Sound stops in USB bluetooth earphones when USB microphone plugged in
The earphones are Sony WF-C700N via an Asus USB dongle. The microphone is a Rode NT-USB:
    ~  aplay -L         ✔
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
    HDA Intel PCH, ALC1220 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
    HDA Intel PCH, ALC1220 Digital
    IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, W2243
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
usbstream:CARD=C920
    HD Pro Webcam C920
    USB Stream Output
sysdefault:CARD=NTUSB
    RODE NT-USB, USB Audio
front:CARD=NTUSB,DEV=0
surround21:CARD=NTUSB,DEV=0
surround40:CARD=NTUSB,DEV=0
surround41:CARD=NTUSB,DEV=0
surround50:CARD=NTUSB,DEV=0
surround51:CARD=NTUSB,DEV=0
surround71:CARD=NTUSB,DEV=0
iec958:CARD=NTUSB,DEV=0
usbstream:CARD=NTUSB
    RODE NT-USB
    USB Stream Output
These devices were working together without any problem for months if not years. Then a few months ago (delay in seeking help due to a bereavement) I logged into a Zoom meeting to discover I had no sound from the earphones. I soon discovered that from then on, as soon as
I plugged in the mic I lost the sound in the earphones, though they stayed connected. Unplug the mic and the sound returns immediately. I’m able to continue online meetings etc because both the earphones and my webcam also have a built in mic, though nothing like the quality of the Rode.
Here’s the output from dmesg following a session including a Google Meet video call during which I plugged and unplugged the microphone several times:
    ~  sudo dmesg         ✔
[sudo] password for nick:
[    0.000000] Linux version 6.18.18-1-MANJARO (linux618@manjaro) (gcc (GCC) 15.2.1 20260209, GNU ld (GNU Binutils) 2.46) #1 SMP PREEMPT_DYNAMIC Fri, 13 Mar 2026 18:47:36 +0000
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008b593fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008b594000-0x000000008b5cefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008b5cf000-0x000000008b982fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008b983000-0x000000008b983fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008b984000-0x000000008b984fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008b985000-0x0000000098688fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000098689000-0x0000000099f45fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000099f46000-0x0000000099f5afff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000099f5b000-0x000000009a05afff] usable
[    0.000000] BIOS-e820: [mem 0x000000009a05b000-0x000000009a382fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000009a383000-0x000000009afa1fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000009afa2000-0x000000009affffff] usable
[    0.000000] BIOS-e820: [mem 0x000000009b000000-0x000000009fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000045effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: System manufacturer System Product Name/PRIME Z370-A, BIOS 0606 12/12/2017
[    0.000000] DMI: Memory slots populated: 2/4
[    0.000000] tsc: Detected 3200.000 MHz processor
[    0.000000] tsc: Detected 3199.980 MHz TSC
[    0.000672] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000675] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000685] last_pfn = 0x45f000 max_arch_pfn = 0x400000000
[    0.000688] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[    0.000690] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001040] last_pfn = 0x9b000 max_arch_pfn = 0x400000000
[    0.007747] found SMP MP-table at [mem 0x000fcee0-0x000fceef]
[    0.007762] Using GB pages for direct mapping
[    0.008304] RAMDISK: [mem 0x271ff000-0x2f8f6fff]
[    0.008396] ACPI: Early table checksum verification disabled
[    0.008399] ACPI: RSDP 0x00000000000F05B0 000024 (v02 ALASKA)
[    0.008402] ACPI: XSDT 0x000000008B5940A8 0000CC (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008407] ACPI: FACP 0x000000008B5C1EB0 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.008412] ACPI: DSDT 0x000000008B594210 02DC9C (v02 ALASKA A M I    01072009 INTL 20160422)
[    0.008415] ACPI: FACS 0x000000009A382F00 000040
[    0.008418] ACPI: APIC 0x000000008B5C1FC8 0000F4 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.008420] ACPI: FPDT 0x000000008B5C20C0 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008423] ACPI: FIDT 0x000000008B5C2108 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008426] ACPI: WSMT 0x000000008B5CEB68 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008428] ACPI: MCFG 0x000000008B5C2200 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.008431] ACPI: SSDT 0x000000008B5C2240 0003A3 (v01 SataRe SataTabl 00001000 INTL 20160422)
[    0.008434] ACPI: SSDT 0x000000008B5C25E8 003043 (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.008437] ACPI: SSDT 0x000000008B5C5630 002611 (v02 PegSsd PegSsdt  00001000 INTL 20160422)
[    0.008440] ACPI: HPET 0x000000008B5C7C48 000038 (v01 INTEL  KBL      00000001 MSFT 0000005F)
[    0.008442] ACPI: SSDT 0x000000008B5C7C80 0011A2 (v02 INTEL  Ther_Rvp 00001000 INTL 20160422)
[    0.008446] ACPI: SSDT 0x000000008B5C8E28 000B13 (v02 INTEL  xh_rvp08 00000000 INTL 20160422)
[    0.008448] ACPI: UEFI 0x000000008B5C9940 000042 (v01 ALASKA A M I    00000002      01000013)
[    0.008451] ACPI: SSDT 0x000000008B5C9988 0017AE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.008454] ACPI: LPIT 0x000000008B5CB138 000094 (v01 INTEL  KBL      00000000 MSFT 0000005F)
[    0.008456] ACPI: SSDT 0x000000008B5CB1D0 000141 (v02 INTEL  HdaDsp   00000000 INTL 20160422)
[    0.008459] ACPI: SSDT 0x000000008B5CB318 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.008462] ACPI: SSDT 0x000000008B5CB5B8 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
[    0.008465] ACPI: SSDT 0x000000008B5CE5C0 000517 (v02 INTEL  TbtTypeC 00000000 INTL 20160422)
[    0.008467] ACPI: DBGP 0x000000008B5CEAD8 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.008470] ACPI: DBG2 0x000000008B5CEB10 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.008472] ACPI: Reserving FACP table memory at [mem 0x8b5c1eb0-0x8b5c1fc3]
[    0.008474] ACPI: Reserving DSDT table memory at [mem 0x8b594210-0x8b5c1eab]
[    0.008474] ACPI: Reserving FACS table memory at [mem 0x9a382f00-0x9a382f3f]
[    0.008475] ACPI: Reserving APIC table memory at [mem 0x8b5c1fc8-0x8b5c20bb]
[    0.008476] ACPI: Reserving FPDT table memory at [mem 0x8b5c20c0-0x8b5c2103]
[    0.008476] ACPI: Reserving FIDT table memory at [mem 0x8b5c2108-0x8b5c21a3]
[    0.008477] ACPI: Reserving WSMT table memory at [mem 0x8b5ceb68-0x8b5ceb8f]
[    0.008478] ACPI: Reserving MCFG table memory at [mem 0x8b5c2200-0x8b5c223b]
[    0.008478] ACPI: Reserving SSDT table memory at [mem 0x8b5c2240-0x8b5c25e2]
[    0.008479] ACPI: Reserving SSDT table memory at [mem 0x8b5c25e8-0x8b5c562a]
[    0.008480] ACPI: Reserving SSDT table memory at [mem 0x8b5c5630-0x8b5c7c40]
[    0.008480] ACPI: Reserving HPET table memory at [mem 0x8b5c7c48-0x8b5c7c7f]
[    0.008481] ACPI: Reserving SSDT table memory at [mem 0x8b5c7c80-0x8b5c8e21]
[    0.008482] ACPI: Reserving SSDT table memory at [mem 0x8b5c8e28-0x8b5c993a]
[    0.008482] ACPI: Reserving UEFI table memory at [mem 0x8b5c9940-0x8b5c9981]
[    0.008483] ACPI: Reserving SSDT table memory at [mem 0x8b5c9988-0x8b5cb135]
[    0.008484] ACPI: Reserving LPIT table memory at [mem 0x8b5cb138-0x8b5cb1cb]
[    0.008484] ACPI: Reserving SSDT table memory at [mem 0x8b5cb1d0-0x8b5cb310]
[    0.008485] ACPI: Reserving SSDT table memory at [mem 0x8b5cb318-0x8b5cb5b6]
[    0.008486] ACPI: Reserving SSDT table memory at [mem 0x8b5cb5b8-0x8b5ce5b9]
[    0.008486] ACPI: Reserving SSDT table memory at [mem 0x8b5ce5c0-0x8b5cead6]
[    0.008487] ACPI: Reserving DBGP table memory at [mem 0x8b5cead8-0x8b5ceb0b]
[    0.008488] ACPI: Reserving DBG2 table memory at [mem 0x8b5ceb10-0x8b5ceb63]
[    0.008709] No NUMA configuration found
[    0.008710] Faking a node at [mem 0x0000000000000000-0x000000045effffff]
[    0.008718] NODE_DATA(0) allocated [mem 0x45efd5280-0x45effffff]
[    0.008906] Zone ranges:
[    0.008906]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.008908]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.008910]   Normal   [mem 0x0000000100000000-0x000000045effffff]
[    0.008911]   Device   empty
[    0.008912] Movable zone start for each node
[    0.008914] Early memory node ranges
[    0.008914]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.008915]   node   0: [mem 0x0000000000100000-0x000000008b593fff]
[    0.008916]   node   0: [mem 0x000000008b5cf000-0x000000008b982fff]
[    0.008917]   node   0: [mem 0x000000008b985000-0x0000000098688fff]
[    0.008918]   node   0: [mem 0x0000000099f5b000-0x000000009a05afff]
[    0.008919]   node   0: [mem 0x000000009afa2000-0x000000009affffff]
[    0.008919]   node   0: [mem 0x0000000100000000-0x000000045effffff]
[    0.008921] Initmem setup node 0 [mem 0x0000000000001000-0x000000045effffff]
[    0.008926] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.008944] On node 0, zone DMA: 99 pages in unavailable ranges
[    0.011553] On node 0, zone DMA32: 59 pages in unavailable ranges
[    0.011793] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.011837] On node 0, zone DMA32: 6354 pages in unavailable ranges
[    0.011862] On node 0, zone DMA32: 3911 pages in unavailable ranges
[    0.028370] On node 0, zone Normal: 20480 pages in unavailable ranges
[    0.028397] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.028659] ACPI: PM-Timer IO Port: 0x1808
[    0.028669] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.028670] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.028671] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.028672] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.028672] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.028673] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.028674] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.028674] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.028675] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.028676] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.028676] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.028677] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.028703] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.028706] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.028707] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.028712] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.028713] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.028716] TSC deadline timer available
[    0.028720] CPU topo: Max. logical packages:   1
[    0.028721] CPU topo: Max. logical dies:       1
[    0.028721] CPU topo: Max. dies per package:   1
[    0.028725] CPU topo: Max. threads per core:   2
[    0.028726] CPU topo: Num. cores per package:     6
[    0.028727] CPU topo: Num. threads per package:  12
[    0.028727] CPU topo: Allowing 12 present CPUs plus 0 hotplug CPUs
[    0.028744] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.028746] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x000fffff]
[    0.028747] PM: hibernation: Registered nosave memory: [mem 0x8b594000-0x8b5cefff]
[    0.028749] PM: hibernation: Registered nosave memory: [mem 0x8b983000-0x8b984fff]
[    0.028750] PM: hibernation: Registered nosave memory: [mem 0x98689000-0x99f5afff]
[    0.028752] PM: hibernation: Registered nosave memory: [mem 0x9a05b000-0x9afa1fff]
[    0.028753] PM: hibernation: Registered nosave memory: [mem 0x9b000000-0xffffffff]
[    0.028754] [mem 0xa0000000-0xdfffffff] available for PCI devices
[    0.028755] Booting paravirtualized kernel on bare hardware
[    0.028757] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.035137] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
[    0.035585] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[    0.035592] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.035594] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.035615] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[    0.035704] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.035730] random: crng init done
[    0.035731] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.036907] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.037493] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.037670] software IO TLB: area num 16.
