[ARM Testing Update] 2022-09-22 - Buttermanager, Pipewire, Firefox and kernels
Hello ARM community.
Another testing update is ready to be tested!
Some highlights:
  • Most of our kernels got updated
  • Buttermanager updated to 2.5.0
  • Pipewire updated to 0.3.58
  • Firefox updated to 105.0
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Thu Sep 22 20:43:16 CEST 2022)
  • arm-testing community aarch64: 300 new and 278 removed package(s)
  • arm-testing core aarch64: 29 new and 25 removed package(s)
  • arm-testing extra aarch64: 298 new and 361 removed package(s)
  • arm-testing kde-unstable aarch64: 284 new and 284 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-09-16         2022-09-22
                       buttermanager              2.4.3-1              2.5.0-1
                                code             1.71.0-1             1.71.2-0
                        eg25-manager              0.4.4-2              0.4.5-1
                            electron             20.1.4-1             20.2.0-1
                         gnome-calls               42.0-1             43.0-0.1
               lipstick-glacier-home             0.37.6-1             0.37.7-2
                               phosh0.21.0+27+g3c1b8dae-10.21.0+32+g9afa49e6-1
            generic-efi-post-install                    -           20220918-1
      glacier-settings-developermode                    -              0.0.3-1
:: Different sync package(s) in repository community aarch64
                               acpid             2.0.33-1             2.0.34-1
                         adwaita-qt5              1.4.1-3              1.4.2-1
                         adwaita-qt6              1.4.1-3              1.4.2-1
                             allegro            5.2.8.0-1            5.2.8.0-2
                        ansible-lint              6.5.2-1              6.6.1-1
                             astroid               0.16-4               0.16-5
                            audacity            1:3.1.3-2            1:3.1.3-3
                       audacity-docs            1:3.1.3-2            1:3.1.3-3
                              awxkit             21.5.0-1             21.6.0-1
                                  b4              0.9.0-1             0.10.0-1
                          babel-core             7.19.0-1             7.19.1-1
                               bacon              2.2.1-1              2.2.3-1
                           bctoolbox             5.1.58-1             5.1.61-1
                          blackmagic              1.7.1-2              1.8.2-1
                             blender           17:3.3.0-2           17:3.3.0-3
                            blop.lv2              1.0.0-5              1.0.4-1
                               bzrtp             5.1.58-1             5.1.61-1
                             calibre              6.4.0-1              6.5.0-1
                    cargo-spellcheck             0.12.1-1             0.12.2-1
                         cargo-tauri              1.0.5-1              1.1.1-1
                              ccache              4.6.1-1              4.6.2-1
                              cclive             0.9.3-27             0.9.3-28
                              chrony                4.2-1                4.3-1
                             clojure        1.11.1.1155-1        1.11.1.1165-1
                                cmus             2.10.0-2             2.10.0-3
                             cockpit                276-1              276.1-1
                  cockpit-packagekit                276-1              276.1-1
                         cockpit-pcp                276-1              276.1-1
                    cockpit-storaged                276-1              276.1-1
                               copyq              6.2.0-3              6.3.0-1
                            corectrl              1.2.7-1              1.3.0-1
                           cpp-hocon             0.3.0-11             0.3.0-12
                               cryfs             0.11.2-4             0.11.2-5
                      cryptominisat5             5.8.0-10             5.8.0-11
                                dart             2.18.0-1             2.18.1-1
          deepin-qt5platform-plugins             5.0.65-2             5.0.66-1
                          difftastic             0.35.0-1             0.36.1-1
                      dns-over-https              2.3.1-1              2.3.2-1
                      docker-compose             2.10.2-1             2.11.1-1
                               doctl             1.79.0-1             1.81.0-1
                               eclib           20220621-2           20220621-3
                                 efl             1.26.2-1             1.26.3-1
                            efl-docs             1.26.2-1             1.26.3-1
                           espeak-ng             1.51.1-1             1.51.1-2
                           exploitdb           20220615-1           20220902-1
                              facter            3.14.24-1            3.14.24-2
               fcitx5-chinese-addons             5.0.15-1             5.0.15-2
                           filezilla             3.60.2-3             3.61.0-1
              firefox-tree-style-tab              3.9.2-1              3.9.5-1
               firefox-ublock-origin             1.44.2-1             1.44.4-1
                              flake8            1:5.0.0-1            1:5.0.4-1
                            fomp.lv2              1.0.0-5              1.2.4-1
                             freecad             0.20.1-6             0.20.1-7
                             freeciv              3.0.2-1              3.0.3-1
                             freecol             0.13.0-1             0.13.0-2
                                 gdu             5.17.1-1             5.18.1-1
                            gearmand           1.1.19.1-2           1.1.19.1-3
                           git-cliff              0.9.0-2              0.9.1-1
                               glob2           0.9.4.4-44           0.9.4.4-45
                                glom             1.32.0-9            1.32.0-10
                                gmtp             1.3.11-2             1.3.11-3
                            gnuradio           3.10.2.0-6           3.10.2.0-8
                  gnuradio-companion           3.10.2.0-6           3.10.2.0-8
                    gnuradio-osmosdr             0.2.3-11             0.2.3-12
                           gogglesmm              1.2.2-2              1.2.2-3
                              gource               0.53-2               0.53-3
                               gpick              0.2.6-5              0.2.6-6
                               gping              1.3.2-1              1.4.0-1
                            guitarix             0.44.1-2             0.44.1-3
                           heaptrack              1.4.0-1              1.4.0-2
                               hugin           2021.0.0-5           2021.0.0-6
                                i2pd             2.43.0-1             2.43.0-2
                               i3-wm             4.20.1-2               4.21-1
                           ibus-m17n             1.4.13-1             1.4.17-1
                  ibus-table-chinese              1.8.7-1              1.8.8-1
                           imagescan             3.65.0-6             3.65.0-7
                         innoextract                1.9-6                1.9-7
                            jacktrip              1.6.3-1              1.6.4-1
                                jalv              1.6.6-2              1.6.8-1
                             jenkins              2.368-1              2.369-1
                                jmol           14.32.74-1           14.32.75-1
                           jpegoptim              1.4.7-1              1.5.0-1
                               jsmol           14.32.74-1           14.32.75-1
                    jupyter-nbformat              5.5.0-1              5.6.0-1
                                 kea              2.2.0-1              2.2.0-2
                            kea-docs              2.2.0-1              2.2.0-2
                                kid3              3.9.2-1              3.9.2-2
                         kid3-common              3.9.2-1              3.9.2-2
                             kid3-qt              3.9.2-1              3.9.2-2
                               kooha              2.0.1-3              2.1.1-1
                   krita-plugin-gmic            3.1.5.1-1            3.1.6.1-1
                         kube-linter              0.4.0-1              0.5.0-1
                             kvantum              1.0.4-1              1.0.5-1
                            ladybird           20220912-2           20220916-1
                          leatherman             1.12.8-2             1.12.8-3
                              ledger             3.2.1-10             3.2.1-11
                            libcomps             0.1.18-1             0.1.19-1
                        libextractor               1.11-2               1.11-3
                        libfishsound              1.0.0-4              1.0.0-5
                              libime             1.0.14-1             1.0.14-2
                              liblas1.8.1.r128+gded46373-11.8.1.r128+gded46373-2
              libperconaserverclient          8.0.29_21-1          8.0.29_21-2
                          libspeechd             0.11.2-1             0.11.3-1
                           libtg_owt    0.git14.10d5f4b-2    0.git15.621f3da-1
                              libuhd            4.2.0.0-2            4.2.0.0-3
                            libvterm                0.2-1                0.3-1
                         libwhereami             0.5.0-13             0.5.0-14
                                lilv            0.24.18-1            0.24.20-1
