Hi.
I have a Dell Latitude 5420.
I think I have only pipewire installed (although a “pulseaudio” process is running).
I have to connect HDMI again, switch the audio output to speakers and then unplug the HDMI.
Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=4d3304fd-330d-42a8-8ac5-623b762942c8 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Latitude 5420 v: N/A
Mobo: Dell model: 0XK71D v: A01 serial: <superuser required> part-nu: 0A20
uuid: <superuser required> UEFI: Dell v: 1.33.0 date: 11/10/2023
ID-1: BAT0 charge: 31.6 Wh (100.0%) condition: 31.6/42.0 Wh (75.3%)
volts: 12.7 min: 11.4 model: BYD DELL M3KCN15 type: Li-poly serial: <filter>
status: full
System RAM: total: 16 GiB available: 15.2 GiB used: 5.02 GiB (33.0%)
Array-1: capacity: 256 GiB note: check slots: 2 modules: 1 EC: None
max-module-size: 128 GiB note: est.
Device-1: DIMM B type: no module installed
Device-2: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 04CB000080AD part-no: AO1P32NCST2-B85S serial: <filter>
Info: model: 11th Gen Intel Core i5-1145G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 513 high: 1045 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 665 2: 400 3: 400 4: 400
5: 400 6: 400 7: 1045 8: 400 bogomips: 23968
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2
chip-ID: 1bcf:28c4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: Najing CEC Panda 0x0056 built: 2020 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.84 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fb class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 31.68 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 92209301 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 155.93 GiB size: 155.93 GiB (100.00%)
used: 31.61 GiB (20.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 4d3304fd-330d-42a8-8ac5-623b762942c8
used: 69.9 MiB (72.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 90E2-0EF8
ID-3: /home raw-size: 155.93 GiB size: 155.93 GiB (100.00%)
ID-4: /mnt/Externo raw-size: N/A size: 916.77 GiB used: 709.33 GiB (77.4%)
fs: cifs dev: /dev/Externo
ID-5: /var/cache raw-size: 155.93 GiB size: 155.93 GiB (100.00%)
ID-6: /var/log raw-size: 155.93 GiB size: 155.93 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 320.17 GiB fs: ntfs label: N/A
uuid: E0B8E974B8E94A1C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 744 MiB fs: ntfs label: N/A
uuid: 381CBEA71CBE6014
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Sunplus Innovation Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1bcf:28c4 class-ID: 0e02 serial: <filter>
Device-2: 3-8:3 info: Broadcom 58200 type: smart card driver: N/A
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 100mA chip-ID: 0a5c:5842 class-ID: 0b00 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 339 Power: uptime: 35m states: freeze,mem,disk suspend: s2idle
image: 6.06 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1325 pm: pacman pkgs: 1309 libs: 374 tools: gnome-software,pamac
pm: flatpak pkgs: 16 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
PID USUARIO PR NI VIRT RES SHR S %CPU %MEM TEMPO+ COMANDO
1898 danilo 9 -11 1722336 35824 22320 S 2,7 0,1 0:13.73 pulseaudio