[    0.047444] Fallback order for Node 0: 0
[    0.047448] Built 1 zonelists, mobility grouping on.  Total pages: 4159302
[    0.047449] Policy zone: Normal
[    0.047621] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.078026] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.078054] Kernel/User page tables isolation: enabled
[    0.086618] ftrace: allocating 57230 entries in 224 pages
[    0.086619] ftrace: allocated 224 pages with 3 groups
[    0.086692] Dynamic Preempt: full
[    0.086749] rcu: Preemptible hierarchical RCU implementation.
[    0.086750] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=12.
[    0.086751] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.086752] 	Trampoline variant of Tasks RCU enabled.
[    0.086753] 	Rude variant of Tasks RCU enabled.
[    0.086753] 	Tracing variant of Tasks RCU enabled.
[    0.086754] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.086754] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.086764] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[    0.086765] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[    0.086767] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[    0.092578] NR_IRQS: 524544, nr_irqs: 2152, preallocated irqs: 16
[    0.092798] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.093038] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.093080] Console: colour dummy device 80x25
[    0.093082] printk: legacy console [tty0] enabled
[    0.093125] ACPI: Core revision 20250807
[    0.093354] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.093421] APIC: Switch to symmetric I/O mode setup
[    0.094643] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.098813] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.103368] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e2036ff8d5, max_idle_ns: 440795275316 ns
[    0.103373] Calibrating delay loop (skipped), value calculated using timer frequency.. 6399.96 BogoMIPS (lpj=3199980)
[    0.103393] x86/cpu: SGX disabled or unsupported by BIOS.
[    0.103397] CPU0: Thermal monitoring enabled (TM1)
[    0.103444] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.103445] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[    0.103451] process: using mwait in idle threads
[    0.103454] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
[    0.103458] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.103459] SRBDS: Mitigation: Microcode
[    0.103461] Spectre V2 : Mitigation: IBRS
[    0.103462] RETBleed: Mitigation: IBRS
[    0.103463] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.103464] MDS: Mitigation: Clear CPU buffers
[    0.103464] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.103465] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.103466] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.103467] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.103469] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.103479] GDS: Mitigation: Microcode
[    0.103484] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.103486] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.103487] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.103489] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.103490] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.103492] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.103493] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.103495] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.103496] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.137557] Freeing SMP alternatives memory: 56K
[    0.137561] pid_max: default: 32768 minimum: 301
[    0.137600] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[    0.137660] landlock: Up and running.
[    0.137662] Yama: becoming mindful.
[    0.137855] LSM support for eBPF active
[    0.137923] AppArmor: AppArmor initialized
[    0.137956] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.137971] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.138427] smpboot: CPU0: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.138602] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.138624] ... version:                   4
[    0.138625] ... bit width:                 48
[    0.138626] ... generic counters:          4
[    0.138627] ... generic bitmap:            000000000000000f
[    0.138628] ... fixed-purpose counters:    3
[    0.138629] ... fixed-purpose bitmap:      0000000000000007
[    0.138630] ... value mask:                0000ffffffffffff
[    0.138631] ... max period:                00007fffffffffff
[    0.138632] ... global_ctrl mask:          000000070000000f
[    0.138802] signal: max sigframe size: 2032
[    0.138816] Estimated ratio of average max frequency by base frequency (times 1024): 1376
[    0.140648] rcu: Hierarchical SRCU implementation.
[    0.140649] rcu: 	Max phase no-delay instances is 400.
[    0.140704] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.141502] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.141592] smp: Bringing up secondary CPUs ...
[    0.141681] smpboot: x86: Booting SMP configuration:
[    0.141682] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11
[    0.146577] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.146577] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.146577] VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
[    0.146577] smp: Brought up 1 node, 12 CPUs
[    0.146577] smpboot: Total of 12 processors activated (76799.52 BogoMIPS)
[    0.147488] Memory: 16065024K/16637208K available (20276K kernel code, 2955K rwdata, 16368K rodata, 4736K init, 4764K bss, 552856K reserved, 0K cma-reserved)
[    0.147840] devtmpfs: initialized
[    0.147840] x86/mm: Memory block size: 128MB
[    0.149620] ACPI: PM: Registering ACPI NVS region [mem 0x8b983000-0x8b983fff] (4096 bytes)
[    0.149620] ACPI: PM: Registering ACPI NVS region [mem 0x9a05b000-0x9a382fff] (3309568 bytes)
[    0.149620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.149620] posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.149620] futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
[    0.149620] pinctrl core: initialized pinctrl subsystem
[    0.149666] PM: RTC time: 08:46:51, date: 2026-04-26
[    0.150567] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.150852] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.150951] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.151050] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.151056] audit: initializing netlink subsys (disabled)
[    0.151062] audit: type=2000 audit(1777193211.054:1): state=initialized audit_enabled=0 res=1
[    0.151062] thermal_sys: Registered thermal governor 'fair_share'
[    0.151062] thermal_sys: Registered thermal governor 'bang_bang'
[    0.151062] thermal_sys: Registered thermal governor 'step_wise'
[    0.151062] thermal_sys: Registered thermal governor 'user_space'
[    0.151062] thermal_sys: Registered thermal governor 'power_allocator'
[    0.151062] cpuidle: using governor ladder
[    0.151062] cpuidle: using governor menu
[    0.151062] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.151062] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.151394] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.151407] PCI: Using configuration type 1 for base access
[    0.151549] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.157441] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.157441] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.157441] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.157441] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.157922] raid6: skipped pq benchmark and selected avx2x4
[    0.157922] raid6: using avx2x2 recovery algorithm
[    0.157922] ACPI: Added _OSI(Module Device)
[    0.157922] ACPI: Added _OSI(Processor Device)
[    0.157922] ACPI: Added _OSI(Processor Aggregator Device)
[    0.204089] ACPI: 11 ACPI AML tables successfully acquired and loaded
[    0.212201] ACPI: Dynamic OEM Table Load:
[    0.212208] ACPI: SSDT 0xFFFF8B5D40E27C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.212696] ACPI: Dynamic OEM Table Load:
[    0.212702] ACPI: SSDT 0xFFFF8B5D40E33000 0006D5 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.215789] ACPI: Dynamic OEM Table Load:
[    0.215796] ACPI: SSDT 0xFFFF8B5D40E2B000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.218002] ACPI: Dynamic OEM Table Load:
[    0.218007] ACPI: SSDT 0xFFFF8B5D40E25400 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.219437] ACPI: Dynamic OEM Table Load:
[    0.219443] ACPI: SSDT 0xFFFF8B5D40E23000 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.227527] ACPI: EC: EC started
[    0.227529] ACPI: EC: interrupt blocked
[    0.228399] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.228402] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.228404] ACPI: Interpreter enabled
[    0.228442] ACPI: PM: (supports S0 S3 S4 S5)
[    0.228443] ACPI: Using IOAPIC for interrupt routing
[    0.230191] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.230193] PCI: Using E820 reservations for host bridge windows
[    0.231495] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.235741] ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
[    0.236145] ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
[    0.236549] ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
[    0.270922] ACPI: \_TZ_.FN00: New power resource
[    0.271013] ACPI: \_TZ_.FN01: New power resource
[    0.271100] ACPI: \_TZ_.FN02: New power resource
[    0.271187] ACPI: \_TZ_.FN03: New power resource
[    0.271274] ACPI: \_TZ_.FN04: New power resource