                           lilv-docs            0.24.18-1            0.24.20-1
                 lua-language-server              3.5.5-1              3.5.6-1
                            lucene++              3.0.8-4              3.0.8-5
                        luminancehdr              2.6.1-8              2.6.1-9
                                 lv2             1.18.8-1            1.18.10-1
                                 lxc            1:5.0.0-4            1:5.0.1-1
                               lxcfs              5.0.0-1              5.0.2-1
                                 lxd                5.4-1                5.5-2
                                 mac               8.43-1               8.81-1
                                mame              0.247-1              0.247-2
                          mame-tools              0.247-1              0.247-2
                              mapnik             3.1.0-12             3.1.0-13
                              marked             4.0.12-1             4.0.16-1
                      matrix-synapse             1.65.0-1             1.67.0-1
                       mediastreamer             5.1.58-1             5.1.61-1
                            mednafen             1.29.0-2             1.29.0-3
                            minidlna              1.3.2-1              1.3.2-2
                           miniserve             0.21.0-1             0.22.0-1
                               munge             0.5.15-2             0.5.15-3
                               munin             2.0.69-1             2.0.70-1
                          munin-node             2.0.69-1             2.0.70-1
                             ncmpcpp              0.9.2-7              0.9.2-8
                     nginx-mod-naxsi                1.3-6                1.3-7
                   npm-check-updates             16.1.1-1             16.2.1-1
                            openh264              2.3.0-2              2.3.1-1
                         openimageio           2.3.19.0-1           2.3.19.0-3
                            openrct2              0.4.1-4              0.4.1-5
                            openscad            2021.01-5            2021.01-6
               opensearch-dashboards              2.2.1-1              2.3.0-1
opensearch-dashboards-alerting-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-anomaly-detection-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-gantt-chart-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-index-management-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-notifications-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-observability-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-query-workbench-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-reports-plugin            2.2.1.0-1            2.3.0.0-1
opensearch-dashboards-security-plugin            2.2.1.0-1            2.3.0.0-1
                 openshadinglanguage          1.11.17.0-4          1.11.17.0-5
                             openvdb              9.1.0-1              9.1.0-2
                          opus-tools                0.2-4                0.2-5
                                ortp             5.1.58-1             5.1.61-1
                           os-prober               1.80-1               1.81-1
                           pax-utils              1.3.3-1              1.3.4-1
                         pdfarranger              1.8.2-1              1.9.0-2
                          pdfmixtool                1.1-1                1.1-2
                           pdfslicer              1.8.8-1              1.8.8-2
                      percona-server          8.0.29_21-1          8.0.29_21-2
              percona-server-clients          8.0.29_21-1          8.0.29_21-2
           perl-acme-alien-dontpanic             2.5900-1             2.6500-1
                    perl-module-find               0.15-1               0.16-1
                      perl-pod-spell               1.20-5               1.23-1
                 perl-ppix-quotelike              0.022-2              0.023-1
                              poedit              1:3.1-1              1:3.1-2
                              povray         2:3.7.0.10-3         2:3.7.0.10-4
                            powerdns              4.6.3-1              4.6.3-2
                   powerdns-recursor              4.7.2-1              4.7.3-1
                          prjtrellis              1.2.1-2              1.2.1-3
                               procs             0.13.0-1             0.13.1-1
                           pulseview              0.4.2-7              0.4.2-8
                             pyright            1.1.271-1            1.1.272-1
                      python-ailment             9.2.14-1             9.2.15-1
                     python-aiofiles              0.8.0-2             22.1.0-1
                 python-aioitertools             0.10.0-1             0.11.0-1
                      python-astroid             2.12.9-1            2.12.10-1
               python-awesomeversion             22.8.0-1             22.9.0-1
                        python-black             22.6.0-1             22.8.0-2
                     python-cfn-lint             0.65.0-1             0.65.1-1
                        python-cliff             3.10.1-1              4.0.0-1
                   python-colorclass             2.2.0-10              2.2.2-1
                         python-copr              1.122-1              1.123-1
                   python-cssselect2              0.6.0-1              0.7.0-1
              python-email-validator              1.2.1-1              1.3.0-1
                        python-emoji              2.0.0-1              2.1.0-1
                        python-faker              9.1.0-1              9.3.0-1
                 python-flake8-black              0.3.3-1              0.3.3-2
                  python-google-auth              2.0.2-1              2.1.0-1
                        python-green              3.4.2-1              3.4.3-1
                       python-gssapi              1.7.3-1              1.8.0-1
                        python-hatch              1.3.1-1              1.5.0-1
                    python-hatchling              1.6.0-1             1.10.0-1
                   python-heatclient              3.0.0-1              3.1.0-1
           python-importlib-metadata              4.8.3-1              4.9.0-1
                 python-latex2mathml             3.64.0-1             3.66.1-1
                         python-lazy                1.4-6                1.5-1
                      python-libtmux             0.15.1-1             0.15.3-1
                 python-magnumclient              3.7.0-1              4.0.0-1
                  python-marshmallow             3.17.1-1             3.18.0-1
                       python-minidb              2.0.6-2              2.0.7-1
                      python-mockito              1.3.4-1              1.3.5-1
                python-neutronclient              8.0.0-1              8.1.0-1
                python-octaviaclient              2.5.0-1              3.0.0-1
                      python-osc-lib              2.6.1-1              2.6.2-1
                      python-pikepdf              5.6.1-1              6.0.2-1
                      python-pip-api             0.0.22-1             0.0.23-1
                       python-pipenv           2022.9.8-1          2022.9.21-1
                       python-poetry              1.2.0-2              1.2.0-5
                   python-pyhamcrest              2.0.1-1              2.0.3-1
                        python-pyjwt              2.4.0-1              2.5.0-1
                    python-pywlroots            0.15.21-1            0.15.22-1
                        python-pyxbe              0.0.4-2              1.0.0-1
                       python-stestr              3.2.1-3              4.0.0-1
                    python-tarantool              0.8.0-1              0.9.0-2
                       python-thrift             0.16.0-1             0.17.0-1
                     python-watchdog              1.0.2-1              2.0.0-1
                      python-wcmatch                8.4-1              8.4.1-1
                    python-xmlschema              2.0.3-1              2.0.4-1
                   python-zope-proxy              4.5.0-3              4.5.1-1
                  qgnomeplatform-qt5              0.8.4-5              0.9.0-1
                  qgnomeplatform-qt6              0.8.4-5              0.9.0-1
                                qmmp              2.1.1-1              2.1.1-2
                             rathole              0.4.3-1              0.4.4-1
                               redis              7.0.4-1              7.0.5-1
                           retroarch             1.10.3-2             1.10.3-3
                            rofimoji              5.5.0-1              5.6.0-1
                           rss2email               3.14-2               3.14-3
       ruby-native-package-installer              1.1.4-1              1.1.5-1
                       rust-analyzer           20220912-1           20220919-1
                        scaleway-cli              2.5.6-1              2.5.6-2
                             schroot            1.6.10-31            1.6.10-32
                             scummvm              2.6.0-1              2.6.0-2
                       scummvm-tools              2.6.0-1              2.6.0-2
                           sdl_sound              1.0.3-8              1.0.3-9
                       selene-linter             0.20.0-1             0.21.1-1
                                sfml              2.5.1-2              2.5.1-3
                             snapper             0.10.2-2             0.10.2-3
                           soapyosmo             0.2.5-14             0.2.5-15
                               sopel              7.1.7-1              7.1.8-1
