Hi all, I am completely new to Linux forums, so my apologies if I format this wrong. After using Manjaro KDE on my laptop for a week (with absolutely no issues), I’ve finally decided to switch my main desktop to Linux as well. The install went well, and everything works fine, except that sound is only coming through the HDMI. My computer has a Gigabyte x370 gaming k7 mobo, 1600x cpu, and Gigabyte 1050 gpu. My kernel is 59. When I go into audio settings, the Family 17h HD Audio controller shows up, but the only option for it is off. The GP107GL HDMI Audio Driver is the only one that it will let me use. My speakers and my headphones do not work when plugged in. Can someone please help me figure this out? I’ve been trying for days to figure something out, but can’t find anything.
Welcome at the Manjaro forum, @RubyDalton,
before a more experienced forum member joins the discussion you could have a look into this Arch wiki entry:
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture
Please post the output of inxi -Fazy
Hello I am on the LTS version and I am getting a similar issue as mentioned above.
Here is the output of inxi -Fazy
Kernel: 5.4.169-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ba626e1a-8ebc-41db-8226-0c53f691b9a8 rw quiet
resume=UUID=168153c3-9a4d-4f89-bdc2-a97a0d4a0d22 udev.log_priority=3
pci=realloc
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Micro-Star product: Bravo 17 A4DDR v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-17FK v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17FKAMS.117 date: 10/29/2020
ID-1: BAT1 charge: 49.1 Wh (100.0%) condition: 49.1/51.3 Wh (95.7%)
volts: 12.9 min: 11.4 model: MSI Corp. MS-17FK type: Li-ion serial: N/A
status: Full
Info: model: AMD Ryzen 7 4800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2900 boost: enabled
base/boost: 2900/4300 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 92662
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: N/A alternate: amdgpu bus-ID: 03:00.0
chip-ID: 1002:7340 class-ID: 0380
Device-2: AMD Renoir vendor: Micro-Star MSI driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 5986:211c class-ID: 0e02
Display: server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Micro-Star MSI driver: N/A alternate: snd_pci_acp3x bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.4.169-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.84 TiB used: 139.96 GiB (7.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS3040 1TB SSD
lanes: 4 type: SSD serial: <filter> rev: CS304131 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 8B scheme: GPT
ID-1: / raw-size: 250 GiB size: 245.02 GiB (98.01%) used: 45.5 GiB (18.6%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 3 GiB size: 2.99 GiB (99.80%)
used: 3.5 MiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-1: swap-1 type: partition size: 78.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 57.2 C mobo: 51.0 C gpu: amdgpu temp: 0.0 C
Processes: 486 Uptime: 14h 47m wakeups: 2 Memory: 62.28 GiB
used: 13.31 GiB (21.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1182 pacman: 1175 lib: 334 flatpak: 7 Shell: Bash (su)
v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