[    0.273536] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.273544] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.273673] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.273907] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.273909] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.275409] PCI host bridge to bus 0000:00
[    0.275414] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.275416] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.275418] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.275419] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xdfffffff window]
[    0.275421] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.275423] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.275514] pci 0000:00:00.0: [8086:3ec2] type 00 class 0x060000 conventional PCI endpoint
[    0.275591] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Root Port
[    0.275602] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.275605] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.275608] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.275613] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.275641] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.276100] pci 0000:00:02.0: [8086:3e92] type 00 class 0x038000 PCIe Root Complex Integrated Endpoint
[    0.276115] pci 0000:00:02.0: BAR 0 [mem 0xdd000000-0xddffffff 64bit]
[    0.276118] pci 0000:00:02.0: BAR 2 [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.276120] pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
[    0.276390] pci 0000:00:14.0: [8086:a2af] type 00 class 0x0c0330 conventional PCI endpoint
[    0.276424] pci 0000:00:14.0: BAR 0 [mem 0xdf830000-0xdf83ffff 64bit]
[    0.276460] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.277313] pci 0000:00:16.0: [8086:a2ba] type 00 class 0x078000 conventional PCI endpoint
[    0.277356] pci 0000:00:16.0: BAR 0 [mem 0xdf84d000-0xdf84dfff 64bit]
[    0.277401] pci 0000:00:16.0: PME# supported from D3hot
[    0.278005] pci 0000:00:17.0: [8086:a282] type 00 class 0x010601 conventional PCI endpoint
[    0.278035] pci 0000:00:17.0: BAR 0 [mem 0xdf848000-0xdf849fff]
[    0.278038] pci 0000:00:17.0: BAR 1 [mem 0xdf84c000-0xdf84c0ff]
[    0.278040] pci 0000:00:17.0: BAR 2 [io  0xf090-0xf097]
[    0.278043] pci 0000:00:17.0: BAR 3 [io  0xf080-0xf083]
[    0.278045] pci 0000:00:17.0: BAR 4 [io  0xf060-0xf07f]
[    0.278047] pci 0000:00:17.0: BAR 5 [mem 0xdf84b000-0xdf84b7ff]
[    0.278078] pci 0000:00:17.0: PME# supported from D3hot
[    0.278435] pci 0000:00:1b.0: [8086:a2e7] type 01 class 0x060400 PCIe Root Port
[    0.278453] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.278457] pci 0000:00:1b.0:   bridge window [mem 0xdf700000-0xdf7fffff]
[    0.278509] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.279204] pci 0000:00:1b.4: [8086:a2eb] type 01 class 0x060400 PCIe Root Port
[    0.279222] pci 0000:00:1b.4: PCI bridge to [bus 03]
[    0.279227] pci 0000:00:1b.4:   bridge window [mem 0xdf600000-0xdf6fffff]
[    0.279277] pci 0000:00:1b.4: PME# supported from D0 D3hot D3cold
[    0.279965] pci 0000:00:1c.0: [8086:a290] type 01 class 0x060400 PCIe Root Port
[    0.279983] pci 0000:00:1c.0: PCI bridge to [bus 04-05]
[    0.279987] pci 0000:00:1c.0:   bridge window [mem 0xdf100000-0xdf2fffff]
[    0.280039] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.280714] pci 0000:00:1c.1: [8086:a291] type 01 class 0x060400 PCIe Root Port
[    0.280732] pci 0000:00:1c.1: PCI bridge to [bus 06]
[    0.280735] pci 0000:00:1c.1:   bridge window [io  0xd000-0xdfff]
[    0.280738] pci 0000:00:1c.1:   bridge window [mem 0xdf500000-0xdf5fffff]
[    0.280790] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.281468] pci 0000:00:1c.4: [8086:a294] type 01 class 0x060400 PCIe Root Port
[    0.281486] pci 0000:00:1c.4: PCI bridge to [bus 07]
[    0.281490] pci 0000:00:1c.4:   bridge window [mem 0xdf400000-0xdf4fffff]
[    0.281542] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.282229] pci 0000:00:1d.0: [8086:a298] type 01 class 0x060400 PCIe Root Port
[    0.282246] pci 0000:00:1d.0: PCI bridge to [bus 08]
[    0.282251] pci 0000:00:1d.0:   bridge window [mem 0xdf300000-0xdf3fffff]
[    0.282302] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.283000] pci 0000:00:1f.0: [8086:a2c9] type 00 class 0x060100 conventional PCI endpoint
[    0.283398] pci 0000:00:1f.2: [8086:a2a1] type 00 class 0x058000 conventional PCI endpoint
[    0.283435] pci 0000:00:1f.2: BAR 0 [mem 0xdf844000-0xdf847fff]
[    0.283746] pci 0000:00:1f.3: [8086:a2f0] type 00 class 0x040300 conventional PCI endpoint
[    0.283792] pci 0000:00:1f.3: BAR 0 [mem 0xdf840000-0xdf843fff 64bit]
[    0.283798] pci 0000:00:1f.3: BAR 4 [mem 0xdf820000-0xdf82ffff 64bit]
[    0.283838] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.284893] pci 0000:00:1f.4: [8086:a2a3] type 00 class 0x0c0500 conventional PCI endpoint
[    0.285022] pci 0000:00:1f.4: BAR 0 [mem 0xdf84a000-0xdf84a0ff 64bit]
[    0.285033] pci 0000:00:1f.4: BAR 4 [io  0xf040-0xf05f]
[    0.285370] pci 0000:00:1f.6: [8086:15b8] type 00 class 0x020000 conventional PCI endpoint
[    0.285423] pci 0000:00:1f.6: BAR 0 [mem 0xdf800000-0xdf81ffff]
[    0.285480] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.285820] pci 0000:01:00.0: [10de:1c82] type 00 class 0x030000 PCIe Legacy Endpoint
[    0.285851] pci 0000:01:00.0: BAR 0 [mem 0xde000000-0xdeffffff]
[    0.285854] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.285857] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.285859] pci 0000:01:00.0: BAR 5 [io  0xe000-0xe07f]
[    0.285862] pci 0000:01:00.0: ROM [mem 0xdf000000-0xdf07ffff pref]
[    0.285890] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.285976] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.286060] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300 PCIe Endpoint
[    0.286090] pci 0000:01:00.1: BAR 0 [mem 0xdf080000-0xdf083fff]
[    0.286202] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.286297] pci 0000:02:00.0: [144d:a804] type 00 class 0x010802 PCIe Endpoint
[    0.286335] pci 0000:02:00.0: BAR 0 [mem 0xdf700000-0xdf703fff 64bit]
[    0.286558] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.286656] pci 0000:03:00.0: [144d:a808] type 00 class 0x010802 PCIe Endpoint
[    0.286696] pci 0000:03:00.0: BAR 0 [mem 0xdf600000-0xdf603fff 64bit]
[    0.286928] pci 0000:00:1b.4: PCI bridge to [bus 03]
[    0.287032] pci 0000:04:00.0: [104c:823e] type 01 class 0x060400 PCIe to PCI/PCI-X bridge
[    0.287066] pci 0000:04:00.0: BAR 1 [mem 0xdf200000-0xdf200fff]
[    0.287071] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.287083] pci 0000:04:00.0:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.287184] pci 0000:04:00.0: supports D1 D2
[    0.287299] pci 0000:00:1c.0: PCI bridge to [bus 04-05]
[    0.287350] pci_bus 0000:05: extended config space not accessible
[    0.287373] pci 0000:05:00.0: [104c:823f] type 00 class 0x0c0010 conventional PCI endpoint
[    0.287437] pci 0000:05:00.0: BAR 0 [mem 0xdf104000-0xdf1047ff]
[    0.287441] pci 0000:05:00.0: BAR 1 [mem 0xdf100000-0xdf103fff]
[    0.287494] pci 0000:05:00.0: supports D1 D2
[    0.287495] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot
[    0.287595] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.287712] pci 0000:06:00.0: [1b4b:9128] type 00 class 0x010601 PCIe Legacy Endpoint
[    0.287752] pci 0000:06:00.0: BAR 0 [io  0xd050-0xd057]
[    0.287754] pci 0000:06:00.0: BAR 1 [io  0xd040-0xd043]
[    0.287757] pci 0000:06:00.0: BAR 2 [io  0xd030-0xd037]
[    0.287759] pci 0000:06:00.0: BAR 3 [io  0xd020-0xd023]
[    0.287761] pci 0000:06:00.0: BAR 4 [io  0xd000-0xd01f]
[    0.287764] pci 0000:06:00.0: BAR 5 [mem 0xdf510000-0xdf5107ff]
[    0.287766] pci 0000:06:00.0: ROM [mem 0xdf500000-0xdf50ffff pref]
[    0.287786] pci 0000:06:00.0: Enabling fixed DMA alias to 00.1
[    0.287823] pci 0000:06:00.0: PME# supported from D3hot
[    0.287926] pci 0000:00:1c.1: PCI bridge to [bus 06]
[    0.288031] pci 0000:07:00.0: [1b21:2142] type 00 class 0x0c0330 PCIe Legacy Endpoint
[    0.288076] pci 0000:07:00.0: BAR 0 [mem 0xdf400000-0xdf407fff 64bit]
[    0.288089] pci 0000:07:00.0: enabling Extended Tags
[    0.288158] pci 0000:07:00.0: PME# supported from D0
[    0.288287] pci 0000:00:1c.4: PCI bridge to [bus 07]
[    0.288386] pci 0000:08:00.0: [144d:a808] type 00 class 0x010802 PCIe Endpoint
[    0.288426] pci 0000:08:00.0: BAR 0 [mem 0xdf300000-0xdf303fff 64bit]
[    0.288659] pci 0000:00:1d.0: PCI bridge to [bus 08]
[    0.291506] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.291571] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.291632] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.291634] ACPI: PCI: Interrupt link LNKC disabled
[    0.291695] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.291696] ACPI: PCI: Interrupt link LNKD disabled
[    0.291757] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.291758] ACPI: PCI: Interrupt link LNKE disabled
[    0.291819] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.291820] ACPI: PCI: Interrupt link LNKF disabled
[    0.291881] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.291882] ACPI: PCI: Interrupt link LNKG disabled
[    0.291943] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.291944] ACPI: PCI: Interrupt link LNKH disabled
[    0.297627] ACPI: EC: interrupt unblocked
[    0.297629] ACPI: EC: event unblocked
[    0.297634] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.297635] ACPI: EC: GPE=0x16
[    0.297637] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    0.297639] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    0.297717] iommu: Default domain type: Translated
[    0.297717] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.297717] SCSI subsystem initialized
[    0.297717] libata version 3.00 loaded.