                                 sox             14.4.2-714.4.2+r182+g42b3557e-1
                   speech-dispatcher             0.11.2-1             0.11.3-1
                                sssd              2.7.4-1              2.7.4-2
                                 stp              2.3.3-5              2.3.3-6
                          streamlink              4.3.0-1              5.0.0-1
                           stylelint            14.11.0-1            14.12.1-1
                       supercollider             3.12.2-2             3.12.2-3
                            supertux              0.6.3-4              0.6.3-5
                            swift-im             4.0.2-10             4.0.2-11
                             swiften             4.0.2-10             4.0.2-11
                              sympol             0.1.9-12             0.1.9-13
                           tailscale             1.30.1-1             1.30.2-1
                               tiled              1.9.1-1              1.9.2-1
                          timidity++             2.15.0-5             2.15.0-6
                              trojan             1.16.0-6             1.16.0-7
                   ttf-sarasa-gothic             0.37.1-1             0.37.4-1
                           uglify-js             3.17.0-1             3.17.1-1
         v2ray-domain-list-community     20220915110629-1     20220921050909-1
                         v2ray-geoip       202209150105-1       202209170841-1
                               vigra1.11.1.r67+g093d57d1-31.11.1.r67+g093d57d1-4
                                vint             0.3.20-5             0.3.21-1
           vscode-css-languageserver             1.71.0-1             1.71.0-2
          vscode-html-languageserver             1.71.0-1             1.71.0-2
          vscode-json-languageserver             1.71.0-1             1.71.0-2
                            wallabag              2.5.1-1              2.5.1-2
                            wasmtime             0.40.1-1              1.0.0-1
                                  wt              4.8.0-1              4.8.0-2
                         x42-plugins           20220714-1           20220914-1
                            xine-lib             1.2.12-2             1.2.12-3
                               xonsh             0.13.1-1             0.13.3-1
                             yoshimi              2.2.2-1            2.2.2.1-1
                               yosys               0.20-1               0.20-2
                                 znc             1.8.2-10             1.8.2-11
                               dexed                    - 0.9.6.r89.g2c03631-1
                             furnace                    -            0.6pre1-1
                             glmark2                    -            2021.12-1
                         goattracker                    -               2.76-2
                      klystrack-plus                    -      0.10.0.alpha1-1
                          libjaylink                    -              0.3.1-1
                            libsonic                    -              0.2.0-1
                            lv2-docs                    -            1.18.10-1
                 lv2-example-plugins                    -            1.18.10-1
                   odin2-synthesizer                    -              2.3.4-1
         python-hatch-nodejs-version                    -              0.3.0-1
         python-poetry-plugin-export                    -              1.0.7-1
                               qperf                    -             0.4.11-3
                            qsopt-ex                    -           2.5.10.3-1
                           rdma-core                    -               42.0-1
                       schismtracker                    -           20220905-1
                 serenity-wallpapers                    -           20220916-1
                          slurm-llnl                    -          22.05.3.1-2
                            surge-xt                    -              1.1.1-4
                                ufmt                    -              2.0.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.19.9-1            5.19.10-4
               linux-clockworkpi-a06             5.19.9-1            5.19.10-1
       linux-clockworkpi-a06-headers             5.19.9-1            5.19.10-1
                       linux-headers             5.19.9-1            5.19.10-4
                        linux-khadas             5.19.1-1             5.19.9-1
                linux-khadas-headers             5.19.1-1             5.19.9-1
                           linux-lts            5.15.68-1            5.15.69-1
                   linux-lts-headers            5.15.68-1            5.15.69-1
                     linux-pinephone             5.19.9-1            5.19.10-1
             linux-pinephone-headers             5.19.9-1            5.19.10-1
                  linux-pinephonepro             5.19.9-1            5.19.10-1
          linux-pinephonepro-headers             5.19.9-1            5.19.10-1
                            linux-rc            6.0.rc5-1            6.0.rc6-5
                    linux-rc-headers            6.0.rc5-1            6.0.rc6-5
                                grub                    -2:2.06.r322.gd9b4638c5-4.2
                            linux515                    -            5.15.69-1
                    linux515-headers                    -            5.15.69-1
                            linux519                    -            5.19.10-1
                    linux519-headers                    -            5.19.10-1
:: Different sync package(s) in repository core aarch64
                         btrfs-progs               5.19-1             5.19.1-1
             ca-certificates-mozilla               3.82-1               3.83-1
                            cracklib              2.9.7-2              2.9.8-1
                                file               5.42-2               5.43-1
                                grub2:2.06.r322.gd9b4638c5-4                    -
                              hdparm               9.64-1               9.65-1
                              hwdata              0.362-1              0.362-2
                                nspr             4.34.1-1               4.35-1
                                 nss               3.82-1               3.83-1
                               pcre2              10.40-1              10.40-2
                                 ppp              2.4.9-1              2.4.9-2
:: Different overlay package(s) in repository extra aarch64
                           calamares             3.2.61-1             3.2.61-2
                   calamares-arm-oem           20220826-1           20220916-1
                            mesa-git22.3.0_devel.159481.dcc52618952-122.3.0_devel.159906.9d3a5c916c5-1
                        qt5-es2-base    5.15.6+kde+r165-1    5.15.6+kde+r177-1
                     qt5-es2-wayland     5.15.6+kde+r43-1     5.15.6+kde+r47-1
         qt5-es2-xcb-private-headers    5.15.6+kde+r165-1    5.15.6+kde+r177-1
                         thunderbird          102.2.2-0.2                    -
                 thunderbird-i18n-af          102.2.2-0.2                    -
                 thunderbird-i18n-ar          102.2.2-0.2                    -
                thunderbird-i18n-ast          102.2.2-0.2                    -
                 thunderbird-i18n-be          102.2.2-0.2                    -
                 thunderbird-i18n-bg          102.2.2-0.2                    -
                 thunderbird-i18n-br          102.2.2-0.2                    -
                 thunderbird-i18n-ca          102.2.2-0.2                    -
                thunderbird-i18n-cak          102.2.2-0.2                    -
                 thunderbird-i18n-cs          102.2.2-0.2                    -
                 thunderbird-i18n-cy          102.2.2-0.2                    -
                 thunderbird-i18n-da          102.2.2-0.2                    -
                 thunderbird-i18n-de          102.2.2-0.2                    -
                thunderbird-i18n-dsb          102.2.2-0.2                    -
                 thunderbird-i18n-el          102.2.2-0.2                    -
              thunderbird-i18n-en-gb          102.2.2-0.2                    -
              thunderbird-i18n-en-us          102.2.2-0.2                    -
              thunderbird-i18n-es-ar          102.2.2-0.2                    -
              thunderbird-i18n-es-es          102.2.2-0.2                    -
                 thunderbird-i18n-et          102.2.2-0.2                    -
                 thunderbird-i18n-eu          102.2.2-0.2                    -
                 thunderbird-i18n-fi          102.2.2-0.2                    -
                 thunderbird-i18n-fr          102.2.2-0.2                    -
              thunderbird-i18n-fy-nl          102.2.2-0.2                    -
              thunderbird-i18n-ga-ie          102.2.2-0.2                    -
                 thunderbird-i18n-gd          102.2.2-0.2                    -
                 thunderbird-i18n-gl          102.2.2-0.2                    -
                 thunderbird-i18n-he          102.2.2-0.2                    -
                 thunderbird-i18n-hr          102.2.2-0.2                    -
                thunderbird-i18n-hsb          102.2.2-0.2                    -
                 thunderbird-i18n-hu          102.2.2-0.2                    -
              thunderbird-i18n-hy-am          102.2.2-0.2                    -
                 thunderbird-i18n-id          102.2.2-0.2                    -
                 thunderbird-i18n-is          102.2.2-0.2                    -
                 thunderbird-i18n-it          102.2.2-0.2                    -
                 thunderbird-i18n-ja          102.2.2-0.2                    -
                 thunderbird-i18n-ka          102.2.2-0.2                    -
