Clean install Manjaro gnome 21.0.4 no sound, but same PC has sound with manjaro previos version and updates, from two years to yesterday, today only Dummy Output
I tried changing the kernel to lastest , but that did not work, i update de bios but dont work.
inxi -Fazy ξ²
Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=7274c44a-93a1-4adc-b8e1-7855574fa1db rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: Micro-Star model: A320M PRO-M2 (MS-7B84) v: 1.0
serial: UEFI: American Megatrends v: 1.50 date: 01/28/2019
Info: Dual Core model: AMD A6-9500 RADEON R5 8 COMPUTE CORES 2C+6G bits: 64
type: MCP arch: Excavator family: 15 (21) model-id: 65 (101) stepping: 1
microcode: 600611A cache: L2: 1024 KiB
bogomips: 14004
Speed: 1399 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
1: 1399 2: 1813
disabled, RSB filling
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: AMD CARRIZO (DRM 3.40.0 5.12.1-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 1b:00.0
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB driver: rtl8192cu
bus-ID: 2-3:2 chip-ID: 0bda:8178 class-ID: 0000 serial:
IF: wlp0s16u3 state: up mac:
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB
driver: hid-generic,usbhid bus-ID: 4-5:3 chip-ID: 0458:6001 class-ID: 0301
Local Storage: total: 931.51 GiB used: 89.82 GiB (9.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
rotation: 7200 rpm serial: rev: 1A02 scheme: GPT
ID-1: / raw-size: 243.93 GiB size: 239.04 GiB (98.00%) used: 9.07 GiB (3.8%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 465 MiB size: 464.1 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 681.27 GiB size: 669.57 GiB (98.28%)
used: 80.76 GiB (12.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 34.2 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 222 Uptime: 2m wakeups: 0 Memory: 3.77 GiB used: 1.33 GiB (35.3%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 Packages:
pacman: 1198 lib: 322 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
sudo dmesg | egrep -i β(snd|sof|alsa|hda)β ξ²
[sudo] password for russell:
[ 0.268670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 7.302945] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 7.303163] snd_hda_intel 0000:00:09.2: enabling device (0004 β 0006)
[ 7.330875] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input4
[ 7.330923] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/sound/card0/input5
[ 7.330962] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/sound/card0/input6
[ 7.394411] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 7.394418] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.394420] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 7.394423] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 7.394424] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 7.394425] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 7.394427] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 7.394428] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 8.136601] snd_hda_intel 0000:00:01.1: bound 0000:00:01.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