[    0.297717] ACPI: bus type USB registered
[    0.297717] usbcore: registered new interface driver usbfs
[    0.297717] usbcore: registered new interface driver hub
[    0.297717] usbcore: registered new device driver usb
[    0.297717] EDAC MC: Ver: 3.0.0
[    0.298441] NetLabel: Initializing
[    0.298442] NetLabel:  domain hash size = 128
[    0.298443] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.298459] NetLabel:  unlabeled traffic allowed by default
[    0.298464] mctp: management component transport protocol core
[    0.298465] NET: Registered PF_MCTP protocol family
[    0.298472] PCI: Using ACPI for IRQ routing
[    0.325730] PCI: pci_cache_line_size set to 64 bytes
[    0.325792] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.325794] e820: reserve RAM buffer [mem 0x8b594000-0x8bffffff]
[    0.325796] e820: reserve RAM buffer [mem 0x8b983000-0x8bffffff]
[    0.325797] e820: reserve RAM buffer [mem 0x98689000-0x9bffffff]
[    0.325799] e820: reserve RAM buffer [mem 0x9a05b000-0x9bffffff]
[    0.325800] e820: reserve RAM buffer [mem 0x9b000000-0x9bffffff]
[    0.325801] e820: reserve RAM buffer [mem 0x45f000000-0x45fffffff]
[    0.325816] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.325816] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.325816] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.325816] vgaarb: loaded
[    0.326498] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.326498] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.328468] clocksource: Switched to clocksource tsc-early
[    0.329104] VFS: Disk quotas dquot_6.6.0
[    0.329114] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.329276] AppArmor: AppArmor Filesystem Enabled
[    0.329309] pnp: PnP ACPI init
[    0.329541] system 00:00: [io  0x0290-0x029f] has been reserved
[    0.329875] pnp 00:01: [dma 0 disabled]
[    0.330163] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.330166] system 00:02: [io  0xffff] has been reserved
[    0.330168] system 00:02: [io  0xffff] has been reserved
[    0.330169] system 00:02: [io  0xffff] has been reserved
[    0.330171] system 00:02: [io  0x1800-0x18fe] could not be reserved
[    0.330173] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.330276] system 00:03: [io  0x0800-0x087f] has been reserved
[    0.330569] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.330572] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.330574] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.330576] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.330578] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.330580] system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.330582] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.330584] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    0.330586] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.330588] system 00:05: [mem 0xdffe0000-0xdfffffff] has been reserved
[    0.330638] system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.330641] system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.330642] system 00:06: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.330644] system 00:06: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.330646] system 00:06: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.330648] system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.330650] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.330652] system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.330654] system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.330656] system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.330995] system 00:07: [io  0xfe00-0xfefe] has been reserved
[    0.332386] system 00:08: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.332389] system 00:08: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.332391] system 00:08: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.333395] pnp: PnP ACPI: found 9 devices
[    0.339320] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.339380] NET: Registered PF_INET protocol family
[    0.339508] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.356308] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.356330] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.356368] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.356587] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.356812] TCP: Hash tables configured (established 131072 bind 65536)
[    0.356889] MPTCP token hash table entries: 16384 (order: 7, 393216 bytes, linear)
[    0.356970] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.357056] UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.357150] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.357156] NET: Registered PF_XDP protocol family
[    0.357173] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.357177] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.357180] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.357183] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.357186] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.357190] pci 0000:00:1b.0:   bridge window [mem 0xdf700000-0xdf7fffff]
[    0.357195] pci 0000:00:1b.4: PCI bridge to [bus 03]
[    0.357198] pci 0000:00:1b.4:   bridge window [mem 0xdf600000-0xdf6fffff]
[    0.357204] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.357210] pci 0000:04:00.0:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.357220] pci 0000:00:1c.0: PCI bridge to [bus 04-05]
[    0.357223] pci 0000:00:1c.0:   bridge window [mem 0xdf100000-0xdf2fffff]
[    0.357228] pci 0000:00:1c.1: PCI bridge to [bus 06]
[    0.357230] pci 0000:00:1c.1:   bridge window [io  0xd000-0xdfff]
[    0.357234] pci 0000:00:1c.1:   bridge window [mem 0xdf500000-0xdf5fffff]
[    0.357239] pci 0000:00:1c.4: PCI bridge to [bus 07]
[    0.357242] pci 0000:00:1c.4:   bridge window [mem 0xdf400000-0xdf4fffff]
[    0.357247] pci 0000:00:1d.0: PCI bridge to [bus 08]
[    0.357250] pci 0000:00:1d.0:   bridge window [mem 0xdf300000-0xdf3fffff]
[    0.357256] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.357258] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.357259] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.357261] pci_bus 0000:00: resource 7 [mem 0xa0000000-0xdfffffff window]
[    0.357262] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.357264] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.357265] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[    0.357267] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.357268] pci_bus 0000:02: resource 1 [mem 0xdf700000-0xdf7fffff]
[    0.357270] pci_bus 0000:03: resource 1 [mem 0xdf600000-0xdf6fffff]
[    0.357271] pci_bus 0000:04: resource 1 [mem 0xdf100000-0xdf2fffff]
[    0.357273] pci_bus 0000:05: resource 1 [mem 0xdf100000-0xdf1fffff]
[    0.357274] pci_bus 0000:06: resource 0 [io  0xd000-0xdfff]
[    0.357276] pci_bus 0000:06: resource 1 [mem 0xdf500000-0xdf5fffff]
[    0.357277] pci_bus 0000:07: resource 1 [mem 0xdf400000-0xdf4fffff]
[    0.357279] pci_bus 0000:08: resource 1 [mem 0xdf300000-0xdf3fffff]
[    0.357695] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.357722] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.357767] pci 0000:07:00.0: PME# does not work under D0, disabling it
[    0.357943] PCI: CLS 64 bytes, default 64
[    0.357987] pci 0000:00:1f.1: [8086:a2a0] type 00 class 0x058000 conventional PCI endpoint
[    0.358122] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    0.358249] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.358250] software IO TLB: mapped [mem 0x0000000094689000-0x0000000098689000] (64MB)
[    0.358318] Trying to unpack rootfs image as initramfs...
[    0.387087] Initialise system trusted keyrings
[    0.387095] Key type blacklist registered
[    0.387203] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    0.387494] fuse: init (API version 7.45)
[    0.387833] integrity: Platform Keyring initialized
[    0.387836] integrity: Machine keyring initialized
[    0.399633] xor: automatically using best checksumming function   avx
[    0.399637] Key type asymmetric registered
[    0.399638] Asymmetric key parser 'x509' registered
[    0.399660] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.399775] io scheduler mq-deadline registered
[    0.399776] io scheduler kyber registered
[    0.399790] io scheduler bfq registered
[    0.400122] ledtrig-cpu: registered to indicate activity on CPUs
[    0.400577] pcieport 0000:00:1b.0: AER: enabled with IRQ 121
[    0.400853] pcieport 0000:00:1b.4: AER: enabled with IRQ 122
[    0.401128] pcieport 0000:00:1c.0: AER: enabled with IRQ 123
[    0.401396] pcieport 0000:00:1c.1: AER: enabled with IRQ 124
[    0.401661] pcieport 0000:00:1c.4: AER: enabled with IRQ 125
[    0.401925] pcieport 0000:00:1d.0: AER: enabled with IRQ 126
[    0.402157] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.402182] ACPI: button: Sleep Button [SLPB]
[    0.402209] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.402227] ACPI: button: Power Button [PWRB]
[    0.402254] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.405560] ACPI: button: Power Button [PWRF]
[    0.406969] thermal LNXTHERM:00: registered as thermal_zone0
[    0.406972] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    0.407148] thermal LNXTHERM:01: registered as thermal_zone1
[    0.407150] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[    0.407349] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.407715] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.411206] Non-volatile memory driver v1.3
[    0.411208] Linux agpgart interface v0.103
[    0.411298] ACPI: bus type drm_connector registered
[    0.422443] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    0.422447] ahci 0000:00:17.0: 4/4 ports implemented (port mask 0xf)
[    0.422462] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds apst
[    0.428986] scsi host0: ahci
[    0.429255] scsi host1: ahci
[    0.429485] scsi host2: ahci
[    0.429647] scsi host3: ahci
[    0.429684] ata1: SATA max UDMA/133 abar m2048@0xdf84b000 port 0xdf84b100 irq 127 lpm-pol 1 ext
[    0.429687] ata2: SATA max UDMA/133 abar m2048@0xdf84b000 port 0xdf84b180 irq 127 lpm-pol 1 ext
[    0.429689] ata3: SATA max UDMA/133 abar m2048@0xdf84b000 port 0xdf84b200 irq 127 lpm-pol 1 ext
[    0.429690] ata4: SATA max UDMA/133 abar m2048@0xdf84b000 port 0xdf84b280 irq 127 lpm-pol 1 ext
[    0.440018] ahci 0000:06:00.0: AHCI vers 0001.0200, 32 command slots, 6 Gbps, SATA mode
[    0.440022] ahci 0000:06:00.0: 8/8 ports implemented (port mask 0xff)
[    0.440024] ahci 0000:06:00.0: flags: 64bit ncq pio
[    0.440806] scsi host4: ahci
[    0.441121] scsi host5: ahci
[    0.441317] scsi host6: ahci
[    0.441456] scsi host7: ahci
[    0.441618] scsi host8: ahci
[    0.441803] scsi host9: ahci
[    0.441913] scsi host10: ahci
[    0.442020] scsi host11: ahci
[    0.442056] ata5: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510100 irq 128 lpm-pol 1 ext
[    0.442059] ata6: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510180 irq 128 lpm-pol 1 ext
[    0.442061] ata7: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510200 irq 128 lpm-pol 1 ext
[    0.442063] ata8: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510280 irq 128 lpm-pol 1 ext
[    0.442065] ata9: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510300 irq 128 lpm-pol 1 ext
[    0.442067] ata10: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510380 irq 128 lpm-pol 1 ext
[    0.442069] ata11: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510400 irq 128 lpm-pol 1 ext
[    0.442071] ata12: SATA max UDMA/133 abar m2048@0xdf510000 port 0xdf510480 irq 128 lpm-pol 1
[    0.442286] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.442291] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.443358] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    0.443571] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.443575] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.443577] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.443614] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.443617] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.443618] usb usb1: Product: xHCI Host Controller
[    0.443620] usb usb1: Manufacturer: Linux 6.18.18-1-MANJARO xhci-hcd
[    0.443621] usb usb1: SerialNumber: 0000:00:14.0
[    0.443780] hub 1-0:1.0: USB hub found
[    0.443797] hub 1-0:1.0: 16 ports detected
[    0.447124] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.447129] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.447131] usb usb2: Product: xHCI Host Controller
[    0.447132] usb usb2: Manufacturer: Linux 6.18.18-1-MANJARO xhci-hcd
[    0.447134] usb usb2: SerialNumber: 0000:00:14.0
[    0.447265] hub 2-0:1.0: USB hub found
[    0.447278] hub 2-0:1.0: 10 ports detected
[    0.449598] xhci_hcd 0000:07:00.0: xHCI Host Controller
[    0.449605] xhci_hcd 0000:07:00.0: new USB bus registered, assigned bus number 3
[    0.449667] pcieport 0000:00:1c.4: AER: Correctable error message received from 0000:00:1c.4
[    0.449672] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[    0.449675] pcieport 0000:00:1c.4:   device [8086:a294] error status/mask=00000001/00002000
[    0.449677] pcieport 0000:00:1c.4:    [ 0] RxErr                  (First)
[    0.459946] Freeing initrd memory: 138208K
[    0.504271] xhci_hcd 0000:07:00.0: hcc params 0x0200ef80 hci version 0x110 quirks 0x0000000000800010
[    0.504512] xhci_hcd 0000:07:00.0: xHCI Host Controller
[    0.504516] xhci_hcd 0000:07:00.0: new USB bus registered, assigned bus number 4
[    0.504519] xhci_hcd 0000:07:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.504569] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.504571] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.504573] usb usb3: Product: xHCI Host Controller
[    0.504574] usb usb3: Manufacturer: Linux 6.18.18-1-MANJARO xhci-hcd
[    0.504576] usb usb3: SerialNumber: 0000:07:00.0
[    0.504712] hub 3-0:1.0: USB hub found
[    0.504719] hub 3-0:1.0: 2 ports detected
[    0.504903] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.504922] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.504924] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.504926] usb usb4: Product: xHCI Host Controller
[    0.504927] usb usb4: Manufacturer: Linux 6.18.18-1-MANJARO xhci-hcd
[    0.504929] usb usb4: SerialNumber: 0000:07:00.0
[    0.505033] hub 4-0:1.0: USB hub found
[    0.505040] hub 4-0:1.0: 2 ports detected
[    0.505235] usbcore: registered new interface driver usbserial_generic
[    0.505241] usbserial: USB Serial support registered for generic
[    0.505276] i8042: PNP: No PS/2 controller found.
