Hi,
I’ve been reading through the forum and saw a similar subject (cannot link it it seems), but the solutions given in it were not working for me.
I have a Xiaomi notebook laptop, and every time I wake it up from sleep, the speakers are not working anymore and I need to reboot it. Also only the speakers are not working, when i try plugin in my earbuds, everything works just fine.
I tried re-scanning like in shared thread :
$ sudo su -
$ echo 1 > /sys/bus/pci/devices/0000:00:1f.3/remove
$ echo 1 > /sys/bus/pci/rescan
And it only works if something plugged in the jack port (my earbuds for example), otherwise the speakers don’t start working again.
Hardware info (sorry for the french !) :
$ aplay -l
**** Liste des périphériques matériels PLAYBACK ****
carte 0 : PCH [HDA Intel PCH], périphérique 0 : ALC256 Analog [ALC256 Analog]
Sous-périphériques : 0/1
Sous-périphérique #0 : subdevice #0
carte 0 : PCH [HDA Intel PCH], périphérique 3 : HDMI 0 [HDMI 0]
Sous-périphériques : 1/1
carte 0 : PCH [HDA Intel PCH], périphérique 7 : HDMI 1 [HDMI 1]
carte 0 : PCH [HDA Intel PCH], périphérique 8 : HDMI 2 [HDMI 2]
carte 0 : PCH [HDA Intel PCH], périphérique 9 : HDMI 3 [HDMI 3]
carte 0 : PCH [HDA Intel PCH], périphérique 10 : HDMI 4 [HDMI 4]
$ cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x9f804000 irq 147
And like in the previously mentioned subject I tried these commands :
systemctl --user disable --now pipewire.socket
systemctl --user disable --now pipewire.service
systemctl --user restart pulseaudio.service
and adding this script in /lib/systemd/system-sleep/99_restart_sound :
#!/bin/sh
case "$1" in
post)
DEVICE_ID=`lspci -D |grep Audio|awk '{print $1}'`
echo 1 > /sys/bus/pci/devices/${DEVICE_ID}/remove
sleep 1
esac
with :
sudo chmod +x /lib/systemd/system-sleep/99_restart_sound
But nothing worked so far, still no sound in my laptop’s speakers after waking up from sleep.
