Every setting seems perfect. The bluetooth and wired headphone both work well. The only problem on my laptop is that the speaker does not work. The related informations are given below. If more information is needed, please tell me.
cat /proc/asound/cards
0 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xd1000000 irq 77
1 [Generic ]: HDA-Intel - HD-Audio Generic
HD-Audio Generic at 0xd1500000 irq 78
inxi -Fazy
Kernel: 5.15.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=338e7e42-79e0-4926-8108-7d8bfb18522d rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82N6 v: Lenovo Legion R9000K2021H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion R9000K2021H
Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN
serial: <superuser required> UEFI: LENOVO v: GKCN50WW date: 11/24/2021
ID-1: BAT0 charge: 82.9 Wh (98.9%) condition: 83.8/80.0 Wh (104.7%)
volts: 16.5 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly serial: <filter>
status: full cycles: 5
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1242 high: 1416 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1198 2: 1293
3: 1198 4: 1198 5: 1198 6: 1197 7: 1397 8: 1399 9: 1197 10: 1197 11: 1416
12: 1197 13: 1198 14: 1197 15: 1197 16: 1197 bogomips: 105444
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Lenovo driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-06) arch: Ampere
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24dc class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 5986:115f class-ID: fe01
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 191 s-size: 340x211mm (13.39x8.31")
s-diag: 400mm (15.75")
Monitor-1: DP-4 res: 2560x1600 dpi: 4064 size: 16x10mm (0.63x0.39")
diag: 19mm (0.74") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.53-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.54 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 262.47 GiB (27.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TDE9X084N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41010C22 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 262.44 GiB (54.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 31.6 MiB (12.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 38 C
Processes: 373 Uptime: 1h 9m wakeups: 1 Memory: 31.21 GiB
used: 4.36 GiB (14.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1551
lib: 395 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
pacmd dump
### Configuration dump generated at Wed Jul 13 17:39:56 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pc
i-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred
_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered
=1"
load-module module-alsa-card device_id="1" name="pci-0000_05_00.6" card_name="alsa_card.pc
i-0000_05_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred
=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/alan/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/alan/.Xauthority session_manager=l
ocal/alan-laptop:@/tmp/.ICE-unix/884,unix/alan-laptop:/tmp/.ICE-unix/884
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_05_00.6.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_05_00.6.analog-stereo no
suspend-sink alsa_output.pci-0000_05_00.6.analog-stereo yes
set-source-volume alsa_output.pci-0000_05_00.6.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_05_00.6.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_05_00.6.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_05_00.6.analog-stereo 0x100a9
set-source-mute alsa_input.pci-0000_05_00.6.analog-stereo no
suspend-source alsa_input.pci-0000_05_00.6.analog-stereo yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_05_00.6 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_05_00.6.analog-stereo
set-default-source alsa_input.pci-0000_05_00.6.analog-stereo
### EOF
amixer
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 65536 [100%] [on]
Front Right: Playback 65536 [100%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 65536
Front Left: Capture 65705 [100%] [on]
Front Right: Capture 65705 [100%] [on]
sudo alsa-info.sh --upload
!!ALSA Information Script v 0.5.1
!!Script ran on: Wed Jul 13 09:42:14 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: LENOVO
Product Name: 82N6
Product Version: Lenovo Legion R9000K2021H
Firmware Version: GKCN50WW
System SKU: LENOVO_MT_82N6_BU_idea_FM_Legion R9000K2021H
Board Vendor: LENOVO
Board Name: LNVNB161216
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/AMDI0010:01/status 15
/sys/bus/acpi/devices/AMDI0010:03/status 15
/sys/bus/acpi/devices/AMDI0030:00/status 15
/sys/bus/acpi/devices/CLSA0100:00/status 15
/sys/bus/acpi/devices/CPLM3218:02/status 15
/sys/bus/acpi/devices/LHK2019:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/NVDA0820:00/status 15
/sys/bus/acpi/devices/NXP8013:02/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/PNP0C50:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/VPC2004:00/status 15
/sys/bus/acpi/devices/device:22/status 15
/sys/bus/acpi/devices/device:3d/status 11
/sys/bus/acpi/devices/device:3e/status 11
/sys/bus/acpi/devices/device:3f/status 11
/sys/bus/acpi/devices/device:40/status 11
/sys/bus/acpi/devices/device:41/status 11
/sys/bus/acpi/devices/device:42/status 11
/sys/bus/acpi/devices/device:43/status 11
/sys/bus/acpi/devices/device:44/status 11
/sys/bus/acpi/devices/device:45/status 11
/sys/bus/acpi/devices/device:46/status 11
/sys/bus/acpi/devices/device:47/status 11
!!Kernel Information
Kernel release: 5.15.53-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.53-1-MANJARO
Library version: 1.2.7.1
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
!!PCI Soundcards installed in the system
01:00.1 Audio device [0403]: NVIDIA Corporation GA104 High Definition Audio Controller [10de:228b] (rev a1)
Control: I/O- Mem BusMaster SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
05:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller [1022:15e3]
Subsystem: Lenovo Device [17aa:382b]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Nvidia GPU 9e HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10de009e
Subsystem Id: 0xffffffff
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=01, enabled=1
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
*Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x05 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Converter: stream=0, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Unsolicited: tag=00, enabled=0
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Codec: Realtek ALC287
Address: 0
Vendor Id: 0x10ec0287
Subsystem Id: 0x17aa3847
Revision Id: 0x100002
Default PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=5, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC287 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x00 0x00]
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