[    0.505390] rtc_cmos 00:04: RTC can wake from S4
[    0.506091] rtc_cmos 00:04: registered as rtc0
[    0.506216] rtc_cmos 00:04: setting system clock to 2026-04-26T08:46:51 UTC (1777193211)
[    0.506240] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
[    0.506738] intel_pstate: Intel P-state driver initializing
[    0.507400] intel_pstate: Disabling energy efficiency optimization
[    0.507401] intel_pstate: HWP enabled
[    0.507609] Relocating firmware framebuffer to offset 0x0000000001000000[d] within [mem 0xd0000000-0xd1ffffff flags 0x14220c]
[    0.507748] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    0.507749] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    0.508962] fbcon: Deferring console take-over
[    0.508963] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.509011] hid: raw HID events driver (C) Jiri Kosina
[    0.509028] usbcore: registered new interface driver usbhid
[    0.509029] usbhid: USB HID core driver
[    0.509079] drop_monitor: Initializing network drop monitor service
[    0.509152] NET: Registered PF_INET6 protocol family
[    0.509442] Segment Routing with IPv6
[    0.509443] RPL Segment Routing with IPv6
[    0.509448] In-situ OAM (IOAM) with IPv6
[    0.509465] NET: Registered PF_PACKET protocol family
[    0.510276] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.510629] microcode: Current revision: 0x000000fa
[    0.510630] microcode: Updated early from: 0x0000007c
[    0.511047] IPI shorthand broadcast: enabled
[    0.512799] sched_clock: Marking stable (509000757, 3449760)->(548876620, -36426103)
[    0.512990] registered taskstats version 1
[    0.513727] Loading compiled-in X.509 certificates
[    0.518228] Loaded X.509 cert 'Build time autogenerated kernel key: b9da1c8fe6adae7a83dfbac132832f8701cf687b'
[    0.520332] zswap: loaded using pool zstd
[    0.520390] Demotion targets for Node 0: null
[    0.520605] Key type .fscrypt registered
[    0.520606] Key type fscrypt-provisioning registered
[    0.520827] Btrfs loaded, zoned=yes, fsverity=yes
[    0.520851] Key type big_key registered
[    0.520852] AppArmor: AppArmor sha256 policy hashing enabled
[    0.521071] PM:   Magic number: 6:26:777
[    0.522024] RAS: Correctable Errors collector initialized.
[    0.526026] clk: Disabling unused clocks
[    0.526028] PM: genpd: Disabling unused power domains
[    0.687555] usb 1-5: new low-speed USB device number 2 using xhci_hcd
[    0.733421] ata1: SATA link down (SStatus 0 SControl 300)
[    0.733559] ata4: SATA link down (SStatus 0 SControl 300)
[    0.733593] ata2: SATA link down (SStatus 0 SControl 300)
[    0.741505] ata3: SATA link down (SStatus 0 SControl 300)
[    0.749391] ata11: SATA link down (SStatus 0 SControl 310)
[    0.749429] ata5: SATA link down (SStatus 0 SControl 310)
[    0.749557] ata7: SATA link down (SStatus 0 SControl 310)
[    0.749594] ata8: SATA link down (SStatus 0 SControl 310)
[    0.749636] ata12: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    0.749672] ata9: SATA link down (SStatus 0 SControl 310)
[    0.749710] ata6: SATA link down (SStatus 0 SControl 310)
[    0.749747] ata10: SATA link down (SStatus 0 SControl 310)
[    0.749803] ata12.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66
[    0.749816] ata12.00: Features: HIPM
[    0.750171] ata12.00: configured for UDMA/66
[    0.751288] scsi 11:0:0:0: Processor         Marvell  91xx Config      1.01 PQ: 0 ANSI: 5
[    0.757203] Freeing unused decrypted memory: 2028K
[    0.759908] Freeing unused kernel image (initmem) memory: 4736K
[    0.760210] Write protecting the kernel read-only data: 36864k
[    0.761431] Freeing unused kernel image (text/rodata gap) memory: 200K
[    0.761731] Freeing unused kernel image (rodata/data gap) memory: 16K
[    0.818745] usb 1-5: New USB device found, idVendor=04b3, idProduct=3025, bcdDevice= 1.09
[    0.818748] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    0.818750] usb 1-5: Product: USB NetVista Full Width Keyboard.
[    0.818751] usb 1-5: Manufacturer: LITE-ON Technology
[    0.824606] input: LITE-ON Technology USB NetVista Full Width Keyboard. as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:04B3:3025.0001/input/input3
[    0.829094] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.829097] rodata_test: all tests were successful
[    0.829098] x86/mm: Checking user space page tables
[    0.862650] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.862653] Run /init as init process
[    0.862654]   with arguments:
[    0.862655]     /init
[    0.862656]     splash
[    0.862657]   with environment:
[    0.862657]     HOME=/
[    0.862658]     TERM=linux
[    0.881101] systemd[1]: Successfully made /usr/ read-only.
[    0.881325] systemd[1]: systemd 259.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    0.881330] systemd[1]: Detected architecture x86-64.
[    0.881332] systemd[1]: Running in initrd.
[    0.881518] systemd[1]: Initializing machine ID from random generator.
[    0.898367] systemd[1]: Queued start job for default target Initrd Default Target.
[    0.905640] hid-generic 0003:04B3:3025.0001: input,hidraw0: USB HID v1.10 Keyboard [LITE-ON Technology USB NetVista Full Width Keyboard.] on usb-0000:00:14.0-5/input0
[    0.939370] systemd[1]: Expecting device /dev/disk/by-uuid/505a427c-a786-41e4-a4bc-690a3c072cbc...
[    0.939418] systemd[1]: Reached target Path Units.
[    0.939431] systemd[1]: Reached target Slice Units.
[    0.939442] systemd[1]: Reached target Swaps.
[    0.939457] systemd[1]: Reached target Timer Units.
[    0.939541] systemd[1]: Listening on Journal Socket (/dev/log).
[    0.939613] systemd[1]: Listening on Journal Sockets.
[    0.939673] systemd[1]: Listening on udev Control Socket.
[    0.939713] systemd[1]: Listening on udev Kernel Socket.
[    0.939723] systemd[1]: Reached target Socket Units.
[    0.939745] systemd[1]: Create List of Static Device Nodes skipped, unmet condition check ConditionFileNotEmpty=/lib/modules/6.18.18-1-MANJARO/modules.devname
[    0.939792] systemd[1]: Early Battery Level Check skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/class/power_supply
[    0.943083] systemd[1]: Started Display Boot-Time Emergency Messages In Full Screen.
[    0.946074] systemd[1]: Starting Journal Service...
[    0.948149] systemd[1]: Starting Load Kernel Modules...
[    0.948166] systemd[1]: TPM PCR Barrier (initrd) skipped, unmet condition check ConditionSecurity=measured-uki
[    0.950118] systemd[1]: Starting Create Static Device Nodes in /dev...
[    0.952080] systemd[1]: Starting Coldplug All udev Devices...
[    0.956607] systemd[1]: Finished Load Kernel Modules.
[    0.958309] systemd[1]: Finished Create Static Device Nodes in /dev.
[    0.958561] systemd[1]: Reached target Preparation for Local File Systems.
[    0.958575] systemd[1]: Reached target Local File Systems.
[    0.959811] systemd-journald[226]: Collecting audit messages is disabled.
[    0.960671] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    0.980200] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    1.008913] systemd[1]: Started Journal Service.
[    1.019512] usb 1-6: new low-speed USB device number 3 using xhci_hcd
[    1.157980] usb 1-6: New USB device found, idVendor=045e, idProduct=0029, bcdDevice= 1.08
[    1.157983] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.157985] usb 1-6: Product: Microsoft IntelliMouse® Optical
[    1.157986] usb 1-6: Manufacturer: Microsoft
[    1.165957] input: Microsoft Microsoft IntelliMouse® Optical as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:045E:0029.0002/input/input4
[    1.166176] hid-generic 0003:045E:0029.0002: input,hidraw1: USB HID v1.00 Mouse [Microsoft Microsoft IntelliMouse® Optical] on usb-0000:00:14.0-6/input0
[    1.239447] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    1.239995] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[    1.249765] Key type psk registered
[    1.263353] nvme nvme0: pci function 0000:02:00.0
[    1.263354] nvme nvme1: pci function 0000:08:00.0
[    1.263358] nvme nvme2: pci function 0000:03:00.0
[    1.269829] nvme nvme2: missing or invalid SUBNQN field.
[    1.269949] nvme nvme1: missing or invalid SUBNQN field.
