Hello, install manjaro kde plasma 20.1 and the audio does not work, at the beginning I got a message of “no input or output devices found”, place the commands: guiding me fromhttps://forum.manjaro.org/t/fresh-manjaro-kde-install-no-sound-card-detected/21531/27
pulseaudio --start
pulseaudio -k
pulseaudio --start
Then the following devices appeared:
HDMI1 / DP1 Output (sof-hda-dsp HDMI1 / DP1 Output)
HDMI2 / DP2 Output (sof-hda-dsp HDMI2 / DP2 Output)
HDMI3 / DP3 Output (sof-hda-dsp HDMI3 / DP3 Output)
Speaker (sof-hda-dsp speaker + Headphones)
Headset mono microphone (sof-hda-dsp Headset mono microphone)
I leave the info of my system:
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=415b645f-4920-4501-b2f1-e5aea1ebcd74 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Convertible System: Dell product: Inspiron 5591 2n1 v: N/A serial: <filter> Chassis: type: 31
serial: <filter>
Mobo: Dell model: 0208H1 v: A00 serial: <filter> UEFI: Dell v: 1.5.0 date: 02/04/2020
Battery: ID-1: BAT0 charge: 42.0 Wh condition: 42.0/42.0 Wh (100%) volts: 13.0/11.4 model: LGC-LGC3.65 DELL FDRHM06
type: Li-ion serial: <filter> status: Full
Device-1: hid-0018:04F3:2854.0002-battery model: CUST0000:00 04F3:2854 serial: N/A charge: N/A status: N/A
CPU: Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: C (12) microcode: D6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33615
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-6:3 chip ID: 0bda:5521 serial: <filter>
Display: x11 server: xorg 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: N/A v: N/A direct render: N/A
Audio: Device-1: Intel vendor: Dell driver: sof-audio-pci alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:02f0
Drives: Local Storage: total: 238.47 GiB used: 9.08 GiB (3.8%)
ID-1: /dev/nvme0n1 model: PC SN530 NVMe WDC 256GB size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 21106012 scheme: GPT
Partition: ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%) used: 9.08 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2521
Info: Processes: 239 Uptime: 1h 01m Memory: 7.44 GiB used: 2.51 GiB (33.8%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1174 lib: 305 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
and ALSA information http://alsa-project.org/db/?f=70e4f73b117a4a17388658089fd75bd60635f9ba
status pulseaudio:
systemctl --user status pulseaudio.service
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2020-09-17 13:22:23 -05; 54min ago
TriggeredBy:
● pulseaudio.socket
Main PID: 4238 (pulseaudio)
CGroup: /user.slice/user-1000.slice/user@1000.service/pulseaudio.service
├─4238 /usr/bin/pulseaudio --daemonize=no
└─4254 /usr/lib/pulse/gsettings-helper
set 17 13:55:08 dell-inspiron pulseaudio[4238]: W: [pulseaudio] sink-input.c: Failed to create sink input: sink is suspended.
please if someone can help me :c thanks
