Brazero
December 21, 2022, 11:40pm
1
Hello,
Im facing a weird issue on a nearly fresh install (installed via last LTS version of manjaro kde plasma one month ago). My sound seems to stop working when :
I use HDMI and start a video (???)
I put my computer in sleep mode and wake it up later
When i plug headphone
When i pause a youtube video and start it again
And when I use pretty much anything that includes sound (slack, youtube, any stream video, …)
Did someone face the same issue ? All my packages are up to date…
The only way I found to have sound again is to restart my computer
Welcome to Manjaro forum
Some users had similar issues after Stable Update 2022-12-06 with kernel v5.15.81:
Audio randomly cutting out on Manjaro KDE
Audio only works the first time I play something. Then I have to restart to get it working again
But there is now another update 2022-12-20 including kernel v5.15.84
If audio is not working as expected with the updated kernel, try installing kernel v6.0
JohnML
December 25, 2022, 3:48pm
3
Out of curiousity i tried today using linux515 again: first it worked with google-chrome-stable but if i stop video and try to continue … no sound any more.
For me the only solution is as nikgnomic mentions:
Now i’m asking myself: why that? linux515 ( updated today ) is a LTS(!!) kernel. I think there is something special on my laptop. But since it works with linux61 i don’t care any more about this issue!
Generated on 2022-12-25 16:43:1671983025
#################### inxi -Fxzc0 ########################
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 Desktop: Xfce v: 4.18.0
Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
v: BYCN39WW date: 05/28/2021
ID-1: BAT0 charge: 64.6 Wh (98.9%) condition: 65.3/62.0 Wh (105.3%) volts: 17.1 min: 15.4
model: LGC L19L4PD2 status: full
Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
L1: 320 KiB L2: 2 MiB L3: 8 MiB
Speed (MHz): avg: 1475 high: 1500 min/max: 400/3900 cores: 1: 1500 2: 1500 3: 1500 4: 1300
5: 1500 6: 1500 7: 1500 8: 1500 bogomips: 23968
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel arch: Gen-11
bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 525.60.11 arch: Pascal
bus-ID: 2b:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:5
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting,nvidia unloaded: nouveau
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: N/A
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
bus-ID: 00:1f.3
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:4
IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:8
Local Storage: total: 1.86 TiB used: 474.59 GiB (25.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 45.9 C
ID-2: /dev/sda type: USB vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB
ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
ID-1: / size: 57.85 GiB used: 40.28 GiB (69.6%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 259.5 MiB used: 114.2 MiB (44.0%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 286 Uptime: 1h 10m Memory: 15.19 GiB used: 2.77 GiB (18.2%) Init: systemd Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1966 Client: Unknown Client: wrapper-2.0 inxi: 3.3.24