[    1.269999] nvme nvme2: D3 entry latency set to 8 seconds
[    1.270151] nvme nvme1: D3 entry latency set to 8 seconds
[    1.275294] nvme nvme0: 7/0/0 default/read/poll queues
[    1.278459] usb 1-11: new full-speed USB device number 4 using xhci_hcd
[    1.284359] nvme nvme2: 12/0/0 default/read/poll queues
[    1.285310] nvme nvme1: 12/0/0 default/read/poll queues
[    1.289487]  nvme2n1: p1
[    1.289520]  nvme0n1: p1
[    1.289534]  nvme1n1: p1
[    1.310553] firewire_ohci 0000:05:00.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x2
[    1.405327] usb 1-11: New USB device found, idVendor=0b05, idProduct=190e, bcdDevice= 2.00
[    1.405331] usb 1-11: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.405334] usb 1-11: Product: ASUS USB-BT500
[    1.405336] usb 1-11: Manufacturer: Realtek
[    1.405337] usb 1-11: SerialNumber: 00E04C239987
[    1.407525] tsc: Refined TSC clocksource calibration: 3192.000 MHz
[    1.407529] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2e02c4a121d, max_idle_ns: 440795236083 ns
[    1.407581] clocksource: Switched to clocksource tsc
[    1.519457] usb 1-13: new high-speed USB device number 5 using xhci_hcd
[    1.642644] usb 1-13: New USB device found, idVendor=0409, idProduct=005a, bcdDevice= 1.00
[    1.642648] usb 1-13: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.643443] hub 1-13:1.0: USB hub found
[    1.643460] hub 1-13:1.0: 4 ports detected
[    1.736074] i915 0000:00:02.0: [drm] Found coffeelake (device ID 3e92) integrated display version 9.00 stepping N/A
[    1.741393] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    1.815574] firewire_core 0000:05:00.0: created device fw0: GUID 080028510101021b, S800
[    1.931455] usb 1-13.4: new high-speed USB device number 6 using xhci_hcd
[    2.017551] usb 1-13.4: New USB device found, idVendor=0409, idProduct=005a, bcdDevice= 1.00
[    2.017554] usb 1-13.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.018120] hub 1-13.4:1.0: USB hub found
[    2.018137] hub 1-13.4:1.0: 4 ports detected
[    2.069685] MXM: GUID detected in BIOS
[    2.069790] nouveau 0000:01:00.0: NVIDIA GP107 (137000a1)
[    2.085132] EXT4-fs (nvme0n1p1): mounted filesystem 505a427c-a786-41e4-a4bc-690a3c072cbc r/w with ordered data mode. Quota mode: none.
[    2.179807] nouveau 0000:01:00.0: bios: version 86.07.42.00.77
[    2.182318] nouveau 0000:01:00.0: pmu: firmware unavailable
[    2.212761] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[    2.212858] nouveau 0000:01:00.0: fb: 4096 MiB GDDR5
[    2.223874] nouveau 0000:01:00.0: drm: VRAM: 4096 MiB
[    2.223877] nouveau 0000:01:00.0: drm: GART: 536870912 MiB
[    2.223879] nouveau 0000:01:00.0: drm: BIT table 'A' not found
[    2.223880] nouveau 0000:01:00.0: drm: BIT table 'L' not found
[    2.223881] nouveau 0000:01:00.0: drm: TMDS table version 2.0
[    2.225056] nouveau 0000:01:00.0: drm: MM: using COPY for buffer copies
[    2.226371] nouveau 0000:01:00.0: [drm] Registered 4 planes with drm panic
[    2.226373] [drm] Initialized nouveau 1.4.0 for 0000:01:00.0 on minor 0
[    2.327404] fbcon: nouveaudrmfb (fb0) is primary device
[    2.327405] fbcon: Deferring console take-over
[    2.327407] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[    2.332461] nouveau 0000:01:00.0: drm: Disabling PCI power management to avoid bug
[    2.382456] i915 0000:00:02.0: [drm] [ENCODER:105:DDI A/PHY A] failed to retrieve link info, disabling eDP
[    2.384384] i915 0000:00:02.0: [drm] Registered 3 planes with drm panic
[    2.384386] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
[    2.412487] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.426611] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.567416] systemd-journald[226]: Received SIGTERM from PID 1 (systemd).
[    2.645525] systemd[1]: systemd 259.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    2.645532] systemd[1]: Detected architecture x86-64.
[    2.653062] systemd[1]: Hostname set to <nick-pc3c>.
[    2.788041] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    3.135753] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[    3.135891] systemd[1]: Stopped Switch Root.
[    3.136574] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[    3.137007] systemd[1]: Created slice CUPS Slice.
[    3.137336] systemd[1]: Created slice Slice /system/dirmngr.
[    3.137701] systemd[1]: Created slice Slice /system/getty.
[    3.138032] systemd[1]: Created slice Slice /system/gpg-agent.
[    3.138359] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    3.138739] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    3.139064] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    3.139387] systemd[1]: Created slice Slice /system/keyboxd.
[    3.139750] systemd[1]: Created slice Slice /system/modprobe.
[    3.140097] systemd[1]: Created slice Slice /system/syncthing.
[    3.140335] systemd[1]: Created slice User and Session Slice.
[    3.140381] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.140552] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.140564] systemd[1]: Expecting device /dev/disk/by-uuid/2a171f5f-7535-4b7f-a544-66a1c4283d1d...
[    3.140569] systemd[1]: Expecting device /dev/disk/by-uuid/d7449928-d30a-4479-bb48-f02d4213b325...
[    3.140580] systemd[1]: Reached target Login Prompts.
[    3.140589] systemd[1]: Reached target Image Downloads.
[    3.140600] systemd[1]: Stopped target Switch Root.
[    3.140611] systemd[1]: Stopped target Initrd File Systems.
[    3.140617] systemd[1]: Stopped target Initrd Root File System.
[    3.140626] systemd[1]: Reached target Local Integrity Protected Volumes.
[    3.140641] systemd[1]: Reached target Slice Units.
[    3.140652] systemd[1]: Reached target Mounting snaps.
[    3.140664] systemd[1]: Reached target Swaps.
[    3.140678] systemd[1]: Reached target Local Verity Protected Volumes.
[    3.140737] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.140801] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.141570] systemd[1]: Listening on Query the User Interactively for a Password.
[    3.142435] systemd[1]: Listening on Process Core Dump Socket.
[    3.143065] systemd[1]: Listening on Credential Encryption/Decryption.
[    3.143775] systemd[1]: Listening on Factory Reset Management.
[    3.144642] systemd[1]: Listening on Console Output Muting Service Socket.
[    3.144661] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    3.144673] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    3.145182] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    3.145238] systemd[1]: Listening on udev Control Socket.
[    3.145289] systemd[1]: Listening on udev Varlink Socket.
[    3.146094] systemd[1]: Mounting Huge Pages File System...
[    3.146786] systemd[1]: Mounting POSIX Message Queue File System...
[    3.147386] systemd[1]: Mounting Kernel Debug File System...
[    3.148131] systemd[1]: Mounting Kernel Trace File System...
[    3.149169] systemd[1]: Starting Load AppArmor profiles...
[    3.150074] systemd[1]: Starting Create List of Static Device Nodes...
[    3.150905] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    3.150936] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    3.151789] systemd[1]: Mounting Kernel Configuration File System...
[    3.151824] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    3.151868] systemd[1]: Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[    3.152857] systemd[1]: Mounting FUSE Control File System...
[    3.152970] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    3.154412] systemd[1]: Starting Load Kernel Modules...
[    3.154437] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    3.154496] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    3.155495] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.155561] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    3.156502] systemd[1]: Starting Load udev Rules from Credentials...
[    3.157408] systemd[1]: Starting Coldplug All udev Devices...
[    3.158239] systemd[1]: Starting Virtual Console Setup...
[    3.159909] systemd[1]: Mounted Huge Pages File System.
[    3.159991] systemd[1]: Mounted POSIX Message Queue File System.
[    3.160067] systemd[1]: Mounted Kernel Debug File System.
[    3.160139] systemd[1]: Mounted Kernel Trace File System.
[    3.160341] systemd[1]: Finished Create List of Static Device Nodes.
[    3.160746] systemd[1]: Mounted Kernel Configuration File System.
[    3.160829] systemd[1]: Mounted FUSE Control File System.
[    3.162034] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    3.166244] systemd[1]: Finished Load udev Rules from Credentials.
[    3.169141] scsi 11:0:0:0: Attached scsi generic sg0 type 3
[    3.169968] i2c_dev: i2c /dev entries driver
[    3.171543] EXT4-fs (nvme0n1p1): re-mounted 505a427c-a786-41e4-a4bc-690a3c072cbc.
[    3.172298] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.172562] systemd[1]: Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[    3.173720] systemd[1]: Starting Load/Save OS Random Seed...
[    3.173744] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    3.173775] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    3.178318] audit: type=1400 audit(1777193214.170:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=530 comm="apparmor_parser"
[    3.178338] audit: type=1400 audit(1777193214.170:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=541 comm="apparmor_parser"
[    3.178400] audit: type=1400 audit(1777193214.170:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=532 comm="apparmor_parser"
[    3.178449] audit: type=1400 audit(1777193214.170:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=535 comm="apparmor_parser"
[    3.178589] audit: type=1400 audit(1777193214.171:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=533 comm="apparmor_parser"
[    3.178846] audit: type=1400 audit(1777193214.171:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=540 comm="apparmor_parser"
[    3.178893] audit: type=1400 audit(1777193214.171:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=537 comm="apparmor_parser"
[    3.179076] audit: type=1400 audit(1777193214.171:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=538 comm="apparmor_parser"
[    3.179335] audit: type=1400 audit(1777193214.171:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=531 comm="apparmor_parser"
[    3.182419] device-mapper: uevent: version 1.0.3
[    3.182495] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    3.183749] systemd[1]: Finished Virtual Console Setup.
[    3.195584] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.196777] systemd[1]: Finished Load/Save OS Random Seed.
[    3.200524] Bridge firewalling registered
[    3.201316] systemd[1]: Finished Load Kernel Modules.
[    3.203633] systemd[1]: Starting Apply Kernel Variables...
[    3.214715] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    3.214888] systemd[1]: Create System Users skipped, no trigger condition checks were met.
[    3.216673] systemd[1]: Starting Network Time Synchronization...
[    3.219821] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.224487] systemd[1]: Finished Apply Kernel Variables.
[    3.228228] systemd[1]: Starting CLI Netfilter Manager...
[    3.228671] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    3.252334] systemd[1]: Finished CLI Netfilter Manager.
[    3.263443] systemd[1]: Finished Create Static Device Nodes in /dev.
[    3.263584] systemd[1]: Reached target Preparation for Local File Systems.
[    3.263824] systemd[1]: Entropy Daemon based on the HAVEGE algorithm skipped, unmet condition check ConditionVersion=<5.6
[    3.265950] systemd[1]: Starting Journal Service...
[    3.266008] systemd[1]: Repartition Root Disk skipped, no trigger condition checks were met.
[    3.267428] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    3.285974] systemd[1]: Started Network Time Synchronization.
[    3.286058] systemd[1]: Reached target System Time Set.
[    3.302180] systemd-journald[629]: Collecting audit messages is disabled.
[    3.311572] systemd[1]: Started Journal Service.
[    3.353746] systemd-journald[629]: Received client request to flush runtime journal.