                thunderbird-i18n-kab          102.2.2-0.2                    -
                 thunderbird-i18n-kk          102.2.2-0.2                    -
                 thunderbird-i18n-ko          102.2.2-0.2                    -
                 thunderbird-i18n-lt          102.2.2-0.2                    -
                 thunderbird-i18n-ms          102.2.2-0.2                    -
              thunderbird-i18n-nb-no          102.2.2-0.2                    -
                 thunderbird-i18n-nl          102.2.2-0.2                    -
              thunderbird-i18n-nn-no          102.2.2-0.2                    -
              thunderbird-i18n-pa-in          102.2.2-0.2                    -
                 thunderbird-i18n-pl          102.2.2-0.2                    -
              thunderbird-i18n-pt-br          102.2.2-0.2                    -
              thunderbird-i18n-pt-pt          102.2.2-0.2                    -
                 thunderbird-i18n-rm          102.2.2-0.2                    -
                 thunderbird-i18n-ro          102.2.2-0.2                    -
                 thunderbird-i18n-ru          102.2.2-0.2                    -
                 thunderbird-i18n-sk          102.2.2-0.2                    -
                 thunderbird-i18n-sl          102.2.2-0.2                    -
                 thunderbird-i18n-sq          102.2.2-0.2                    -
                 thunderbird-i18n-sr          102.2.2-0.2                    -
              thunderbird-i18n-sv-se          102.2.2-0.2                    -
                 thunderbird-i18n-th          102.2.2-0.2                    -
                 thunderbird-i18n-tr          102.2.2-0.2                    -
                 thunderbird-i18n-uk          102.2.2-0.2                    -
                 thunderbird-i18n-uz          102.2.2-0.2                    -
                 thunderbird-i18n-vi          102.2.2-0.2                    -
              thunderbird-i18n-zh-cn          102.2.2-0.2                    -
              thunderbird-i18n-zh-tw          102.2.2-0.2                    -
:: Different sync package(s) in repository extra aarch64
                  alsa-card-profiles           1:0.3.57-1           1:0.3.58-1
                  arch-rebuild-order                0.3-2              0.3.1-1
                   audacious-plugins                4.2-1                4.2-2
                         audiocd-kio            22.08.1-1            22.08.1-2
                           audiofile              0.3.6-6              0.3.6-7
                     bash-completion               2.11-2               2.11-3
                              bigloo             4.4c_4-1             4.4c_4-2
                               boost             1.79.0-1             1.80.0-2
                          boost-libs             1.79.0-1             1.80.0-2
                             booster                0.8-1                0.9-1
                            chromium     105.0.5195.125-1     105.0.5195.125-3
                            composer              2.4.1-1              2.4.2-1
                        cups-filters            1.28.16-1            1.28.16-2
                                dkms              3.0.6-1              3.0.6-2
                             easytag              2.4.3-4              2.4.3-5
                             firefox            104.0.2-1              105.0-2
                    firefox-i18n-ach            104.0.2-1              105.0-1
                     firefox-i18n-af            104.0.2-1              105.0-1
                     firefox-i18n-an            104.0.2-1              105.0-1
                     firefox-i18n-ar            104.0.2-1              105.0-1
                    firefox-i18n-ast            104.0.2-1              105.0-1
                     firefox-i18n-az            104.0.2-1              105.0-1
                     firefox-i18n-be            104.0.2-1              105.0-1
                     firefox-i18n-bg            104.0.2-1              105.0-1
                     firefox-i18n-bn            104.0.2-1              105.0-1
                     firefox-i18n-br            104.0.2-1              105.0-1
                     firefox-i18n-bs            104.0.2-1              105.0-1
                     firefox-i18n-ca            104.0.2-1              105.0-1
            firefox-i18n-ca-valencia            104.0.2-1              105.0-1
                    firefox-i18n-cak            104.0.2-1              105.0-1
                     firefox-i18n-cs            104.0.2-1              105.0-1
                     firefox-i18n-cy            104.0.2-1              105.0-1
                     firefox-i18n-da            104.0.2-1              105.0-1
                     firefox-i18n-de            104.0.2-1              105.0-1
                    firefox-i18n-dsb            104.0.2-1              105.0-1
                     firefox-i18n-el            104.0.2-1              105.0-1
                  firefox-i18n-en-ca            104.0.2-1              105.0-1
                  firefox-i18n-en-gb            104.0.2-1              105.0-1
                  firefox-i18n-en-us            104.0.2-1              105.0-1
                     firefox-i18n-eo            104.0.2-1              105.0-1
                  firefox-i18n-es-ar            104.0.2-1              105.0-1
                  firefox-i18n-es-cl            104.0.2-1              105.0-1
                  firefox-i18n-es-es            104.0.2-1              105.0-1
                  firefox-i18n-es-mx            104.0.2-1              105.0-1
                     firefox-i18n-et            104.0.2-1              105.0-1
                     firefox-i18n-eu            104.0.2-1              105.0-1
                     firefox-i18n-fa            104.0.2-1              105.0-1
                     firefox-i18n-ff            104.0.2-1              105.0-1
                     firefox-i18n-fi            104.0.2-1              105.0-1
                     firefox-i18n-fr            104.0.2-1              105.0-1
                  firefox-i18n-fy-nl            104.0.2-1              105.0-1
                  firefox-i18n-ga-ie            104.0.2-1              105.0-1
                     firefox-i18n-gd            104.0.2-1              105.0-1
                     firefox-i18n-gl            104.0.2-1              105.0-1
                     firefox-i18n-gn            104.0.2-1              105.0-1
                  firefox-i18n-gu-in            104.0.2-1              105.0-1
                     firefox-i18n-he            104.0.2-1              105.0-1
                  firefox-i18n-hi-in            104.0.2-1              105.0-1
                     firefox-i18n-hr            104.0.2-1              105.0-1
                    firefox-i18n-hsb            104.0.2-1              105.0-1
                     firefox-i18n-hu            104.0.2-1              105.0-1
                  firefox-i18n-hy-am            104.0.2-1              105.0-1
                     firefox-i18n-ia            104.0.2-1              105.0-1
                     firefox-i18n-id            104.0.2-1              105.0-1
                     firefox-i18n-is            104.0.2-1              105.0-1
                     firefox-i18n-it            104.0.2-1              105.0-1
                     firefox-i18n-ja            104.0.2-1              105.0-1
                     firefox-i18n-ka            104.0.2-1              105.0-1
                    firefox-i18n-kab            104.0.2-1              105.0-1
                     firefox-i18n-kk            104.0.2-1              105.0-1
                     firefox-i18n-km            104.0.2-1              105.0-1
                     firefox-i18n-kn            104.0.2-1              105.0-1
                     firefox-i18n-ko            104.0.2-1              105.0-1
                    firefox-i18n-lij            104.0.2-1              105.0-1
                     firefox-i18n-lt            104.0.2-1              105.0-1
                     firefox-i18n-lv            104.0.2-1              105.0-1
                     firefox-i18n-mk            104.0.2-1              105.0-1
                     firefox-i18n-mr            104.0.2-1              105.0-1
                     firefox-i18n-ms            104.0.2-1              105.0-1
                     firefox-i18n-my            104.0.2-1              105.0-1
                  firefox-i18n-nb-no            104.0.2-1              105.0-1
                  firefox-i18n-ne-np            104.0.2-1              105.0-1
                     firefox-i18n-nl            104.0.2-1              105.0-1
                  firefox-i18n-nn-no            104.0.2-1              105.0-1
                     firefox-i18n-oc            104.0.2-1              105.0-1
                  firefox-i18n-pa-in            104.0.2-1              105.0-1
                     firefox-i18n-pl            104.0.2-1              105.0-1
                  firefox-i18n-pt-br            104.0.2-1              105.0-1
                  firefox-i18n-pt-pt            104.0.2-1              105.0-1
                     firefox-i18n-rm            104.0.2-1              105.0-1
                     firefox-i18n-ro            104.0.2-1              105.0-1
                     firefox-i18n-ru            104.0.2-1              105.0-1
                    firefox-i18n-sco            104.0.2-1              105.0-1
                     firefox-i18n-si            104.0.2-1              105.0-1
                     firefox-i18n-sk            104.0.2-1              105.0-1
                     firefox-i18n-sl            104.0.2-1              105.0-1
                    firefox-i18n-son            104.0.2-1              105.0-1
                     firefox-i18n-sq            104.0.2-1              105.0-1
                     firefox-i18n-sr            104.0.2-1              105.0-1
