Hello guys,
I have a SoundBlaster on dual boot machine. My main problem is if I am switching from Manjaro to Windows, sound is distorted and I need to shutdown and start again.
and also how to switch from headphones to speakers with KDE except alsamixer method
See this discussion regarding distortion problem in other OS
reddit.com/r/SoundBlasterOfficial - Sound Blaster AE-5 plus resets audio channels on restart
Switching between headphones and speakers requires changing one ALSA control, usually called Output Select (but Creative make many versions of AE-5 cards and some have different names for controls)
One alternative to using alsamixer is:
- Work out commands needed to switch the ALSA mixer control to either Headphone or Speaker output
- Use the commands in a script to toggle between Headphone and Speaker
- Create a keyboard shortcut or desktop launcher to run the toggle script
get ALSA audio device card numbers and names
cat /proc/asound/cards
and use the Soundblaster card number to get ALSA mixer control in text format
(e.g. if card number is 1):
amixer --card=1
To show the information needed to create the commands and script
script would be similar to this
#!/bin/bash
## soundblaster_output_switcher.sh
## toggle speakers/headphone output
# check if speakers are set for output
if (amixer --card=1 sget "Output Select" | grep "Item0: 'Speakers'") > /dev/null;
then
# set headphone output
amixer --quiet --card=1 sset "Output Select" Headphone
else
# select speaker output
amixer --quiet --card=1 sset "Output Select" Speakers
fi
