information about Btrfs in the wiki
I increased it’s size with gparted not long ago. df and gparted both say I have 75G free. So does your suggested command. I am going to have to learn more about btrfs.
[gnuorder@gnuorder-ds81d shared]$ sudo btrfs filesystem usage /
Overall:
    Device size:		 192.22GiB
    Device allocated:		 125.64GiB
    Device unallocated:		  66.58GiB
    Device missing:		     0.00B
    Device slack:		     0.00B
    Used:			 116.20GiB
    Free (estimated):		  74.95GiB	(min: 74.95GiB)
    Free (statfs, df):		  74.94GiB
    Data ratio:			      1.00
    Metadata ratio:		      1.00
    Global reserve:		 177.06MiB	(used: 0.00B)
    Multiple profiles:		        no
Data,single: Size:123.66GiB, Used:115.29GiB (93.23%)
   /dev/sda4	 123.66GiB
Metadata,single: Size:1.98GiB, Used:933.95MiB (46.14%)
   /dev/sda4	   1.98GiB
System,single: Size:4.00MiB, Used:64.00KiB (1.56%)
   /dev/sda4	   4.00MiB
Unallocated:
   /dev/sda4	  66.58GiB
I’m booted up now but from the live image it looked pretty much like this:
[gnuorder@gnuorder-ds81d ~]$ sudo lsblk -f
NAME   FSTYPE FSVER LABEL      UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat   FAT32 EFI        0C5A-87F5                             456.8M    11% /boot/efi
├─sda2 ext4   1.0   Boot       d7c5b3f3-f6a2-46ea-a020-fc5e9aaf918b  877.5M    25% /boot
├─sda3 ntfs         Windows 10 5208F48108F464FF
├─sda4        74.9G    61% /
├─sda5 ext4   1.0   Ubuntu     0ce37a6d-d76f-4599-ae2e-a701a9836721
└─sda6 swap   1                2c99a5cd-a236-42fc-a710-770a98b1b5b3                [SWAP]
sdb
└─sdb1 ext4   1.0   home       bfa899b9-f545-4ead-a125-da3138006af5  100.8G    84% /home
sdc
├─sdc1 exfat  1.0   Linux      4E21-0000
└─sdc2 vfat   FAT16 VTOYEFI    223C-F3F8
sdd
From in the chroot I would only get info on fsavail, fsuse, and mountpoint. sda4 has never shown a UUID. Same with blkid. The UUID that is in my fstab is the one I’ve used since installing. I have it commented out now.
How do I upgrade the kernal? I thought pamac did that. I upgraded not long ago using pamac and the gui software manager says I’m up to date.
Edit. Figured out the kernel upgrade. I don’t know if I want to do it now until I get this UUID thing figured out.
I found this which matches my situation. Of course no solution so I joined the redit and will ask. There is a btrfs tool to change the UUID but I’ll hold off on doing that. Also I’ll try the btrfs scrub.
https://www.reddit.com/r/btrfs/comments/v4sxzc/comment/ib8z0sy/
[gnuorder@gnuorder-ds81d ~]$ sudo  btrfs scrub start -Bd /
Starting scrub on devid 1
Scrub device /dev/sda4 (id 1) done
Scrub started:    Wed Oct 16 15:00:27 2024
Status:           finished
Duration:         0:04:33
Total to scrub:   116.20GiB
Rate:             435.86MiB/s
Error summary:    csum=2
  Corrected:      0
  Uncorrectable:  2
  Unverified:     0
ERROR: there are 1 uncorrectable errors
BTRFS volumes work much like Apple’s APFS in that the actual available space reported spans all volumes on the disk.
In this case, 75 GB is the amount available to the entire disk; every (BTRFS) volume thus indicates 75 GB because it is shared by all volumes, and not allocated per volume like a conventional filesystem (EXT4, HFS+, for NTFS for example).
To put this in perspective; say you have a 70 GB file; you copy that file to any partition shpwing 75 GB available; when the copy completes, every BTRFS file system on that disk will now show 5 GB available.
I’ve been using APFS for many years, but this concept still confuses me momentarily when moving back and forth between Manjaro and MacOS. :smile_cat:
I’m new to btrfs but I only have the one partition and haven’t added any volumes to it. I understand it also uses compression. I did resize it using gparted to make it larger. I don’t know if gparted also resizes the filesystem.
But when you do, at least you might better understand, if it seems strange at first.
I won’t offer any advice as such, because I’ve never actually used BTRFS myself; I simply understand some of the basics.
If I ever decide to use BTRFS no doubt that will change accordingly. :smile_cat:
Cheers.
Yes it does :+1:
for btrfs at least
:footprints:
That’s good to know. I seem to remember gparted giving a warning back when ntfs was fairly new saying you had to use ntfsresize after you resized with gparted.
Having this, without RAID or backups, would make me reinstall. Copy what you need off, and re-create the file system. You can actually see what files are affected in those bad chunks. But it does get a little more on the advanced side of btrfs most people never need. (Using btrfs inspect-internal to translate logical addresses, to inodes, to files.)
Especially given the situation, there’s also the chance of this still being faulty hardware. Btrfs is actually good at catching things like this. If you did remake the file system or reinstall, at least you will know for fact it’s your hardware if it happens again.
This should not happen at all ! :cry:
Well I found no answer. I’m going to reformat to ext4.
You had an answer…
There is a serious problem with your data. Yes, it needs to be rebuilt.
Ironically it was the built in btrfs checksumming that caught the problem before it could of have been something worse.
ext4 would have carried on, and had a chance of doing something much worse. (If this was any sort of hardware issue, you will find out soon enough.) But I would advise against it, especially given the circumstances.
In the link I gave earlier the method for using chroot with BTRFS is adequately described. If you now finally read that link you will discover the subtle differences between what is needed (for BTRFS) and the method that you used:
How this may have affected the outcome, I can’t say with certainty.
Probably for the best.
Cheers.