                  firefox-i18n-sv-se            104.0.2-1              105.0-1
                    firefox-i18n-szl            104.0.2-1              105.0-1
                     firefox-i18n-ta            104.0.2-1              105.0-1
                     firefox-i18n-te            104.0.2-1              105.0-1
                     firefox-i18n-th            104.0.2-1              105.0-1
                     firefox-i18n-tl            104.0.2-1              105.0-1
                     firefox-i18n-tr            104.0.2-1              105.0-1
                    firefox-i18n-trs            104.0.2-1              105.0-1
                     firefox-i18n-uk            104.0.2-1              105.0-1
                     firefox-i18n-ur            104.0.2-1              105.0-1
                     firefox-i18n-uz            104.0.2-1              105.0-1
                     firefox-i18n-vi            104.0.2-1              105.0-1
                     firefox-i18n-xh            104.0.2-1              105.0-1
                  firefox-i18n-zh-cn            104.0.2-1              105.0-1
                  firefox-i18n-zh-tw            104.0.2-1              105.0-1
                                flac              1.3.4-3              1.4.0-1
                            flac-doc              1.3.4-3              1.4.0-1
                         fuse-common             3.11.0-1             3.12.0-1
                               fuse3             3.11.0-1             3.12.0-1
                              galera            26.4.12-1            26.4.12-2
                         gnome-shell             1:42.4-1             1:42.5-1
                gst-editing-services             1.20.3-1             1.20.3-2
                           gst-libav             1.20.3-1             1.20.3-2
                      gst-plugin-gtk             1.20.3-1             1.20.3-2
                   gst-plugin-opencv             1.20.3-1             1.20.3-2
                 gst-plugin-pipewire           1:0.3.57-1           1:0.3.58-1
                    gst-plugin-qmlgl             1.20.3-1             1.20.3-2
                       gst-plugin-va             1.20.3-1             1.20.3-2
                      gst-plugin-wpe             1.20.3-1             1.20.3-2
                     gst-plugins-bad             1.20.3-1             1.20.3-2
                gst-plugins-bad-libs             1.20.3-1             1.20.3-2
                    gst-plugins-base             1.20.3-1             1.20.3-2
               gst-plugins-base-libs             1.20.3-1             1.20.3-2
                    gst-plugins-good             1.20.3-1             1.20.3-2
                    gst-plugins-ugly             1.20.3-1             1.20.3-2
                          gst-python             1.20.3-1             1.20.3-2
                     gst-rtsp-server             1.20.3-1             1.20.3-2
                           gstreamer             1.20.3-1             1.20.3-2
                      gstreamer-docs             1.20.3-1             1.20.3-2
                     gstreamer-vaapi             1.20.3-1             1.20.3-2
               gtk-update-icon-cache            1:4.8.0-1            1:4.8.1-1
                                gtk4            1:4.8.0-1            1:4.8.1-1
                          gtk4-demos            1:4.8.0-1            1:4.8.1-1
                           gtk4-docs            1:4.8.0-1            1:4.8.1-1
                            harfbuzz              5.1.0-1              5.2.0-1
                        harfbuzz-icu              5.1.0-1              5.2.0-1
                            hwdetect            2022.09-1            2022.09-3
                               imath              3.1.5-2              3.1.5-3
                            inkscape              1.2.1-5              1.2.1-6
                                 k3b          1:22.08.1-1          1:22.08.1-2
                                 kig            22.08.1-1            22.08.1-2
                       kopeninghours            22.08.1-1            22.08.1-2
                               kwave            22.08.1-1            22.08.1-2
                            kwayland             5.98.0-1             5.98.0-2
                                 ldb            2:2.5.2-2            2:2.6.1-1
                         libappimage            1.0.4.5-2            1.0.4.5-3
                         libblockdev               2.27-1               2.28-1
                             libcmis             0.5.2-11             0.5.2-12
                          libetonyek             0.1.10-1             0.1.10-2
                            libixion             0.17.0-2             0.17.0-3
                         libkolabxml             1.1.6-18             1.1.6-19
                          libmp3splt              0.9.2-3              0.9.2-4
                          libopenmpt              0.6.5-1              0.6.5-2
                            liborcus             0.17.2-2             0.17.2-3
                      libphonenumber          1:8.12.52-3          1:8.12.52-4
                              libpng           1.6.37-3.1             1.6.38-1
                              libpst             0.6.76-7             0.6.76-8
                         libpst-docs             0.6.76-7             0.6.76-8
                             libquvi              0.9.4-6              0.9.4-7
                   libreoffice-fresh              7.4.1-1              7.4.1-2
               libreoffice-fresh-sdk              7.4.1-1              7.4.1-2
                   libreoffice-still              7.3.6-1              7.3.6-2
               libreoffice-still-sdk              7.3.6-1              7.3.6-2
                          libsndfile              1.1.0-2              1.1.0-3
                libtorrent-rasterbar            1:2.0.7-1            1:2.0.7-2
                            lighttpd             1.4.66-1             1.4.67-1
                           maeparser              1.3.0-1              1.3.0-2
                             mariadb             10.9.2-1             10.9.3-1
                     mariadb-clients             10.9.2-1             10.9.3-1
                        mariadb-libs             10.9.2-1             10.9.3-1
                      mkvtoolnix-cli             70.0.0-1             70.0.0-2
                      mkvtoolnix-gui             70.0.0-1             70.0.0-2
                                 moc            1:2.5.2-6            1:2.5.2-7
                                 mpd             0.23.9-2             0.23.9-3
                              mtools           1:4.0.40-1           1:4.0.41-1
                              mutter               42.4-1               42.5-1
                         mutter-docs               42.4-1               42.5-1
                               mytop             10.9.2-1             10.9.3-1
                                neon             0.32.3-1             0.32.4-1
                    noto-fonts-emoji           20211101-1           20220906-1
                               pango           1:1.50.9-1          1:1.50.10-1
                          pango-docs           1:1.50.9-1          1:1.50.10-1
                    perl-alien-build               2.65-1               2.68-1
                  perl-exporter-tiny           1.004001-1           1.004002-1
                     perl-net-ssleay               1.90-3               1.92-1
                            php-apcu             5.1.21-3             5.1.22-1
                           php7-apcu             5.1.21-3             5.1.22-1
                       pipewire-alsa           1:0.3.57-1           1:0.3.58-1
                       pipewire-docs           1:0.3.57-1           1:0.3.58-1
                       pipewire-jack           1:0.3.57-1           1:0.3.58-1
                      pipewire-pulse           1:0.3.57-1           1:0.3.58-1
                       pipewire-v4l2           1:0.3.57-1           1:0.3.58-1
                   pipewire-x11-bell           1:0.3.57-1           1:0.3.58-1
                   pipewire-zeroconf           1:0.3.57-1           1:0.3.58-1
                            pkgstats              3.2.4-1              3.2.5-1
                            protobuf               21.5-1               21.6-1
                     python-protobuf               21.5-1               21.6-1
                        python-pyqt5             5.15.7-1             5.15.7-2
                        python-pyqt6              6.3.1-1              6.3.1-2
                   python-virtualenv            20.13.3-1            20.14.0-1
                                qpdf             10.6.3-1             11.1.0-1
                           qpdf-docs             10.6.3-1             11.1.0-1
                            qt5-base    5.15.6+kde+r167-1    5.15.6+kde+r177-1
                         qt5-wayland     5.15.6+kde+r43-2     5.15.6+kde+r48-1
             qt5-xcb-private-headers    5.15.6+kde+r167-1    5.15.6+kde+r177-1
                               samba             4.16.5-1             4.17.0-1
                           smbclient             4.16.5-1             4.17.0-1
                    source-highlight              3.1.9-8              3.1.9-9
                      squashfs-tools              4.5.1-1              4.5.1-2
                         thunderbird            102.2.0-1            102.2.2-1
                 thunderbird-i18n-af            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ar            102.2.0-1            102.2.2-1
                thunderbird-i18n-ast            102.2.0-1            102.2.2-1
                 thunderbird-i18n-be            102.2.0-1            102.2.2-1
                 thunderbird-i18n-bg            102.2.0-1            102.2.2-1
                 thunderbird-i18n-br            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ca            102.2.0-1            102.2.2-1