Amp-Out vals: [0x57 0x57]
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0x3f 0x3f]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x25
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x03 0x03]
Pincap 0x00000020: IN
Pin Default 0x90a60140: [Fixed] Mic at Int N/A
DefAssociation = 0x4, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In vals: [0x00 0x00]
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Pincap 0x0000001c: OUT HP Detect
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 4
0x02 0x03* 0x06 0x08
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x03a11030: [Jack] Mic at Ext Left
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40600001: [N/A] Modem Line at Ext N/A
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=142
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x03211020: [Jack] HP Out at Ext Left
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Connection: 2
0x02* 0x03
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x19 0x1a 0x1b 0x1d 0x13
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
Connection: 5
0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 3
0x12* 0x13 0x18
Node 0x25 [Audio Selector] wcaps 0x300101: Stereo
Connection: 2
0x12* 0x13
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 9 Jul 13 16:29 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 13 Jul 13 16:29 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 8 Jul 13 16:29 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 12 Jul 13 16:29 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 6 Jul 13 16:29 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 7 Jul 13 16:29 /dev/snd/pcmC0D11p
crw-rw---- 1 root audio 116, 2 Jul 13 16:29 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 3 Jul 13 16:29 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 4 Jul 13 16:29 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 5 Jul 13 16:29 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 11 Jul 13 17:23 /dev/snd/pcmC1D0c
crw-rw---- 1 root audio 116, 10 Jul 13 17:23 /dev/snd/pcmC1D0p
crw-rw---- 1 root audio 116, 1 Jul 13 16:29 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jul 13 16:29 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jul 13 16:29 .
drwxr-xr-x 3 root root 340 Jul 13 16:29 ..
lrwxrwxrwx 1 root root 12 Jul 13 16:29 pci-0000:01:00.1 -> ../controlC0
lrwxrwxrwx 1 root root 12 Jul 13 16:29 pci-0000:05:00.6 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC287 Analog [ALC287 Analog]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card NVidia
Card sysdefault:0 'NVidia'/'HDA NVidia at 0xd1000000 irq 77'
Mixer name : 'Nvidia GPU 9e HDMI/DP'
Components : 'HDA:10de009e,ffffffff,00100100'
Controls : 42
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!-------Mixer controls for card Generic
Card sysdefault:1 'Generic'/'HD-Audio Generic at 0xd1500000 irq 78'
Mixer name : 'Realtek ALC287'
Components : 'HDA:10ec0287,17aa3847,00100002'
Controls : 18
Simple ctrls : 8
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [30.00dB] [on]
Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
!!Alsactl output
--startcollapse--
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Generic {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Volume'
value.0 63
value.1 63
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.7 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 3
value.1 3
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.10 {
iface MIXER
name 'Master Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.11 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.16 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.17 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.18 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
ccp
cfg80211
cm32181
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
ecdh_generic
edac_mce_amd
ext4
fat
fuse
ghash_clmulni_intel
hid_multitouch
i2c_hid
i2c_hid_acpi
i2c_piix4
i8042
ideapad_laptop
industrialio
intel_rapl_common
intel_rapl_msr
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mousedev
mt76
mt76_connac_lib
mt7921e
ns
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
pcspkr
pinctrl_amd
platform_profile
qrtr
r8169
rapl
realtek
rfcomm
rfkill
rng_core
roles
serio
serio_raw
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_timer
soundcore
sp5100_tco
sparse_keymap
squashfs
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wdat_wdt
wmi
wmi_bmof
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x04 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x90a60140
0x13 0x40000000
0x14 0x411111f0
0x17 0x90170110
0x18 0x411111f0
0x19 0x03a11030
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40600001
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 0.252352] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.252352] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.252352] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 2.047615] SVM: Virtual GIF supported
[ 2.052134] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 2.052254] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.052266] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.052410] snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
[ 2.091256] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[ 2.145725] MCE: In-kernel MCE decoding enabled.
[ 2.151652] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input11
[ 2.159932] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC287: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 2.159937] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.159939] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.159940] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 2.159941] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 2.159942] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 2.159943] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 2.181253] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input12
[ 2.217332] nvidia: loading out-of-tree module taints kernel.
[ 2.217339] Disabling lock debugging due to kernel taint
[ 2.225490] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input13
[ 2.225561] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input14
[ 2.225595] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input15
[ 2.225659] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input16
[ 2.233973] input: MSFT0001:00 06CB:CE44 Mouse as /devices/platform/AMDI0010:01/i2c-0/i2c-MSFT0001:00/0018:06CB:CE44.0001/input/input19
[ 2.258126] usb 1-4: Manufacturer: ITE Tech. Inc.
[ 2.267002] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input17
[ 2.267076] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input18
[ 2.298711] nvidia: module verification failed: signature and/or required key missing - tainting kernel