[    3.678637] mousedev: PS/2 mouse device common for all mice
[    3.726880] EDAC ie31200: No ECC support
[    3.726922] EDAC ie31200: No ECC support
[    3.739599] resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:06 [mem 0xfdb00000-0xfdffffff]
[    3.739604] caller get_primary_reg_base+0x4c/0xa0 [intel_pmc_core] mapping multiple BARs
[    3.739631] intel_pmc_core INT33A1:00:  initialized
[    3.772334] pps_core: LinuxPPS API ver. 1 registered
[    3.772335] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    3.772337] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.798619] input: PC Speaker as /devices/platform/pcspkr/input/input6
[    3.808038] PTP clock support registered
[    3.808220] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    3.808234] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    3.810637] i2c i2c-19: Successfully instantiated SPD at 0x51
[    3.811155] i2c i2c-19: Successfully instantiated SPD at 0x53
[    3.847389] Bluetooth: Core ver 2.22
[    3.847422] NET: Registered PF_BLUETOOTH protocol family
[    3.847425] Bluetooth: HCI device and connection manager initialized
[    3.847432] Bluetooth: HCI socket layer initialized
[    3.847436] Bluetooth: L2CAP socket layer initialized
[    3.847441] Bluetooth: SCO socket layer initialized
[    3.858637] e1000e: Intel(R) PRO/1000 Network Driver
[    3.858640] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.859153] asus_wmi: ASUS WMI generic driver loaded
[    3.859812] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    3.870668] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    3.870671] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.870673] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.870674] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.870675] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    3.877308] asus_wmi: Initialization: 0x0
[    3.877335] asus_wmi: BIOS WMI version: 0.9
[    3.877483] asus_wmi: SFUN value: 0x0
[    3.877486] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[    3.882194] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
[    3.911078] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[    3.911797] usbcore: registered new interface driver btusb
[    3.912277] Bluetooth: hci0: RTL: rom_version status=0 version=1
[    3.913080] Bluetooth: hci0: RTL: btrtl_initialize: key id 0
[    3.913083] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[    3.918277] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[    3.919065] Bluetooth: hci0: RTL: cfg_sz 6, total sz 30210
[    3.919110] iTCO_vendor_support: vendor-support=0
[    3.929012] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    3.929096] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    3.929507] ee1004 19-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[    3.931008] ee1004 19-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[    3.938405] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
[    3.938965] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.938970] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    4.012792] snd_hda_codec_alc882 hdaudioC0D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    4.012795] snd_hda_codec_alc882 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.012797] snd_hda_codec_alc882 hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    4.012799] snd_hda_codec_alc882 hdaudioC0D0:    mono: mono_out=0x0
[    4.012800] snd_hda_codec_alc882 hdaudioC0D0:    dig-out=0x1e/0x0
[    4.012801] snd_hda_codec_alc882 hdaudioC0D0:    inputs:
[    4.012802] snd_hda_codec_alc882 hdaudioC0D0:      Rear Mic=0x18
[    4.012803] snd_hda_codec_alc882 hdaudioC0D0:      Front Mic=0x19
[    4.012804] snd_hda_codec_alc882 hdaudioC0D0:      Line=0x1a
[    4.013798] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[    4.017925] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[    4.017990] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[    4.018037] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[    4.018100] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[    4.034573] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    4.034619] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    4.034666] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    4.034726] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    4.034770] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    4.034811] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    4.034847] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    4.034885] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[    4.034927] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    4.034964] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    4.049494] intel_tcc_cooling: Programmable TCC Offset detected
[    4.070081] Bluetooth: hci0: RTL: fw version 0xdfc6d922
[    4.091187] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    4.105239] intel_rapl_common: Found RAPL domain package
[    4.105241] intel_rapl_common: Found RAPL domain core
[    4.105242] intel_rapl_common: Found RAPL domain uncore
[    4.105243] intel_rapl_common: Found RAPL domain dram
[    4.153240] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 2c:fd:a1:be:5a:f0
[    4.153259] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    4.153322] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[    4.170196] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[    4.223125] loop: module loaded
[    4.231988] loop0: detected capacity change from 0 to 8
[    4.232192] loop2: detected capacity change from 0 to 113640
[    4.232407] loop1: detected capacity change from 0 to 1144
[    4.233095] loop3: detected capacity change from 0 to 113648
[    4.238319] EXT4-fs (nvme1n1p1): mounted filesystem d7449928-d30a-4479-bb48-f02d4213b325 r/w with ordered data mode. Quota mode: none.
[    4.245299] loop4: detected capacity change from 0 to 130616
[    4.261241] loop5: detected capacity change from 0 to 151456
[    4.263433] loop6: detected capacity change from 0 to 130608
[    4.266484] loop7: detected capacity change from 0 to 151512
[    4.276345] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    4.296630] loop9: detected capacity change from 0 to 136904
[    4.297563] loop10: detected capacity change from 0 to 136872
[    4.306850] EXT4-fs (nvme2n1p1): mounted filesystem 2a171f5f-7535-4b7f-a544-66a1c4283d1d r/w with ordered data mode. Quota mode: none.
[    4.661083] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.661086] Bluetooth: BNEP filters: protocol multicast
[    4.661088] Bluetooth: BNEP socket layer initialized
[    4.662163] Bluetooth: MGMT ver 1.23
[    4.667652] NET: Registered PF_ALG protocol family
[    4.783438] NET: Registered PF_QIPCRTR protocol family
[    5.260125] kauditd_printk_skb: 183 callbacks suppressed
[    5.260127] audit: type=1400 audit(1777193216.252:194): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/1220/mountinfo" pid=1220 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[    5.641385] audit: type=1400 audit(1777193216.633:195): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/1220/mountinfo" pid=1220 comm="nordvpnd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[    5.985843] audit: error in audit_log_subj_ctx
[    5.985873] audit: type=1326 audit(1777193216.978:196): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1220 comm="nordvpnd" exe="/snap/nordvpn/64/bin/nordvpnd" sig=0 arch=c000003e syscall=424 compat=0 ip=0x55e9d07dbb6e code=0x50000
[    6.075078] audit: error in audit_log_subj_ctx
[    6.075090] audit: type=1326 audit(1777193217.067:197): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1220 comm="nordvpnd" exe="/snap/nordvpn/64/bin/nordvpnd" sig=0 arch=c000003e syscall=260 compat=0 ip=0x55e9d07dbb6e code=0x50000
[    6.249350] audit: type=1400 audit(1777193217.241:198): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/1220/mountinfo" pid=1220 comm="nordvpnd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[    6.434770] audit: type=1400 audit(1777193217.427:199): apparmor="DENIED" operation="exec" class="file" profile="snap.nordvpn.nordvpnd" name="/usr/bin/timedatectl" pid=1372 comm="nordvpnd" requested_mask="x" denied_mask="x" fsuid=0 ouid=0
[    6.439043] audit: type=1400 audit(1777193217.431:200): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/1/environ" pid=1220 comm="nordvpnd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[    6.440158] audit: type=1400 audit(1777193217.432:201): apparmor="DENIED" operation="exec" class="file" profile="snap.nordvpn.nordvpnd" name="/usr/bin/systemctl" pid=1375 comm="nordvpnd" requested_mask="x" denied_mask="x" fsuid=0 ouid=0
[    7.738040] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[   12.292835] netfs: FS-Cache loaded
[   12.336767] RPC: Registered named UNIX socket transport module.
[   12.336769] RPC: Registered udp transport module.
[   12.336770] RPC: Registered tcp transport module.
[   12.336771] RPC: Registered tcp-with-tls transport module.
[   12.336771] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.398718] Key type dns_resolver registered
[   12.530945] NFS: Registering the id_resolver key type
[   12.530952] Key type id_resolver registered
[   12.530953] Key type id_legacy registered
[   12.607591] kauditd_printk_skb: 3 callbacks suppressed
[   12.607593] audit: type=1400 audit(1777193223.600:205): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=1627 comm="apparmor_parser"
[   12.847875] Initializing XFRM netlink socket
[   18.165428] rfkill: input handler disabled
[   18.252791] nvme nvme0: using unchecked data buffer
[   19.157501] Bluetooth: RFCOMM TTY layer initialized
[   19.157509] Bluetooth: RFCOMM socket layer initialized
[   19.157512] Bluetooth: RFCOMM ver 1.11
[   87.376524] rfkill: input handler enabled
[   90.460968] rfkill: input handler disabled
[   90.527067] audit: type=1400 audit(1777193300.635:206): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpn" name="/proc/3910/mountinfo" pid=3910 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   90.655708] audit: type=1400 audit(1777193300.763:207): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpn" name="/proc/3910/mountinfo" pid=3910 comm="nordvpn" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   90.932423] audit: type=1400 audit(1777193301.040:208): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/4143/mountinfo" pid=4143 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[   90.940969] audit: type=1400 audit(1777193301.049:209): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/4150/mountinfo" pid=4150 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[   90.948414] audit: type=1400 audit(1777193301.056:210): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/4156/mountinfo" pid=4156 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[   90.956018] audit: type=1400 audit(1777193301.064:211): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/4162/mountinfo" pid=4162 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[   90.961169] audit: error in audit_log_subj_ctx
[   90.961184] audit: type=1326 audit(1777193301.069:212): auid=1000 uid=1000 gid=1000 ses=4 pid=3910 comm="nordvpn" exe="/snap/nordvpn/64/bin/nordvpn" sig=0 arch=c000003e syscall=424 compat=0 ip=0x55ec5e87b68e code=0x50000
[   91.147973] audit: type=1400 audit(1777193301.256:213): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpn" name="/proc/4168/mountinfo" pid=4168 comm="norduserd" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   91.373819] audit: type=1400 audit(1777193301.481:214): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/4632/mountinfo" pid=4632 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[  195.331320] input: WF-C700N (AVRCP) as /devices/virtual/input/input22
[  274.293044] usb 1-12: new full-speed USB device number 7 using xhci_hcd
[  274.419288] usb 1-12: New USB device found, idVendor=19f7, idProduct=0003, bcdDevice= 1.00
