Apologies in advance if this question has already been asked before, but I feel like this may be a bit of a unique situation. Also, this is a bit of a mix of gnome and xfce, so I didn’t know which forum to post it in sorry!
I am currently facing a problem with notification sounds, since I get regular pop up desktop notifications on Manjaro XFCE, yet no sounds ever play (even when I specify).
I’ve already followed the steps on this page from ToZ, and have tried changing my soundtheme to freedesktop, and gnome, but it still does not work.
The application from which I am trying to get sound notifications is the gnome-calendar, which is the first result you get if you search up ‘calendar’ on the add/remove software store, as a reminder for an event. Is it something to do with the fact that it’s gnome?
Thank you in advance!
sorry, I still don’t seem to be registering any sound. It’s only desktop notifications by the way, thunderbird notifications work and I can assure you my earphones work!
Thank you for helping so far
I ran the command “gnome-terminal --debug” and set an arbritrary reminder, but no error shows. It’s weird because the evolution calendar reminders work but not gnome-calendar
The freedesktop theme didn’t work for me, but sound-theme-smooth from AUR works
Or the suggested Borealis theme can be downloaded and extracted to /usr/share/sounds/ https://dolys.fr/Dossier/Borealis.tar.gz
