Hello, I have some weird sounds and sudden stops of the song.
PD: I dont know what commands i have to put here.
I would appreciate help
ALSA info here
More info:
### Configuration dump generated at Tue Apr 20 08:52:14 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-alsa-source device=hw:3,0
load-module module-udev-detect
load-module module-alsa-card device_id="2" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_03.0" card_name="alsa_card.pci-0000_00_03.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-alsa-card device_id="3" name="usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03" card_name="alsa_card.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_01_00.1.hdmi-stereo 0x10000
set-sink-mute alsa_output.pci-0000_01_00.1.hdmi-stereo no
suspend-sink alsa_output.pci-0000_01_00.1.hdmi-stereo yes
set-sink-volume alsa_output.pci-0000_00_1b.0.iec958-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1b.0.iec958-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.iec958-stereo yes
set-source-volume alsa_input.hw_3_0 0x10000
set-source-mute alsa_input.hw_3_0 no
suspend-source alsa_input.hw_3_0 yes
set-source-volume alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor no
suspend-source alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor yes
set-source-volume alsa_output.pci-0000_00_1b.0.iec958-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.iec958-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.iec958-stereo.monitor yes
set-source-volume alsa_input.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03.analog-stereo 0x10000
set-source-mute alsa_input.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03.analog-stereo no
suspend-source alsa_input.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03.analog-stereo yes
set-card-profile alsa_card.pci-0000_01_00.1 output:hdmi-stereo
set-card-profile alsa_card.pci-0000_00_03.0 off
set-card-profile alsa_card.pci-0000_00_1b.0 output:iec958-stereo
set-card-profile alsa_card.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03 input:analog-stereo
set-default-sink alsa_output.pci-0000_01_00.1.hdmi-stereo
set-default-source alsa_input.usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-03.analog-stereo
### EOF