[  274.419308] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  274.419316] usb 1-12: Product: RODE NT-USB
[  274.419322] usb 1-12: Manufacturer: RODE Microphones
[  274.429846] input: RODE Microphones RODE NT-USB Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.3/0003:19F7:0003.0003/input/input23
[  274.480800] hid-generic 0003:19F7:0003.0003: input,hiddev96,hidraw2: USB HID v1.00 Device [RODE Microphones RODE NT-USB] on usb-0000:00:14.0-12/input3
[  274.554564] mc: Linux media interface: v0.10
[  274.714675] usb 1-12: applying playback min mute quirk
[  274.717046] usb 1-12: applying playback min mute quirk
[  274.720219] usbcore: registered new interface driver snd-usb-audio
[  293.301522] usb 1-12: USB disconnect, device number 7
[  329.040154] set_capacity_and_notify: 19 callbacks suppressed
[  329.040156] loop28: detected capacity change from 0 to 8784
[ 1263.581666] usb 1-1: new high-speed USB device number 9 using xhci_hcd
[ 1265.948103] usb 1-1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
[ 1265.948126] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 1265.948136] usb 1-1: Product: HD Pro Webcam C920
[ 1265.948144] usb 1-1: SerialNumber: 2E61B95F
[ 1266.309047] videodev: Linux video capture interface: v2.00
[ 1266.443373] uvcvideo 1-1:1.0: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[ 1266.444960] usbcore: registered new interface driver uvcvideo
[ 1269.147873] Bluetooth: hci0: SCO packet for unknown connection handle 2
[ 1392.052749] usb 1-1: reset high-speed USB device number 9 using xhci_hcd
[ 3609.321767] kauditd_printk_skb: 14 callbacks suppressed
[ 3609.321769] audit: type=1400 audit(1777196819.407:229): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/13379/mountinfo" pid=13379 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 3609.337441] audit: type=1400 audit(1777196819.422:230): apparmor="DENIED" operation="open" class="file" profile="snap.nordvpn.nordvpnd" name="/proc/13385/mountinfo" pid=13385 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 4116.916742] usb 1-12: new full-speed USB device number 10 using xhci_hcd
[ 4117.042109] usb 1-12: New USB device found, idVendor=19f7, idProduct=0003, bcdDevice= 1.00
[ 4117.042127] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4117.042135] usb 1-12: Product: RODE NT-USB
[ 4117.042141] usb 1-12: Manufacturer: RODE Microphones
[ 4117.048066] usb 1-12: applying playback min mute quirk
[ 4117.050471] usb 1-12: applying playback min mute quirk
[ 4117.056603] input: RODE Microphones RODE NT-USB Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.3/0003:19F7:0003.0004/input/input25
[ 4117.107285] hid-generic 0003:19F7:0003.0004: input,hiddev96,hidraw2: USB HID v1.00 Device [RODE Microphones RODE NT-USB] on usb-0000:00:14.0-12/input3
[ 4166.771469] usb 1-12: USB disconnect, device number 10
And here’s my system info:
    ~  inxi -zv8         ✔
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1
  Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
    Firmware: UEFI-[Legacy] vendor: American Megatrends v: 0606
    date: 12/12/2017
  System RAM: total: 16 GiB available: 15.48 GiB used: 3.55 GiB (22.9%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2A2400C14
    serial: N/A
  Device-3: ChannelB-DIMM1 type: no module installed
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76799
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: none empty: DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel
    alternate: nova_core non-free: 550-580.xx+ status: current (as of 2025-11;
    EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0
    chip-ID: 10de:1c82 class-ID: 0300 temp: 47.0 C
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:9
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: gpu: nouveau display-ID: 0
  Monitor-1: DVI-D-1 model: NEC 20WGX2 serial: <filter> built: 2007
    res: 1680x1050 dpi: 99 gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green:
    x: 0.290 y: 0.612 blue: x: 0.145 y: 0.071 white: x: 0.314 y: 0.329
    size: 433x270mm (17.05x10.63") diag: 510mm (20.1") ratio: 16:10
    modes: 1680x1050, 1400x1050, 1280x1024, 1440x900, 1280x960, 1152x864,
    1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
  Monitor-2: HDMI-A-1 model: LG (GoldStar) W2243 serial: <filter>
    built: 2009 res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.635
    y: 0.341 green: x: 0.290 y: 0.612 blue: x: 0.145 y: 0.071 white: x: 0.314
    y: 0.329 size: 477x269mm (18.78x10.59") diag: 548mm (21.6") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1280x960, 1152x864, 1280x720,
    1024x768, 800x600, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: nouveau x11: drv: nouveau
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.0.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: NV137 device-ID: 10de:1c82 memory: 3.89 GiB
    unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:4 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 3.19 TiB used: 1.56 TiB (48.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
    model: MZVKW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: CXA7500Q temp: 49.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 45.9 C
    scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 71.43 GiB (15.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:4
    label: N/A uuid: 505a427c-a786-41e4-a4bc-690a3c072cbc
  ID-2: /mnt/2a171f5f-7535-4b7f-a544-66a1c4283d1d raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 824.05 GiB (45.0%) fs: ext4
    dev: /dev/nvme2n1p1 maj-min: 259:3 label: Data_2
    uuid: 2a171f5f-7535-4b7f-a544-66a1c4283d1d
  ID-3: /mnt/d7449928-d30a-4479-bb48-f02d4213b325 raw-size: 931.51 GiB
    size: 915.82 GiB (98.32%) used: 703.91 GiB (76.9%) fs: ext4
    dev: /dev/nvme1n1p1 maj-min: 259:5 label: Data_1
    uuid: d7449928-d30a-4479-bb48-f02d4213b325
  ID-4: /var/Music raw-size: N/A size: 458.17 GiB used: 150.84 GiB (32.9%)
    fs: nfs4 remote: 192.168.1.77:/home/nick/Music
  Device-1: 1-1:9 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-2: 1-5:2 info: IBM NetVista Full Width Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 70mA
    chip-ID: 04b3:3025 class-ID: 0301
  Device-3: 1-6:3 info: Microsoft IntelliMouse Optical type: mouse
    chip-ID: 045e:0029 class-ID: 0301
  Device-4: 1-11:4 info: ASUSTek ASUS USB-BT500 type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Hub-2: 1-13:5 info: NEC HighSpeed Hub ports: 4 rev: 2.0
    chip-ID: 0409:005a class-ID: 0900
  Hub-3: 1-13.4:6 info: NEC HighSpeed Hub ports: 4 rev: 2.0
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 47.0 C
  Fan Speeds (rpm): N/A
  Packages: 1970 pm: pacman pkgs: 1919 libs: 446 tools: gnome-software,pamac
    pm: flatpak pkgs: 33 pm: snap pkgs: 18
    1: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
  CPU top: 5 of 349
  1: cpu: 73.6% command: firefox pid: 6639 mem: 670.7 MiB (4.2%)
  2: cpu: 43.3% command: localsearch-extractor-3 pid: 19387
    mem: 48.7 MiB (0.3%)
  3: cpu: 11.6% command: gnome-shell pid: 3615 mem: 296.9 MiB (1.8%)
  4: cpu: 10.7% command: firefox pid: 13703 mem: 518.1 MiB (3.2%)
  5: cpu: 7.5% command: firefox pid: 18530 mem: 450.2 MiB (2.8%)
  Memory top: 5 of 349
  1: mem: 670.7 MiB (4.2%) command: firefox pid: 6639 cpu: 73.6%
  2: mem: 518.1 MiB (3.2%) command: firefox pid: 13703 cpu: 10.7%
  3: mem: 486.1 MiB (3.0%) command: firefox pid: 7678 cpu: 3.1%
  4: mem: 471.1 MiB (2.9%) command: firefox pid: 7360 cpu: 3.4%
  5: mem: 450.2 MiB (2.8%) command: firefox pid: 18530 cpu: 7.5%
  Processes: 349 Power: uptime: 2h 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.14 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx
    inxi: 3.3.40
Seems a simple thing but I’ve not found anything so far from searching. I’m not knowledgeable enough to be able to work it out from the dmesg output. Is there a command I can run which will target what happens when I connect and disconnect the mic? Or perhaps a log file I should be looking for? Any advice greatly appreciated.
The first thing I would do is to go to the audio/speaker icon of my desktop environment and check if the headphones merely got muted and if so i would try to unmute them again.
This is a shot in the dark, but could you post the output of lsusb with the microphone connected?
I have a suspicion it might be being seen as a headset and switching audio output to that. Maybe a kernel driver change? I’d try another Kernel and see if the issue persists.
I am not familiar with Gnome nor do I have Zoom on my system, but there should be settings to change which device the audio output is routed to.
Thanks, but no, it doesn’t get muted.
With microphone connected:
    ~  lsusb         ✔
Bus 001 Device 002: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
Bus 001 Device 003: ID 045e:0029 Microsoft Corp. IntelliMouse Optical
Bus 001 Device 004: ID 0b05:190e ASUSTek Computer, Inc. ASUS USB-BT500
Bus 001 Device 005: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 001 Device 006: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 001 Device 009: ID 046d:082d Logitech, Inc. HD Pro Webcam C920
Bus 001 Device 016: ID 19f7:0003 RODE Microphones RODE NT-USB
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I’m not seeing an entry for an audio output device there. Is that also connected (I should have been a bit clearer)?
If so, does it then show when the microphone is unplugged? :thinking:
What do you see in the user interface - normally there should be an entry for each device. I don’t use Gnome but Plasma. Don’t the earphones show up in the device list if the mic is plugged in and then it reappears (out of the blue sky) if the mic gets unplugged again? Or is the device in the list and seems to play the audio but you hear no output? It’s hard to tell what is going on if you only say “the earphones don’t play anything while the mic is in” - what did you try already? When you disconnect the earphones does the audio play via the internal speakers? And if so and you connect the earphones again are the internal speakers muted and if so why should they if the earphones don’t play?
This is what i think, too
Please post more information about audio devices detected in PipeWire:
pactl list cards
I would suspect that the NT USB microphone is set to use a duplex audio profile: stereo-input + stereo-output and is taking over from the headphones to play audio to the headphone jack on the microphone
The simplest solution for this is to change the card profile to stereo-input only.
It should be possible to change card profiles in Gnome audio controls, but I am not very familiar with Gnome GUI controls.
The card profile can also be changed using the card Name and Profile from the card data:
pactl set-card-profile NAME PROFILE
Another solution would be to use wired headphones plugged in to the microphone for Zoom meetings and use the Bluetooth earphones for other applications that only require audio playback.
The built-in headphone jack provides zero latency monitoring of microphone audio
Wired headphones would also have lower latency than Bluetooth earphones for listening to others in a zoom meeting
The ASUS bluetooth dongle is in effect the output device. (Though when I start using the earphones they then show up in the sound settings. See below.)
I must apologise. Whether too much in the sun, early onset dementia or grieving, I failed to open the sound settings!!! I had a feeling I was missing something! Once I got there it was clear that @nikgnomic is right: the mic is taking over as audio output device. I can simply change that in the settings. I feel a complete idiot and I’m sorry to have taken up your time.
Thanks @nikgnomic. Your suspicion was right and that somehow cleared my head and I was able to open the audio settings and confirm what was happening. No need to list the cards or change the card profile: see above.
Mod edit: Merged consecutive posts to keep things tidy. :wink:
