Sound not working after fresh install
I have freshly installed the system and sound stops working all of sudden.
$ sudo alsa-info.sh --upload
http://alsa-project.org/db/?f=7f8364c0a431d7a1760612945c62a87b8083f22b
$ inxi -Fazy
  Host: h3ll Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
    root=UUID=f00da942-a971-473b-a260-4c2aa8551a88 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX505GT.311 date: 02/08/2021
  ID-1: BAT0 charge: 34.0 Wh (98.3%) condition: 34.6/48.1 Wh (72.0%)
    volts: 12.4 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
    serial: 123456789 status: N/A cycles: 41
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4094 high: 4107 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4098 2: 4099 3: 4091
    4: 4089 5: 4097 6: 4100 7: 4081 8: 4092 9: 4094 10: 4099 11: 4083 12: 4107
    bogomips: 62431
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
    built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f91 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: 0x0001
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting unloaded: nvidia alternate: fbdev,nouveau,nv,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: no
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: ee:de:3e:43:a5:6e
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 04:d4:c4:e4:71:fd
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 1.38 TiB used: 547.25 GiB (38.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
    lanes: 4 type: SSD serial: 192223882457 rev: P1MA0V4 temp: 28.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-11Z10T0
    type: HDD rpm: 5400 serial: WD-WX31AA7CLVNK rev: 1A01 scheme: GPT
  ID-1: / raw-size: 212.69 GiB size: 208.29 GiB (97.93%) used: 16.43 GiB (7.9%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 254.97 GiB size: 249.91 GiB (98.02%)
    used: 81.59 GiB (32.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8.79 GiB used: 23 MiB (0.3%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 59.0 C pch: 45.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 465 Uptime: 12h 36m wakeups: 3 Memory: 15.48 GiB
  used: 10.7 GiB (69.1%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1147 libs: 316 tools: pamac,yay Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.23
 amixer -c 0
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
$ amixer -c 1
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 85 [98%] [-1.50dB] [off]
  Front Right: Playback 85 [98%] [-1.50dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 86 [99%] [-0.75dB] [on]
  Front Right: Playback 86 [99%] [-0.75dB] [on]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 2 [67%] [20.00dB]
  Front Right: 2 [67%] [20.00dB]
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Dmic0',0
  Capture channels: Front Left - Front Right - Rear Left - Rear Right
  Limits: Capture 0 - 70
  Front Left: Capture 49 [70%] [-1.00dB] [on]
  Front Right: Capture 49 [70%] [-1.00dB] [on]
  Rear Left: Capture 49 [70%] [-1.00dB] [on]
  Rear Right: Capture 49 [70%] [-1.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
  Front Left: Capture 50 [71%] [0.00dB]
  Front Right: Capture 50 [71%] [0.00dB]
  Rear Left: Capture 50 [71%] [0.00dB]
  Rear Right: Capture 50 [71%] [0.00dB]
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'PGA1.0 1 Master',0
  Limits: Playback 0 - 32
  Mono:
  Front Left: Playback 32 [100%] [0.00dB]
  Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
  Limits: Capture 0 - 80
  Front Left: Capture 50 [62%] [0.00dB]
  Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA30.0 30',0
  Mono:
Simple mixer control 'PGA31.0 31',0
  Mono:
Simple mixer control 'PGA7.0 7 Master',0
  Mono:
Simple mixer control 'PGA8.0 8 Master',0
  Mono:
Simple mixer control 'PGA9.0 9 Master',0
  Mono:
There have been a lot of similar reports in the last few days about audio problems after latest stable branch updates. The issue affects ALSA audio for Intel Skylake (6th gen) to TigerLake (11th gen) systems with LTS kernels v5.10 and v5.15
A lot of users have confirmed that the best, simple solution for this is to install kernel v6.0 using either Manjaro Settings Manager GUI tool, or copy/paste this to terminal
sudo mhwd-kernel -i linux60
