Hi there!
Well, that’s gonna be along post. Here we go:
Kernel 5.4 pa-info
Devices: 0
Connection: 0
In-driver Connection: 3
0x02 0x03 0x04
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 11 Nov 28 16:54 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 9 Nov 28 16:54 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 10 Nov 28 16:54 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 3 Nov 28 16:57 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 2 Nov 28 20:34 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 8 Nov 28 16:57 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116, 4 Nov 28 16:57 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 5 Nov 28 16:57 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 6 Nov 28 16:57 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 7 Nov 28 16:57 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 1 Nov 28 16:57 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Nov 28 16:54 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Nov 28 16:54 .
drwxr-xr-x 3 root root 300 Nov 28 16:54 ..
lrwxrwxrwx 1 root root 12 Nov 28 16:54 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC233 Analog [ALC233 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xc4318000 irq 149'
Mixer name : 'Realtek ALC233'
Components : 'HDA:10ec0235,1b0a2440,00100002 HDA:8086280b,80860101,00100000'
Controls : 54
Simple ctrls : 14
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 79 [91%] [-6.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Beep',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.7 {
iface MIXER
name 'Capture Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.8 {
iface MIXER
name 'Capture Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.11 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Master Playback Volume'
value 79
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -600
control.13 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.18 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.19 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.44 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.45 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.46 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.47 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.48 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.49 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.50 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.51 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.52 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.53 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.54 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac
ac97_bus
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
agpgart
ahci
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
cmac
cmdlinepart
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
eeprom
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_i801
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libahci
libarc4
libata
libps2
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
memstick
mmc_core
mousedev
mtd
mxm_wmi
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
ofpart
pcspkr
processor_thermal_device
rapl
rfcomm
rfkill
rng_core
rtsx_usb
rtsx_usb_ms
rtsx_usb_sdmmc
scsi_mod
sd_mod
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_nhlt
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
spi_nor
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x90a60130
0x14 0x90170110
0x17 0x40000000
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40f79a2d
0x1e 0x411111f0
0x21 0x04211020
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
Kernel 5.4 dmesg | egrep -i ‘(snd|sound|sof|alsa|hda)’
[ 0.810441] pci 0000:02:00.0: Enabling HDA controller
[ 0.819424] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.199354] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.199357] software IO TLB: mapped [mem 0x92b6e000-0x96b6e000] (64MB)
[ 4.502205] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.503006] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.605829] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC233: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.605831] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.605832] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.605833] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.605833] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.605834] snd_hda_codec_realtek hdaudioC0D0: Mic=0x12
[ 4.707201] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 4.707246] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 4.707288] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 4.707327] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 4.707365] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 4.707403] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 4.707440] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 5.716048] nvidia 0000:02:00.0: Enabling HDA controller
[ 6.339639] nvidia 0000:02:00.0: Enabling HDA controller
Kernel 5.9 pa-info
pa-info
Server Version: 14.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: 31bc:0b9a
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.0"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #7
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #9
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #12
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #15
Argument: sink_name=auto_null sink_properties='device.description="Dummy Output"'
Usage counter: 0
Properties:
module.description = "Clocked NULL sink"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #24
Argument: display=:0 xauthority=/home/user0/.Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #25
Argument: display=:0 xauthority=/home/user0/.Xauthority session_manager=local/notebook0:@/tmp/.ICE-unix/1147,unix/notebook0:/tmp/.ICE-unix/1147
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: SUSPENDED
Description: Dummy Output
Driver: module-null-sink.c
Owner Module: 15
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of Dummy Output
Owner Module: 15
Mute: no
balance 0.00
Monitor of Sink: auto_null
Properties:
device.description = "Monitor of Dummy Output"
device.class = "monitor"
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 19
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #3
Driver: module-x11-xsmp.c
Owner Module: 25
Properties:
application.name = "XSMP Session on KDE as 10100dee3d0000160659386900000011470004"
xsmp.vendor = "KDE"
xsmp.client.id = "10100dee3d0000160659386900000011470004"
Client #4
Driver: protocol-native.c
Owner Module: 11
Properties:
application.name = "QPulse"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.process.id = "1155"
application.process.user = "user0"
application.process.host = "notebook0"
application.process.binary = "plasmashell"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "a49a39bb229d4f68a7ee327fbdb899a1"
application.process.session_id = "2"
Client #6
Owner Module: 11
Properties:
application.name = "pactl"
application.process.id = "1610"
application.process.binary = "pactl"
application.language = "C"
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 33 Nov 28 21:04 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Nov 28 21:04 /dev/snd/seq
________________
> lsof /dev/snd/*
________________
> jacks_do
ls: cannot access '/proc/asound/card[0-9]': No such file or directory
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
________________
> alsa_info_do
alsactl: save_state:1595: No soundcards found...
cat: /tmp/alsa-info.Nbu9EzF67B/alsactl.tmp: No such file or directory
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Sat Nov 28 21:28:31 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: MEDION
Product Name: P15647 MD61662
Product Version: Default string
Firmware Version: 207
System SKU: ML-230008 30027558
Board Vendor: MEDION
Board Name: M15CLN
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/FTCS1000:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT34BB:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 15
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:03/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C0A:03/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/PTK0001:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:11/status 15
/sys/bus/acpi/devices/device:87/status 15
!!Kernel Information
Kernel release: 5.9.11-3-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.11-3-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
--- no soundcards ---
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:02c8] (prog-if 80)
DeviceName: Onboard - Sound
!!Loaded sound module options
!!ALSA Device nodes
APLAY
aplay: device_list:274: no soundcards found...
ARECORD
arecord: device_list:274: no soundcards found...
!!Amixer output
!!Alsactl output
--startcollapse--
--endcollapse--
8250_dw
ac
ac97_bus
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
cmdlinepart
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
eeprom
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
memstick
mmc_core
mousedev
mtd
mxm_wmi
nls_cp437
nls_iso8859_1
ofpart
pcspkr
rapl
rc_core
rfcomm
rfkill
rng_core
rtsx_usb
rtsx_usb_ms
rtsx_usb_sdmmc
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
spi_nor
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
!!ALSA/HDA dmesg
Kernel 5.9 dmesg | egrep -i ‘(snd|sound|sof|alsa|hda)’
[ 0.553535] pci 0000:02:00.0: Enabling HDA controller
[ 0.562393] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.876098] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.876100] software IO TLB: mapped [mem 0x92b6e000-0x96b6e000] (64MB)
[ 4.216277] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 4.216283] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.498078] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 4.498082] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.618246] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 4.618250] sof-audio-pci 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.618284] sof-audio-pci 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.618514] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 4.618630] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.626764] sof-audio-pci 0000:00:1f.3: use msi interrupt mode
[ 4.679078] sof-audio-pci 0000:00:1f.3: hda codecs found, mask 5
[ 4.679079] sof-audio-pci 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 4.679082] sof-audio-pci 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 4.679234] sof-audio-pci 0000:00:1f.3: Direct firmware load for intel/sof/sof-cml.ri failed with error -2
[ 4.679235] sof-audio-pci 0000:00:1f.3: error: request firmware intel/sof/sof-cml.ri failed err: -2
[ 4.679236] sof-audio-pci 0000:00:1f.3: error: failed to load DSP firmware -2
[ 4.680008] sof-audio-pci 0000:00:1f.3: error: sof_probe_work failed err: -2
Thx for helping!