                thunderbird-i18n-cak            102.2.0-1            102.2.2-1
                 thunderbird-i18n-cs            102.2.0-1            102.2.2-1
                 thunderbird-i18n-cy            102.2.0-1            102.2.2-1
                 thunderbird-i18n-da            102.2.0-1            102.2.2-1
                 thunderbird-i18n-de            102.2.0-1            102.2.2-1
                thunderbird-i18n-dsb            102.2.0-1            102.2.2-1
                 thunderbird-i18n-el            102.2.0-1            102.2.2-1
              thunderbird-i18n-en-gb            102.2.0-1            102.2.2-1
              thunderbird-i18n-en-us            102.2.0-1            102.2.2-1
              thunderbird-i18n-es-ar            102.2.0-1            102.2.2-1
              thunderbird-i18n-es-es            102.2.0-1            102.2.2-1
                 thunderbird-i18n-et            102.2.0-1            102.2.2-1
                 thunderbird-i18n-eu            102.2.0-1            102.2.2-1
                 thunderbird-i18n-fi            102.2.0-1            102.2.2-1
                 thunderbird-i18n-fr            102.2.0-1            102.2.2-1
              thunderbird-i18n-fy-nl            102.2.0-1            102.2.2-1
              thunderbird-i18n-ga-ie            102.2.0-1            102.2.2-1
                 thunderbird-i18n-gd            102.2.0-1            102.2.2-1
                 thunderbird-i18n-gl            102.2.0-1            102.2.2-1
                 thunderbird-i18n-he            102.2.0-1            102.2.2-1
                 thunderbird-i18n-hr            102.2.0-1            102.2.2-1
                thunderbird-i18n-hsb            102.2.0-1            102.2.2-1
                 thunderbird-i18n-hu            102.2.0-1            102.2.2-1
              thunderbird-i18n-hy-am            102.2.0-1            102.2.2-1
                 thunderbird-i18n-id            102.2.0-1            102.2.2-1
                 thunderbird-i18n-is            102.2.0-1            102.2.2-1
                 thunderbird-i18n-it            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ja            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ka            102.2.0-1            102.2.2-1
                thunderbird-i18n-kab            102.2.0-1            102.2.2-1
                 thunderbird-i18n-kk            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ko            102.2.0-1            102.2.2-1
                 thunderbird-i18n-lt            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ms            102.2.0-1            102.2.2-1
              thunderbird-i18n-nb-no            102.2.0-1            102.2.2-1
                 thunderbird-i18n-nl            102.2.0-1            102.2.2-1
              thunderbird-i18n-nn-no            102.2.0-1            102.2.2-1
              thunderbird-i18n-pa-in            102.2.0-1            102.2.2-1
                 thunderbird-i18n-pl            102.2.0-1            102.2.2-1
              thunderbird-i18n-pt-br            102.2.0-1            102.2.2-1
              thunderbird-i18n-pt-pt            102.2.0-1            102.2.2-1
                 thunderbird-i18n-rm            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ro            102.2.0-1            102.2.2-1
                 thunderbird-i18n-ru            102.2.0-1            102.2.2-1
                 thunderbird-i18n-sk            102.2.0-1            102.2.2-1
                 thunderbird-i18n-sl            102.2.0-1            102.2.2-1
                 thunderbird-i18n-sq            102.2.0-1            102.2.2-1
                 thunderbird-i18n-sr            102.2.0-1            102.2.2-1
              thunderbird-i18n-sv-se            102.2.0-1            102.2.2-1
                 thunderbird-i18n-th            102.2.0-1            102.2.2-1
                 thunderbird-i18n-tr            102.2.0-1            102.2.2-1
                 thunderbird-i18n-uk            102.2.0-1            102.2.2-1
                 thunderbird-i18n-uz            102.2.0-1            102.2.2-1
                 thunderbird-i18n-vi            102.2.0-1            102.2.2-1
              thunderbird-i18n-zh-cn            102.2.0-1            102.2.2-1
              thunderbird-i18n-zh-tw            102.2.0-1            102.2.2-1
                      tracker-miners1:2.3.5+r3+gd9d61d87f-11:2.3.5+r3+gd9d61d87f-2
                              upower            0.99.20-1             1.90.0-1
                             varnish              7.1.1-1              7.2.0-1
                                 vlc           3.0.17.4-7           3.0.17.4-8
                        vorbis-tools              1.4.2-2              1.4.2-3
            vulkan-validation-layers          1.3.216.0-1          1.3.224.1-1
               xfce4-datetime-plugin              0.8.1-1              0.8.2-1
                                zbar             0.23.1-9            0.23.90-1
                       xorg-xkbprint                    -              1.0.5-1
:: Different overlay package(s) in repository kde-unstable aarch64
                    akonadi-contacts22.08.1.r3241.g2167502f-122.08.1.r3242.gd848b75c-1
                        akonadi-mime22.08.1.r1755.g9a4e8bf-122.08.1.r1756.gd65619b-1
                       akonadi-notes22.08.1.r1089.g63c6808-122.08.1.r1090.ged199e3-1
                      akonadi-search22.08.1.r1278.gc4e6f04-122.08.1.r1279.ge613ca6-1
                           alligator 22.06.r51.g0da5e73-1 22.06.r53.g3533c4b-1
                            amazfish 2.0.8.r12.gb7023fd-1 2.0.8.r21.g1656e09-1
                           angelfish 22.06.r56.gb000b84-1 22.06.r60.g516a931-1
                              attica5.98.0.r884.ga909265-15.98.0.r888.gabe6e78-1
                           audiotube 22.06.r37.gf26bc80-1 22.06.r38.g4c7db5d-1
                        aura-browser        r81.aa492e5-1        r85.ad7280d-1
                               baloo5.98.0.r3065.gdff7e8f4-15.98.0.r3067.gd421b4b6-1
                       baloo-widgets22.08.1.r771.g7e9603a-122.08.1.r772.geeb816a-1
                           bluedevil1:5.25.5.r2434.g18f444a6-11:5.25.5.r2441.g2a9d5252-1
                            bluez-qt5.98.0.r719.g932455b-15.98.0.r722.g0aa271c-1
                              bomber22.08.1.r575.g68168a2-122.08.1.r579.g407b742-1
                                bovo22.08.1.r786.gcd9e2ac-122.08.1.r789.g31db868-1
                              breeze5.25.5.r2452.g6e278306-15.25.5.r2459.g1548737f-1
                          breeze-gtk5.25.5.r488.gcc0f107-15.25.5.r490.g2f51f29-1
                        breeze-icons5.98.0.r1918.g0e430302-15.98.0.r1919.ge88c5b7b-1
                                buho  2.2.0.r0.gdfd2429-1  2.2.0.r5.gd39a889-1
                           calindori 22.06.r19.gac70dc6-1 22.06.r20.gcc4435e-1
                         cask-server        r7.ga16cff8-1        r8.ga13a253-1
                            cervisia22.08.1.r1701.g3c23021-122.08.1.r1704.g617b67c-1
                            discover5.25.5.r8831.g071f300f-15.25.5.r8842.gecb14532-1
                             dolphin22.08.1.r7085.g8ff021ca6-122.08.1.r7090.g6c65d06bc-1
                             drkonqi5.25.5.r824.gb1e5bb03-15.25.5.r828.gef22aade-1
                               elisa22.08.1.r3032.g921aff71-122.08.1.r3036.g01f63956-1
                          elisa-qtmm22.08.1.r3032.g921aff71-122.08.1.r3036.g01f63956-1
                 extra-cmake-modules5.98.0.r3519.gf51c901e-15.98.0.r3522.g5b1b9370-1
                frameworkintegration5.98.0.r653.g0bc14a7-15.98.0.r655.gfdbc2d3-1
                           granatier22.08.1.r989.g0066152-122.08.1.r991.gf23f2d2-1
                       grantleetheme22.08.1.r418.gf8ee1d0-122.08.1.r419.ge42e3c4-1
                            index-fm  2.2.0.r1.g9619c9b-1  2.2.0.r3.g08b7662-1
                           itinerary22.08.1.r2005.g554eefd-122.08.1.r2010.g239b4b7-1
                                 juk22.08.1.r3181.ga16fd747-122.08.1.r3182.g16db4762-1
                                 k3b1:22.08.1.r6816.ga94f8d7ef-11:22.08.1.r6820.g06791702e-1
               kaccounts-integration22.08.1.r1274.gb317f0f-122.08.1.r1286.ged86f13-1
                         kactivities5.98.0.r1409.g3ba53fcd-15.98.0.r1411.g6f54fb4b-1
                   kactivities-stats5.98.0.r417.gc9ad8e7-15.98.0.r419.g6d112a4-1
                   kactivitymanagerd5.25.5.r1421.g703ebd6-15.25.5.r1422.g3e55209-1
                             kajongg22.08.1.r4350.g4110278b-122.08.1.r4352.g3f78e423-1
                              kalarm22.08.1.r8003.g113a8345-122.08.1.r8004.gd6c9eea4-1
                                kalk 22.06.r26.g149d00c-1 22.06.r29.ge189845-1
                              kamoso22.08.1.r1477.g4744064-122.08.1.r1478.gb1487f2-1
                            kanagram22.08.1.r1327.g09d3b7f-122.08.1.r1328.gabb0747-1
                             kapidox5.98.0.r575.g6ed0a41-15.98.0.r576.gacdea21-1
                              kapman22.08.1.r668.g9f495fa-122.08.1.r669.g6d4383e-1
                            karchive5.98.0.r554.g0a17848-15.98.0.r558.g06d226d-1
                               kasts 22.06.r56.g7a052bf-1 22.06.r59.g6309427-1
                                kate22.08.1.r19533.gaba9082fd-122.08.1.r19581.gd650cd552-1
                             katomic22.08.1.r975.gd2f9b5b-122.08.1.r976.g51140f8-1
                               kauth5.98.0.r508.g29871cb-15.98.0.r511.g5416919-1
                           kblackbox22.08.1.r779.gd725db4-122.08.1.r781.g4d2b8fd-1
                             kblocks22.08.1.r755.gde3f9bd-122.08.1.r756.g7316fc6-1
                          kbookmarks5.98.0.r469.g04303ac-15.98.0.r471.g664adfb-1
                             kbounce22.08.1.r860.gab57d45-122.08.1.r862.gc6d4be8-1
                           kbreakout22.08.1.r936.gb91a653-122.08.1.r938.g53cd2d7-1
                               kcalc22.08.1.r1631.gade2032-122.08.1.r1632.gf5f967a-1
                       kcalendarcore5.98.0.r1343.gf62b4e6b3-15.98.0.r1347.g3febe4523-1
                              kclock 22.06.r36.gfb1572f-1 22.06.r44.gf9de383-1
                            kcmutils5.98.0.r663.g9258334-15.98.0.r666.g7d88a75-1
                             kcodecs5.98.0.r430.g233229e-15.98.0.r433.g2b15541-1
                         kcompletion5.98.0.r511.g4418032-15.98.0.r513.gea536b2-1
                             kconfig5.98.0.r976.ge7183b90-15.98.0.r982.g11cf7268-1
                      kconfigwidgets5.98.0.r775.g0f0cf30-15.98.0.r777.gfcb9672-1
                           kcontacts1:5.98.0.r3346.g41ed7faf-11:5.98.0.r3349.ga80a7142-1
                         kcoreaddons5.98.0.r1555.g48525592-15.98.0.r1562.gb1deba29-1
                              kcrash5.98.0.r455.g863ce2b-15.98.0.r457.gd2f3085-1
                                kdav1:5.98.0.r1354.g738ee0e-11:5.98.0.r1356.gc8fb1d7-1
                         kdbusaddons5.98.0.r427.gcf1194c-15.98.0.r431.g36a9cf6-1
                       kde-cli-tools5.25.5.r1954.gee512e1-15.25.5.r1957.g3528835-1
                      kde-gtk-config5.25.5.r945.g30898d4-15.25.5.r948.g22b3968-1
                        kdeclarative5.98.0.r1041.g0fd84c6-15.98.0.r1045.g51f62d7-1
                          kdeconnect22.08.1.r3537.gdcf41545-122.08.1.r3541.g6e679320-1
                         kdecoration5.25.5.r297.g8e8c753-15.25.5.r300.g2c711db-1
                                kded5.98.0.r475.ge98fa6e-15.98.0.r477.gc8d2ebd-1
                     kdelibs4support5.98.0.r1108.g848ff7a6-15.98.0.r1109.gd597d15f-1
              kdenetwork-filesharing22.08.1.r984.g4b523fb-122.08.1.r985.g34f8836-1
                            kdenlive22.08.1.r16641.g81e4196b2-122.08.1.r16674.g21c8731e6-1
                       kdepim-addons22.08.1.r4837.gce705c16e-122.08.1.r4849.g01efbdf34-1
                      kdepim-runtime22.08.1.r15599.gb7a26f3be-122.08.1.r15600.g57a31df55-1
                    kdeplasma-addons5.25.5.r9034.gec364f86f-15.25.5.r9039.g4353fcb11-1
                     kdesignerplugin5.98.0.r361.g87a3cdd-15.98.0.r362.g8ddd4cd-1
                               kdesu5.98.0.r517.g6c84dc0-15.98.0.r519.g3e2efce-1
                           kdewebkit5.98.0.r308.gd200b32-15.98.0.r309.g6a96cc9-1
                                 kdf22.08.1.r874.gaaf2494-122.08.1.r876.gd8e3425-1
                             kdialog22.08.1.r1239.ge1e295bba-122.08.1.r1240.g076549769-1
                            kdiamond22.08.1.r737.g34a28f2-122.08.1.r739.gbf0fdb0-1
                              kdnssd5.98.0.r359.gd95a3bc-15.98.0.r363.g36f9a06-1
                           kdoctools5.98.0.r679.gf8bb0e5-15.98.0.r683.g0f794d4-1
                          kemoticons5.98.0.r425.g460be3d-15.98.0.r426.g103a043-1
                            keysmith 22.06.r22.g2a67db5-1 22.06.r24.g82be984-1
                       kfilemetadata5.98.0.r874.g44ad4ae-15.98.0.r876.gca96468-1
                               kfind22.08.1.r2728.g6bb945983-122.08.1.r2729.g4b42e460d-1
                             kfloppy22.08.1.r804.g7094a06-122.08.1.r806.gc7a5ca2-1
                         kfourinline22.08.1.r1042.g292eea5-122.08.1.r1043.ga21db14-1
                             kgamma55.25.5.r483.g7f02758-15.25.5.r486.gaa07f95-1
                          kgeography22.08.1.r1168.gbe6af72-122.08.1.r1169.g0c690ba-1
                                kget22.08.1.r3223.ge0e262f4-122.08.1.r3224.g4b3e7310-1
                        kglobalaccel5.98.0.r574.g93b431e-15.98.0.r576.g6b1ab68-1
                         kgoldrunner22.08.1.r1298.g8011965-122.08.1.r1299.g2abb019-1
                                kgpg22.08.1.r3207.g8a45bc3c-122.08.1.r3208.g3cb453b4-1
                          kguiaddons5.98.0.r493.g58e08d5-15.98.0.r498.gebc9be7-1
                           kholidays1:5.98.0.r1056.ge295e2e-11:5.98.0.r1060.g6f1fe68-1
                            khotkeys5.25.5.r2158.g3582ef1-15.25.5.r2161.ge4cd6f2-1
                               khtml5.98.0.r598.g40dedf5-15.98.0.r599.g71a9ee2-1
                               ki18n5.98.0.r571.g241e0cf-15.98.0.r579.gda282de-1
                         kiconthemes5.98.0.r632.gc5b74ac-15.98.0.r634.gd8ca344-1
                           kidletime5.98.0.r368.g5ceaf67-15.98.0.r373.g6bbee45-1
                                kigo22.08.1.r589.g1a9aafc-122.08.1.r590.g43518cb-1
                            killbots22.08.1.r807.gc917a99-122.08.1.r809.g09ebca2-1
                       kimageformats5.98.0.r429.g2192830-15.98.0.r433.g6f3a326-1
                         kinfocenter5.25.5.r2152.g434eb250-15.25.5.r2158.gb05c2fd6-1
                               kinit5.98.0.r447.gabd053b-15.98.0.r448.g32fd61a-1
                                 kio5.98.0.r5698.ged1a8a529-15.98.0.r5706.g0b5eb5566-1
                          kio-gdrive22.08.1.r634.g39f110c-122.08.1.r641.g7278f5f-1
                     kirigami-addons 1:0.3.r13.gf1ed873-1 1:0.3.r16.gbd37cc5-1
                    kirigami-gallery22.08.1.r270.g5800f94-122.08.1.r271.g0a3c38b-1
                           kirigami25.98.0.r3331.gc9339665-15.98.0.r3347.gb88f096b-1
                              kiriki22.08.1.r466.g3f55813-122.08.1.r468.g9af41d5-1
                         kitemmodels5.98.0.r618.gdc308cd-15.98.0.r621.g7c5f2a2-1
                          kitemviews5.98.0.r383.gf9ff0f1-15.98.0.r386.g0a3c806-1
                          kitinerary22.08.1.r2386.g7fb9196-122.08.1.r2394.g903ea18-1
                         kjobwidgets5.98.0.r428.g1de71b2-15.98.0.r431.g4d2f999-1
                                 kjs5.98.0.r370.gd8755f9-15.98.0.r371.g8647a59-1
                            kjsembed5.98.0.r335.g92e03cc-15.98.0.r336.g790fa36-1
                        kjumpingcube22.08.1.r835.gadc4c50-122.08.1.r839.g3247359-1
                           kleopatra22.08.1.r6849.g0f4b3205-122.08.1.r6850.g8e527a1d-1
                            klickety22.08.1.r708.gdb9481b-122.08.1.r710.g7a33058-1
                              klines22.08.1.r835.g1cf8674-122.08.1.r836.g7834f4a-1
                           kmahjongg22.08.1.r1572.g923c705-122.08.1.r1575.g9eae5cf-1
                      kmailtransport22.08.1.r1762.g9eeaf6a-122.08.1.r1763.g0e4b04b-1
                        kmediaplayer5.98.0.r324.g77060a5-15.98.0.r325.gf28ed33-1
                           kmenuedit5.25.5.r1067.g87c38a3-15.25.5.r1073.gb012eed-1
                              kmines22.08.1.r1779.g6da5312-122.08.1.r1782.g5acee96-1
                        knavalbattle22.08.1.r1446.g8c77ca2-122.08.1.r1447.gde3836e-1
                            knetwalk22.08.1.r714.gc3077a0-122.08.1.r728.g533eb88-1
                           knewstuff5.98.0.r1385.g3538e95a-15.98.0.r1388.g35320e38-1
                             knights22.08.1.r1155.g5d8fcd1-122.08.1.r1157.gccdf867-1
                      knotifications5.98.0.r757.g190c316-15.98.0.r759.g6281974-1
                       knotifyconfig5.98.0.r393.g71dd801-15.98.0.r395.gf7228f4-1
                                koko 22.06.r17.g2b6fdde-1 22.06.r24.g6719be6-1
                                kolf22.08.1.r1520.g6e60a80-122.08.1.r1523.g2598f74-1
                           kollision22.08.1.r546.g966b81b-122.08.1.r548.g6ab62f4-1
                            kongress 22.06.r29.g67a91ab-1 22.06.r30.g9639f36-1
                           konqueror22.08.1.r15171.g093e76722-122.08.1.r15172.gc9f3d1957-1
                            konquest22.08.1.r950.g43ef992-122.08.1.r952.g5143f85-1
                             konsole22.08.1.r8614.g26c678e2-122.08.1.r8617.g2b3d46fa-1
                            kontrast22.08.1.r235.g9667712-122.08.1.r237.g386d770-1
                          korganizer22.08.1.r11796.g4c0125d79-122.08.1.r11797.g4f7fab3f2-1
                            kpackage5.98.0.r768.gc9d1f3d-15.98.0.r773.geb0cc78-1
                              kparts5.98.0.r599.g5ea9476-15.98.0.r601.gcd467a1-1
                                kpat22.08.1.r2631.ge867674a-122.08.1.r2638.g09f30038-1
                             kpeople5.98.0.r1385.g7ef76d6-15.98.0.r1388.g7d10f85-1
                        kpimtextedit22.08.1.r1623.gb9c0e14-122.08.1.r1624.gf3cdc48-1
                           kpipewire5.25.5.r138.gcef4bfc-15.25.5.r141.g2fa5913-1
                           kplotting5.98.0.r332.g6becc5c-15.98.0.r335.g8859977-1
                                kpty5.98.0.r385.g6d29a4f-15.98.0.r388.gdc2e4cb-1
                    kpublictransport22.08.1.r2044.g80e0e620-122.08.1.r2046.g1bc888f3-1
                        kquickcharts5.98.0.r534.g0c70041-15.98.0.r535.g907e6f7-1
                           krecorder 22.06.r23.g8a71b35-1 22.06.r25.gc263a6c-1
                            kreversi22.08.1.r1282.ge56b129-122.08.1.r1288.gcc0aee6-1
                               kross5.98.0.r366.g0e1db3e-15.98.0.r367.gd01acf1-1
                             krunner5.98.0.r786.g0f73c7a-15.98.0.r788.g6daf35c-1
                             kscreen5.25.5.r1532.g072f7d2-15.25.5.r1537.g58b71b4-1
                       kscreenlocker5.25.5.r981.gc5d4169-15.25.5.r988.g07e2e4d-1
                            kservice5.98.0.r1031.gcca46c7-15.98.0.r1033.g4f9844f-1
                             kshisen22.08.1.r1254.g6889e36-122.08.1.r1256.g9a87551-1
                               ksirk22.08.1.r1048.gd16cf92-122.08.1.r1050.gd98652a-1
                          ksnakeduel22.08.1.r866.g0bc5994-122.08.1.r867.g5bebcf7-1
                          kspaceduel22.08.1.r684.gf712f53-122.08.1.r686.g26f7611-1
                            ksquares22.08.1.r571.g3ce16cd-122.08.1.r574.g7cc207d-1
                         ksshaskpass5.25.5.r214.gf64c107-15.25.5.r217.g9064dd1-1
                             ksudoku22.08.1.r1135.gcbc8725-122.08.1.r1137.gfad8a9e-1
                        ksystemstats5.25.5.r234.g8175033-15.25.5.r237.g89b9c67-1
                         ktexteditor5.98.0.r3530.g17415653-15.98.0.r3545.gfa13320b-1
                        ktextwidgets5.98.0.r458.gb929a68-15.98.0.r460.gc1cb26b-1
                               ktnef22.08.1.r731.ge241cb1-122.08.1.r732.g08dbc1c-1
                               ktrip 22.06.r14.g3130146-1 22.06.r15.g3d5793e-1
                          ktuberling22.08.1.r1075.ge0ebc3a-122.08.1.r1089.g35d1440-1
                             kturtle22.08.1.r1186.gca7d0ef-122.08.1.r1187.g0f7f862-1
                             kubrick22.08.1.r419.gf5fd79b-122.08.1.r434.gdde3286-1
                     kunitconversion5.98.0.r428.g598f3a2-15.98.0.r430.g73d0917-1
                             kwallet5.98.0.r1177.g6522935-15.98.0.r1180.g2ce5ea8-1
                         kwallet-pam5.25.5.r274.ga7b1f15-15.25.5.r277.gb7fcbcf-1
                            kwayland5.98.0.r1182.gcb6e4e3-15.98.0.r1185.g315270d-1
                kwayland-integration5.25.5.r214.gbc75096-15.25.5.r218.g12a2791-1
                            kweather 22.06.r73.gc3f313d-1 22.06.r78.g561d6ec-1
                        kweathercore   0.6.r22.ge27d7c8-1   0.6.r24.gbed7445-1
                      kwidgetsaddons5.98.0.r981.gce728c52-15.98.0.r985.g9294cb7f-1
                                kwin5.25.5.r23172.g106d06125-15.25.5.r23215.gf2defd1df-1
                       kwindowsystem5.98.0.r695.gacf85e4-15.98.0.r697.g5618f22-1
                              kwrite22.08.1.r19533.gaba9082fd-122.08.1.r19581.gd650cd552-1
                             kwrited5.25.5.r517.g3ef9176-15.25.5.r520.g5ddc413-1
                             kxmlgui5.98.0.r905.g72919b5e-15.98.0.r908.g3726b9c3-1
                       kxmlrpcclient5.98.0.r488.ga317aa5fc-15.98.0.r489.g6e327a026-1
                      layer-shell-qt5.25.5.r64.g5af50ac-15.25.5.r67.g7b9c2c1-1
                         libkdegames22.08.1.r2256.g2529b8c6-122.08.1.r2263.g82613897-1
                            libkgapi22.08.1.r1377.g7ea83ff-122.08.1.r1378.gced5fe2-1
                             libkipi22.08.1.r1280.g5b6d13f-122.08.1.r1282.gabe801d-1
                        libkmahjongg22.08.1.r489.g38ac255-122.08.1.r491.g0dd8adc-1
                            libksane22.08.1.r605.g800eed2-122.08.1.r606.g65ca6b1-1
                          libkscreen5.25.5.r1637.gc6265f2-15.25.5.r1640.g5cf0d28-1
                        libksysguard5.25.5.r2430.g8e1f0fc-15.25.5.r2434.gc3655d6-1
                               lskat22.08.1.r866.g3211e3f-122.08.1.r868.g0403570-1
                        mailimporter22.08.1.r535.g0483511-122.08.1.r536.gecc74b6-1
                    maliit-framework 2.3.0.r2.g7a929ce8-2 2.3.0.r4.g19a763cb-1
                           maui-nota  2.2.0.r2.g1719b5d-1  2.2.0.r3.g65ca8ec-1
                            maui-pix  2.2.0.r5.g2d0e7bb-1  2.2.0.r8.g5ef7ce1-1
                          maui-shell 0.5.5.r16.g9fea97c-1 0.5.5.r18.ge077362-1
                             mauikit2.2.0.r11.g533a7027-12.2.0.r14.ge1516871-1
                    mauikit-accounts  2.2.0.r0.g9fa3cde-1  2.2.0.r2.g6fc7fa1-1
                mauikit-filebrowsing  2.2.0.r0.g3fd0caa-1  2.2.0.r2.gf82d491-1
                  mauikit-imagetools  2.2.0.r0.g478c15d-1  2.2.0.r1.g6176a4d-1
                  mauikit-texteditor  2.2.0.r1.g3dad8cc-1  2.2.0.r2.g7f00868-1
                               milou5.25.5.r783.g951b63d-15.25.5.r786.g28fdf01-1
                     modemmanager-qt5.98.0.r561.g07130ae-15.98.0.r564.g84f4ec4-1
             mycroft-skill-installer        r98.fc1ada8-1        r99.9d15a5e-1
                             neochat22.06.r127.g3797b012-122.06.r135.gd2ed1cfb-1
                   networkmanager-qt5.98.0.r1162.g4ec5aab-15.98.0.r1165.gbdae716-1
                              okular22.08.1.r9832.g2911f7a88-122.08.1.r9834.g804cadfb5-1
                              oxygen5.25.5.r4505.gc39dab71-15.25.5.r4508.g989fa534-1
                            palapeli22.08.1.r1311.g1feacd5-122.08.1.r1313.g145d8bf-1
                    partitionmanager22.08.1.r1644.g00a0f40-122.08.1.r1645.g923e449-1
                               picmi22.08.1.r567.g0daadd8-122.08.1.r587.g1043549-1
                        plank-player        r49.bb1c245-1        r55.9aa61fa-1
                    plasma-bigscreen      r505.g15257d7-1      r513.g885deff-1
          plasma-browser-integration5.25.5.r1352.g43589ce7-15.25.5.r1354.g9d4e7a64-1
                       plasma-camera  1.0.r132.g239459e-1  1.0.r133.gd326078-1
                      plasma-desktop5.25.5.r9628.gfb77be09d-15.25.5.r9653.g7204c2c95-1
                       plasma-dialer 22.06.r97.ge775b13-122.06.r118.gfaa6e37-1
                        plasma-disks5.25.5.r291.g97e0a00-15.25.5.r294.g5143e85-1
                     plasma-firewall5.25.5.r648.g914424c-15.25.5.r652.gd090cf4-1
                    plasma-framework5.98.0.r16415.g7cbafee75-15.98.0.r16427.g3ec8b097c-1
                  plasma-integration5.25.5.r576.g52bd3c9-15.25.5.r580.g97a2a80-1
                       plasma-mobile5.25.5.r1973.ga15475b8f-15.25.5.r1980.ge11f31f48-1
                    plasma-mobile-nm5.25.5.r3330.gf33cfdd8-15.25.5.r3336.ge914305c-1
                         plasma-nano5.25.5.r195.g66fe6fd-15.25.5.r196.ge5b051c-1
                           plasma-nm5.25.5.r3330.gf33cfdd8-15.25.5.r3336.ge914305c-1
                           plasma-pa5.25.5.r1086.gc022e8a-15.25.5.r1090.g0fee41e-1
                    plasma-phonebook 22.06.r19.g7e61336-1 22.06.r21.g150891f-1
            plasma-remotecontrollers      r130.gb11be55-1      r133.g4411c9c-1
                          plasma-sdk5.25.5.r2399.g57df86fc-15.25.5.r2403.g114fccad-1
                     plasma-settings 22.06.r94.gc756da8-1 22.06.r97.g5afcbb0-1
                plasma-systemmonitor5.25.5.r621.g9ca406b-15.25.5.r627.gbfe2062-1
                        plasma-vault5.25.5.r390.gacc70f5-15.25.5.r393.g564938f-1
            plasma-wayland-protocols1.4.0.r1060.gc958440-11.4.0.r1063.gab8fbdd-1
              plasma-wayland-session5.25.5.r12334.g48ffa11cd-15.25.5.r12379.gda38d4b03-1
                    plasma-workspace5.25.5.r12334.g48ffa11cd-15.25.5.r12379.gda38d4b03-1
         plasma-workspace-wallpapers5.25.5.r377.g59418f2-15.25.5.r382.g0f355ce-1
                          plasmatube 22.06.r30.gcd9313c-1 22.06.r32.g4594844-1
                    polkit-kde-agent5.25.5.r532.ga21bd57-15.25.5.r535.gf6e159c-1
                          powerdevil5.25.5.r2593.gcabacd5a-15.25.5.r2597.g0a37c1a7-1
                              prison5.98.0.r400.g83f1b09-15.98.0.r403.g3c3e1b7-1
                       pulseaudio-qt 1.3.0.r23.g126665b-1 1.3.0.r24.g648894d-1
                             purpose5.98.0.r996.g7605fe1-15.98.0.r998.g8a0ecf4-1
                          qmlkonsole 22.06.r41.g7602599-1 22.06.r43.g6f19359-1
                  qqc2-desktop-style5.98.0.r667.g50bec91-15.98.0.r671.ga6612fb-1
                                sddm0.19.0.r148.g0280166-10.19.0.r159.g21e965a-1
                            sddm-kcm5.25.5.r688.ga2f59af-15.25.5.r691.g3828937-1
                               solid5.98.0.r793.gb9ef941-15.98.0.r796.g2156b5e-1
                              sonnet5.98.0.r711.ge10fd9b-15.98.0.r714.gbad8b5d-1
                            spacebar 22.06.r70.gea1300b-1 22.06.r76.g538438b-1
                         syndication5.98.0.r883.g427c476-15.98.0.r886.gdadc406-1
                 syntax-highlighting5.98.0.r1922.g52b6928f-15.98.0.r1926.gb128085d-1
                      systemsettings5.25.5.r2712.gc9ce49e4-15.25.5.r2718.gb3ce91ba-1
          telepathy-kde-accounts-kcm22.08.1.r1220.g5d7feff-122.08.1.r1221.gf2005ff-1
              telepathy-kde-approver22.08.1.r306.g53cec00-122.08.1.r308.g156c44b-1
          telepathy-kde-auth-handler22.08.1.r285.gcb15eb7-122.08.1.r286.g8ce5b15-1
               telepathy-kde-call-ui22.08.1.r450.ga1ee093-122.08.1.r452.g88b3c1d-1
      telepathy-kde-common-internals22.08.1.r2024.g02d14eb-122.08.1.r2025.g8dd13f3-1
          telepathy-kde-contact-list22.08.1.r1094.g3721af4-122.08.1.r1095.g0752a93-1
        telepathy-kde-contact-runner22.08.1.r263.gac42a1d-122.08.1.r265.g2ba5909-1
       telepathy-kde-desktop-applets22.08.1.r1008.gaa3cc9d-122.08.1.r1009.g74f8391-1
  telepathy-kde-filetransfer-handler22.08.1.r228.g9e012f5-122.08.1.r229.g203f247-1
    telepathy-kde-integration-module22.08.1.r403.ga4e79eb-122.08.1.r404.g9d6c6b3-1
             telepathy-kde-send-file22.08.1.r237.g7c8384d-122.08.1.r238.ga0381d5-1
               telepathy-kde-text-ui22.08.1.r2050.g168fa8b-122.08.1.r2051.g0e0cac4-1
                        threadweaver5.98.0.r551.ga95dbf6-15.98.0.r555.gf2d78a3-1
                             tokodon 22.06.r36.g58852da-1 22.06.r37.g9f22197-1
                         vakzination 22.06.r48.g88ccd4a-1 22.06.r50.g0857b8f-1
                               vvave  2.2.0.r2.ga07311d-1  2.2.0.r4.g2686e9c-1
              xdg-desktop-portal-kde5.25.5.r520.g62dd495-15.25.5.r523.gdd3c2ff-1
                             yakuake22.08.1.r826.g50a8719-122.08.1.r828.gce92c38-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Before 2022-08-23
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Before 2022-07-22
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
firefox-105-1,-2/mesa-git, youtube went wrong miss red color.
Try with regular mesa.
And not sure what you mean with “youtube went wrong miss red color.”…
ok, wait mesa-22.2 & firefox-105.1 is out.
Arch has not updated to those yet.
webrender is no more software rendered in firefox 105. Cf. https://gitlab.freedesktop.org/mesa/mesa/-/issues/7062
Hi,
After upgrading to Testing 2022-09-22, Timeshift doesn’t start anymore (either in Plasma Wayland or Plasma X11), and was working perfectly before.
The error is :
❯ timeshift-launcher
localuser:root being added to access control list
(timeshift-gtk:12133): Gtk-WARNING **: 12:26:24.814: cannot open display:
localuser:root being removed from access control list
access control enabled, only authorized clients can connect
However, starting it from a terminal after ˘sudo -s”, works.
I suspect this is an environment or GUI authorization issue that might affect other applications.
I could fix this by editing /usr/bin/timeshift-launcher
And replace :
app_command='timeshift-gtk'
with :
app_command="env WAYLAND_DISPLAY=$WAYLAND_DISPLAY DISPLAY=$DISPLAY GDK_BACKEND=wayland,x11 timeshift-gtk"
Ad now it works, but I believe it’s a real dirty fix for something that I assume has changed outside of Timeshift itself…
